Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17033
commit dd4c2c483fa091b2dc1c5a58f7ae3aeafff0a2d9 Author: Arthur Heymans arthur@aheymans.xyz Date: Sat Oct 15 18:00:22 2016 +0200
mb/gigabyte/ga-945gcm-s2l: add mainboard
Startpoint was Intel d945gclf. Resume from suspend does not seem to work. It requires to reset the Realtek nic, which currently hardcodes the MAC address.
Everything else seems to work fine.
Change-Id: I0ff9f193105facc1b276a791790e27eb4c275085 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/mainboard/gigabyte/ga-945gcm-s2l/Kconfig | 58 ++++++ src/mainboard/gigabyte/ga-945gcm-s2l/Kconfig.name | 2 + src/mainboard/gigabyte/ga-945gcm-s2l/Makefile.inc | 1 + src/mainboard/gigabyte/ga-945gcm-s2l/acpi/ec.asl | 51 +++++ .../gigabyte/ga-945gcm-s2l/acpi/i945_pci_irqs.asl | 75 +++++++ .../gigabyte/ga-945gcm-s2l/acpi/ich7_pci_irqs.asl | 44 +++++ .../gigabyte/ga-945gcm-s2l/acpi/mainboard.asl | 30 +++ .../gigabyte/ga-945gcm-s2l/acpi/platform.asl | 48 +++++ .../gigabyte/ga-945gcm-s2l/acpi/superio.asl | 1 + .../gigabyte/ga-945gcm-s2l/acpi/thermal.asl | 1 + src/mainboard/gigabyte/ga-945gcm-s2l/acpi_tables.c | 32 +++ .../gigabyte/ga-945gcm-s2l/board_info.txt | 6 + src/mainboard/gigabyte/ga-945gcm-s2l/cmos.default | 7 + src/mainboard/gigabyte/ga-945gcm-s2l/cmos.layout | 122 ++++++++++++ src/mainboard/gigabyte/ga-945gcm-s2l/cstates.c | 20 ++ src/mainboard/gigabyte/ga-945gcm-s2l/devicetree.cb | 160 +++++++++++++++ src/mainboard/gigabyte/ga-945gcm-s2l/dsdt.asl | 53 +++++ src/mainboard/gigabyte/ga-945gcm-s2l/hda_verb.c | 37 ++++ src/mainboard/gigabyte/ga-945gcm-s2l/romstage.c | 217 +++++++++++++++++++++ 19 files changed, 965 insertions(+)
diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/Kconfig b/src/mainboard/gigabyte/ga-945gcm-s2l/Kconfig new file mode 100644 index 0000000..b41becc --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/Kconfig @@ -0,0 +1,58 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2009 coresystems GmbH +## Copyright (C) 2016 Arthur Heymans <arthur@ahemans.xyz +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +if BOARD_GIGABYTE_GA_945GCM_S2L + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select ARCH_X86 + select CPU_INTEL_SOCKET_LGA775 + select NORTHBRIDGE_INTEL_I945 + select NORTHBRIDGE_INTEL_SUBTYPE_I945GC + select CHECK_SLFRCS_ON_RESUME + select SOUTHBRIDGE_INTEL_I82801GX + select SUPERIO_ITE_IT8718F + select HAVE_OPTION_TABLE + select HAVE_CMOS_DEFAULT + select HAVE_MP_TABLE + select HAVE_ACPI_TABLES + select HAVE_ACPI_RESUME + select BOARD_ROMSIZE_KB_512 + select CHANNEL_XOR_RANDOMIZATION + select MAINBOARD_HAS_NATIVE_VGA_INIT + select INTEL_EDID + select REALTEK_8168_RESET + +config MAINBOARD_DIR + string + default gigabyte/ga-945gcm-s2l + +config MAINBOARD_PART_NUMBER + string + default "GA-945GCM-S2L" + +config MMCONF_BASE_ADDRESS + hex + default 0xf0000000 + +config IRQ_SLOT_COUNT + int + default 18 + +config MAX_CPUS + int + default 2 + +endif # BOARD_GIGABYTE_GA_945GCM_S2L diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/Kconfig.name b/src/mainboard/gigabyte/ga-945gcm-s2l/Kconfig.name new file mode 100644 index 0000000..95baebe --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_GIGABYTE_GA_945GCM_S2L + bool "GA-945GCM-S2L" diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/Makefile.inc b/src/mainboard/gigabyte/ga-945gcm-s2l/Makefile.inc new file mode 100644 index 0000000..f9621db --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/Makefile.inc @@ -0,0 +1 @@ +ramstage-y += cstates.c diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/ec.asl b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/ec.asl new file mode 100644 index 0000000..5362bb2 --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/ec.asl @@ -0,0 +1,51 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +Device(EC0) +{ + Name (_HID, EISAID("PNP0C09")) + Name (_UID, 1) + + // _REG method requires that an operation region be defined. + OperationRegion (ERAM, EmbeddedControl, 0x00, 0xff) + Field (ERAM, ByteAcc, Lock, Preserve) + { + } + + Method (_CRS, 0, Serialized) + { + Name (ECMD, ResourceTemplate() + { + IO (Decode16, 0x62, 0x62, 0, 1) + IO (Decode16, 0x66, 0x66, 0, 1) + }) + + Return (ECMD) + } + + Method (_REG, 2) + { + // This method is needed by Windows XP/2000 + // for EC initialization before a driver + // is loaded + } + + Name (_GPE, 23) // GPI07 / GPE23 -> Runtime SCI + + // TODO EC Query methods + + // TODO Scope _SB devices for AC power, LID, Power button + +} diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/i945_pci_irqs.asl b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/i945_pci_irqs.asl new file mode 100644 index 0000000..eddf840 --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/i945_pci_irqs.asl @@ -0,0 +1,75 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* This is board specific information: IRQ routing for the + * i945 + */ + + +// PCI Interrupt Routing +Method(_PRT) +{ + If (PICM) { + Return (Package() { + // PCIe Graphics 0:1.0 + Package() { 0x0001ffff, 0, 0, 16 }, + // Onboard graphics (IGD) 0:2.0 + Package() { 0x0002ffff, 0, 0, 16 }, + // High Definition Audio 0:1b.0 + Package() { 0x001bffff, 0, 0, 16 }, + // PCIe Root Ports 0:1c.x + Package() { 0x001cffff, 0, 0, 16 }, + Package() { 0x001cffff, 1, 0, 17 }, + Package() { 0x001cffff, 2, 0, 18 }, + Package() { 0x001cffff, 3, 0, 19 }, + // USB and EHCI 0:1d.x + Package() { 0x001dffff, 0, 0, 16 }, + Package() { 0x001dffff, 1, 0, 17 }, + Package() { 0x001dffff, 2, 0, 18 }, + Package() { 0x001dffff, 3, 0, 19 }, + // LPC device 0:1f.0 + Package() { 0x001fffff, 0, 0, 16 }, + Package() { 0x001fffff, 1, 0, 17 }, + Package() { 0x001fffff, 2, 0, 18 }, + Package() { 0x001fffff, 3, 0, 19 }, + + }) + + } Else { + Return (Package() { + // PCIe Graphics 0:1.0 + Package() { 0x0001ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + // Onboard graphics (IGD) 0:2.0 + Package() { 0x0002ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + // High Definition Audio 0:1b.0 + Package() { 0x001bffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + // PCIe Root Ports 0:1c.x + Package() { 0x001cffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + Package() { 0x001cffff, 1, _SB.PCI0.LPCB.LNKB, 0 }, + Package() { 0x001cffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, + Package() { 0x001cffff, 3, _SB.PCI0.LPCB.LNKD, 0 }, + // USB and EHCI 0:1d.x + Package() { 0x001dffff, 0, _SB.PCI0.LPCB.LNKH, 0 }, + Package() { 0x001dffff, 1, _SB.PCI0.LPCB.LNKD, 0 }, + Package() { 0x001dffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, + Package() { 0x001dffff, 3, _SB.PCI0.LPCB.LNKA, 0 }, + // LPC device 0:1f.0 + Package() { 0x001fffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, + Package() { 0x001fffff, 1, _SB.PCI0.LPCB.LNKB, 0 }, + Package() { 0x001fffff, 2, _SB.PCI0.LPCB.LNKC, 0 }, + Package() { 0x001fffff, 3, _SB.PCI0.LPCB.LNKD, 0 }, + }) + } +} diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/ich7_pci_irqs.asl b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/ich7_pci_irqs.asl new file mode 100644 index 0000000..cc229a5 --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/ich7_pci_irqs.asl @@ -0,0 +1,44 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* This is board specific information: IRQ routing for the + * 0:1e.0 PCI bridge of the ICH7 + */ + + +If (PICM) { + Return (Package() { + Package (0x04) { 0x0000FFFF, 0x00, 0x00, 0x14 }, + Package (0x04) { 0x0000FFFF, 0x01, 0x00, 0x13 }, + Package (0x04) { 0x0000FFFF, 0x02, 0x00, 0x12 }, + Package (0x04) { 0x0000FFFF, 0x03, 0x00, 0x10 }, + Package (0x04) { 0x0001FFFF, 0x00, 0x00, 0x13 }, + Package (0x04) { 0x0001FFFF, 0x01, 0x00, 0x12 }, + Package (0x04) { 0x0001FFFF, 0x02, 0x00, 0x10 }, + Package (0x04) { 0x0001FFFF, 0x03, 0x00, 0x14 }, + + }) +} Else { + Return (Package() { + Package (0x04) { 0x0000FFFF, 0x00, _SB.PCI0.LPCB.LNKE, 0x00 }, + Package (0x04) { 0x0000FFFF, 0x01, _SB.PCI0.LPCB.LNKD, 0x00 }, + Package (0x04) { 0x0000FFFF, 0x02, _SB.PCI0.LPCB.LNKC, 0x00 }, + Package (0x04) { 0x0000FFFF, 0x03, _SB.PCI0.LPCB.LNKA, 0x00 }, + Package (0x04) { 0x0001FFFF, 0x00, _SB.PCI0.LPCB.LNKD, 0x00 }, + Package (0x04) { 0x0001FFFF, 0x01, _SB.PCI0.LPCB.LNKC, 0x00 }, + Package (0x04) { 0x0001FFFF, 0x02, _SB.PCI0.LPCB.LNKA, 0x00 }, + Package (0x04) { 0x0001FFFF, 0x03, _SB.PCI0.LPCB.LNKE, 0x00 }, + }) +} diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/mainboard.asl b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/mainboard.asl new file mode 100644 index 0000000..0454c3f --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/mainboard.asl @@ -0,0 +1,30 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +Device (SLPB) +{ + Name(_HID, EisaId("PNP0C0E")) + + // Wake + Name(_PRW, Package(){0x1d, 0x04}) +} + +Device (PWRB) +{ + Name(_HID, EisaId("PNP0C0C")) + + // Wake + Name(_PRW, Package(){0x1d, 0x04}) +} diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/platform.asl b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/platform.asl new file mode 100644 index 0000000..21eb3df --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/platform.asl @@ -0,0 +1,48 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* The _PTS method (Prepare To Sleep) is called before the OS is + * entering a sleep state. The sleep state number is passed in Arg0 + */ + +Method(_PTS,1) +{ + // Call a trap so SMI can prepare for Sleep as well. + // TRAP(0x55) +} + +/* The _WAK method is called on system wakeup */ + +Method(_WAK,1) +{ + // CPU specific part + + // Notify PCI Express slots in case a card + // was inserted while a sleep state was active. + + // Are we going to S3? + If (LEqual(Arg0, 3)) { + // .. + } + + // Are we going to S4? + If (LEqual(Arg0, 4)) { + // .. + } + + // TODO: Windows XP SP2 P-State restore + + Return(Package(){0,0}) +} diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/superio.asl b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/superio.asl new file mode 100644 index 0000000..4107d3b --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/superio.asl @@ -0,0 +1 @@ +/* dummy */ \ No newline at end of file diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/thermal.asl b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/thermal.asl new file mode 100644 index 0000000..4107d3b --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi/thermal.asl @@ -0,0 +1 @@ +/* dummy */ \ No newline at end of file diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/acpi_tables.c b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi_tables.c new file mode 100644 index 0000000..677ebcf --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/acpi_tables.c @@ -0,0 +1,32 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <types.h> +#include <string.h> +#include <console/console.h> +#include <arch/acpi.h> +#include <arch/acpigen.h> +#include <arch/smp/mpspec.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <cpu/x86/msr.h> +#include <arch/ioapic.h> + +#include "southbridge/intel/i82801gx/nvs.h" + +void acpi_create_gnvs(global_nvs_t *gnvs) +{ +} diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/board_info.txt b/src/mainboard/gigabyte/ga-945gcm-s2l/board_info.txt new file mode 100644 index 0000000..70cbe41 --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/board_info.txt @@ -0,0 +1,6 @@ +Category: desktop +Board URL: http://www.gigabyte.com/products/product-page.aspx?pid=2669#ov +Release year: 2007 +ROM package: SOIC-8 +ROM protocol: SPI +ROM socketed: n diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/cmos.default b/src/mainboard/gigabyte/ga-945gcm-s2l/cmos.default new file mode 100644 index 0000000..ab7aac1 --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/cmos.default @@ -0,0 +1,7 @@ +boot_option=Fallback +baud_rate=115200 +debug_level=Spew +hyper_threading=Enable +nmi=Enable +boot_devices='' +gfx_uma_size=8M \ No newline at end of file diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/cmos.layout b/src/mainboard/gigabyte/ga-945gcm-s2l/cmos.layout new file mode 100644 index 0000000..47f48dd --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/cmos.layout @@ -0,0 +1,122 @@ +# +# This file is part of the coreboot project. +# +# Copyright (C) 2007-2008 coresystems GmbH +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +# ----------------------------------------------------------------- +entries + +# ----------------------------------------------------------------- +# Status Register A +# ----------------------------------------------------------------- +# Status Register B +# ----------------------------------------------------------------- +# Status Register C +#96 4 r 0 status_c_rsvd +#100 1 r 0 uf_flag +#101 1 r 0 af_flag +#102 1 r 0 pf_flag +#103 1 r 0 irqf_flag +# ----------------------------------------------------------------- +# Status Register D +#104 7 r 0 status_d_rsvd +#111 1 r 0 valid_cmos_ram +# ----------------------------------------------------------------- +# Diagnostic Status Register +#112 8 r 0 diag_rsvd1 + +# ----------------------------------------------------------------- +0 120 r 0 reserved_memory +#120 264 r 0 unused + +# ----------------------------------------------------------------- +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +388 4 h 0 reboot_counter +#390 2 r 0 unused? + +# ----------------------------------------------------------------- +# coreboot config options: console +392 3 e 5 baud_rate +395 4 e 6 debug_level +#399 1 r 0 unused + +# coreboot config options: cpu +400 1 e 2 hyper_threading +#401 7 r 0 unused + +# coreboot config options: southbridge +408 1 e 1 nmi +409 2 e 7 power_on_after_fail + +# coreboot config options: northbridge +411 3 e 11 gfx_uma_size + +# coreboot config options: bootloader +416 512 s 0 boot_devices +#928 80 r 0 unused + +# coreboot config options: check sums +984 16 h 0 check_sum +#1000 24 r 0 amd_reserved + +# RAM initialization internal data +1024 8 r 0 C0WL0REOST +1032 8 r 0 C1WL0REOST +1040 8 r 0 RCVENMT +1048 4 r 0 C0DRT1 +1052 4 r 0 C1DRT1 + +# ----------------------------------------------------------------- + +enumerations + +#ID value text +1 0 Disable +1 1 Enable +2 0 Enable +2 1 Disable +4 0 Fallback +4 1 Normal +5 0 115200 +5 1 57600 +5 2 38400 +5 3 19200 +5 4 9600 +5 5 4800 +5 6 2400 +5 7 1200 +6 1 Emergency +6 2 Alert +6 3 Critical +6 4 Error +6 5 Warning +6 6 Notice +6 7 Info +6 8 Debug +6 9 Spew +7 0 Disable +7 1 Enable +7 2 Keep +11 0 1M +11 1 4M +11 2 8M +11 3 16M +11 4 32M +11 5 48M +11 6 64M + +# ----------------------------------------------------------------- +checksums + +checksum 392 983 984 diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/cstates.c b/src/mainboard/gigabyte/ga-945gcm-s2l/cstates.c new file mode 100644 index 0000000..f683756 --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/cstates.c @@ -0,0 +1,20 @@ +/* + * This file is part of the coreboot project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <device/device.h> +#include <arch/x86/include/arch/acpigen.h> + +int get_cst_entries(acpi_cstate_t **entries) +{ + return 0; +} diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/devicetree.cb b/src/mainboard/gigabyte/ga-945gcm-s2l/devicetree.cb new file mode 100644 index 0000000..a993848 --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/devicetree.cb @@ -0,0 +1,160 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2007-2009 coresystems GmbH +## Copyright (C) 2016 Arthur Heymans arthur@aheymans.xyz +## +## This program is free software; you can redistribute it and/or +## modify it under the terms of the GNU General Public License as +## published by the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +chip northbridge/intel/i945 + + device cpu_cluster 0 on + chip cpu/intel/socket_LGA775 + device lapic 0 on end + end + chip cpu/intel/model_1067x + device lapic 0xACAC off end + end + end + + device domain 0 on + device pci 00.0 on # host bridge + subsystemid 0x1458 0x5000 + end + device pci 01.0 on # i945 PCIe root port + subsystemid 0x1458 0x5000 + ioapic_irq 2 INTA 0x10 + end + device pci 02.0 on # vga controller + subsystemid 0x1458 0xd000 + ioapic_irq 2 INTA 0x10 + end + + chip southbridge/intel/i82801gx + register "pirqa_routing" = "0x8c" + register "pirqb_routing" = "0x8a" + register "pirqc_routing" = "0x83" + register "pirqd_routing" = "0x8b" + register "pirqe_routing" = "0x80" + register "pirqf_routing" = "0x80" + register "pirqg_routing" = "0x80" + register "pirqh_routing" = "0x85" + + # GPI routing + # 0 No effect (default) + # 1 SMI# (if corresponding ALT_GPI_SMI_EN bit is also set) + # 2 SCI (if corresponding GPIO_EN bit is also set) + register "gpi0_routing" = "1" + register "gpi1_routing" = "1" + register "gpi2_routing" = "1" + register "gpi3_routing" = "1" + register "gpi4_routing" = "1" + register "gpi5_routing" = "1" + register "gpi6_routing" = "1" + register "gpi7_routing" = "1" + register "gpi8_routing" = "1" + register "gpi9_routing" = "1" + register "gpi10_routing" = "1" + register "gpi11_routing" = "1" + register "gpi12_routing" = "1" + register "gpi13_routing" = "2" + register "gpi14_routing" = "1" + register "gpi15_routing" = "1" + + register "gpe0_en" = "0" + + register "ide_legacy_combined" = "0x0" + register "ide_enable_primary" = "0x1" + register "ide_enable_secondary" = "0x0" + register "sata_ahci" = "0x0" + register "c3_latency" = "85" + + register "p_cnt_throttling_supported" = "0" + + device pci 1b.0 on # High Definition Audio + ioapic_irq 2 INTA 0x10 + end + device pci 1c.0 on end # PCIe + device pci 1c.1 on end # PCIe + #device pci 1c.2 off end # PCIe port 3 + #device pci 1c.3 off end # PCIe port 4 + #device pci 1c.4 off end # PCIe port 5 + #device pci 1c.5 off end # PCIe port 6 + device pci 1d.0 on # USB UHCI + ioapic_irq 2 INTA 0x10 + end + device pci 1d.1 on # USB UHCI + ioapic_irq 2 INTB 0x11 + end + device pci 1d.2 on # USB UHCI + ioapic_irq 2 INTC 0x12 + end + device pci 1d.3 on # USB UHCI + ioapic_irq 2 INTD 0x13 + end + device pci 1d.7 on # USB2 EHCI + ioapic_irq 2 INTA 0x10 + end + device pci 1e.0 on end # PCI bridge + + device pci 1f.0 on # LPC bridge + ioapic_irq 2 INTA 0x10 + chip superio/ite/it8718f # Super I/O + device pnp 2e.0 off end # Floppy + device pnp 2e.1 on # COM1 + io 0x60 = 0x3f8 + irq 0x70 = 4 + end + device pnp 2e.2 off end # COM2 + device pnp 2e.3 on # Parallel port + io 0x60 = 0x378 + irq 0x70 = 7 + io 0x62 = 0 + drq 0x74 = 4 + irq 0xf0 = 0x08 + end + device pnp 2e.4 on # Environment controller + io 0x60 = 0x290 + irq 0x70 = 0x00 + io 0x62 = 0x000 + irq 0xf0 = 0x00 + irq 0xf1 = 0x00 + irq 0xf2 = 0x0a + irq 0xf3 = 0x00 + irq 0xf4 = 0x80 + irq 0xf5 = 0x20 + irq 0xf6 = 0x3e + end + device pnp 2e.5 on # Keyboard + io 0x60 = 0x60 + irq 0x70 = 1 + io 0x62 = 0x64 + irq 0xf0 = 0x48 + end + device pnp 2e.6 on # Mouse + irq 0x70 = 0 + irq 0x71 = 2 + irq 0xf0 = 0 + end + end + end + device pci 1f.1 on # IDE + ioapic_irq 2 INTB 0x11 + end + device pci 1f.2 on # SATA + ioapic_irq 2 INTC 0x12 + end + device pci 1f.3 on # SMBus + ioapic_irq 2 INTD 0x13 + end + end + end +end diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/dsdt.asl b/src/mainboard/gigabyte/ga-945gcm-s2l/dsdt.asl new file mode 100644 index 0000000..187481a --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/dsdt.asl @@ -0,0 +1,53 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +DefinitionBlock( + "dsdt.aml", + "DSDT", + 0x02, // DSDT revision: ACPI v2.0 + "COREv4", // OEM id + "COREBOOT", // OEM table id + 0x20090419 // OEM revision +) +{ + // Some generic macros + #include "acpi/platform.asl" + + // global NVS and variables + #include <southbridge/intel/i82801gx/acpi/globalnvs.asl> + #include <southbridge/intel/common/acpi/platform.asl> + + // General Purpose Events + //#include "acpi/gpe.asl" + + // mainboard specific devices + #include "acpi/mainboard.asl" + + // Thermal Zone + //#include "acpi/thermal.asl" + + #include <cpu/intel/common/acpi/cpu.asl> + + Scope (_SB) { + Device (PCI0) + { + #include <northbridge/intel/i945/acpi/i945.asl> + #include <southbridge/intel/i82801gx/acpi/ich7.asl> + } + } + + /* Chipset specific sleep states */ + #include <southbridge/intel/i82801gx/acpi/sleepstates.asl> +} diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/hda_verb.c b/src/mainboard/gigabyte/ga-945gcm-s2l/hda_verb.c new file mode 100644 index 0000000..1b57dfa --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/hda_verb.c @@ -0,0 +1,37 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Arthur Heymans arthur@aheymans.xyz + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + /* coreboot specific header */ + 0x10ec0662, /* Vendor ID */ + 0x1458a002, /* Subsystem ID */ + 0x00000009, /* Number of entries */ + + /* Pin Widget Verb Table */ + AZALIA_PIN_CFG(0, 0x14, 0x01014010), + AZALIA_PIN_CFG(0, 0x15, 0x411111f0), + AZALIA_PIN_CFG(0, 0x16, 0x411111f0), + AZALIA_PIN_CFG(0, 0x18, 0x01a19830), + AZALIA_PIN_CFG(0, 0x19, 0x02a19c31), + AZALIA_PIN_CFG(0, 0x1a, 0x0181303f), + AZALIA_PIN_CFG(0, 0x1b, 0x02214c1f), + AZALIA_PIN_CFG(0, 0x1c, 0x593301f0), + AZALIA_PIN_CFG(0, 0x1d, 0x4005c603), + AZALIA_PIN_CFG(0, 0x1e, 0x014b6120), +}; + +const u32 pc_beep_verbs[0] = {}; +AZALIA_ARRAY_SIZES; diff --git a/src/mainboard/gigabyte/ga-945gcm-s2l/romstage.c b/src/mainboard/gigabyte/ga-945gcm-s2l/romstage.c new file mode 100644 index 0000000..2965ff4 --- /dev/null +++ b/src/mainboard/gigabyte/ga-945gcm-s2l/romstage.c @@ -0,0 +1,217 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2008 coresystems GmbH + * Copyright (C) 2016 Arthur Heymans arthur@aheymans.xyz + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +// __PRE_RAM__ means: use "unsigned" for device, not a struct. + +#include <stdint.h> +#include <string.h> +#include <arch/io.h> +#include <device/pci_def.h> +#include <device/pnp_def.h> +#include <cpu/x86/lapic.h> +#include <lib.h> +#include <arch/acpi.h> +#include <cbmem.h> +#include <superio/ite/it8718f/it8718f.h> +#include <superio/ite/common/ite.h> +#include <pc80/mc146818rtc.h> +#include <console/console.h> +#include <cpu/x86/bist.h> +#include <cpu/intel/romstage.h> +#include <northbridge/intel/i945/i945.h> +#include <northbridge/intel/i945/raminit.h> +#include <southbridge/intel/i82801gx/i82801gx.h> + +#define SERIAL_DEV PNP_DEV(0x2e, IT8718F_SP1) +#define GPIO_DEV PNP_DEV(0x2e, IT8718F_GPIO) +#define EC_DEV PNP_DEV(0x2e, IT8718F_EC) +#define SUPERIO_DEV PNP_DEV(0x2e, 0) + +void setup_ich7_gpios(void) +{ + /* TODO: This is highly board specific and should be moved */ + printk(BIOS_DEBUG, " GPIOS..."); + /* General Registers */ + outl(0x1f15f7c1, DEFAULT_GPIOBASE + 0x00); /* GPIO_USE_SEL */ + outl(0xe0e8ffc3, DEFAULT_GPIOBASE + 0x04); /* GP_IO_SEL */ + outl(0xe2fefc03, DEFAULT_GPIOBASE + 0x0c); /* GP_LVL */ + /* Output Control Registers */ + outl(0x00400000, DEFAULT_GPIOBASE + 0x18); /* GPO_BLINK */ + /* Input Control Registers */ + outl(0x000039ff, DEFAULT_GPIOBASE + 0x2c); /* GPI_INV */ + outl(0x000000c7, DEFAULT_GPIOBASE + 0x30); /* GPIO_USE_SEL2 */ + outl(0x000000f0, DEFAULT_GPIOBASE + 0x34); /* GP_IO_SEL2 */ + outl(0x000000f2, DEFAULT_GPIOBASE + 0x38); /* GP_LVL2 */ +} + +static void setup_sio(void) +{ + /* Set default GPIOs on superio */ + ite_reg_write(GPIO_DEV, 0x25, 0x40); + ite_reg_write(GPIO_DEV, 0x26, 0x3f); + ite_reg_write(GPIO_DEV, 0x28, 0x41); + ite_reg_write(GPIO_DEV, 0x29, 0x88); + ite_reg_write(GPIO_DEV, 0x2c, 0x1c); + ite_reg_write(GPIO_DEV, 0x62, 0x08); + ite_reg_write(GPIO_DEV, 0x72, 0x00); + ite_reg_write(GPIO_DEV, 0x73, 0x38); + ite_reg_write(GPIO_DEV, 0xb1, 0x01); + ite_reg_write(GPIO_DEV, 0xb8, 0x80); + ite_reg_write(GPIO_DEV, 0xbb, 0x40); + ite_reg_write(GPIO_DEV, 0xc0, 0x00); + ite_reg_write(GPIO_DEV, 0xc3, 0x00); + ite_reg_write(GPIO_DEV, 0xc8, 0x00); + ite_reg_write(GPIO_DEV, 0xcb, 0x00); + ite_reg_write(GPIO_DEV, 0xf6, 0x26); + ite_reg_write(GPIO_DEV, 0xfc, 0x4a); + + ite_reg_write(EC_DEV, 0x70, 0x00); // Don't use IRQ9 + ite_reg_write(EC_DEV, 0x30, 0xff); // Enable +} + +static void ich7_enable_lpc(void) +{ + // Enable Serial IRQ + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0x64, 0xd0); + // Set COM1/COM2 decode range + pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x80, 0x0000); + // Enable COM1 + pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x82, 0x340d); + // Enable SuperIO Power Management Events + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x84, 0x000c0801); +} + +static void rcba_config(void) +{ + /* Enable IOAPIC */ + RCBA8(0x31ff) = 0x03; + + /* Disable unused devices */ + RCBA32(0x3418) = 0x003c0061; + + /* Enable PCIe Root Port Clock Gate */ + RCBA32(0x341c) = 0x00000001; +} + +static void early_ich7_init(void) +{ + uint8_t reg8; + uint32_t reg32; + + // program secondary mlt XXX byte? + pci_write_config8(PCI_DEV(0, 0x1e, 0), 0x1b, 0x20); + + // reset rtc power status + reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xa4); + reg8 &= ~(1 << 2); + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa4, reg8); + + // usb transient disconnect + reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xad); + reg8 |= (3 << 0); + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xad, reg8); + + reg32 = pci_read_config32(PCI_DEV(0, 0x1d, 7), 0xfc); + reg32 |= (1 << 29) | (1 << 17); + pci_write_config32(PCI_DEV(0, 0x1d, 7), 0xfc, reg32); + + reg32 = pci_read_config32(PCI_DEV(0, 0x1d, 7), 0xdc); + reg32 |= (1 << 31) | (1 << 27); + pci_write_config32(PCI_DEV(0, 0x1d, 7), 0xdc, reg32); + + RCBA32(0x0088) = 0x0011d000; + RCBA16(0x01fc) = 0x060f; + RCBA32(0x01f4) = 0x86000040; + RCBA32(0x0214) = 0x10030509; + RCBA32(0x0218) = 0x00020504; + RCBA8(0x0220) = 0xc5; + reg32 = RCBA32(0x3410); + reg32 |= (1 << 6); + RCBA32(0x3410) = reg32; + reg32 = RCBA32(0x3430); + reg32 &= ~(3 << 0); + reg32 |= (1 << 0); + RCBA32(0x3430) = reg32; + RCBA32(0x3418) |= (1 << 0); + RCBA16(0x0200) = 0x2008; + RCBA8(0x2027) = 0x0d; + RCBA16(0x3e08) |= (1 << 7); + RCBA16(0x3e48) |= (1 << 7); + RCBA32(0x3e0e) |= (1 << 7); + RCBA32(0x3e4e) |= (1 << 7); + + // next step only on ich7m b0 and later: + reg32 = RCBA32(0x2034); + reg32 &= ~(0x0f << 16); + reg32 |= (5 << 16); + RCBA32(0x2034) = reg32; +} + +void mainboard_romstage_entry(unsigned long bist) +{ + int s3resume = 0, boot_mode = 0; + + if (bist == 0) + enable_lapic(); + + ich7_enable_lpc(); + /* Enable SuperIO PM */ + setup_sio(); + ite_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); + + /* Disable SIO reboot */ + ite_reg_write(GPIO_DEV, 0xEF, 0x7E); + + /* Set up the console */ + console_init(); + + /* Halt if there was a built in self test failure */ + report_bist_failure(bist); + + if (MCHBAR16(SSKPD) == 0xCAFE) { + printk(BIOS_DEBUG, "soft reset detected.\n"); + boot_mode = 1; + } + + /* Perform some early chipset initialization required + * before RAM initialization can work + */ + i945_early_initialization(); + + s3resume = southbridge_detect_s3_resume(); + + /* Enable SPD ROMs and DDR-II DRAM */ + enable_smbus(); + +#if CONFIG_DEFAULT_CONSOLE_LOGLEVEL > 8 + dump_spd_registers(); +#endif + sdram_initialize(s3resume ? 2 : boot_mode, NULL); + + /* Perform some initialization that must run before stage2 */ + early_ich7_init(); + + /* This should probably go away. Until now it is required + * and mainboard specific + */ + rcba_config(); + + /* Chipset Errata! */ + fixup_i945_errata(); + + /* Initialize the internal PCIe links before we go into stage2 */ + i945_late_initialization(s3resume); +}
