Lijian Zhao (lijian.zhao@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15084
commit fea687bea516180e1d290a010588538010fbebdd Author: Zhao, Lijian lijian.zhao@intel.com Date: Tue May 17 19:01:34 2016 -0700
soc/intel/apollolake: Add EMMC DLL API
Newer FSP supports to update all the SDIO DLL programming value through silicon init upd. Implement the interface to pass board specific programming value to fsp silicon init.
Change-Id: Ifd901148f3f7f89f966217491c661ec346337c38 Signed-off-by: Zhao, Lijian lijian.zhao@intel.com Reviewed-on: https://chromium.devtools.intel.com/7372 Reviewed-by: Petrov, Andrey andrey.petrov@intel.com Tested-by: Petrov, Andrey andrey.petrov@intel.com Reviewed-on: https://chromium.devtools.intel.com/7585 --- src/soc/intel/apollolake/chip.c | 4 ++++ src/soc/intel/apollolake/chip.h | 7 +++++++ 2 files changed, 11 insertions(+)
diff --git a/src/soc/intel/apollolake/chip.c b/src/soc/intel/apollolake/chip.c index 17bceec..286a91d 100644 --- a/src/soc/intel/apollolake/chip.c +++ b/src/soc/intel/apollolake/chip.c @@ -115,6 +115,10 @@ void platform_fsp_silicon_init_params_cb(struct FSPS_UPD *silupd) silconfig->PcieRpClkReqNumber[4] = cfg->pcie_rp4_clkreq_pin; silconfig->PcieRpClkReqNumber[5] = cfg->pcie_rp5_clkreq_pin;
+ if (cfg->emmc_tx_data_cntl1 != 0) { + silconfig->EmmcTxDataCntl1 = cfg->emmc_tx_data_cntl1; + } + /* Our defaults may not match FSP defaults, so set them explicitly */ silconfig->AcpiBase = ACPI_PMIO_BASE; /* First 4k in BAR0 is used for IPC, real registers start at 4k offset */ diff --git a/src/soc/intel/apollolake/chip.h b/src/soc/intel/apollolake/chip.h index 3d9f5bd..a84eba1 100644 --- a/src/soc/intel/apollolake/chip.h +++ b/src/soc/intel/apollolake/chip.h @@ -40,6 +40,13 @@ struct soc_intel_apollolake_config { uint8_t pcie_rp4_clkreq_pin; uint8_t pcie_rp5_clkreq_pin;
+ uint32_t emmc_tx_cmd_cntl; + uint32_t emmc_tx_data_cntl1; + uint32_t emmc_tx_data_cntl2; + uint32_t emmc_rx_cmd_data_cntl1; + uint32_t emmc_rx_strobe_cntl; + uint32_t emmc_rx_cmd_data_cntl2; + /* Configure serial IRQ (SERIRQ) line. */ enum serirq_mode serirq_mode;
