Leroy P Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14497
commit e29c1b15fef0c54907bd30cd5f95fb2852713def Author: Lee Leahy leroy.p.leahy@intel.com Date: Sat Apr 23 17:27:44 2016 -0700
soc/intel/quark: Add IntelQNCConfig.h from EDK-II
Add the EDK-II Quark file IntelQNCConfig.h. This adds the definitions for the temperature sensor.
Change-Id: I70896e6187b878ea572535432912f1d4db895a99 Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- src/soc/intel/quark/include/soc/IntelQNCConfig.h | 73 ++++++++++++++++++++++++ 1 file changed, 73 insertions(+)
diff --git a/src/soc/intel/quark/include/soc/IntelQNCConfig.h b/src/soc/intel/quark/include/soc/IntelQNCConfig.h new file mode 100644 index 0000000..0375397 --- /dev/null +++ b/src/soc/intel/quark/include/soc/IntelQNCConfig.h @@ -0,0 +1,73 @@ +/** @file +Some configuration of QNC Package + +Copyright (c) 2013-2015 Intel Corporation. + +This program and the accompanying materials +are licensed and made available under the terms and conditions of the BSD License +which accompanies this distribution. The full text of the license may be found at +http://opensource.org/licenses/bsd-license.php + +THE PROGRAM IS DISTRIBUTED UNDER THE BSD LICENSE ON AN "AS IS" BASIS, +WITHOUT WARRANTIES OR REPRESENTATIONS OF ANY KIND, EITHER EXPRESS OR IMPLIED. + +**/ + +#ifndef __INTEL_QNC_CONFIG_H__ +#define __INTEL_QNC_CONFIG_H__ + +// +// QNC Fixed configurations. +// + +// +// Memory arbiter fixed config values. +// +#define QNC_FIXED_CONFIG_ASTATUS ((UINT32) (\ + (ASTATUS_PRI_NORMAL << ASTATUS0_DEFAULT_BP) | \ + (ASTATUS_PRI_NORMAL << ASTATUS1_DEFAULT_BP) | \ + (ASTATUS_PRI_URGENT << ASTATUS0_RASISED_BP) | \ + (ASTATUS_PRI_URGENT << ASTATUS1_RASISED_BP) \ + )) + +// +// Memory Manager fixed config values. +// +#define V_DRAM_NON_HOST_RQ_LIMIT 2 + +// +// RMU Thermal config fixed config values for TS in Vref Mode. +// +#define V_TSCGF1_CONFIG_ISNSCURRENTSEL_VREF_MODE 0x04 +#define V_TSCGF2_CONFIG2_ISPARECTRL_VREF_MODE 0x01 +#define V_TSCGF1_CONFIG_IBGEN_VREF_MODE 1 +#define V_TSCGF2_CONFIG_IDSCONTROL_VREF_MODE 0x011b +#define V_TSCGF2_CONFIG2_ICALCOARSETUNE_VREF_MODE 0x34 + +// +// RMU Thermal config fixed config values for TS in Ratiometric mode. +// +#define V_TSCGF1_CONFIG_ISNSCURRENTSEL_RATIO_MODE 0x04 +#define V_TSCGF1_CONFIG_ISNSCHOPSEL_RATIO_MODE 0x02 +#define V_TSCGF1_CONFIG_ISNSINTERNALVREFEN_RATIO_MODE 1 +#define V_TSCGF2_CONFIG_IDSCONTROL_RATIO_MODE 0x011f +#define V_TSCGF2_CONFIG_IDSTIMING_RATIO_MODE 0x0001 +#define V_TSCGF2_CONFIG2_ICALCONFIGSEL_RATIO_MODE 0x01 +#define V_TSCGF2_CONFIG2_ISPARECTRL_RATIO_MODE 0x00 +#define V_TSCGF1_CONFIG_IBGEN_RATIO_MODE 0 +#define V_TSCGF1_CONFIG_IBGCHOPEN_RATIO_MODE 0 +#define V_TSCGF3_CONFIG_ITSGAMMACOEFF_RATIO_MODE 0xC8 +#define V_TSCGF2_CONFIG2_ICALCOARSETUNE_RATIO_MODE 0x17 + +// +// iCLK fixed config values. +// +#define V_MUXTOP_FLEX2 3 +#define V_MUXTOP_FLEX1 1 + +// +// PCIe Root Port fixed config values. +// +#define V_PCIE_ROOT_PORT_SBIC_VALUE (B_QNC_PCIE_IOSFSBCTL_SBIC_IDLE_NEVER) + +#endif
