Hannah Williams (hannah.williams@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/12749
commit 5a4962b2fc028e7c737f7f3f29debeceaeafaf4e Author: Shobhit Srivastava shobhit.srivastava@intel.com Date: Fri Oct 9 17:05:16 2015 +0530
Strago: Enable CA Mirror
Configuring UPD PcdCaMirrorEn. This is a board specific parameter. CA mirror is the Command Address mirroring option that is enabled on this board
CQ-DEPEND=CL:13038
Original-Reviewed-on: https://chromium-review.googlesource.com/309190 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org Original-Tested-by: Hannah Williams hannah.williams@intel.com Original-Reviewed-by: Duncan Laurie dlaurie@chromium.org
Change-Id: I05174e18d650332d838e5036c713e91c4840ee75 Signed-off-by: Divya Sasidharan divya.s.sasidharan@intel.com Signed-off-by: Hannah Williams hannah.williams@intel.com --- src/mainboard/intel/strago/devicetree.cb | 1 + src/soc/intel/braswell/chip.h | 1 + src/soc/intel/braswell/romstage/romstage.c | 1 + 3 files changed, 3 insertions(+)
diff --git a/src/mainboard/intel/strago/devicetree.cb b/src/mainboard/intel/strago/devicetree.cb index 3b93f44..ae8c11e 100755 --- a/src/mainboard/intel/strago/devicetree.cb +++ b/src/mainboard/intel/strago/devicetree.cb @@ -13,6 +13,7 @@ chip soc/intel/braswell register "PcdApertureSize" = "2" register "PcdGttSize" = "1" register "PcdDvfsEnable" = "0" + register "PcdCaMirrorEn" = "1"
############################################################ # Set the parameters for SiliconInit diff --git a/src/soc/intel/braswell/chip.h b/src/soc/intel/braswell/chip.h index 7b01f0b..e302d6c 100644 --- a/src/soc/intel/braswell/chip.h +++ b/src/soc/intel/braswell/chip.h @@ -75,6 +75,7 @@ struct soc_intel_braswell_config { UINT8 PcdGttSize; UINT8 PcdLegacySegDecode; UINT8 PcdDvfsEnable; + UINT8 PcdCaMirrorEn; /* Command Address Mirroring Enabled */
/* * The following fields come from fsp_vpd.h .aka. VpdHeader.h. diff --git a/src/soc/intel/braswell/romstage/romstage.c b/src/soc/intel/braswell/romstage/romstage.c index 71402ac..5c38c18 100644 --- a/src/soc/intel/braswell/romstage/romstage.c +++ b/src/soc/intel/braswell/romstage/romstage.c @@ -219,6 +219,7 @@ void soc_memory_init_params(struct romstage_params *params, upd->PcdGttSize = config->PcdGttSize; upd->PcdLegacySegDecode = config->PcdLegacySegDecode; upd->PcdDvfsEnable = config->PcdDvfsEnable; + upd->PcdCaMirrorEn = config->PcdCaMirrorEn; }
void soc_display_memory_init_params(const MEMORY_INIT_UPD *old,
