Attention is currently required from: Raul Rangel, Mariusz Szafrański, Jonathan Zhang, Paul Menzel, Stefan Reinauer, Kyösti Mälkki, Andrey Petrov, Patrick Rudolph, Nico Huber, Anjaneya "Reddy" Chagam, Johnny Lin, Suresh Bellampalli, Morgan Jang, Michal Motyl, Alexander Couzens, Felix Held, Furquan Shaikh, Angel Pons, Lance Zhao, Jason Glenesk, Martin Roth, Damien Zammit, Lee Leahy, Marshall Dawson, Tim Wawrzynczak, Vanessa Eusebio, Huang Jin.
Shelley Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/57333 )
Change subject: Rename MMCONF Kconfigs to ECAM_MMCONF
Patch Set 4:
(8 comments)
Commit Message:
https://review.coreboot.org/c/coreboot/+/57333/comment/e0b27b24_12c9b8ac
PS3, Line 10: pci
nit: […]
Done
https://review.coreboot.org/c/coreboot/+/57333/comment/d1672181_cd6f1053
PS3, Line 11: This can be confusing as
: other platforms, such as ARM, use a different way of mapping the pci
: config space to memory.
My understanding so far (for QC IIUC) is that there is a single 4K window in MMIO space, and some ot […]
Thanks, Tim. That's probably much better than I can explain it :).
File payloads/external/Makefile.inc:
https://review.coreboot.org/c/coreboot/+/57333/comment/e717aa2a_a6f2a2b6
PS3, Line 149: CONFIG_ECAM_MMCONF_BASE_ADDRESS=$(CONFIG_ECAM_MMCONF_BASE_ADDRESS) \
This change and the one in payloads/external/tianocore/Makefile. […]
This was not intentional, but what I wanted to do was maintain functionality at this point. As ECAM is the only access method implemented right now, I wanted to stick all existing MMIO functionality under that umbrella. The intention is to create another config for the ARM MMIO access mechanism. We should be able to add support for both if needed in the future.
File src/device/Kconfig:
https://review.coreboot.org/c/coreboot/+/57333/comment/e9ff90ce_92c7e827
PS3, Line 502: NO_ECAM_MMCONF_SUPPORT
Maybe add some help text to this and the config below explaining what ECAM_MMCONF is? Basically jus […]
Done
https://review.coreboot.org/c/coreboot/+/57333/comment/39fcd6a7_261b0771
PS3, Line 504: default n
default y if !x86 ?
Done
https://review.coreboot.org/c/coreboot/+/57333/comment/cab25a6e_4bdf345a
PS3, Line 506: ECAM_MMCONF_SUPPORT
Make this depend on X86?
Done
https://review.coreboot.org/c/coreboot/+/57333/comment/7192a7b4_984cc922
PS3, Line 622: depends on (ECAM_MMCONF_SUPPORT || PCI_IO_CFG_EXT)
Does this specifically depend on ECAM, or just MMCONF?
No, but all the current MMCONF support only covers ECAM and is only used by x86, so we thought that it would be cleaner to just move everything to under the ECAM config and create a new config for the ARM side of things.
https://review.coreboot.org/c/coreboot/+/57333/comment/e8e61883_53f63b3c
PS3, Line 639: default 16 if ECAM_MMCONF_SUPPORT && ECAM_MMCONF_BUS_NUMBER <= 128
Same as above.
See response above.
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: I1e196a1ed52d131a71f00cba1d93a23e54aca3e2
Gerrit-Change-Number: 57333
Gerrit-PatchSet: 4
Gerrit-Owner: Shelley Chen
shchen@google.com
Gerrit-Reviewer: Alexander Couzens
lynxis@fe80.eu
Gerrit-Reviewer: Andrey Petrov
andrey.petrov@gmail.com
Gerrit-Reviewer: Angel Pons
th3fanbus@gmail.com
Gerrit-Reviewer: Anjaneya "Reddy" Chagam
anjaneya.chagam@intel.com
Gerrit-Reviewer: Damien Zammit
Gerrit-Reviewer: Felix Held
felix-coreboot@felixheld.de
Gerrit-Reviewer: Furquan Shaikh
furquan@google.com
Gerrit-Reviewer: Huang Jin
huang.jin@intel.com
Gerrit-Reviewer: Jason Glenesk
jason.glenesk@gmail.com
Gerrit-Reviewer: Johnny Lin
Johnny_Lin@wiwynn.com
Gerrit-Reviewer: Jonathan Zhang
jonzhang@fb.com
Gerrit-Reviewer: Kyösti Mälkki
kyosti.malkki@gmail.com
Gerrit-Reviewer: Lance Zhao
Gerrit-Reviewer: Lee Leahy
leroy.p.leahy@intel.com
Gerrit-Reviewer: Mariusz Szafrański
mariuszx.szafranski@intel.com
Gerrit-Reviewer: Marshall Dawson
marshalldawson3rd@gmail.com
Gerrit-Reviewer: Martin Roth
martinroth@google.com
Gerrit-Reviewer: Michal Motyl
michalx.motyl@intel.com
Gerrit-Reviewer: Morgan Jang
Morgan_Jang@wiwynn.com
Gerrit-Reviewer: Nico Huber
nico.h@gmx.de
Gerrit-Reviewer: Patrick Rudolph
siro@das-labor.org
Gerrit-Reviewer: Raul Rangel
rrangel@chromium.org
Gerrit-Reviewer: Stefan Reinauer
stefan.reinauer@coreboot.org
Gerrit-Reviewer: Suresh Bellampalli
suresh.bellampalli@intel.com
Gerrit-Reviewer: Tim Wawrzynczak
twawrzynczak@chromium.org
Gerrit-Reviewer: Vanessa Eusebio
vanessa.f.eusebio@intel.com
no-reply@coreboot.org
Gerrit-CC: Paul Menzel
paulepanter@mailbox.org
Gerrit-Attention: Raul Rangel
Gerrit-Attention: Mariusz Szafrański
Gerrit-Attention: Jonathan Zhang
jonzhang@fb.com
Gerrit-Attention: Paul Menzel
Gerrit-Attention: Stefan Reinauer
Gerrit-Attention: Kyösti Mälkki
Gerrit-Attention: Andrey Petrov
Gerrit-Attention: Patrick Rudolph
siro@das-labor.org
Gerrit-Attention: Nico Huber
nico.h@gmx.de
Gerrit-Attention: Anjaneya "Reddy" Chagam
Gerrit-Attention: Johnny Lin
Gerrit-Attention: Suresh Bellampalli
Gerrit-Attention: Morgan Jang
Gerrit-Attention: Michal Motyl
Gerrit-Attention: Alexander Couzens
lynxis@fe80.eu
Gerrit-Attention: Felix Held
Gerrit-Attention: Furquan Shaikh
furquan@google.com
Gerrit-Attention: Angel Pons
th3fanbus@gmail.com
Gerrit-Attention: Lance Zhao
Gerrit-Attention: Jason Glenesk
Gerrit-Attention: Martin Roth
Gerrit-Attention: Damien Zammit
Gerrit-Attention: Lee Leahy
Gerrit-Attention: Marshall Dawson
Gerrit-Attention: Tim Wawrzynczak
Gerrit-Attention: Vanessa Eusebio
Gerrit-Attention: Huang Jin
huang.jin@intel.com
Gerrit-Comment-Date: Fri, 03 Sep 2021 07:00:40 +0000
Gerrit-HasComments: Yes
Gerrit-Has-Labels: No
Comment-In-Reply-To: Martin Roth
Comment-In-Reply-To: Tim Wawrzynczak
Comment-In-Reply-To: Angel Pons
th3fanbus@gmail.com
Gerrit-MessageType: comment
