Attention is currently required from: Raul Rangel, Mariusz Szafrański, Jonathan Zhang, Paul Menzel, Stefan Reinauer, Kyösti Mälkki, Andrey Petrov, Patrick Rudolph, Nico Huber, Anjaneya "Reddy" Chagam, Johnny Lin, Suresh Bellampalli, Morgan Jang, Michal Motyl, Alexander Couzens, Felix Held, Shelley Chen, Furquan Shaikh, Angel Pons, Lance Zhao, Jason Glenesk, Damien Zammit, Lee Leahy, Marshall Dawson, Vanessa Eusebio, Huang Jin. Hello build bot (Jenkins), Raul Rangel, Mariusz Szafrański, Jonathan Zhang, Stefan Reinauer, Kyösti Mälkki, Andrey Petrov, Patrick Rudolph, Nico Huber, Anjaneya "Reddy" Chagam, Johnny Lin, Suresh Bellampalli, Michal Motyl, Morgan Jang, Alexander Couzens, Felix Held, Furquan Shaikh, Angel Pons, Lance Zhao, Jason Glenesk, Damien Zammit, Martin Roth, Lee Leahy, Marshall Dawson, Tim Wawrzynczak, Vanessa Eusebio, Huang Jin,
https://review.coreboot.org/c/coreboot/+/57333
Change subject: Rename MMCONF Kconfigs to ECAM_MMCONF ......................................................................
Currently, the MMCONF Kconfigs only use the Enhanced Configuration Access mechanism (ECAM) method for accessing the PCI config address space, which applies only to x86 platforms. This can be confusing as other platforms, such as ARM, use a different way of mapping the PCI config space to memory. Renaming the following configs to make it clear that these configs only apply to ECAM:
NO_MMCONF_SUPPORT --> NO_ECAM_MMCONF_SUPPORT MMCONF_SUPPORT --> ECAM_MMCONF_SUPPORT MMCONF_BASE_ADDRESS --> ECAM_MMCONF_BASE_ADDRESS MMCONF_BUS_NUMBER --> ECAM_MMCONF_BUS_NUMBER MMCONF_LENGTH --> ECAM_MMCONF_LENGTH
BUG=b:181098581 BRANCH=None TEST=./util/abuild/abuild -p none -t GOOGLE_KOHAKU -x -a -c max Make sure Jenkins verifies that builds on other boards
Change-Id: I1e196a1ed52d131a71f00cba1d93a23e54aca3e2 Signed-off-by: Shelley Chen shchen@google.com --- M payloads/external/Makefile.inc M payloads/external/tianocore/Makefile M src/acpi/dsdt_top.asl M src/arch/x86/include/arch/pci_io_cfg.h M src/device/Kconfig M src/device/device_util.c M src/device/pci_ops.c M src/drivers/intel/fsp1_1/romstage.c M src/include/device/pci_mmio_cfg.h M src/lib/Kconfig M src/mainboard/asus/p8x7x-series/variants/p8z77-m_pro/early_init.c M src/mainboard/emulation/qemu-i440fx/Kconfig M src/mainboard/emulation/qemu-q35/Kconfig M src/mainboard/emulation/qemu-q35/acpi_tables.c M src/mainboard/emulation/qemu-q35/bootblock.c M src/mainboard/emulation/qemu-q35/memmap.c M src/mainboard/google/butterfly/early_init.c M src/mainboard/google/link/early_init.c M src/mainboard/google/parrot/early_init.c M src/mainboard/google/stout/early_init.c M src/mainboard/intel/dcp847ske/romstage.c M src/mainboard/intel/emeraldlake2/early_init.c M src/mainboard/kontron/ktqm77/early_init.c M src/mainboard/lenovo/x220/early_init.c M src/mainboard/roda/rv11/variants/rv11/early_init.c M src/mainboard/roda/rv11/variants/rw11/early_init.c M src/mainboard/samsung/lumpy/early_init.c M src/mainboard/samsung/stumpy/early_init.c M src/northbridge/amd/agesa/family14/Kconfig M src/northbridge/amd/agesa/family15tn/Kconfig M src/northbridge/amd/agesa/family16kb/Kconfig M src/northbridge/amd/pi/00730F01/Kconfig M src/northbridge/intel/e7505/Kconfig M src/northbridge/intel/gm45/Kconfig M src/northbridge/intel/gm45/acpi.c M src/northbridge/intel/gm45/acpi/gm45.asl M src/northbridge/intel/gm45/bootblock.c M src/northbridge/intel/haswell/Kconfig M src/northbridge/intel/haswell/acpi.c M src/northbridge/intel/haswell/acpi/hostbridge.asl M src/northbridge/intel/haswell/bootblock.c M src/northbridge/intel/haswell/haswell_mrc/raminit.c M src/northbridge/intel/i440bx/Kconfig M src/northbridge/intel/i945/Kconfig M src/northbridge/intel/i945/acpi.c M src/northbridge/intel/i945/acpi/i945.asl M src/northbridge/intel/i945/bootblock.c M src/northbridge/intel/ironlake/Kconfig M src/northbridge/intel/ironlake/acpi.c M src/northbridge/intel/ironlake/acpi/ironlake.asl M src/northbridge/intel/ironlake/bootblock.c M src/northbridge/intel/ironlake/ironlake.h M src/northbridge/intel/pineview/Kconfig M src/northbridge/intel/pineview/acpi.c M src/northbridge/intel/pineview/acpi/pineview.asl M src/northbridge/intel/pineview/bootblock.c M src/northbridge/intel/sandybridge/Kconfig M src/northbridge/intel/sandybridge/acpi.c M src/northbridge/intel/sandybridge/acpi/hostbridge.asl M src/northbridge/intel/sandybridge/bootblock.c M src/northbridge/intel/sandybridge/raminit_mrc.c M src/northbridge/intel/x4x/Kconfig M src/northbridge/intel/x4x/acpi.c M src/northbridge/intel/x4x/acpi/x4x.asl M src/northbridge/intel/x4x/bootblock.c M src/security/intel/stm/StmPlatformResource.c M src/soc/amd/cezanne/Kconfig M src/soc/amd/cezanne/acpi/pci0.asl M src/soc/amd/cezanne/fsp_m_params.c M src/soc/amd/common/block/acpi/tables.c M src/soc/amd/common/block/pci/amd_pci_mmconf.c M src/soc/amd/picasso/Kconfig M src/soc/amd/picasso/acpi/sb_pci0_fch.asl M src/soc/amd/picasso/fsp_m_params.c M src/soc/amd/stoneyridge/Kconfig M src/soc/cavium/cn81xx/Kconfig M src/soc/example/min86/Kconfig M src/soc/intel/alderlake/Kconfig M src/soc/intel/alderlake/systemagent.c M src/soc/intel/apollolake/systemagent.c M src/soc/intel/baytrail/Kconfig M src/soc/intel/baytrail/acpi.c M src/soc/intel/baytrail/acpi/southcluster.asl M src/soc/intel/baytrail/bootblock/bootblock.c M src/soc/intel/braswell/Kconfig M src/soc/intel/braswell/acpi.c M src/soc/intel/braswell/acpi/southcluster.asl M src/soc/intel/braswell/bootblock/bootblock.c M src/soc/intel/broadwell/Kconfig M src/soc/intel/broadwell/acpi.c M src/soc/intel/broadwell/bootblock.c M src/soc/intel/broadwell/pei_data.c M src/soc/intel/cannonlake/systemagent.c M src/soc/intel/common/block/acpi/acpi.c M src/soc/intel/common/block/systemagent/Kconfig M src/soc/intel/common/block/systemagent/systemagent_early.c M src/soc/intel/denverton_ns/Kconfig M src/soc/intel/denverton_ns/acpi.c M src/soc/intel/denverton_ns/acpi/northcluster.asl M src/soc/intel/denverton_ns/bootblock/bootblock.c M src/soc/intel/elkhartlake/Kconfig M src/soc/intel/elkhartlake/systemagent.c M src/soc/intel/icelake/Kconfig M src/soc/intel/icelake/systemagent.c M src/soc/intel/jasperlake/Kconfig M src/soc/intel/jasperlake/systemagent.c M src/soc/intel/quark/Kconfig M src/soc/intel/skylake/acpi.c M src/soc/intel/skylake/systemagent.c M src/soc/intel/tigerlake/Kconfig M src/soc/intel/tigerlake/systemagent.c M src/soc/intel/xeon_sp/Kconfig M src/soc/intel/xeon_sp/uncore.c M src/southbridge/amd/agesa/hudson/lpc.c M src/southbridge/amd/cimx/sb800/late.c M src/southbridge/amd/pi/hudson/lpc.c M src/vendorcode/amd/agesa/f14/Config/PlatformInstall.h M src/vendorcode/amd/agesa/f15tn/Config/PlatformInstall.h M src/vendorcode/amd/agesa/f16kb/Config/PlatformInstall.h M src/vendorcode/amd/cimx/sb800/OEM.h 120 files changed, 234 insertions(+), 217 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/33/57333/4
