Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10635
commit e56004c50fdd441ef733783676a853ef059e7935 Author: Patrick Georgi pgeorgi@chromium.org Date: Mon Jun 22 19:43:18 2015 +0200
google/smaug: add new mainboard
This is an nvidia t210 based board. The commit includes all Chrome OS changes up to Change-Id: I714fdc87e7.
Change-Id: I4d77659f4f2d21b1bbdcfc3467e1a166c02ddd47 Signed-off-by: Patrick Georgi pgeorgi@chromium.org --- src/mainboard/google/smaug/Kconfig | 109 +++ src/mainboard/google/smaug/Kconfig.name | 2 + src/mainboard/google/smaug/Makefile.inc | 52 ++ src/mainboard/google/smaug/bct/Makefile.inc | 30 + src/mainboard/google/smaug/bct/cfg2inc.sh | 34 + src/mainboard/google/smaug/bct/emmc.cfg | 16 + src/mainboard/google/smaug/bct/jtag.cfg | 16 + src/mainboard/google/smaug/bct/odmdata.cfg | 1 + .../google/smaug/bct/sdram-samsung-204.cfg | 958 +++++++++++++++++++++ .../google/smaug/bct/sdram-samsung-3GB-204.inc | 476 ++++++++++ .../google/smaug/bct/sdram-samsung-4GB-204.inc | 476 ++++++++++ src/mainboard/google/smaug/bct/sdram-unused.inc | 4 + src/mainboard/google/smaug/bct/spi.cfg | 16 + src/mainboard/google/smaug/boardid.c | 43 + src/mainboard/google/smaug/bootblock.c | 119 +++ src/mainboard/google/smaug/chromeos.c | 107 +++ src/mainboard/google/smaug/devicetree.cb | 53 ++ src/mainboard/google/smaug/gpio.h | 72 ++ src/mainboard/google/smaug/mainboard.c | 229 +++++ src/mainboard/google/smaug/memlayout.ld | 6 + src/mainboard/google/smaug/pmic.c | 112 +++ src/mainboard/google/smaug/pmic.h | 79 ++ src/mainboard/google/smaug/reset.c | 30 + src/mainboard/google/smaug/romstage.c | 57 ++ src/mainboard/google/smaug/sdram_configs.c | 54 ++ 25 files changed, 3151 insertions(+)
diff --git a/src/mainboard/google/smaug/Kconfig b/src/mainboard/google/smaug/Kconfig new file mode 100644 index 0000000..e96c7c6 --- /dev/null +++ b/src/mainboard/google/smaug/Kconfig @@ -0,0 +1,109 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2015 Google Inc. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc. +## + +if BOARD_GOOGLE_SMAUG + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select BOARD_ID_AUTO + select BOARD_ROMSIZE_KB_16384 + select CHROMEOS_VBNV_EC + select EC_GOOGLE_CHROMEEC + select EC_GOOGLE_CHROMEEC_I2C + select EC_GOOGLE_CHROMEEC_I2C_PROTO3 + select EC_SOFTWARE_SYNC + select MAINBOARD_DO_NATIVE_VGA_INIT + select SPI_FLASH + select SOC_NVIDIA_TEGRA210 + select MAINBOARD_DO_DSI_INIT + select MAINBOARD_HAS_BOOTBLOCK_INIT + select MAINBOARD_HAS_CHROMEOS + select VIRTUAL_DEV_SWITCH + select RAM_CODE_SUPPORT + +config MAINBOARD_DIR + string + default google/smaug + +config MAINBOARD_PART_NUMBER + string + default "Smaug" + +config DRAM_SIZE_MB + int + default 2048 + +choice + prompt "BCT boot media" + default SMAUG_BCT_CFG_SPI + help + Which boot media to configure the BCT for. + +config SMAUG_BCT_CFG_SPI + bool "SPI" + help + Configure the BCT for booting from SPI. + +config SMAUG_BCT_CFG_EMMC + bool "eMMC" + help + Configure the BCT for booting from eMMC. + +endchoice + +config BOOT_MEDIA_SPI_BUS + int "SPI bus with boot media ROM" + range 1 7 + depends on SMAUG_BCT_CFG_SPI + default 7 + help + Which SPI bus the boot media is connected to. + +config BOOT_MEDIA_SPI_CHIP_SELECT + int "Chip select for SPI boot media" + range 0 3 + depends on SMAUG_BCT_CFG_SPI + default 0 + help + Which chip select to use for boot media. + +# For smaug, we are using vboot2. Thus, index for stages: +# VBOOT_ROMSTAGE_INDEX -> Use default value of 0x2 +# VBOOT_RAMSTAGE_INDEX -> Use 0x3 +config VBOOT_BL31_INDEX + hex + default 0x4 + +config VBOOT_RAMSTAGE_INDEX + hex + default 0x3 + +config DRIVER_TPM_I2C_BUS + hex + default 0x2 + +config DRIVER_TPM_I2C_ADDR + hex + default 0x20 + +config EC_GOOGLE_CHROMEEC_I2C_BUS + hex + default 1 + +endif # BOARD_GOOGLE_SMAUG diff --git a/src/mainboard/google/smaug/Kconfig.name b/src/mainboard/google/smaug/Kconfig.name new file mode 100644 index 0000000..7f83a3a --- /dev/null +++ b/src/mainboard/google/smaug/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_GOOGLE_SMAUG + bool "Smaug" diff --git a/src/mainboard/google/smaug/Makefile.inc b/src/mainboard/google/smaug/Makefile.inc new file mode 100644 index 0000000..1e84d54 --- /dev/null +++ b/src/mainboard/google/smaug/Makefile.inc @@ -0,0 +1,52 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2015 Google Inc. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc. +## + +# Add a handler for BCT config files +$(call add-special-class,bct-cfg) +bct-cfg-handler= $(eval $(obj)/generated/bct.cfg: $(1)$(2)) + +$(obj)/generated/bct.cfg: + @printf " CAT $(subst $(obj)/,,$(@))\n" + cat $^ > $@ + +subdirs-y += bct + +bootblock-y += bootblock.c +bootblock-y += pmic.c +bootblock-y += reset.c + +verstage-y += chromeos.c +verstage-y += reset.c + +romstage-y += chromeos.c +romstage-y += pmic.c +romstage-y += reset.c +romstage-y += romstage.c +romstage-y += sdram_configs.c + +ramstage-y += chromeos.c +ramstage-y += boardid.c +ramstage-y += mainboard.c +ramstage-y += reset.c +ramstage-y += pmic.c + +bootblock-y += memlayout.ld +romstage-y += memlayout.ld +ramstage-y += memlayout.ld +verstage-y += memlayout.ld diff --git a/src/mainboard/google/smaug/bct/Makefile.inc b/src/mainboard/google/smaug/bct/Makefile.inc new file mode 100644 index 0000000..74ff385a --- /dev/null +++ b/src/mainboard/google/smaug/bct/Makefile.inc @@ -0,0 +1,30 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2015 Google Inc. +## Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc. +## + +bct-cfg-$(CONFIG_SMAUG_BCT_CFG_EMMC) += emmc.cfg +bct-cfg-$(CONFIG_SMAUG_BCT_CFG_SPI) += spi.cfg +bct-cfg-y += odmdata.cfg +bct-cfg-y += jtag.cfg +#NOTE: When full LPDDR4 SDRAM config is done in romstage, remove this +bct-cfg-$(CONFIG_BOOTROM_SDRAM_INIT) += sdram-samsung-204.cfg + +# Note when SDRAM config (sdram-*.cfg) files are changed, we have to regenerate +# the include files (sdram-*.inc) by running "./cfg2inc.sh sdram-*.cfg". +# TODO(hungte) Change cfg2inc.sh to NVIDIA's official tool in cbootimage. diff --git a/src/mainboard/google/smaug/bct/cfg2inc.sh b/src/mainboard/google/smaug/bct/cfg2inc.sh new file mode 100644 index 0000000..cfa6709 --- /dev/null +++ b/src/mainboard/google/smaug/bct/cfg2inc.sh @@ -0,0 +1,34 @@ +#!/bin/sh +# +# This file is part of the coreboot project. +# +# Copyright 2015 Google Inc. +# +# This program is free software; you can redistribute it and/or modify +# it under the terms of the GNU General Public License as published by +# the Free Software Foundation; version 2 of the License. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc. + +bct_cfg2inc() { + local in_file="$1" + local out_file="$2" + echo "{ /* generated from ${in_file}; do not edit. */" >"${out_file}" + # Note currently we can only handle DDR3 type memory, even in C + # implementation. + sed "/^#.*$/d; s/^SDRAM.0./ /; s/\r$//; s/;$/,/;" \ + "${in_file}" >> "${out_file}" + echo "}," >>"${out_file}" +} + +for file in $@; do + echo "Generating $file => ${file%cfg}inc..." + bct_cfg2inc "${file}" "${file%cfg}inc" +done diff --git a/src/mainboard/google/smaug/bct/emmc.cfg b/src/mainboard/google/smaug/bct/emmc.cfg new file mode 100644 index 0000000..13ee047 --- /dev/null +++ b/src/mainboard/google/smaug/bct/emmc.cfg @@ -0,0 +1,16 @@ +# Copyright 2015 Google Inc. All rights reserved. +# Distributed under the terms of the GNU General Public License v2 + +Version = 0x00210001; +BlockSize = 0x00004000; +PageSize = 0x00000200; +PartitionSize = 0x01000000; + +# +# T210 bct only supports one boot device +# +DevType[0] = NvBootDevType_Sdmmc; +DeviceParam[0].SdmmcParams.ClockDivider = 0x00000009; +DeviceParam[0].SdmmcParams.DataWidth = NvBootSdmmcDataWidth_8Bit; +DeviceParam[0].SdmmcParams.MaxPowerClassSupported = 0x00000000; +DeviceParam[0].SdmmcParams.MultiPageSupport = 0x00000000; diff --git a/src/mainboard/google/smaug/bct/jtag.cfg b/src/mainboard/google/smaug/bct/jtag.cfg new file mode 100644 index 0000000..4f2c36c --- /dev/null +++ b/src/mainboard/google/smaug/bct/jtag.cfg @@ -0,0 +1,16 @@ +# +# Set JtagCtrl to 1 to reenable Jtag +# +JtagCtrl = 0; +# +# Fill in chip unique id +# +# ChipUid can be found by running tegrarcm in tegra recovery mode +# (also hooking up A-A USB cable) and looking for console output +# on line starting with "Chip UID:" +# +# Command example: +# $ sudo tegrarcm --bct=/build/foster/firmware/bct/board.bct --bootloader=/build/foster/firmware/u-boot.bin --loadaddr=0x80108000 +# Where board.bct and u-boot.bin do not have to be prebuilt. +# +ChipUid = 0x00000000000000000000000000000000; diff --git a/src/mainboard/google/smaug/bct/odmdata.cfg b/src/mainboard/google/smaug/bct/odmdata.cfg new file mode 100644 index 0000000..45648af --- /dev/null +++ b/src/mainboard/google/smaug/bct/odmdata.cfg @@ -0,0 +1 @@ +OdmData = 0x00294000; diff --git a/src/mainboard/google/smaug/bct/sdram-samsung-204.cfg b/src/mainboard/google/smaug/bct/sdram-samsung-204.cfg new file mode 100644 index 0000000..9bf9c97 --- /dev/null +++ b/src/mainboard/google/smaug/bct/sdram-samsung-204.cfg @@ -0,0 +1,958 @@ +# Do not edit. Generated by t210_emc_reg_tool_P975 V9.7.5. Command: +# t210_emc_reg_tool_P975 -i Samsung_K4F2E304HA-MGCH_3GB.par 4.90196078431372549019 -dram_board_cfg 40 +# -dbi_rd_en 1 -data_bus_to_0 1 -fly_by_time_ps 1717 -t T210DSC_TBKV_A44_P5.xlsm_BKV.txt +# -o T210_A44_R1_LP4_DSC_204Mhz.cfg +# Parameter file: Samsung_K4F2E304HA-MGCH_3GB.par, tck = 4.90 ns (204.00 MHz) +SDRAM[2].MemoryType = NvBootMemoryType_LpDdr4; +SDRAM[2].PllMInputDivider = 0x00000001; +SDRAM[2].PllMFeedbackDivider = 0x00000022; +SDRAM[2].PllMStableTime = 0x0000012c; +SDRAM[2].PllMSetupControl = 0x00000000; +SDRAM[2].PllMPostDivider = 0x00000000; +SDRAM[2].PllMKCP = 0x00000000; +SDRAM[2].PllMKVCO = 0x00000000; +SDRAM[2].EmcBctSpare0 = 0x00000000; +SDRAM[2].EmcBctSpare1 = 0x00000000; +SDRAM[2].EmcBctSpare2 = 0x00000000; +SDRAM[2].EmcBctSpare3 = 0x00000000; +SDRAM[2].EmcBctSpare4 = 0x7001bc3c; +SDRAM[2].EmcBctSpare5 = 0x00000032; +SDRAM[2].EmcBctSpare6 = 0x7001b404; +SDRAM[2].EmcBctSpare7 = 0x76342501; +SDRAM[2].EmcBctSpare8 = 0x7000e6c8; +SDRAM[2].EmcBctSpare9 = 0x00000000; +SDRAM[2].EmcBctSpare10 = 0x00000000; +SDRAM[2].EmcBctSpare11 = 0x00000000; +SDRAM[2].EmcBctSpare12 = 0x7001bc3c; +SDRAM[2].EmcBctSpare13 = 0x00000033; +SDRAM[2].EmcClockSource = 0x40188002; +SDRAM[2].EmcClockSourceDll = 0x40000000; +SDRAM[2].ClkRstControllerPllmMisc2Override = 0x00000000; +SDRAM[2].ClkRstControllerPllmMisc2OverrideEnable = 0x00000000; +SDRAM[2].ClearClk2Mc1 = 0x00000000; +SDRAM[2].EmcAutoCalInterval = 0x001fffff; +SDRAM[2].EmcAutoCalConfig = 0xa01a51d8; +SDRAM[2].EmcAutoCalConfig2 = 0x05500000; +SDRAM[2].EmcAutoCalConfig3 = 0x00770000; +SDRAM[2].EmcAutoCalConfig4 = 0x00770000; +SDRAM[2].EmcAutoCalConfig5 = 0x00770000; +SDRAM[2].EmcAutoCalConfig6 = 0x00770000; +SDRAM[2].EmcAutoCalConfig7 = 0x00770000; +SDRAM[2].EmcAutoCalConfig8 = 0x00770000; +SDRAM[2].EmcAutoCalVrefSel0 = 0xb3afa6a6; +SDRAM[2].EmcAutoCalVrefSel1 = 0x00009e3c; +SDRAM[2].EmcAutoCalChannel = 0xc1e00303; +SDRAM[2].EmcPmacroAutocalCfg0 = 0x04040404; +SDRAM[2].EmcPmacroAutocalCfg1 = 0x04040404; +SDRAM[2].EmcPmacroAutocalCfg2 = 0x00000000; +SDRAM[2].EmcPmacroRxTerm = 0x1f1f1f1f; +SDRAM[2].EmcPmacroDqTxDrv = 0x1f1f1f1f; +SDRAM[2].EmcPmacroCaTxDrv = 0x1f1f1f1f; +SDRAM[2].EmcPmacroCmdTxDrv = 0x00001f1f; +SDRAM[2].EmcPmacroAutocalCfgCommon = 0x00000804; +SDRAM[2].EmcPmacroZctrl = 0x00000550; +SDRAM[2].EmcAutoCalWait = 0x000001a1; +SDRAM[2].EmcXm2CompPadCtrl = 0x00000032; +SDRAM[2].EmcXm2CompPadCtrl2 = 0x00000000; +SDRAM[2].EmcXm2CompPadCtrl3 = 0x00000000; +SDRAM[2].EmcAdrCfg = 0x00000001; +SDRAM[2].EmcPinProgramWait = 0x00000002; +SDRAM[2].EmcPinExtraWait = 0x00000000; +SDRAM[2].EmcPinGpioEn = 0x00000003; +SDRAM[2].EmcPinGpio = 0x00000003; +SDRAM[2].EmcTimingControlWait = 0x0000001e; +SDRAM[2].EmcRc = 0x0000000d; +SDRAM[2].EmcRfc = 0x00000025; +SDRAM[2].EmcRfcPb = 0x00000013; +SDRAM[2].EmcRefctrl2 = 0x00000000; +SDRAM[2].EmcRfcSlr = 0x00000000; +SDRAM[2].EmcRas = 0x00000009; +SDRAM[2].EmcRp = 0x00000004; +SDRAM[2].EmcR2r = 0x00000000; +SDRAM[2].EmcW2w = 0x00000000; +SDRAM[2].EmcR2w = 0x0000000b; +SDRAM[2].EmcW2r = 0x0000000d; +SDRAM[2].EmcR2p = 0x00000008; +SDRAM[2].EmcW2p = 0x0000000b; +SDRAM[2].EmcTppd = 0x00000004; +SDRAM[2].EmcCcdmw = 0x00000020; +SDRAM[2].EmcRdRcd = 0x00000006; +SDRAM[2].EmcWrRcd = 0x00000006; +SDRAM[2].EmcRrd = 0x00000006; +SDRAM[2].EmcRext = 0x00000003; +SDRAM[2].EmcWext = 0x00000000; +SDRAM[2].EmcWdv = 0x00000004; +SDRAM[2].EmcWdvChk = 0x00000006; +SDRAM[2].EmcWsv = 0x00000002; +SDRAM[2].EmcWev = 0x00000000; +SDRAM[2].EmcWdvMask = 0x00000004; +SDRAM[2].EmcWsDuration = 0x00000008; +SDRAM[2].EmcWeDuration = 0x0000000d; +SDRAM[2].EmcQUse = 0x00000005; +SDRAM[2].EmcQuseWidth = 0x00000006; +SDRAM[2].EmcIbdly = 0x00000000; +SDRAM[2].EmcObdly = 0x00000000; +SDRAM[2].EmcEInput = 0x00000002; +SDRAM[2].EmcEInputDuration = 0x0000000d; +SDRAM[2].EmcPutermExtra = 0x00000002; +SDRAM[2].EmcPutermWidth = 0x0000000b; +SDRAM[2].EmcQRst = 0x00010000; +SDRAM[2].EmcQSafe = 0x00000012; +SDRAM[2].EmcRdv = 0x00000014; +SDRAM[2].EmcRdvMask = 0x00000016; +SDRAM[2].EmcRdvEarly = 0x00000012; +SDRAM[2].EmcRdvEarlyMask = 0x00000014; +SDRAM[2].EmcQpop = 0x0000000a; +SDRAM[2].EmcRefresh = 0x00000304; +SDRAM[2].EmcBurstRefreshNum = 0x00000000; +SDRAM[2].EmcPreRefreshReqCnt = 0x000000c1; +SDRAM[2].EmcPdEx2Wr = 0x00000008; +SDRAM[2].EmcPdEx2Rd = 0x00000008; +SDRAM[2].EmcPChg2Pden = 0x00000003; +SDRAM[2].EmcAct2Pden = 0x00000003; +SDRAM[2].EmcAr2Pden = 0x00000003; +SDRAM[2].EmcRw2Pden = 0x00000012; +SDRAM[2].EmcCke2Pden = 0x00000005; +SDRAM[2].EmcPdex2Cke = 0x00000002; +SDRAM[2].EmcPdex2Mrr = 0x0000000d; +SDRAM[2].EmcTxsr = 0x00000027; +SDRAM[2].EmcTxsrDll = 0x00000027; +SDRAM[2].EmcTcke = 0x00000005; +SDRAM[2].EmcTckesr = 0x00000005; +SDRAM[2].EmcTpd = 0x00000004; +SDRAM[2].EmcTfaw = 0x00000009; +SDRAM[2].EmcTrpab = 0x00000005; +SDRAM[2].EmcTClkStable = 0x00000003; +SDRAM[2].EmcTClkStop = 0x00000009; +SDRAM[2].EmcTRefBw = 0x0000031c; +SDRAM[2].EmcFbioCfg5 = 0x9160a00d; +SDRAM[2].EmcFbioCfg7 = 0x00003bbf; +SDRAM[2].EmcFbioCfg8 = 0x0cf30000; +SDRAM[2].EmcCmdMappingCmd0_0 = 0x07050203; +SDRAM[2].EmcCmdMappingCmd0_1 = 0x06041b1c; +SDRAM[2].EmcCmdMappingCmd0_2 = 0x05252523; +SDRAM[2].EmcCmdMappingCmd1_0 = 0x1e0d0b0a; +SDRAM[2].EmcCmdMappingCmd1_1 = 0x240c091d; +SDRAM[2].EmcCmdMappingCmd1_2 = 0x04262608; +SDRAM[2].EmcCmdMappingCmd2_0 = 0x051b0302; +SDRAM[2].EmcCmdMappingCmd2_1 = 0x0604231c; +SDRAM[2].EmcCmdMappingCmd2_2 = 0x09252507; +SDRAM[2].EmcCmdMappingCmd3_0 = 0x0c0b0d0a; +SDRAM[2].EmcCmdMappingCmd3_1 = 0x08091e1d; +SDRAM[2].EmcCmdMappingCmd3_2 = 0x08262624; +SDRAM[2].EmcCmdMappingByte = 0x0a070623; +SDRAM[2].EmcFbioSpare = 0x00000012; +SDRAM[2].EmcCfgRsv = 0xff00ff00; +SDRAM[2].EmcMrs = 0x00000000; +SDRAM[2].EmcEmrs = 0x00000000; +SDRAM[2].EmcEmrs2 = 0x00000000; +SDRAM[2].EmcEmrs3 = 0x00000000; +SDRAM[2].EmcMrw1 = 0x08010004; +SDRAM[2].EmcMrw2 = 0x08020000; +SDRAM[2].EmcMrw3 = 0x080d0000; +SDRAM[2].EmcMrw4 = 0xc0000000; +SDRAM[2].EmcMrw6 = 0x08037171; +SDRAM[2].EmcMrw8 = 0x080b0000; +SDRAM[2].EmcMrw9 = 0x0c0e6b6b; +SDRAM[2].EmcMrw10 = 0x00000000; +SDRAM[2].EmcMrw12 = 0x0c0d0808; +SDRAM[2].EmcMrw13 = 0x0c0d0000; +SDRAM[2].EmcMrw14 = 0x08161414; +SDRAM[2].EmcMrwExtra = 0x08010004; +SDRAM[2].EmcWarmBootMrwExtra = 0x08110000; +SDRAM[2].EmcWarmBootExtraModeRegWriteEnable = 0x00000001; +SDRAM[2].EmcExtraModeRegWriteEnable = 0x00000000; +SDRAM[2].EmcMrwResetCommand = 0x00000000; +SDRAM[2].EmcMrwResetNInitWait = 0x00000000; +SDRAM[2].EmcMrsWaitCnt = 0x00cc0015; +SDRAM[2].EmcMrsWaitCnt2 = 0x0033000a; +SDRAM[2].EmcCfg = 0xf3200000; +SDRAM[2].EmcCfg2 = 0x00110805; +SDRAM[2].EmcCfgPipe = 0x0fff0fff; +SDRAM[2].EmcCfgPipeClk = 0x00000000; +SDRAM[2].EmcFdpdCtrlCmdNoRamp = 0x00000001; +SDRAM[2].EmcCfgUpdate = 0x70000301; +SDRAM[2].EmcDbg = 0x01000c00; +SDRAM[2].EmcDbgWriteMux = 0x00000001; +SDRAM[2].EmcCmdQ = 0x10004408; +SDRAM[2].EmcMc2EmcQ = 0x06000404; +SDRAM[2].EmcDynSelfRefControl = 0x80000713; +SDRAM[2].AhbArbitrationXbarCtrlMemInitDone = 0x00000001; +SDRAM[2].EmcCfgDigDll = 0x002c00a0; +SDRAM[2].EmcCfgDigDll_1 = 0x00003701; +SDRAM[2].EmcCfgDigDllPeriod = 0x00008000; +SDRAM[2].EmcDevSelect = 0x00000000; +SDRAM[2].EmcSelDpdCtrl = 0x00040008; +SDRAM[2].EmcFdpdCtrlDq = 0x8020221f; +SDRAM[2].EmcFdpdCtrlCmd = 0x0220f40f; +SDRAM[2].EmcPmacroIbVrefDq_0 = 0x28282828; +SDRAM[2].EmcPmacroIbVrefDq_1 = 0x28282828; +SDRAM[2].EmcPmacroIbVrefDqs_0 = 0x11111111; +SDRAM[2].EmcPmacroIbVrefDqs_1 = 0x11111111; +SDRAM[2].EmcPmacroIbRxrt = 0x000000be; +SDRAM[2].EmcCfgPipe1 = 0x0fff0fff; +SDRAM[2].EmcCfgPipe2 = 0x0fff0fff; +SDRAM[2].EmcPmacroQuseDdllRank0_0 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank0_1 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank0_2 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank0_3 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank0_4 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank0_5 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank1_0 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank1_1 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank1_2 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank1_3 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank1_4 = 0x00000000; +SDRAM[2].EmcPmacroQuseDdllRank1_5 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank0_0 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank0_1 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank0_2 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank0_3 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank0_4 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank0_5 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank1_0 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank1_1 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank1_2 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank1_3 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank1_4 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqRank1_5 = 0x00000000; +SDRAM[2].EmcPmacroObDdllLongDqsRank0_0 = 0x00320032; +SDRAM[2].EmcPmacroObDdllLongDqsRank0_1 = 0x00320032; +SDRAM[2].EmcPmacroObDdllLongDqsRank0_2 = 0x00320032; +SDRAM[2].EmcPmacroObDdllLongDqsRank0_3 = 0x00320032; +SDRAM[2].EmcPmacroObDdllLongDqsRank0_4 = 0x00090009; +SDRAM[2].EmcPmacroObDdllLongDqsRank0_5 = 0x00090009; +SDRAM[2].EmcPmacroObDdllLongDqsRank1_0 = 0x00320032; +SDRAM[2].EmcPmacroObDdllLongDqsRank1_1 = 0x00320032; +SDRAM[2].EmcPmacroObDdllLongDqsRank1_2 = 0x00320032; +SDRAM[2].EmcPmacroObDdllLongDqsRank1_3 = 0x00320032; +SDRAM[2].EmcPmacroObDdllLongDqsRank1_4 = 0x00090009; +SDRAM[2].EmcPmacroObDdllLongDqsRank1_5 = 0x00090009; +SDRAM[2].EmcPmacroIbDdllLongDqsRank0_0 = 0x00280028; +SDRAM[2].EmcPmacroIbDdllLongDqsRank0_1 = 0x00280028; +SDRAM[2].EmcPmacroIbDdllLongDqsRank0_2 = 0x00280028; +SDRAM[2].EmcPmacroIbDdllLongDqsRank0_3 = 0x00280028; +SDRAM[2].EmcPmacroIbDdllLongDqsRank1_0 = 0x00280028; +SDRAM[2].EmcPmacroIbDdllLongDqsRank1_1 = 0x00280028; +SDRAM[2].EmcPmacroIbDdllLongDqsRank1_2 = 0x00280028; +SDRAM[2].EmcPmacroIbDdllLongDqsRank1_3 = 0x00280028; +SDRAM[2].EmcPmacroDdllLongCmd_0 = 0x00000000; +SDRAM[2].EmcPmacroDdllLongCmd_1 = 0x00000000; +SDRAM[2].EmcPmacroDdllLongCmd_2 = 0x00000000; +SDRAM[2].EmcPmacroDdllLongCmd_3 = 0x00000000; +SDRAM[2].EmcPmacroDdllLongCmd_4 = 0x00000000; +SDRAM[2].EmcPmacroDdllShortCmd_0 = 0x00000000; +SDRAM[2].EmcPmacroDdllShortCmd_1 = 0x00000000; +SDRAM[2].EmcPmacroDdllShortCmd_2 = 0x00000000; +SDRAM[2].WarmBootWait = 0x00000001; +SDRAM[2].EmcOdtWrite = 0x00000000; +SDRAM[2].EmcZcalInterval = 0x00064000; +SDRAM[2].EmcZcalWaitCnt = 0x000900cc; +SDRAM[2].EmcZcalMrwCmd = 0x0051004f; +SDRAM[2].EmcMrsResetDll = 0x00000000; +SDRAM[2].EmcZcalInitDev0 = 0x80000001; +SDRAM[2].EmcZcalInitDev1 = 0x40000001; +SDRAM[2].EmcZcalInitWait = 0x00000001; +SDRAM[2].EmcZcalWarmColdBootEnables = 0x00000003; +SDRAM[2].EmcMrwLpddr2ZcalWarmBoot = 0x040a00ab; +SDRAM[2].EmcZqCalDdr3WarmBoot = 0x00000011; +SDRAM[2].EmcZqCalLpDdr4WarmBoot = 0x00000001; +SDRAM[2].EmcZcalWarmBootWait = 0x00000001; +SDRAM[2].EmcMrsWarmBootEnable = 0x00000001; +SDRAM[2].EmcMrsResetDllWait = 0x00000000; +SDRAM[2].EmcMrsExtra = 0x00000000; +SDRAM[2].EmcWarmBootMrsExtra = 0x00000000; +SDRAM[2].EmcEmrsDdr2DllEnable = 0x00000000; +SDRAM[2].EmcMrsDdr2DllReset = 0x00000000; +SDRAM[2].EmcEmrsDdr2OcdCalib = 0x00000000; +SDRAM[2].EmcDdr2Wait = 0x00000000; +SDRAM[2].EmcClkenOverride = 0x00000000; +SDRAM[2].EmcExtraRefreshNum = 0x00000002; +SDRAM[2].EmcClkenOverrideAllWarmBoot = 0x00000000; +SDRAM[2].McClkenOverrideAllWarmBoot = 0x00000000; +SDRAM[2].EmcCfgDigDllPeriodWarmBoot = 0x00000003; +SDRAM[2].PmcVddpSel = 0x00000001; +SDRAM[2].PmcVddpSelWait = 0x00000002; +SDRAM[2].PmcDdrPwr = 0x0000000f; +SDRAM[2].PmcDdrCfg = 0x20220100; +SDRAM[2].PmcIoDpd3Req = 0x4bafffff; +SDRAM[2].PmcIoDpd3ReqWait = 0x00000001; +SDRAM[2].PmcIoDpd4ReqWait = 0x00000002; +SDRAM[2].PmcRegShort = 0x00000000; +SDRAM[2].PmcNoIoPower = 0x00000000; +SDRAM[2].PmcDdrCntrlWait = 0x00000000; +SDRAM[2].PmcDdrCntrl = 0x0007ff8b; +SDRAM[2].EmcAcpdControl = 0x00000000; +SDRAM[2].EmcSwizzleRank0Byte0 = 0x76342501; +SDRAM[2].EmcSwizzleRank0Byte1 = 0x56243701; +SDRAM[2].EmcSwizzleRank0Byte2 = 0x34267510; +SDRAM[2].EmcSwizzleRank0Byte3 = 0x45763210; +SDRAM[2].EmcSwizzleRank1Byte0 = 0x72345601; +SDRAM[2].EmcSwizzleRank1Byte1 = 0x23456701; +SDRAM[2].EmcSwizzleRank1Byte2 = 0x65427310; +SDRAM[2].EmcSwizzleRank1Byte3 = 0x75432610; +SDRAM[2].EmcTxdsrvttgen = 0x00000000; +SDRAM[2].EmcDataBrlshft0 = 0x00249249; +SDRAM[2].EmcDataBrlshft1 = 0x00249249; +SDRAM[2].EmcDqsBrlshft0 = 0x00000000; +SDRAM[2].EmcDqsBrlshft1 = 0x00000000; +SDRAM[2].EmcCmdBrlshft0 = 0x00000000; +SDRAM[2].EmcCmdBrlshft1 = 0x00000000; +SDRAM[2].EmcCmdBrlshft2 = 0x00000012; +SDRAM[2].EmcCmdBrlshft3 = 0x00000012; +SDRAM[2].EmcQuseBrlshft0 = 0x00000000; +SDRAM[2].EmcQuseBrlshft1 = 0x00000000; +SDRAM[2].EmcQuseBrlshft2 = 0x00000000; +SDRAM[2].EmcQuseBrlshft3 = 0x00000000; +SDRAM[2].EmcDllCfg0 = 0x1f13412f; +SDRAM[2].EmcDllCfg1 = 0x00010014; +SDRAM[2].EmcPmcScratch1 = 0x4bafffff; +SDRAM[2].EmcPmcScratch2 = 0x7fffffff; +SDRAM[2].EmcPmcScratch3 = 0x4005d70b; +SDRAM[2].EmcPmacroPadCfgCtrl = 0x00020000; +SDRAM[2].EmcPmacroVttgenCtrl0 = 0x00030808; +SDRAM[2].EmcPmacroVttgenCtrl1 = 0x00015000; +SDRAM[2].EmcPmacroVttgenCtrl2 = 0x00101010; +SDRAM[2].EmcPmacroBrickCtrlRfu1 = 0x00001600; +SDRAM[2].EmcPmacroCmdBrickCtrlFdpd = 0x00000000; +SDRAM[2].EmcPmacroBrickCtrlRfu2 = 0x00000000; +SDRAM[2].EmcPmacroDataBrickCtrlFdpd = 0x00000000; +SDRAM[2].EmcPmacroBgBiasCtrl0 = 0x00000030; +SDRAM[2].EmcPmacroDataPadRxCtrl = 0x10050037; +SDRAM[2].EmcPmacroCmdPadRxCtrl = 0x00000000; +SDRAM[2].EmcPmacroDataRxTermMode = 0x00000010; +SDRAM[2].EmcPmacroCmdRxTermMode = 0x00003000; +SDRAM[2].EmcPmacroDataPadTxCtrl = 0x02000111; +SDRAM[2].EmcPmacroCommonPadTxCtrl = 0x00000008; +SDRAM[2].EmcPmacroCmdPadTxCtrl = 0x0a000000; +SDRAM[2].EmcCfg3 = 0x00000040; +SDRAM[2].EmcPmacroTxPwrd0 = 0x10000000; +SDRAM[2].EmcPmacroTxPwrd1 = 0x08000000; +SDRAM[2].EmcPmacroTxPwrd2 = 0x08000000; +SDRAM[2].EmcPmacroTxPwrd3 = 0x08000000; +SDRAM[2].EmcPmacroTxPwrd4 = 0x00000000; +SDRAM[2].EmcPmacroTxPwrd5 = 0x00000000; +SDRAM[2].EmcConfigSampleDelay = 0x00000020; +SDRAM[2].EmcPmacroBrickMapping0 = 0x28190081; +SDRAM[2].EmcPmacroBrickMapping1 = 0x44a53293; +SDRAM[2].EmcPmacroBrickMapping2 = 0x76b76a5b; +SDRAM[2].EmcPmacroTxSelClkSrc0 = 0x00000000; +SDRAM[2].EmcPmacroTxSelClkSrc1 = 0x00000000; +SDRAM[2].EmcPmacroTxSelClkSrc2 = 0x00000000; +SDRAM[2].EmcPmacroTxSelClkSrc3 = 0x00000000; +SDRAM[2].EmcPmacroTxSelClkSrc4 = 0x00000000; +SDRAM[2].EmcPmacroTxSelClkSrc5 = 0x00000000; +SDRAM[2].EmcPmacroDdllBypass = 0xefffefff; +SDRAM[2].EmcPmacroDdllPwrd0 = 0xc0c0c0c0; +SDRAM[2].EmcPmacroDdllPwrd1 = 0xc0c0c0c0; +SDRAM[2].EmcPmacroDdllPwrd2 = 0xdcdcdcdc; +SDRAM[2].EmcPmacroCmdCtrl0 = 0x0a0a0a0a; +SDRAM[2].EmcPmacroCmdCtrl1 = 0x0a0a0a0a; +SDRAM[2].EmcPmacroCmdCtrl2 = 0x0a0a0a0a; +SDRAM[2].McEmemAdrCfg = 0x00000001; +SDRAM[2].McEmemAdrCfgDev0 = 0x000d0302; +SDRAM[2].McEmemAdrCfgDev1 = 0x000d0302; +SDRAM[2].McEmemAdrCfgChannelMask = 0xffff2400; +SDRAM[2].McEmemAdrCfgBankMask0 = 0x6e574400; +SDRAM[2].McEmemAdrCfgBankMask1 = 0x39722800; +SDRAM[2].McEmemAdrCfgBankMask2 = 0x4b9c1000; +SDRAM[2].McEmemCfg = 0x00000c00; +SDRAM[2].McEmemArbCfg = 0x08000001; +SDRAM[2].McEmemArbOutstandingReq = 0x8000004c; +SDRAM[2].McEmemArbRefpbHpCtrl = 0x000a1020; +SDRAM[2].McEmemArbRefpbBankCtrl = 0x80001028; +SDRAM[2].McEmemArbTimingRcd = 0x00000001; +SDRAM[2].McEmemArbTimingRp = 0x00000000; +SDRAM[2].McEmemArbTimingRc = 0x00000003; +SDRAM[2].McEmemArbTimingRas = 0x00000001; +SDRAM[2].McEmemArbTimingFaw = 0x00000002; +SDRAM[2].McEmemArbTimingRrd = 0x00000001; +SDRAM[2].McEmemArbTimingRap2Pre = 0x00000002; +SDRAM[2].McEmemArbTimingWap2Pre = 0x00000005; +SDRAM[2].McEmemArbTimingR2R = 0x00000001; +SDRAM[2].McEmemArbTimingW2W = 0x00000001; +SDRAM[2].McEmemArbTimingR2W = 0x00000004; +SDRAM[2].McEmemArbTimingW2R = 0x00000005; +SDRAM[2].McEmemArbTimingRFCPB = 0x00000004; +SDRAM[2].McEmemArbDaTurns = 0x02020000; +SDRAM[2].McEmemArbDaCovers = 0x00030201; +SDRAM[2].McEmemArbMisc0 = 0x71c30504; +SDRAM[2].McEmemArbMisc1 = 0x70000f0f; +SDRAM[2].McEmemArbMisc2 = 0x00000000; +SDRAM[2].McEmemArbRing1Throttle = 0x001f0000; +SDRAM[2].McEmemArbOverride = 0x10000000; +SDRAM[2].McEmemArbOverride1 = 0x00000000; +SDRAM[2].McEmemArbRsv = 0xff00ff00; +SDRAM[2].McDaCfg0 = 0x00000001; +SDRAM[2].McEmemArbTimingCcdmw = 0x00000008; +SDRAM[2].McClkenOverride = 0x00008000; +SDRAM[2].McStatControl = 0x00000000; +SDRAM[2].McVideoProtectBom = 0xfff00000; +SDRAM[2].McVideoProtectBomAdrHi = 0x00000000; +SDRAM[2].McVideoProtectSizeMb = 0x00000000; +SDRAM[2].McVideoProtectVprOverride = 0xe4bac343; +SDRAM[2].McVideoProtectVprOverride1 = 0x00001ed3; +SDRAM[2].McVideoProtectGpuOverride0 = 0x00000000; +SDRAM[2].McVideoProtectGpuOverride1 = 0x00000000; +SDRAM[2].McSecCarveoutBom = 0xfff00000; +SDRAM[2].McSecCarveoutAdrHi = 0x00000000; +SDRAM[2].McSecCarveoutSizeMb = 0x00000000; +SDRAM[2].McVideoProtectWriteAccess = 0x00000000; +SDRAM[2].McSecCarveoutProtectWriteAccess = 0x00000000; +SDRAM[2].McGeneralizedCarveout1Bom = 0x00000000; +SDRAM[2].McGeneralizedCarveout1BomHi = 0x00000000; +SDRAM[2].McGeneralizedCarveout1Size128kb = 0x00000008; +SDRAM[2].McGeneralizedCarveout1Access0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout1Access1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout1Access2 = 0x00300000; +SDRAM[2].McGeneralizedCarveout1Access3 = 0x03000000; +SDRAM[2].McGeneralizedCarveout1Access4 = 0x00000000; +SDRAM[2].McGeneralizedCarveout1ForceInternalAccess0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout1ForceInternalAccess1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout1ForceInternalAccess2 = 0x00000000; +SDRAM[2].McGeneralizedCarveout1ForceInternalAccess3 = 0x00000000; +SDRAM[2].McGeneralizedCarveout1ForceInternalAccess4 = 0x00000000; +SDRAM[2].McGeneralizedCarveout1Cfg0 = 0x04000c75; +SDRAM[2].McGeneralizedCarveout2Bom = 0x00000000; +SDRAM[2].McGeneralizedCarveout2BomHi = 0x00000000; +SDRAM[2].McGeneralizedCarveout2Size128kb = 0x00000002; +SDRAM[2].McGeneralizedCarveout2Access0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout2Access1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout2Access2 = 0x03000000; +SDRAM[2].McGeneralizedCarveout2Access3 = 0x00000000; +SDRAM[2].McGeneralizedCarveout2Access4 = 0x00000300; +SDRAM[2].McGeneralizedCarveout2ForceInternalAccess0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout2ForceInternalAccess1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout2ForceInternalAccess2 = 0x00000000; +SDRAM[2].McGeneralizedCarveout2ForceInternalAccess3 = 0x00000000; +SDRAM[2].McGeneralizedCarveout2ForceInternalAccess4 = 0x00000000; +SDRAM[2].McGeneralizedCarveout2Cfg0 = 0x0440167c; +SDRAM[2].McGeneralizedCarveout3Bom = 0x00000000; +SDRAM[2].McGeneralizedCarveout3BomHi = 0x00000000; +SDRAM[2].McGeneralizedCarveout3Size128kb = 0x00000000; +SDRAM[2].McGeneralizedCarveout3Access0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout3Access1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout3Access2 = 0x03000000; +SDRAM[2].McGeneralizedCarveout3Access3 = 0x00000000; +SDRAM[2].McGeneralizedCarveout3Access4 = 0x00000300; +SDRAM[2].McGeneralizedCarveout3ForceInternalAccess0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout3ForceInternalAccess1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout3ForceInternalAccess2 = 0x00000000; +SDRAM[2].McGeneralizedCarveout3ForceInternalAccess3 = 0x00000000; +SDRAM[2].McGeneralizedCarveout3ForceInternalAccess4 = 0x00000000; +SDRAM[2].McGeneralizedCarveout3Cfg0 = 0x04401e7c; +SDRAM[2].McGeneralizedCarveout4Bom = 0x00000000; +SDRAM[2].McGeneralizedCarveout4BomHi = 0x00000000; +SDRAM[2].McGeneralizedCarveout4Size128kb = 0x00000008; +SDRAM[2].McGeneralizedCarveout4Access0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout4Access1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout4Access2 = 0x00300000; +SDRAM[2].McGeneralizedCarveout4Access3 = 0x00000000; +SDRAM[2].McGeneralizedCarveout4Access4 = 0x00000000; +SDRAM[2].McGeneralizedCarveout4ForceInternalAccess0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout4ForceInternalAccess1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout4ForceInternalAccess2 = 0x00000000; +SDRAM[2].McGeneralizedCarveout4ForceInternalAccess3 = 0x00000000; +SDRAM[2].McGeneralizedCarveout4ForceInternalAccess4 = 0x00000000; +SDRAM[2].McGeneralizedCarveout4Cfg0 = 0x04002442; +SDRAM[2].McGeneralizedCarveout5Bom = 0x00000000; +SDRAM[2].McGeneralizedCarveout5BomHi = 0x00000000; +SDRAM[2].McGeneralizedCarveout5Size128kb = 0x00000008; +SDRAM[2].McGeneralizedCarveout5Access0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout5Access1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout5Access2 = 0x00300000; +SDRAM[2].McGeneralizedCarveout5Access3 = 0x00000000; +SDRAM[2].McGeneralizedCarveout5Access4 = 0x00000000; +SDRAM[2].McGeneralizedCarveout5ForceInternalAccess0 = 0x00000000; +SDRAM[2].McGeneralizedCarveout5ForceInternalAccess1 = 0x00000000; +SDRAM[2].McGeneralizedCarveout5ForceInternalAccess2 = 0x00000000; +SDRAM[2].McGeneralizedCarveout5ForceInternalAccess3 = 0x00000000; +SDRAM[2].McGeneralizedCarveout5ForceInternalAccess4 = 0x00000000; +SDRAM[2].McGeneralizedCarveout5Cfg0 = 0x04002c42; +SDRAM[2].EmcCaTrainingEnable = 0x00000000; +SDRAM[2].SwizzleRankByteEncode = 0x0000002e; +SDRAM[2].BootRomPatchControl = 0x00000000; +SDRAM[2].BootRomPatchData = 0x00000000; +SDRAM[2].McMtsCarveoutBom = 0xfff00000; +SDRAM[2].McMtsCarveoutAdrHi = 0x00000000; +SDRAM[2].McMtsCarveoutSizeMb = 0x00000000; +SDRAM[2].McMtsCarveoutRegCtrl = 0x00000000; +# Do not edit. Generated by t210_emc_reg_tool_P975 V9.7.5. Command: +# t210_emc_reg_tool_P975 -i Samsung_K4F6E304HA-MGCH_4GB.par 4.90196078431372549019 -dram_board_cfg 40 +# -dbi_rd_en 1 -data_bus_to_0 1 -fly_by_time_ps 1717 -t T210DSC_TBKV_A44_P5.xlsm_BKV.txt +# -o T210_A44_R1_LP4_DSC_4G_204Mhz.cfg +# Parameter file: Samsung_K4F6E304HA-MGCH_4GB.par, tck = 4.90 ns (204.00 MHz) +SDRAM[3].MemoryType = NvBootMemoryType_LpDdr4; +SDRAM[3].PllMInputDivider = 0x00000001; +SDRAM[3].PllMFeedbackDivider = 0x00000022; +SDRAM[3].PllMStableTime = 0x0000012c; +SDRAM[3].PllMSetupControl = 0x00000000; +SDRAM[3].PllMPostDivider = 0x00000000; +SDRAM[3].PllMKCP = 0x00000000; +SDRAM[3].PllMKVCO = 0x00000000; +SDRAM[3].EmcBctSpare0 = 0x00000000; +SDRAM[3].EmcBctSpare1 = 0x00000000; +SDRAM[3].EmcBctSpare2 = 0x00000000; +SDRAM[3].EmcBctSpare3 = 0x00000000; +SDRAM[3].EmcBctSpare4 = 0x7001bc3c; +SDRAM[3].EmcBctSpare5 = 0x00000032; +SDRAM[3].EmcBctSpare6 = 0x7001b404; +SDRAM[3].EmcBctSpare7 = 0x76342501; +SDRAM[3].EmcBctSpare8 = 0x7000e6c8; +SDRAM[3].EmcBctSpare9 = 0x00000000; +SDRAM[3].EmcBctSpare10 = 0x00000000; +SDRAM[3].EmcBctSpare11 = 0x00000000; +SDRAM[3].EmcBctSpare12 = 0x7001bc3c; +SDRAM[3].EmcBctSpare13 = 0x00000033; +SDRAM[3].EmcClockSource = 0x40188002; +SDRAM[3].EmcClockSourceDll = 0x40000000; +SDRAM[3].ClkRstControllerPllmMisc2Override = 0x00000000; +SDRAM[3].ClkRstControllerPllmMisc2OverrideEnable = 0x00000000; +SDRAM[3].ClearClk2Mc1 = 0x00000000; +SDRAM[3].EmcAutoCalInterval = 0x001fffff; +SDRAM[3].EmcAutoCalConfig = 0xa01a51d8; +SDRAM[3].EmcAutoCalConfig2 = 0x05500000; +SDRAM[3].EmcAutoCalConfig3 = 0x00770000; +SDRAM[3].EmcAutoCalConfig4 = 0x00770000; +SDRAM[3].EmcAutoCalConfig5 = 0x00770000; +SDRAM[3].EmcAutoCalConfig6 = 0x00770000; +SDRAM[3].EmcAutoCalConfig7 = 0x00770000; +SDRAM[3].EmcAutoCalConfig8 = 0x00770000; +SDRAM[3].EmcAutoCalVrefSel0 = 0xb3afa6a6; +SDRAM[3].EmcAutoCalVrefSel1 = 0x00009e3c; +SDRAM[3].EmcAutoCalChannel = 0xc1e00303; +SDRAM[3].EmcPmacroAutocalCfg0 = 0x04040404; +SDRAM[3].EmcPmacroAutocalCfg1 = 0x04040404; +SDRAM[3].EmcPmacroAutocalCfg2 = 0x00000000; +SDRAM[3].EmcPmacroRxTerm = 0x1f1f1f1f; +SDRAM[3].EmcPmacroDqTxDrv = 0x1f1f1f1f; +SDRAM[3].EmcPmacroCaTxDrv = 0x1f1f1f1f; +SDRAM[3].EmcPmacroCmdTxDrv = 0x00001f1f; +SDRAM[3].EmcPmacroAutocalCfgCommon = 0x00000804; +SDRAM[3].EmcPmacroZctrl = 0x00000550; +SDRAM[3].EmcAutoCalWait = 0x000001a1; +SDRAM[3].EmcXm2CompPadCtrl = 0x00000032; +SDRAM[3].EmcXm2CompPadCtrl2 = 0x00000000; +SDRAM[3].EmcXm2CompPadCtrl3 = 0x00000000; +SDRAM[3].EmcAdrCfg = 0x00000001; +SDRAM[3].EmcPinProgramWait = 0x00000002; +SDRAM[3].EmcPinExtraWait = 0x00000000; +SDRAM[3].EmcPinGpioEn = 0x00000003; +SDRAM[3].EmcPinGpio = 0x00000003; +SDRAM[3].EmcTimingControlWait = 0x0000001e; +SDRAM[3].EmcRc = 0x0000000d; +SDRAM[3].EmcRfc = 0x00000025; +SDRAM[3].EmcRfcPb = 0x00000013; +SDRAM[3].EmcRefctrl2 = 0x00000000; +SDRAM[3].EmcRfcSlr = 0x00000000; +SDRAM[3].EmcRas = 0x00000009; +SDRAM[3].EmcRp = 0x00000004; +SDRAM[3].EmcR2r = 0x00000000; +SDRAM[3].EmcW2w = 0x00000000; +SDRAM[3].EmcR2w = 0x0000000b; +SDRAM[3].EmcW2r = 0x0000000d; +SDRAM[3].EmcR2p = 0x00000008; +SDRAM[3].EmcW2p = 0x0000000b; +SDRAM[3].EmcTppd = 0x00000004; +SDRAM[3].EmcCcdmw = 0x00000020; +SDRAM[3].EmcRdRcd = 0x00000006; +SDRAM[3].EmcWrRcd = 0x00000006; +SDRAM[3].EmcRrd = 0x00000006; +SDRAM[3].EmcRext = 0x00000003; +SDRAM[3].EmcWext = 0x00000000; +SDRAM[3].EmcWdv = 0x00000004; +SDRAM[3].EmcWdvChk = 0x00000006; +SDRAM[3].EmcWsv = 0x00000002; +SDRAM[3].EmcWev = 0x00000000; +SDRAM[3].EmcWdvMask = 0x00000004; +SDRAM[3].EmcWsDuration = 0x00000008; +SDRAM[3].EmcWeDuration = 0x0000000d; +SDRAM[3].EmcQUse = 0x00000005; +SDRAM[3].EmcQuseWidth = 0x00000006; +SDRAM[3].EmcIbdly = 0x00000000; +SDRAM[3].EmcObdly = 0x00000000; +SDRAM[3].EmcEInput = 0x00000002; +SDRAM[3].EmcEInputDuration = 0x0000000d; +SDRAM[3].EmcPutermExtra = 0x00000002; +SDRAM[3].EmcPutermWidth = 0x0000000b; +SDRAM[3].EmcQRst = 0x00010000; +SDRAM[3].EmcQSafe = 0x00000012; +SDRAM[3].EmcRdv = 0x00000014; +SDRAM[3].EmcRdvMask = 0x00000016; +SDRAM[3].EmcRdvEarly = 0x00000012; +SDRAM[3].EmcRdvEarlyMask = 0x00000014; +SDRAM[3].EmcQpop = 0x0000000a; +SDRAM[3].EmcRefresh = 0x00000304; +SDRAM[3].EmcBurstRefreshNum = 0x00000000; +SDRAM[3].EmcPreRefreshReqCnt = 0x000000c1; +SDRAM[3].EmcPdEx2Wr = 0x00000008; +SDRAM[3].EmcPdEx2Rd = 0x00000008; +SDRAM[3].EmcPChg2Pden = 0x00000003; +SDRAM[3].EmcAct2Pden = 0x00000003; +SDRAM[3].EmcAr2Pden = 0x00000003; +SDRAM[3].EmcRw2Pden = 0x00000012; +SDRAM[3].EmcCke2Pden = 0x00000005; +SDRAM[3].EmcPdex2Cke = 0x00000002; +SDRAM[3].EmcPdex2Mrr = 0x0000000d; +SDRAM[3].EmcTxsr = 0x00000027; +SDRAM[3].EmcTxsrDll = 0x00000027; +SDRAM[3].EmcTcke = 0x00000005; +SDRAM[3].EmcTckesr = 0x00000005; +SDRAM[3].EmcTpd = 0x00000004; +SDRAM[3].EmcTfaw = 0x00000009; +SDRAM[3].EmcTrpab = 0x00000005; +SDRAM[3].EmcTClkStable = 0x00000003; +SDRAM[3].EmcTClkStop = 0x00000009; +SDRAM[3].EmcTRefBw = 0x0000031c; +SDRAM[3].EmcFbioCfg5 = 0x9160a00d; +SDRAM[3].EmcFbioCfg7 = 0x00003bbf; +SDRAM[3].EmcFbioCfg8 = 0x0cf30000; +SDRAM[3].EmcCmdMappingCmd0_0 = 0x07050203; +SDRAM[3].EmcCmdMappingCmd0_1 = 0x06041b1c; +SDRAM[3].EmcCmdMappingCmd0_2 = 0x05252523; +SDRAM[3].EmcCmdMappingCmd1_0 = 0x1e0d0b0a; +SDRAM[3].EmcCmdMappingCmd1_1 = 0x240c091d; +SDRAM[3].EmcCmdMappingCmd1_2 = 0x04262608; +SDRAM[3].EmcCmdMappingCmd2_0 = 0x051b0302; +SDRAM[3].EmcCmdMappingCmd2_1 = 0x0604231c; +SDRAM[3].EmcCmdMappingCmd2_2 = 0x09252507; +SDRAM[3].EmcCmdMappingCmd3_0 = 0x0c0b0d0a; +SDRAM[3].EmcCmdMappingCmd3_1 = 0x08091e1d; +SDRAM[3].EmcCmdMappingCmd3_2 = 0x08262624; +SDRAM[3].EmcCmdMappingByte = 0x0a070623; +SDRAM[3].EmcFbioSpare = 0x00000012; +SDRAM[3].EmcCfgRsv = 0xff00ff00; +SDRAM[3].EmcMrs = 0x00000000; +SDRAM[3].EmcEmrs = 0x00000000; +SDRAM[3].EmcEmrs2 = 0x00000000; +SDRAM[3].EmcEmrs3 = 0x00000000; +SDRAM[3].EmcMrw1 = 0x08010004; +SDRAM[3].EmcMrw2 = 0x08020000; +SDRAM[3].EmcMrw3 = 0x080d0000; +SDRAM[3].EmcMrw4 = 0xc0000000; +SDRAM[3].EmcMrw6 = 0x08037171; +SDRAM[3].EmcMrw8 = 0x080b0000; +SDRAM[3].EmcMrw9 = 0x0c0e6b6b; +SDRAM[3].EmcMrw10 = 0x00000000; +SDRAM[3].EmcMrw12 = 0x0c0d0808; +SDRAM[3].EmcMrw13 = 0x0c0d0000; +SDRAM[3].EmcMrw14 = 0x08161414; +SDRAM[3].EmcMrwExtra = 0x08010004; +SDRAM[3].EmcWarmBootMrwExtra = 0x08110000; +SDRAM[3].EmcWarmBootExtraModeRegWriteEnable = 0x00000001; +SDRAM[3].EmcExtraModeRegWriteEnable = 0x00000000; +SDRAM[3].EmcMrwResetCommand = 0x00000000; +SDRAM[3].EmcMrwResetNInitWait = 0x00000000; +SDRAM[3].EmcMrsWaitCnt = 0x00cc0015; +SDRAM[3].EmcMrsWaitCnt2 = 0x0033000a; +SDRAM[3].EmcCfg = 0xf3200000; +SDRAM[3].EmcCfg2 = 0x00110805; +SDRAM[3].EmcCfgPipe = 0x0fff0fff; +SDRAM[3].EmcCfgPipeClk = 0x00000000; +SDRAM[3].EmcFdpdCtrlCmdNoRamp = 0x00000001; +SDRAM[3].EmcCfgUpdate = 0x70000301; +SDRAM[3].EmcDbg = 0x01000c00; +SDRAM[3].EmcDbgWriteMux = 0x00000001; +SDRAM[3].EmcCmdQ = 0x10004408; +SDRAM[3].EmcMc2EmcQ = 0x06000404; +SDRAM[3].EmcDynSelfRefControl = 0x80000713; +SDRAM[3].AhbArbitrationXbarCtrlMemInitDone = 0x00000001; +SDRAM[3].EmcCfgDigDll = 0x002c00a0; +SDRAM[3].EmcCfgDigDll_1 = 0x00003701; +SDRAM[3].EmcCfgDigDllPeriod = 0x00008000; +SDRAM[3].EmcDevSelect = 0x00000000; +SDRAM[3].EmcSelDpdCtrl = 0x00040008; +SDRAM[3].EmcFdpdCtrlDq = 0x8020221f; +SDRAM[3].EmcFdpdCtrlCmd = 0x0220f40f; +SDRAM[3].EmcPmacroIbVrefDq_0 = 0x28282828; +SDRAM[3].EmcPmacroIbVrefDq_1 = 0x28282828; +SDRAM[3].EmcPmacroIbVrefDqs_0 = 0x11111111; +SDRAM[3].EmcPmacroIbVrefDqs_1 = 0x11111111; +SDRAM[3].EmcPmacroIbRxrt = 0x000000be; +SDRAM[3].EmcCfgPipe1 = 0x0fff0fff; +SDRAM[3].EmcCfgPipe2 = 0x0fff0fff; +SDRAM[3].EmcPmacroQuseDdllRank0_0 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank0_1 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank0_2 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank0_3 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank0_4 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank0_5 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank1_0 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank1_1 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank1_2 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank1_3 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank1_4 = 0x00000000; +SDRAM[3].EmcPmacroQuseDdllRank1_5 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank0_0 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank0_1 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank0_2 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank0_3 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank0_4 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank0_5 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank1_0 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank1_1 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank1_2 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank1_3 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank1_4 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqRank1_5 = 0x00000000; +SDRAM[3].EmcPmacroObDdllLongDqsRank0_0 = 0x00320032; +SDRAM[3].EmcPmacroObDdllLongDqsRank0_1 = 0x00320032; +SDRAM[3].EmcPmacroObDdllLongDqsRank0_2 = 0x00320032; +SDRAM[3].EmcPmacroObDdllLongDqsRank0_3 = 0x00320032; +SDRAM[3].EmcPmacroObDdllLongDqsRank0_4 = 0x00090009; +SDRAM[3].EmcPmacroObDdllLongDqsRank0_5 = 0x00090009; +SDRAM[3].EmcPmacroObDdllLongDqsRank1_0 = 0x00320032; +SDRAM[3].EmcPmacroObDdllLongDqsRank1_1 = 0x00320032; +SDRAM[3].EmcPmacroObDdllLongDqsRank1_2 = 0x00320032; +SDRAM[3].EmcPmacroObDdllLongDqsRank1_3 = 0x00320032; +SDRAM[3].EmcPmacroObDdllLongDqsRank1_4 = 0x00090009; +SDRAM[3].EmcPmacroObDdllLongDqsRank1_5 = 0x00090009; +SDRAM[3].EmcPmacroIbDdllLongDqsRank0_0 = 0x00280028; +SDRAM[3].EmcPmacroIbDdllLongDqsRank0_1 = 0x00280028; +SDRAM[3].EmcPmacroIbDdllLongDqsRank0_2 = 0x00280028; +SDRAM[3].EmcPmacroIbDdllLongDqsRank0_3 = 0x00280028; +SDRAM[3].EmcPmacroIbDdllLongDqsRank1_0 = 0x00280028; +SDRAM[3].EmcPmacroIbDdllLongDqsRank1_1 = 0x00280028; +SDRAM[3].EmcPmacroIbDdllLongDqsRank1_2 = 0x00280028; +SDRAM[3].EmcPmacroIbDdllLongDqsRank1_3 = 0x00280028; +SDRAM[3].EmcPmacroDdllLongCmd_0 = 0x00000000; +SDRAM[3].EmcPmacroDdllLongCmd_1 = 0x00000000; +SDRAM[3].EmcPmacroDdllLongCmd_2 = 0x00000000; +SDRAM[3].EmcPmacroDdllLongCmd_3 = 0x00000000; +SDRAM[3].EmcPmacroDdllLongCmd_4 = 0x00000000; +SDRAM[3].EmcPmacroDdllShortCmd_0 = 0x00000000; +SDRAM[3].EmcPmacroDdllShortCmd_1 = 0x00000000; +SDRAM[3].EmcPmacroDdllShortCmd_2 = 0x00000000; +SDRAM[3].WarmBootWait = 0x00000001; +SDRAM[3].EmcOdtWrite = 0x00000000; +SDRAM[3].EmcZcalInterval = 0x00064000; +SDRAM[3].EmcZcalWaitCnt = 0x000900cc; +SDRAM[3].EmcZcalMrwCmd = 0x0051004f; +SDRAM[3].EmcMrsResetDll = 0x00000000; +SDRAM[3].EmcZcalInitDev0 = 0x80000001; +SDRAM[3].EmcZcalInitDev1 = 0x40000001; +SDRAM[3].EmcZcalInitWait = 0x00000001; +SDRAM[3].EmcZcalWarmColdBootEnables = 0x00000003; +SDRAM[3].EmcMrwLpddr2ZcalWarmBoot = 0x040a00ab; +SDRAM[3].EmcZqCalDdr3WarmBoot = 0x00000011; +SDRAM[3].EmcZqCalLpDdr4WarmBoot = 0x00000001; +SDRAM[3].EmcZcalWarmBootWait = 0x00000001; +SDRAM[3].EmcMrsWarmBootEnable = 0x00000001; +SDRAM[3].EmcMrsResetDllWait = 0x00000000; +SDRAM[3].EmcMrsExtra = 0x00000000; +SDRAM[3].EmcWarmBootMrsExtra = 0x00000000; +SDRAM[3].EmcEmrsDdr2DllEnable = 0x00000000; +SDRAM[3].EmcMrsDdr2DllReset = 0x00000000; +SDRAM[3].EmcEmrsDdr2OcdCalib = 0x00000000; +SDRAM[3].EmcDdr2Wait = 0x00000000; +SDRAM[3].EmcClkenOverride = 0x00000000; +SDRAM[3].EmcExtraRefreshNum = 0x00000002; +SDRAM[3].EmcClkenOverrideAllWarmBoot = 0x00000000; +SDRAM[3].McClkenOverrideAllWarmBoot = 0x00000000; +SDRAM[3].EmcCfgDigDllPeriodWarmBoot = 0x00000003; +SDRAM[3].PmcVddpSel = 0x00000001; +SDRAM[3].PmcVddpSelWait = 0x00000002; +SDRAM[3].PmcDdrPwr = 0x0000000f; +SDRAM[3].PmcDdrCfg = 0x20220100; +SDRAM[3].PmcIoDpd3Req = 0x4bafffff; +SDRAM[3].PmcIoDpd3ReqWait = 0x00000001; +SDRAM[3].PmcIoDpd4ReqWait = 0x00000002; +SDRAM[3].PmcRegShort = 0x00000000; +SDRAM[3].PmcNoIoPower = 0x00000000; +SDRAM[3].PmcDdrCntrlWait = 0x00000000; +SDRAM[3].PmcDdrCntrl = 0x0007ff8b; +SDRAM[3].EmcAcpdControl = 0x00000000; +SDRAM[3].EmcSwizzleRank0Byte0 = 0x76342501; +SDRAM[3].EmcSwizzleRank0Byte1 = 0x56243701; +SDRAM[3].EmcSwizzleRank0Byte2 = 0x34267510; +SDRAM[3].EmcSwizzleRank0Byte3 = 0x45763210; +SDRAM[3].EmcSwizzleRank1Byte0 = 0x72345601; +SDRAM[3].EmcSwizzleRank1Byte1 = 0x23456701; +SDRAM[3].EmcSwizzleRank1Byte2 = 0x65427310; +SDRAM[3].EmcSwizzleRank1Byte3 = 0x75432610; +SDRAM[3].EmcTxdsrvttgen = 0x00000000; +SDRAM[3].EmcDataBrlshft0 = 0x00249249; +SDRAM[3].EmcDataBrlshft1 = 0x00249249; +SDRAM[3].EmcDqsBrlshft0 = 0x00000000; +SDRAM[3].EmcDqsBrlshft1 = 0x00000000; +SDRAM[3].EmcCmdBrlshft0 = 0x00000000; +SDRAM[3].EmcCmdBrlshft1 = 0x00000000; +SDRAM[3].EmcCmdBrlshft2 = 0x00000012; +SDRAM[3].EmcCmdBrlshft3 = 0x00000012; +SDRAM[3].EmcQuseBrlshft0 = 0x00000000; +SDRAM[3].EmcQuseBrlshft1 = 0x00000000; +SDRAM[3].EmcQuseBrlshft2 = 0x00000000; +SDRAM[3].EmcQuseBrlshft3 = 0x00000000; +SDRAM[3].EmcDllCfg0 = 0x1f13412f; +SDRAM[3].EmcDllCfg1 = 0x00010014; +SDRAM[3].EmcPmcScratch1 = 0x4bafffff; +SDRAM[3].EmcPmcScratch2 = 0x7fffffff; +SDRAM[3].EmcPmcScratch3 = 0x4005d70b; +SDRAM[3].EmcPmacroPadCfgCtrl = 0x00020000; +SDRAM[3].EmcPmacroVttgenCtrl0 = 0x00030808; +SDRAM[3].EmcPmacroVttgenCtrl1 = 0x00015000; +SDRAM[3].EmcPmacroVttgenCtrl2 = 0x00101010; +SDRAM[3].EmcPmacroBrickCtrlRfu1 = 0x00001600; +SDRAM[3].EmcPmacroCmdBrickCtrlFdpd = 0x00000000; +SDRAM[3].EmcPmacroBrickCtrlRfu2 = 0x00000000; +SDRAM[3].EmcPmacroDataBrickCtrlFdpd = 0x00000000; +SDRAM[3].EmcPmacroBgBiasCtrl0 = 0x00000030; +SDRAM[3].EmcPmacroDataPadRxCtrl = 0x10050037; +SDRAM[3].EmcPmacroCmdPadRxCtrl = 0x00000000; +SDRAM[3].EmcPmacroDataRxTermMode = 0x00000010; +SDRAM[3].EmcPmacroCmdRxTermMode = 0x00003000; +SDRAM[3].EmcPmacroDataPadTxCtrl = 0x02000111; +SDRAM[3].EmcPmacroCommonPadTxCtrl = 0x00000008; +SDRAM[3].EmcPmacroCmdPadTxCtrl = 0x0a000000; +SDRAM[3].EmcCfg3 = 0x00000040; +SDRAM[3].EmcPmacroTxPwrd0 = 0x10000000; +SDRAM[3].EmcPmacroTxPwrd1 = 0x08000000; +SDRAM[3].EmcPmacroTxPwrd2 = 0x08000000; +SDRAM[3].EmcPmacroTxPwrd3 = 0x08000000; +SDRAM[3].EmcPmacroTxPwrd4 = 0x00000000; +SDRAM[3].EmcPmacroTxPwrd5 = 0x00000000; +SDRAM[3].EmcConfigSampleDelay = 0x00000020; +SDRAM[3].EmcPmacroBrickMapping0 = 0x28190081; +SDRAM[3].EmcPmacroBrickMapping1 = 0x44a53293; +SDRAM[3].EmcPmacroBrickMapping2 = 0x76b76a5b; +SDRAM[3].EmcPmacroTxSelClkSrc0 = 0x00000000; +SDRAM[3].EmcPmacroTxSelClkSrc1 = 0x00000000; +SDRAM[3].EmcPmacroTxSelClkSrc2 = 0x00000000; +SDRAM[3].EmcPmacroTxSelClkSrc3 = 0x00000000; +SDRAM[3].EmcPmacroTxSelClkSrc4 = 0x00000000; +SDRAM[3].EmcPmacroTxSelClkSrc5 = 0x00000000; +SDRAM[3].EmcPmacroDdllBypass = 0xefffefff; +SDRAM[3].EmcPmacroDdllPwrd0 = 0xc0c0c0c0; +SDRAM[3].EmcPmacroDdllPwrd1 = 0xc0c0c0c0; +SDRAM[3].EmcPmacroDdllPwrd2 = 0xdcdcdcdc; +SDRAM[3].EmcPmacroCmdCtrl0 = 0x0a0a0a0a; +SDRAM[3].EmcPmacroCmdCtrl1 = 0x0a0a0a0a; +SDRAM[3].EmcPmacroCmdCtrl2 = 0x0a0a0a0a; +SDRAM[3].McEmemAdrCfg = 0x00000001; +SDRAM[3].McEmemAdrCfgDev0 = 0x00070302; +SDRAM[3].McEmemAdrCfgDev1 = 0x00070302; +SDRAM[3].McEmemAdrCfgChannelMask = 0xffff2400; +SDRAM[3].McEmemAdrCfgBankMask0 = 0x6e574400; +SDRAM[3].McEmemAdrCfgBankMask1 = 0x39722800; +SDRAM[3].McEmemAdrCfgBankMask2 = 0x4b9c1000; +SDRAM[3].McEmemCfg = 0x00001000; +SDRAM[3].McEmemArbCfg = 0x08000001; +SDRAM[3].McEmemArbOutstandingReq = 0x8000004c; +SDRAM[3].McEmemArbRefpbHpCtrl = 0x000a1020; +SDRAM[3].McEmemArbRefpbBankCtrl = 0x80001028; +SDRAM[3].McEmemArbTimingRcd = 0x00000001; +SDRAM[3].McEmemArbTimingRp = 0x00000000; +SDRAM[3].McEmemArbTimingRc = 0x00000003; +SDRAM[3].McEmemArbTimingRas = 0x00000001; +SDRAM[3].McEmemArbTimingFaw = 0x00000002; +SDRAM[3].McEmemArbTimingRrd = 0x00000001; +SDRAM[3].McEmemArbTimingRap2Pre = 0x00000002; +SDRAM[3].McEmemArbTimingWap2Pre = 0x00000005; +SDRAM[3].McEmemArbTimingR2R = 0x00000001; +SDRAM[3].McEmemArbTimingW2W = 0x00000001; +SDRAM[3].McEmemArbTimingR2W = 0x00000004; +SDRAM[3].McEmemArbTimingW2R = 0x00000005; +SDRAM[3].McEmemArbTimingRFCPB = 0x00000004; +SDRAM[3].McEmemArbDaTurns = 0x02020000; +SDRAM[3].McEmemArbDaCovers = 0x00030201; +SDRAM[3].McEmemArbMisc0 = 0x71c30504; +SDRAM[3].McEmemArbMisc1 = 0x70000f0f; +SDRAM[3].McEmemArbMisc2 = 0x00000000; +SDRAM[3].McEmemArbRing1Throttle = 0x001f0000; +SDRAM[3].McEmemArbOverride = 0x10000000; +SDRAM[3].McEmemArbOverride1 = 0x00000000; +SDRAM[3].McEmemArbRsv = 0xff00ff00; +SDRAM[3].McDaCfg0 = 0x00000001; +SDRAM[3].McEmemArbTimingCcdmw = 0x00000008; +SDRAM[3].McClkenOverride = 0x00008000; +SDRAM[3].McStatControl = 0x00000000; +SDRAM[3].McVideoProtectBom = 0xfff00000; +SDRAM[3].McVideoProtectBomAdrHi = 0x00000000; +SDRAM[3].McVideoProtectSizeMb = 0x00000000; +SDRAM[3].McVideoProtectVprOverride = 0xe4bac343; +SDRAM[3].McVideoProtectVprOverride1 = 0x00001ed3; +SDRAM[3].McVideoProtectGpuOverride0 = 0x00000000; +SDRAM[3].McVideoProtectGpuOverride1 = 0x00000000; +SDRAM[3].McSecCarveoutBom = 0xfff00000; +SDRAM[3].McSecCarveoutAdrHi = 0x00000000; +SDRAM[3].McSecCarveoutSizeMb = 0x00000000; +SDRAM[3].McVideoProtectWriteAccess = 0x00000000; +SDRAM[3].McSecCarveoutProtectWriteAccess = 0x00000000; +SDRAM[3].McGeneralizedCarveout1Bom = 0x00000000; +SDRAM[3].McGeneralizedCarveout1BomHi = 0x00000000; +SDRAM[3].McGeneralizedCarveout1Size128kb = 0x00000008; +SDRAM[3].McGeneralizedCarveout1Access0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout1Access1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout1Access2 = 0x00300000; +SDRAM[3].McGeneralizedCarveout1Access3 = 0x03000000; +SDRAM[3].McGeneralizedCarveout1Access4 = 0x00000000; +SDRAM[3].McGeneralizedCarveout1ForceInternalAccess0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout1ForceInternalAccess1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout1ForceInternalAccess2 = 0x00000000; +SDRAM[3].McGeneralizedCarveout1ForceInternalAccess3 = 0x00000000; +SDRAM[3].McGeneralizedCarveout1ForceInternalAccess4 = 0x00000000; +SDRAM[3].McGeneralizedCarveout1Cfg0 = 0x04000c75; +SDRAM[3].McGeneralizedCarveout2Bom = 0x00000000; +SDRAM[3].McGeneralizedCarveout2BomHi = 0x00000000; +SDRAM[3].McGeneralizedCarveout2Size128kb = 0x00000002; +SDRAM[3].McGeneralizedCarveout2Access0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout2Access1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout2Access2 = 0x03000000; +SDRAM[3].McGeneralizedCarveout2Access3 = 0x00000000; +SDRAM[3].McGeneralizedCarveout2Access4 = 0x00000300; +SDRAM[3].McGeneralizedCarveout2ForceInternalAccess0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout2ForceInternalAccess1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout2ForceInternalAccess2 = 0x00000000; +SDRAM[3].McGeneralizedCarveout2ForceInternalAccess3 = 0x00000000; +SDRAM[3].McGeneralizedCarveout2ForceInternalAccess4 = 0x00000000; +SDRAM[3].McGeneralizedCarveout2Cfg0 = 0x0440167c; +SDRAM[3].McGeneralizedCarveout3Bom = 0x00000000; +SDRAM[3].McGeneralizedCarveout3BomHi = 0x00000000; +SDRAM[3].McGeneralizedCarveout3Size128kb = 0x00000000; +SDRAM[3].McGeneralizedCarveout3Access0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout3Access1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout3Access2 = 0x03000000; +SDRAM[3].McGeneralizedCarveout3Access3 = 0x00000000; +SDRAM[3].McGeneralizedCarveout3Access4 = 0x00000300; +SDRAM[3].McGeneralizedCarveout3ForceInternalAccess0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout3ForceInternalAccess1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout3ForceInternalAccess2 = 0x00000000; +SDRAM[3].McGeneralizedCarveout3ForceInternalAccess3 = 0x00000000; +SDRAM[3].McGeneralizedCarveout3ForceInternalAccess4 = 0x00000000; +SDRAM[3].McGeneralizedCarveout3Cfg0 = 0x04401e7c; +SDRAM[3].McGeneralizedCarveout4Bom = 0x00000000; +SDRAM[3].McGeneralizedCarveout4BomHi = 0x00000000; +SDRAM[3].McGeneralizedCarveout4Size128kb = 0x00000008; +SDRAM[3].McGeneralizedCarveout4Access0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout4Access1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout4Access2 = 0x00300000; +SDRAM[3].McGeneralizedCarveout4Access3 = 0x00000000; +SDRAM[3].McGeneralizedCarveout4Access4 = 0x00000000; +SDRAM[3].McGeneralizedCarveout4ForceInternalAccess0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout4ForceInternalAccess1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout4ForceInternalAccess2 = 0x00000000; +SDRAM[3].McGeneralizedCarveout4ForceInternalAccess3 = 0x00000000; +SDRAM[3].McGeneralizedCarveout4ForceInternalAccess4 = 0x00000000; +SDRAM[3].McGeneralizedCarveout4Cfg0 = 0x04002442; +SDRAM[3].McGeneralizedCarveout5Bom = 0x00000000; +SDRAM[3].McGeneralizedCarveout5BomHi = 0x00000000; +SDRAM[3].McGeneralizedCarveout5Size128kb = 0x00000008; +SDRAM[3].McGeneralizedCarveout5Access0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout5Access1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout5Access2 = 0x00300000; +SDRAM[3].McGeneralizedCarveout5Access3 = 0x00000000; +SDRAM[3].McGeneralizedCarveout5Access4 = 0x00000000; +SDRAM[3].McGeneralizedCarveout5ForceInternalAccess0 = 0x00000000; +SDRAM[3].McGeneralizedCarveout5ForceInternalAccess1 = 0x00000000; +SDRAM[3].McGeneralizedCarveout5ForceInternalAccess2 = 0x00000000; +SDRAM[3].McGeneralizedCarveout5ForceInternalAccess3 = 0x00000000; +SDRAM[3].McGeneralizedCarveout5ForceInternalAccess4 = 0x00000000; +SDRAM[3].McGeneralizedCarveout5Cfg0 = 0x04002c42; +SDRAM[3].EmcCaTrainingEnable = 0x00000000; +SDRAM[3].SwizzleRankByteEncode = 0x0000002e; +SDRAM[3].BootRomPatchControl = 0x00000000; +SDRAM[3].BootRomPatchData = 0x00000000; +SDRAM[3].McMtsCarveoutBom = 0xfff00000; +SDRAM[3].McMtsCarveoutAdrHi = 0x00000000; +SDRAM[3].McMtsCarveoutSizeMb = 0x00000000; +SDRAM[3].McMtsCarveoutRegCtrl = 0x00000000; diff --git a/src/mainboard/google/smaug/bct/sdram-samsung-3GB-204.inc b/src/mainboard/google/smaug/bct/sdram-samsung-3GB-204.inc new file mode 100644 index 0000000..745bb51 --- /dev/null +++ b/src/mainboard/google/smaug/bct/sdram-samsung-3GB-204.inc @@ -0,0 +1,476 @@ +{ /* generated from T210_A44_R1_LP4_DSC_204Mhz.cfg; do not edit. */ + .MemoryType = NvBootMemoryType_LpDdr4, + .PllMInputDivider = 0x00000001, + .PllMFeedbackDivider = 0x00000022, + .PllMStableTime = 0x0000012c, + .PllMSetupControl = 0x00000000, + .PllMPostDivider = 0x00000000, + .PllMKCP = 0x00000000, + .PllMKVCO = 0x00000000, + .EmcBctSpare0 = 0x00000000, + .EmcBctSpare1 = 0x00000000, + .EmcBctSpare2 = 0x00000000, + .EmcBctSpare3 = 0x00000000, + .EmcBctSpare4 = 0x7001bc3c, + .EmcBctSpare5 = 0x00000032, + .EmcBctSpare6 = 0x7001b404, + .EmcBctSpare7 = 0x76342501, + .EmcBctSpare8 = 0x7000e6c8, + .EmcBctSpare9 = 0x00000000, + .EmcBctSpare10 = 0x00000000, + .EmcBctSpare11 = 0x00000000, + .EmcBctSpare12 = 0x7001bc3c, + .EmcBctSpare13 = 0x00000033, + .EmcClockSource = 0x40188002, + .EmcClockSourceDll = 0x40000000, + .ClkRstControllerPllmMisc2Override = 0x00000000, + .ClkRstControllerPllmMisc2OverrideEnable = 0x00000000, + .ClearClk2Mc1 = 0x00000000, + .EmcAutoCalInterval = 0x001fffff, + .EmcAutoCalConfig = 0xa01a51d8, + .EmcAutoCalConfig2 = 0x05500000, + .EmcAutoCalConfig3 = 0x00770000, + .EmcAutoCalConfig4 = 0x00770000, + .EmcAutoCalConfig5 = 0x00770000, + .EmcAutoCalConfig6 = 0x00770000, + .EmcAutoCalConfig7 = 0x00770000, + .EmcAutoCalConfig8 = 0x00770000, + .EmcAutoCalVrefSel0 = 0xb3afa6a6, + .EmcAutoCalVrefSel1 = 0x00009e3c, + .EmcAutoCalChannel = 0xc1e00303, + .EmcPmacroAutocalCfg0 = 0x04040404, + .EmcPmacroAutocalCfg1 = 0x04040404, + .EmcPmacroAutocalCfg2 = 0x00000000, + .EmcPmacroRxTerm = 0x1f1f1f1f, + .EmcPmacroDqTxDrv = 0x1f1f1f1f, + .EmcPmacroCaTxDrv = 0x1f1f1f1f, + .EmcPmacroCmdTxDrv = 0x00001f1f, + .EmcPmacroAutocalCfgCommon = 0x00000804, + .EmcPmacroZctrl = 0x00000550, + .EmcAutoCalWait = 0x000001a1, + .EmcXm2CompPadCtrl = 0x00000032, + .EmcXm2CompPadCtrl2 = 0x00000000, + .EmcXm2CompPadCtrl3 = 0x00000000, + .EmcAdrCfg = 0x00000001, + .EmcPinProgramWait = 0x00000002, + .EmcPinExtraWait = 0x00000000, + .EmcPinGpioEn = 0x00000003, + .EmcPinGpio = 0x00000003, + .EmcTimingControlWait = 0x0000001e, + .EmcRc = 0x0000000d, + .EmcRfc = 0x00000025, + .EmcRfcPb = 0x00000013, + .EmcRefctrl2 = 0x00000000, + .EmcRfcSlr = 0x00000000, + .EmcRas = 0x00000009, + .EmcRp = 0x00000004, + .EmcR2r = 0x00000000, + .EmcW2w = 0x00000000, + .EmcR2w = 0x0000000b, + .EmcW2r = 0x0000000d, + .EmcR2p = 0x00000008, + .EmcW2p = 0x0000000b, + .EmcTppd = 0x00000004, + .EmcCcdmw = 0x00000020, + .EmcRdRcd = 0x00000006, + .EmcWrRcd = 0x00000006, + .EmcRrd = 0x00000006, + .EmcRext = 0x00000003, + .EmcWext = 0x00000000, + .EmcWdv = 0x00000004, + .EmcWdvChk = 0x00000006, + .EmcWsv = 0x00000002, + .EmcWev = 0x00000000, + .EmcWdvMask = 0x00000004, + .EmcWsDuration = 0x00000008, + .EmcWeDuration = 0x0000000d, + .EmcQUse = 0x00000005, + .EmcQuseWidth = 0x00000006, + .EmcIbdly = 0x00000000, + .EmcObdly = 0x00000000, + .EmcEInput = 0x00000002, + .EmcEInputDuration = 0x0000000d, + .EmcPutermExtra = 0x00000002, + .EmcPutermWidth = 0x0000000b, + .EmcQRst = 0x00010000, + .EmcQSafe = 0x00000012, + .EmcRdv = 0x00000014, + .EmcRdvMask = 0x00000016, + .EmcRdvEarly = 0x00000012, + .EmcRdvEarlyMask = 0x00000014, + .EmcQpop = 0x0000000a, + .EmcRefresh = 0x00000304, + .EmcBurstRefreshNum = 0x00000000, + .EmcPreRefreshReqCnt = 0x000000c1, + .EmcPdEx2Wr = 0x00000008, + .EmcPdEx2Rd = 0x00000008, + .EmcPChg2Pden = 0x00000003, + .EmcAct2Pden = 0x00000003, + .EmcAr2Pden = 0x00000003, + .EmcRw2Pden = 0x00000012, + .EmcCke2Pden = 0x00000005, + .EmcPdex2Cke = 0x00000002, + .EmcPdex2Mrr = 0x0000000d, + .EmcTxsr = 0x00000027, + .EmcTxsrDll = 0x00000027, + .EmcTcke = 0x00000005, + .EmcTckesr = 0x00000005, + .EmcTpd = 0x00000004, + .EmcTfaw = 0x00000009, + .EmcTrpab = 0x00000005, + .EmcTClkStable = 0x00000003, + .EmcTClkStop = 0x00000009, + .EmcTRefBw = 0x0000031c, + .EmcFbioCfg5 = 0x9160a00d, + .EmcFbioCfg7 = 0x00003bbf, + .EmcFbioCfg8 = 0x0cf30000, + .EmcCmdMappingCmd0_0 = 0x07050203, + .EmcCmdMappingCmd0_1 = 0x06041b1c, + .EmcCmdMappingCmd0_2 = 0x05252523, + .EmcCmdMappingCmd1_0 = 0x1e0d0b0a, + .EmcCmdMappingCmd1_1 = 0x240c091d, + .EmcCmdMappingCmd1_2 = 0x04262608, + .EmcCmdMappingCmd2_0 = 0x051b0302, + .EmcCmdMappingCmd2_1 = 0x0604231c, + .EmcCmdMappingCmd2_2 = 0x09252507, + .EmcCmdMappingCmd3_0 = 0x0c0b0d0a, + .EmcCmdMappingCmd3_1 = 0x08091e1d, + .EmcCmdMappingCmd3_2 = 0x08262624, + .EmcCmdMappingByte = 0x0a070623, + .EmcFbioSpare = 0x00000012, + .EmcCfgRsv = 0xff00ff00, + .EmcMrs = 0x00000000, + .EmcEmrs = 0x00000000, + .EmcEmrs2 = 0x00000000, + .EmcEmrs3 = 0x00000000, + .EmcMrw1 = 0x08010004, + .EmcMrw2 = 0x08020000, + .EmcMrw3 = 0x080d0000, + .EmcMrw4 = 0xc0000000, + .EmcMrw6 = 0x08037171, + .EmcMrw8 = 0x080b0000, + .EmcMrw9 = 0x0c0e6b6b, + .EmcMrw10 = 0x00000000, + .EmcMrw12 = 0x0c0d0808, + .EmcMrw13 = 0x0c0d0000, + .EmcMrw14 = 0x08161414, + .EmcMrwExtra = 0x08010004, + .EmcWarmBootMrwExtra = 0x08110000, + .EmcWarmBootExtraModeRegWriteEnable = 0x00000001, + .EmcExtraModeRegWriteEnable = 0x00000000, + .EmcMrwResetCommand = 0x00000000, + .EmcMrwResetNInitWait = 0x00000000, + .EmcMrsWaitCnt = 0x00cc0015, + .EmcMrsWaitCnt2 = 0x0033000a, + .EmcCfg = 0xf3200000, + .EmcCfg2 = 0x00110805, + .EmcCfgPipe = 0x0fff0fff, + .EmcCfgPipeClk = 0x00000000, + .EmcFdpdCtrlCmdNoRamp = 0x00000001, + .EmcCfgUpdate = 0x70000301, + .EmcDbg = 0x01000c00, + .EmcDbgWriteMux = 0x00000001, + .EmcCmdQ = 0x10004408, + .EmcMc2EmcQ = 0x06000404, + .EmcDynSelfRefControl = 0x80000713, + .AhbArbitrationXbarCtrlMemInitDone = 0x00000001, + .EmcCfgDigDll = 0x002c00a0, + .EmcCfgDigDll_1 = 0x00003701, + .EmcCfgDigDllPeriod = 0x00008000, + .EmcDevSelect = 0x00000000, + .EmcSelDpdCtrl = 0x00040008, + .EmcFdpdCtrlDq = 0x8020221f, + .EmcFdpdCtrlCmd = 0x0220f40f, + .EmcPmacroIbVrefDq_0 = 0x28282828, + .EmcPmacroIbVrefDq_1 = 0x28282828, + .EmcPmacroIbVrefDqs_0 = 0x11111111, + .EmcPmacroIbVrefDqs_1 = 0x11111111, + .EmcPmacroIbRxrt = 0x000000be, + .EmcCfgPipe1 = 0x0fff0fff, + .EmcCfgPipe2 = 0x0fff0fff, + .EmcPmacroQuseDdllRank0_0 = 0x00000000, + .EmcPmacroQuseDdllRank0_1 = 0x00000000, + .EmcPmacroQuseDdllRank0_2 = 0x00000000, + .EmcPmacroQuseDdllRank0_3 = 0x00000000, + .EmcPmacroQuseDdllRank0_4 = 0x00000000, + .EmcPmacroQuseDdllRank0_5 = 0x00000000, + .EmcPmacroQuseDdllRank1_0 = 0x00000000, + .EmcPmacroQuseDdllRank1_1 = 0x00000000, + .EmcPmacroQuseDdllRank1_2 = 0x00000000, + .EmcPmacroQuseDdllRank1_3 = 0x00000000, + .EmcPmacroQuseDdllRank1_4 = 0x00000000, + .EmcPmacroQuseDdllRank1_5 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_0 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_1 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_2 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_3 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_4 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_5 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_0 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_1 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_2 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_3 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_4 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_5 = 0x00000000, + .EmcPmacroObDdllLongDqsRank0_0 = 0x00320032, + .EmcPmacroObDdllLongDqsRank0_1 = 0x00320032, + .EmcPmacroObDdllLongDqsRank0_2 = 0x00320032, + .EmcPmacroObDdllLongDqsRank0_3 = 0x00320032, + .EmcPmacroObDdllLongDqsRank0_4 = 0x00090009, + .EmcPmacroObDdllLongDqsRank0_5 = 0x00090009, + .EmcPmacroObDdllLongDqsRank1_0 = 0x00320032, + .EmcPmacroObDdllLongDqsRank1_1 = 0x00320032, + .EmcPmacroObDdllLongDqsRank1_2 = 0x00320032, + .EmcPmacroObDdllLongDqsRank1_3 = 0x00320032, + .EmcPmacroObDdllLongDqsRank1_4 = 0x00090009, + .EmcPmacroObDdllLongDqsRank1_5 = 0x00090009, + .EmcPmacroIbDdllLongDqsRank0_0 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank0_1 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank0_2 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank0_3 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank1_0 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank1_1 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank1_2 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank1_3 = 0x00280028, + .EmcPmacroDdllLongCmd_0 = 0x00000000, + .EmcPmacroDdllLongCmd_1 = 0x00000000, + .EmcPmacroDdllLongCmd_2 = 0x00000000, + .EmcPmacroDdllLongCmd_3 = 0x00000000, + .EmcPmacroDdllLongCmd_4 = 0x00000000, + .EmcPmacroDdllShortCmd_0 = 0x00000000, + .EmcPmacroDdllShortCmd_1 = 0x00000000, + .EmcPmacroDdllShortCmd_2 = 0x00000000, + .WarmBootWait = 0x00000001, + .EmcOdtWrite = 0x00000000, + .EmcZcalInterval = 0x00064000, + .EmcZcalWaitCnt = 0x000900cc, + .EmcZcalMrwCmd = 0x0051004f, + .EmcMrsResetDll = 0x00000000, + .EmcZcalInitDev0 = 0x80000001, + .EmcZcalInitDev1 = 0x40000001, + .EmcZcalInitWait = 0x00000001, + .EmcZcalWarmColdBootEnables = 0x00000003, + .EmcMrwLpddr2ZcalWarmBoot = 0x040a00ab, + .EmcZqCalDdr3WarmBoot = 0x00000011, + .EmcZqCalLpDdr4WarmBoot = 0x00000001, + .EmcZcalWarmBootWait = 0x00000001, + .EmcMrsWarmBootEnable = 0x00000001, + .EmcMrsResetDllWait = 0x00000000, + .EmcMrsExtra = 0x00000000, + .EmcWarmBootMrsExtra = 0x00000000, + .EmcEmrsDdr2DllEnable = 0x00000000, + .EmcMrsDdr2DllReset = 0x00000000, + .EmcEmrsDdr2OcdCalib = 0x00000000, + .EmcDdr2Wait = 0x00000000, + .EmcClkenOverride = 0x00000000, + .EmcExtraRefreshNum = 0x00000002, + .EmcClkenOverrideAllWarmBoot = 0x00000000, + .McClkenOverrideAllWarmBoot = 0x00000000, + .EmcCfgDigDllPeriodWarmBoot = 0x00000003, + .PmcVddpSel = 0x00000001, + .PmcVddpSelWait = 0x00000002, + .PmcDdrPwr = 0x0000000f, + .PmcDdrCfg = 0x20220100, + .PmcIoDpd3Req = 0x4bafffff, + .PmcIoDpd3ReqWait = 0x00000001, + .PmcIoDpd4ReqWait = 0x00000002, + .PmcRegShort = 0x00000000, + .PmcNoIoPower = 0x00000000, + .PmcDdrCntrlWait = 0x00000000, + .PmcDdrCntrl = 0x0007ff8b, + .EmcAcpdControl = 0x00000000, + .EmcSwizzleRank0Byte0 = 0x76342501, + .EmcSwizzleRank0Byte1 = 0x56243701, + .EmcSwizzleRank0Byte2 = 0x34267510, + .EmcSwizzleRank0Byte3 = 0x45763210, + .EmcSwizzleRank1Byte0 = 0x72345601, + .EmcSwizzleRank1Byte1 = 0x23456701, + .EmcSwizzleRank1Byte2 = 0x65427310, + .EmcSwizzleRank1Byte3 = 0x75432610, + .EmcTxdsrvttgen = 0x00000000, + .EmcDataBrlshft0 = 0x00249249, + .EmcDataBrlshft1 = 0x00249249, + .EmcDqsBrlshft0 = 0x00000000, + .EmcDqsBrlshft1 = 0x00000000, + .EmcCmdBrlshft0 = 0x00000000, + .EmcCmdBrlshft1 = 0x00000000, + .EmcCmdBrlshft2 = 0x00000012, + .EmcCmdBrlshft3 = 0x00000012, + .EmcQuseBrlshft0 = 0x00000000, + .EmcQuseBrlshft1 = 0x00000000, + .EmcQuseBrlshft2 = 0x00000000, + .EmcQuseBrlshft3 = 0x00000000, + .EmcDllCfg0 = 0x1f13412f, + .EmcDllCfg1 = 0x00010014, + .EmcPmcScratch1 = 0x4bafffff, + .EmcPmcScratch2 = 0x7fffffff, + .EmcPmcScratch3 = 0x4005d70b, + .EmcPmacroPadCfgCtrl = 0x00020000, + .EmcPmacroVttgenCtrl0 = 0x00030808, + .EmcPmacroVttgenCtrl1 = 0x00015000, + .EmcPmacroVttgenCtrl2 = 0x00101010, + .EmcPmacroBrickCtrlRfu1 = 0x00001600, + .EmcPmacroCmdBrickCtrlFdpd = 0x00000000, + .EmcPmacroBrickCtrlRfu2 = 0x00000000, + .EmcPmacroDataBrickCtrlFdpd = 0x00000000, + .EmcPmacroBgBiasCtrl0 = 0x00000030, + .EmcPmacroDataPadRxCtrl = 0x10050037, + .EmcPmacroCmdPadRxCtrl = 0x00000000, + .EmcPmacroDataRxTermMode = 0x00000010, + .EmcPmacroCmdRxTermMode = 0x00003000, + .EmcPmacroDataPadTxCtrl = 0x02000111, + .EmcPmacroCommonPadTxCtrl = 0x00000008, + .EmcPmacroCmdPadTxCtrl = 0x0a000000, + .EmcCfg3 = 0x00000040, + .EmcPmacroTxPwrd0 = 0x10000000, + .EmcPmacroTxPwrd1 = 0x08000000, + .EmcPmacroTxPwrd2 = 0x08000000, + .EmcPmacroTxPwrd3 = 0x08000000, + .EmcPmacroTxPwrd4 = 0x00000000, + .EmcPmacroTxPwrd5 = 0x00000000, + .EmcConfigSampleDelay = 0x00000020, + .EmcPmacroBrickMapping0 = 0x28190081, + .EmcPmacroBrickMapping1 = 0x44a53293, + .EmcPmacroBrickMapping2 = 0x76b76a5b, + .EmcPmacroTxSelClkSrc0 = 0x00000000, + .EmcPmacroTxSelClkSrc1 = 0x00000000, + .EmcPmacroTxSelClkSrc2 = 0x00000000, + .EmcPmacroTxSelClkSrc3 = 0x00000000, + .EmcPmacroTxSelClkSrc4 = 0x00000000, + .EmcPmacroTxSelClkSrc5 = 0x00000000, + .EmcPmacroDdllBypass = 0xefffefff, + .EmcPmacroDdllPwrd0 = 0xc0c0c0c0, + .EmcPmacroDdllPwrd1 = 0xc0c0c0c0, + .EmcPmacroDdllPwrd2 = 0xdcdcdcdc, + .EmcPmacroCmdCtrl0 = 0x0a0a0a0a, + .EmcPmacroCmdCtrl1 = 0x0a0a0a0a, + .EmcPmacroCmdCtrl2 = 0x0a0a0a0a, + .McEmemAdrCfg = 0x00000001, + .McEmemAdrCfgDev0 = 0x000d0302, + .McEmemAdrCfgDev1 = 0x000d0302, + .McEmemAdrCfgChannelMask = 0xffff2400, + .McEmemAdrCfgBankMask0 = 0x6e574400, + .McEmemAdrCfgBankMask1 = 0x39722800, + .McEmemAdrCfgBankMask2 = 0x4b9c1000, + .McEmemCfg = 0x00000c00, + .McEmemArbCfg = 0x08000001, + .McEmemArbOutstandingReq = 0x8000004c, + .McEmemArbRefpbHpCtrl = 0x000a1020, + .McEmemArbRefpbBankCtrl = 0x80001028, + .McEmemArbTimingRcd = 0x00000001, + .McEmemArbTimingRp = 0x00000000, + .McEmemArbTimingRc = 0x00000003, + .McEmemArbTimingRas = 0x00000001, + .McEmemArbTimingFaw = 0x00000002, + .McEmemArbTimingRrd = 0x00000001, + .McEmemArbTimingRap2Pre = 0x00000002, + .McEmemArbTimingWap2Pre = 0x00000005, + .McEmemArbTimingR2R = 0x00000001, + .McEmemArbTimingW2W = 0x00000001, + .McEmemArbTimingR2W = 0x00000004, + .McEmemArbTimingW2R = 0x00000005, + .McEmemArbTimingRFCPB = 0x00000004, + .McEmemArbDaTurns = 0x02020000, + .McEmemArbDaCovers = 0x00030201, + .McEmemArbMisc0 = 0x71c30504, + .McEmemArbMisc1 = 0x70000f0f, + .McEmemArbMisc2 = 0x00000000, + .McEmemArbRing1Throttle = 0x001f0000, + .McEmemArbOverride = 0x10000000, + .McEmemArbOverride1 = 0x00000000, + .McEmemArbRsv = 0xff00ff00, + .McDaCfg0 = 0x00000001, + .McEmemArbTimingCcdmw = 0x00000008, + .McClkenOverride = 0x00008000, + .McStatControl = 0x00000000, + .McVideoProtectBom = 0xfff00000, + .McVideoProtectBomAdrHi = 0x00000000, + .McVideoProtectSizeMb = 0x00000000, + .McVideoProtectVprOverride = 0xe4bac343, + .McVideoProtectVprOverride1 = 0x00001ed3, + .McVideoProtectGpuOverride0 = 0x00000000, + .McVideoProtectGpuOverride1 = 0x00000000, + .McSecCarveoutBom = 0xfff00000, + .McSecCarveoutAdrHi = 0x00000000, + .McSecCarveoutSizeMb = 0x00000000, + .McVideoProtectWriteAccess = 0x00000000, + .McSecCarveoutProtectWriteAccess = 0x00000000, + .McGeneralizedCarveout1Bom = 0x00000000, + .McGeneralizedCarveout1BomHi = 0x00000000, + .McGeneralizedCarveout1Size128kb = 0x00000008, + .McGeneralizedCarveout1Access0 = 0x00000000, + .McGeneralizedCarveout1Access1 = 0x00000000, + .McGeneralizedCarveout1Access2 = 0x00300000, + .McGeneralizedCarveout1Access3 = 0x03000000, + .McGeneralizedCarveout1Access4 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout1Cfg0 = 0x04000c75, + .McGeneralizedCarveout2Bom = 0x00000000, + .McGeneralizedCarveout2BomHi = 0x00000000, + .McGeneralizedCarveout2Size128kb = 0x00000002, + .McGeneralizedCarveout2Access0 = 0x00000000, + .McGeneralizedCarveout2Access1 = 0x00000000, + .McGeneralizedCarveout2Access2 = 0x03000000, + .McGeneralizedCarveout2Access3 = 0x00000000, + .McGeneralizedCarveout2Access4 = 0x00000300, + .McGeneralizedCarveout2ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout2Cfg0 = 0x0440167c, + .McGeneralizedCarveout3Bom = 0x00000000, + .McGeneralizedCarveout3BomHi = 0x00000000, + .McGeneralizedCarveout3Size128kb = 0x00000000, + .McGeneralizedCarveout3Access0 = 0x00000000, + .McGeneralizedCarveout3Access1 = 0x00000000, + .McGeneralizedCarveout3Access2 = 0x03000000, + .McGeneralizedCarveout3Access3 = 0x00000000, + .McGeneralizedCarveout3Access4 = 0x00000300, + .McGeneralizedCarveout3ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout3Cfg0 = 0x04401e7c, + .McGeneralizedCarveout4Bom = 0x00000000, + .McGeneralizedCarveout4BomHi = 0x00000000, + .McGeneralizedCarveout4Size128kb = 0x00000008, + .McGeneralizedCarveout4Access0 = 0x00000000, + .McGeneralizedCarveout4Access1 = 0x00000000, + .McGeneralizedCarveout4Access2 = 0x00300000, + .McGeneralizedCarveout4Access3 = 0x00000000, + .McGeneralizedCarveout4Access4 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout4Cfg0 = 0x04002442, + .McGeneralizedCarveout5Bom = 0x00000000, + .McGeneralizedCarveout5BomHi = 0x00000000, + .McGeneralizedCarveout5Size128kb = 0x00000008, + .McGeneralizedCarveout5Access0 = 0x00000000, + .McGeneralizedCarveout5Access1 = 0x00000000, + .McGeneralizedCarveout5Access2 = 0x00300000, + .McGeneralizedCarveout5Access3 = 0x00000000, + .McGeneralizedCarveout5Access4 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout5Cfg0 = 0x04002c42, + .EmcCaTrainingEnable = 0x00000000, + .SwizzleRankByteEncode = 0x0000002e, + .BootRomPatchControl = 0x00000000, + .BootRomPatchData = 0x00000000, + .McMtsCarveoutBom = 0xfff00000, + .McMtsCarveoutAdrHi = 0x00000000, + .McMtsCarveoutSizeMb = 0x00000000, + .McMtsCarveoutRegCtrl = 0x00000000, +}, diff --git a/src/mainboard/google/smaug/bct/sdram-samsung-4GB-204.inc b/src/mainboard/google/smaug/bct/sdram-samsung-4GB-204.inc new file mode 100644 index 0000000..2e7142e --- /dev/null +++ b/src/mainboard/google/smaug/bct/sdram-samsung-4GB-204.inc @@ -0,0 +1,476 @@ +{ /* generated from T210_A44_R1_LP4_DSC_4G_204Mhz.cfg; do not edit. */ + .MemoryType = NvBootMemoryType_LpDdr4, + .PllMInputDivider = 0x00000001, + .PllMFeedbackDivider = 0x00000022, + .PllMStableTime = 0x0000012c, + .PllMSetupControl = 0x00000000, + .PllMPostDivider = 0x00000000, + .PllMKCP = 0x00000000, + .PllMKVCO = 0x00000000, + .EmcBctSpare0 = 0x00000000, + .EmcBctSpare1 = 0x00000000, + .EmcBctSpare2 = 0x00000000, + .EmcBctSpare3 = 0x00000000, + .EmcBctSpare4 = 0x7001bc3c, + .EmcBctSpare5 = 0x00000032, + .EmcBctSpare6 = 0x7001b404, + .EmcBctSpare7 = 0x76342501, + .EmcBctSpare8 = 0x7000e6c8, + .EmcBctSpare9 = 0x00000000, + .EmcBctSpare10 = 0x00000000, + .EmcBctSpare11 = 0x00000000, + .EmcBctSpare12 = 0x7001bc3c, + .EmcBctSpare13 = 0x00000033, + .EmcClockSource = 0x40188002, + .EmcClockSourceDll = 0x40000000, + .ClkRstControllerPllmMisc2Override = 0x00000000, + .ClkRstControllerPllmMisc2OverrideEnable = 0x00000000, + .ClearClk2Mc1 = 0x00000000, + .EmcAutoCalInterval = 0x001fffff, + .EmcAutoCalConfig = 0xa01a51d8, + .EmcAutoCalConfig2 = 0x05500000, + .EmcAutoCalConfig3 = 0x00770000, + .EmcAutoCalConfig4 = 0x00770000, + .EmcAutoCalConfig5 = 0x00770000, + .EmcAutoCalConfig6 = 0x00770000, + .EmcAutoCalConfig7 = 0x00770000, + .EmcAutoCalConfig8 = 0x00770000, + .EmcAutoCalVrefSel0 = 0xb3afa6a6, + .EmcAutoCalVrefSel1 = 0x00009e3c, + .EmcAutoCalChannel = 0xc1e00303, + .EmcPmacroAutocalCfg0 = 0x04040404, + .EmcPmacroAutocalCfg1 = 0x04040404, + .EmcPmacroAutocalCfg2 = 0x00000000, + .EmcPmacroRxTerm = 0x1f1f1f1f, + .EmcPmacroDqTxDrv = 0x1f1f1f1f, + .EmcPmacroCaTxDrv = 0x1f1f1f1f, + .EmcPmacroCmdTxDrv = 0x00001f1f, + .EmcPmacroAutocalCfgCommon = 0x00000804, + .EmcPmacroZctrl = 0x00000550, + .EmcAutoCalWait = 0x000001a1, + .EmcXm2CompPadCtrl = 0x00000032, + .EmcXm2CompPadCtrl2 = 0x00000000, + .EmcXm2CompPadCtrl3 = 0x00000000, + .EmcAdrCfg = 0x00000001, + .EmcPinProgramWait = 0x00000002, + .EmcPinExtraWait = 0x00000000, + .EmcPinGpioEn = 0x00000003, + .EmcPinGpio = 0x00000003, + .EmcTimingControlWait = 0x0000001e, + .EmcRc = 0x0000000d, + .EmcRfc = 0x00000025, + .EmcRfcPb = 0x00000013, + .EmcRefctrl2 = 0x00000000, + .EmcRfcSlr = 0x00000000, + .EmcRas = 0x00000009, + .EmcRp = 0x00000004, + .EmcR2r = 0x00000000, + .EmcW2w = 0x00000000, + .EmcR2w = 0x0000000b, + .EmcW2r = 0x0000000d, + .EmcR2p = 0x00000008, + .EmcW2p = 0x0000000b, + .EmcTppd = 0x00000004, + .EmcCcdmw = 0x00000020, + .EmcRdRcd = 0x00000006, + .EmcWrRcd = 0x00000006, + .EmcRrd = 0x00000006, + .EmcRext = 0x00000003, + .EmcWext = 0x00000000, + .EmcWdv = 0x00000004, + .EmcWdvChk = 0x00000006, + .EmcWsv = 0x00000002, + .EmcWev = 0x00000000, + .EmcWdvMask = 0x00000004, + .EmcWsDuration = 0x00000008, + .EmcWeDuration = 0x0000000d, + .EmcQUse = 0x00000005, + .EmcQuseWidth = 0x00000006, + .EmcIbdly = 0x00000000, + .EmcObdly = 0x00000000, + .EmcEInput = 0x00000002, + .EmcEInputDuration = 0x0000000d, + .EmcPutermExtra = 0x00000002, + .EmcPutermWidth = 0x0000000b, + .EmcQRst = 0x00010000, + .EmcQSafe = 0x00000012, + .EmcRdv = 0x00000014, + .EmcRdvMask = 0x00000016, + .EmcRdvEarly = 0x00000012, + .EmcRdvEarlyMask = 0x00000014, + .EmcQpop = 0x0000000a, + .EmcRefresh = 0x00000304, + .EmcBurstRefreshNum = 0x00000000, + .EmcPreRefreshReqCnt = 0x000000c1, + .EmcPdEx2Wr = 0x00000008, + .EmcPdEx2Rd = 0x00000008, + .EmcPChg2Pden = 0x00000003, + .EmcAct2Pden = 0x00000003, + .EmcAr2Pden = 0x00000003, + .EmcRw2Pden = 0x00000012, + .EmcCke2Pden = 0x00000005, + .EmcPdex2Cke = 0x00000002, + .EmcPdex2Mrr = 0x0000000d, + .EmcTxsr = 0x00000027, + .EmcTxsrDll = 0x00000027, + .EmcTcke = 0x00000005, + .EmcTckesr = 0x00000005, + .EmcTpd = 0x00000004, + .EmcTfaw = 0x00000009, + .EmcTrpab = 0x00000005, + .EmcTClkStable = 0x00000003, + .EmcTClkStop = 0x00000009, + .EmcTRefBw = 0x0000031c, + .EmcFbioCfg5 = 0x9160a00d, + .EmcFbioCfg7 = 0x00003bbf, + .EmcFbioCfg8 = 0x0cf30000, + .EmcCmdMappingCmd0_0 = 0x07050203, + .EmcCmdMappingCmd0_1 = 0x06041b1c, + .EmcCmdMappingCmd0_2 = 0x05252523, + .EmcCmdMappingCmd1_0 = 0x1e0d0b0a, + .EmcCmdMappingCmd1_1 = 0x240c091d, + .EmcCmdMappingCmd1_2 = 0x04262608, + .EmcCmdMappingCmd2_0 = 0x051b0302, + .EmcCmdMappingCmd2_1 = 0x0604231c, + .EmcCmdMappingCmd2_2 = 0x09252507, + .EmcCmdMappingCmd3_0 = 0x0c0b0d0a, + .EmcCmdMappingCmd3_1 = 0x08091e1d, + .EmcCmdMappingCmd3_2 = 0x08262624, + .EmcCmdMappingByte = 0x0a070623, + .EmcFbioSpare = 0x00000012, + .EmcCfgRsv = 0xff00ff00, + .EmcMrs = 0x00000000, + .EmcEmrs = 0x00000000, + .EmcEmrs2 = 0x00000000, + .EmcEmrs3 = 0x00000000, + .EmcMrw1 = 0x08010004, + .EmcMrw2 = 0x08020000, + .EmcMrw3 = 0x080d0000, + .EmcMrw4 = 0xc0000000, + .EmcMrw6 = 0x08037171, + .EmcMrw8 = 0x080b0000, + .EmcMrw9 = 0x0c0e6b6b, + .EmcMrw10 = 0x00000000, + .EmcMrw12 = 0x0c0d0808, + .EmcMrw13 = 0x0c0d0000, + .EmcMrw14 = 0x08161414, + .EmcMrwExtra = 0x08010004, + .EmcWarmBootMrwExtra = 0x08110000, + .EmcWarmBootExtraModeRegWriteEnable = 0x00000001, + .EmcExtraModeRegWriteEnable = 0x00000000, + .EmcMrwResetCommand = 0x00000000, + .EmcMrwResetNInitWait = 0x00000000, + .EmcMrsWaitCnt = 0x00cc0015, + .EmcMrsWaitCnt2 = 0x0033000a, + .EmcCfg = 0xf3200000, + .EmcCfg2 = 0x00110805, + .EmcCfgPipe = 0x0fff0fff, + .EmcCfgPipeClk = 0x00000000, + .EmcFdpdCtrlCmdNoRamp = 0x00000001, + .EmcCfgUpdate = 0x70000301, + .EmcDbg = 0x01000c00, + .EmcDbgWriteMux = 0x00000001, + .EmcCmdQ = 0x10004408, + .EmcMc2EmcQ = 0x06000404, + .EmcDynSelfRefControl = 0x80000713, + .AhbArbitrationXbarCtrlMemInitDone = 0x00000001, + .EmcCfgDigDll = 0x002c00a0, + .EmcCfgDigDll_1 = 0x00003701, + .EmcCfgDigDllPeriod = 0x00008000, + .EmcDevSelect = 0x00000000, + .EmcSelDpdCtrl = 0x00040008, + .EmcFdpdCtrlDq = 0x8020221f, + .EmcFdpdCtrlCmd = 0x0220f40f, + .EmcPmacroIbVrefDq_0 = 0x28282828, + .EmcPmacroIbVrefDq_1 = 0x28282828, + .EmcPmacroIbVrefDqs_0 = 0x11111111, + .EmcPmacroIbVrefDqs_1 = 0x11111111, + .EmcPmacroIbRxrt = 0x000000be, + .EmcCfgPipe1 = 0x0fff0fff, + .EmcCfgPipe2 = 0x0fff0fff, + .EmcPmacroQuseDdllRank0_0 = 0x00000000, + .EmcPmacroQuseDdllRank0_1 = 0x00000000, + .EmcPmacroQuseDdllRank0_2 = 0x00000000, + .EmcPmacroQuseDdllRank0_3 = 0x00000000, + .EmcPmacroQuseDdllRank0_4 = 0x00000000, + .EmcPmacroQuseDdllRank0_5 = 0x00000000, + .EmcPmacroQuseDdllRank1_0 = 0x00000000, + .EmcPmacroQuseDdllRank1_1 = 0x00000000, + .EmcPmacroQuseDdllRank1_2 = 0x00000000, + .EmcPmacroQuseDdllRank1_3 = 0x00000000, + .EmcPmacroQuseDdllRank1_4 = 0x00000000, + .EmcPmacroQuseDdllRank1_5 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_0 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_1 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_2 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_3 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_4 = 0x00000000, + .EmcPmacroObDdllLongDqRank0_5 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_0 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_1 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_2 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_3 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_4 = 0x00000000, + .EmcPmacroObDdllLongDqRank1_5 = 0x00000000, + .EmcPmacroObDdllLongDqsRank0_0 = 0x00320032, + .EmcPmacroObDdllLongDqsRank0_1 = 0x00320032, + .EmcPmacroObDdllLongDqsRank0_2 = 0x00320032, + .EmcPmacroObDdllLongDqsRank0_3 = 0x00320032, + .EmcPmacroObDdllLongDqsRank0_4 = 0x00090009, + .EmcPmacroObDdllLongDqsRank0_5 = 0x00090009, + .EmcPmacroObDdllLongDqsRank1_0 = 0x00320032, + .EmcPmacroObDdllLongDqsRank1_1 = 0x00320032, + .EmcPmacroObDdllLongDqsRank1_2 = 0x00320032, + .EmcPmacroObDdllLongDqsRank1_3 = 0x00320032, + .EmcPmacroObDdllLongDqsRank1_4 = 0x00090009, + .EmcPmacroObDdllLongDqsRank1_5 = 0x00090009, + .EmcPmacroIbDdllLongDqsRank0_0 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank0_1 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank0_2 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank0_3 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank1_0 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank1_1 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank1_2 = 0x00280028, + .EmcPmacroIbDdllLongDqsRank1_3 = 0x00280028, + .EmcPmacroDdllLongCmd_0 = 0x00000000, + .EmcPmacroDdllLongCmd_1 = 0x00000000, + .EmcPmacroDdllLongCmd_2 = 0x00000000, + .EmcPmacroDdllLongCmd_3 = 0x00000000, + .EmcPmacroDdllLongCmd_4 = 0x00000000, + .EmcPmacroDdllShortCmd_0 = 0x00000000, + .EmcPmacroDdllShortCmd_1 = 0x00000000, + .EmcPmacroDdllShortCmd_2 = 0x00000000, + .WarmBootWait = 0x00000001, + .EmcOdtWrite = 0x00000000, + .EmcZcalInterval = 0x00064000, + .EmcZcalWaitCnt = 0x000900cc, + .EmcZcalMrwCmd = 0x0051004f, + .EmcMrsResetDll = 0x00000000, + .EmcZcalInitDev0 = 0x80000001, + .EmcZcalInitDev1 = 0x40000001, + .EmcZcalInitWait = 0x00000001, + .EmcZcalWarmColdBootEnables = 0x00000003, + .EmcMrwLpddr2ZcalWarmBoot = 0x040a00ab, + .EmcZqCalDdr3WarmBoot = 0x00000011, + .EmcZqCalLpDdr4WarmBoot = 0x00000001, + .EmcZcalWarmBootWait = 0x00000001, + .EmcMrsWarmBootEnable = 0x00000001, + .EmcMrsResetDllWait = 0x00000000, + .EmcMrsExtra = 0x00000000, + .EmcWarmBootMrsExtra = 0x00000000, + .EmcEmrsDdr2DllEnable = 0x00000000, + .EmcMrsDdr2DllReset = 0x00000000, + .EmcEmrsDdr2OcdCalib = 0x00000000, + .EmcDdr2Wait = 0x00000000, + .EmcClkenOverride = 0x00000000, + .EmcExtraRefreshNum = 0x00000002, + .EmcClkenOverrideAllWarmBoot = 0x00000000, + .McClkenOverrideAllWarmBoot = 0x00000000, + .EmcCfgDigDllPeriodWarmBoot = 0x00000003, + .PmcVddpSel = 0x00000001, + .PmcVddpSelWait = 0x00000002, + .PmcDdrPwr = 0x0000000f, + .PmcDdrCfg = 0x20220100, + .PmcIoDpd3Req = 0x4bafffff, + .PmcIoDpd3ReqWait = 0x00000001, + .PmcIoDpd4ReqWait = 0x00000002, + .PmcRegShort = 0x00000000, + .PmcNoIoPower = 0x00000000, + .PmcDdrCntrlWait = 0x00000000, + .PmcDdrCntrl = 0x0007ff8b, + .EmcAcpdControl = 0x00000000, + .EmcSwizzleRank0Byte0 = 0x76342501, + .EmcSwizzleRank0Byte1 = 0x56243701, + .EmcSwizzleRank0Byte2 = 0x34267510, + .EmcSwizzleRank0Byte3 = 0x45763210, + .EmcSwizzleRank1Byte0 = 0x72345601, + .EmcSwizzleRank1Byte1 = 0x23456701, + .EmcSwizzleRank1Byte2 = 0x65427310, + .EmcSwizzleRank1Byte3 = 0x75432610, + .EmcTxdsrvttgen = 0x00000000, + .EmcDataBrlshft0 = 0x00249249, + .EmcDataBrlshft1 = 0x00249249, + .EmcDqsBrlshft0 = 0x00000000, + .EmcDqsBrlshft1 = 0x00000000, + .EmcCmdBrlshft0 = 0x00000000, + .EmcCmdBrlshft1 = 0x00000000, + .EmcCmdBrlshft2 = 0x00000012, + .EmcCmdBrlshft3 = 0x00000012, + .EmcQuseBrlshft0 = 0x00000000, + .EmcQuseBrlshft1 = 0x00000000, + .EmcQuseBrlshft2 = 0x00000000, + .EmcQuseBrlshft3 = 0x00000000, + .EmcDllCfg0 = 0x1f13412f, + .EmcDllCfg1 = 0x00010014, + .EmcPmcScratch1 = 0x4bafffff, + .EmcPmcScratch2 = 0x7fffffff, + .EmcPmcScratch3 = 0x4005d70b, + .EmcPmacroPadCfgCtrl = 0x00020000, + .EmcPmacroVttgenCtrl0 = 0x00030808, + .EmcPmacroVttgenCtrl1 = 0x00015000, + .EmcPmacroVttgenCtrl2 = 0x00101010, + .EmcPmacroBrickCtrlRfu1 = 0x00001600, + .EmcPmacroCmdBrickCtrlFdpd = 0x00000000, + .EmcPmacroBrickCtrlRfu2 = 0x00000000, + .EmcPmacroDataBrickCtrlFdpd = 0x00000000, + .EmcPmacroBgBiasCtrl0 = 0x00000030, + .EmcPmacroDataPadRxCtrl = 0x10050037, + .EmcPmacroCmdPadRxCtrl = 0x00000000, + .EmcPmacroDataRxTermMode = 0x00000010, + .EmcPmacroCmdRxTermMode = 0x00003000, + .EmcPmacroDataPadTxCtrl = 0x02000111, + .EmcPmacroCommonPadTxCtrl = 0x00000008, + .EmcPmacroCmdPadTxCtrl = 0x0a000000, + .EmcCfg3 = 0x00000040, + .EmcPmacroTxPwrd0 = 0x10000000, + .EmcPmacroTxPwrd1 = 0x08000000, + .EmcPmacroTxPwrd2 = 0x08000000, + .EmcPmacroTxPwrd3 = 0x08000000, + .EmcPmacroTxPwrd4 = 0x00000000, + .EmcPmacroTxPwrd5 = 0x00000000, + .EmcConfigSampleDelay = 0x00000020, + .EmcPmacroBrickMapping0 = 0x28190081, + .EmcPmacroBrickMapping1 = 0x44a53293, + .EmcPmacroBrickMapping2 = 0x76b76a5b, + .EmcPmacroTxSelClkSrc0 = 0x00000000, + .EmcPmacroTxSelClkSrc1 = 0x00000000, + .EmcPmacroTxSelClkSrc2 = 0x00000000, + .EmcPmacroTxSelClkSrc3 = 0x00000000, + .EmcPmacroTxSelClkSrc4 = 0x00000000, + .EmcPmacroTxSelClkSrc5 = 0x00000000, + .EmcPmacroDdllBypass = 0xefffefff, + .EmcPmacroDdllPwrd0 = 0xc0c0c0c0, + .EmcPmacroDdllPwrd1 = 0xc0c0c0c0, + .EmcPmacroDdllPwrd2 = 0xdcdcdcdc, + .EmcPmacroCmdCtrl0 = 0x0a0a0a0a, + .EmcPmacroCmdCtrl1 = 0x0a0a0a0a, + .EmcPmacroCmdCtrl2 = 0x0a0a0a0a, + .McEmemAdrCfg = 0x00000001, + .McEmemAdrCfgDev0 = 0x00070302, + .McEmemAdrCfgDev1 = 0x00070302, + .McEmemAdrCfgChannelMask = 0xffff2400, + .McEmemAdrCfgBankMask0 = 0x6e574400, + .McEmemAdrCfgBankMask1 = 0x39722800, + .McEmemAdrCfgBankMask2 = 0x4b9c1000, + .McEmemCfg = 0x00001000, + .McEmemArbCfg = 0x08000001, + .McEmemArbOutstandingReq = 0x8000004c, + .McEmemArbRefpbHpCtrl = 0x000a1020, + .McEmemArbRefpbBankCtrl = 0x80001028, + .McEmemArbTimingRcd = 0x00000001, + .McEmemArbTimingRp = 0x00000000, + .McEmemArbTimingRc = 0x00000003, + .McEmemArbTimingRas = 0x00000001, + .McEmemArbTimingFaw = 0x00000002, + .McEmemArbTimingRrd = 0x00000001, + .McEmemArbTimingRap2Pre = 0x00000002, + .McEmemArbTimingWap2Pre = 0x00000005, + .McEmemArbTimingR2R = 0x00000001, + .McEmemArbTimingW2W = 0x00000001, + .McEmemArbTimingR2W = 0x00000004, + .McEmemArbTimingW2R = 0x00000005, + .McEmemArbTimingRFCPB = 0x00000004, + .McEmemArbDaTurns = 0x02020000, + .McEmemArbDaCovers = 0x00030201, + .McEmemArbMisc0 = 0x71c30504, + .McEmemArbMisc1 = 0x70000f0f, + .McEmemArbMisc2 = 0x00000000, + .McEmemArbRing1Throttle = 0x001f0000, + .McEmemArbOverride = 0x10000000, + .McEmemArbOverride1 = 0x00000000, + .McEmemArbRsv = 0xff00ff00, + .McDaCfg0 = 0x00000001, + .McEmemArbTimingCcdmw = 0x00000008, + .McClkenOverride = 0x00008000, + .McStatControl = 0x00000000, + .McVideoProtectBom = 0xfff00000, + .McVideoProtectBomAdrHi = 0x00000000, + .McVideoProtectSizeMb = 0x00000000, + .McVideoProtectVprOverride = 0xe4bac343, + .McVideoProtectVprOverride1 = 0x00001ed3, + .McVideoProtectGpuOverride0 = 0x00000000, + .McVideoProtectGpuOverride1 = 0x00000000, + .McSecCarveoutBom = 0xfff00000, + .McSecCarveoutAdrHi = 0x00000000, + .McSecCarveoutSizeMb = 0x00000000, + .McVideoProtectWriteAccess = 0x00000000, + .McSecCarveoutProtectWriteAccess = 0x00000000, + .McGeneralizedCarveout1Bom = 0x00000000, + .McGeneralizedCarveout1BomHi = 0x00000000, + .McGeneralizedCarveout1Size128kb = 0x00000008, + .McGeneralizedCarveout1Access0 = 0x00000000, + .McGeneralizedCarveout1Access1 = 0x00000000, + .McGeneralizedCarveout1Access2 = 0x00300000, + .McGeneralizedCarveout1Access3 = 0x03000000, + .McGeneralizedCarveout1Access4 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout1ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout1Cfg0 = 0x04000c75, + .McGeneralizedCarveout2Bom = 0x00000000, + .McGeneralizedCarveout2BomHi = 0x00000000, + .McGeneralizedCarveout2Size128kb = 0x00000002, + .McGeneralizedCarveout2Access0 = 0x00000000, + .McGeneralizedCarveout2Access1 = 0x00000000, + .McGeneralizedCarveout2Access2 = 0x03000000, + .McGeneralizedCarveout2Access3 = 0x00000000, + .McGeneralizedCarveout2Access4 = 0x00000300, + .McGeneralizedCarveout2ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout2ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout2Cfg0 = 0x0440167c, + .McGeneralizedCarveout3Bom = 0x00000000, + .McGeneralizedCarveout3BomHi = 0x00000000, + .McGeneralizedCarveout3Size128kb = 0x00000000, + .McGeneralizedCarveout3Access0 = 0x00000000, + .McGeneralizedCarveout3Access1 = 0x00000000, + .McGeneralizedCarveout3Access2 = 0x03000000, + .McGeneralizedCarveout3Access3 = 0x00000000, + .McGeneralizedCarveout3Access4 = 0x00000300, + .McGeneralizedCarveout3ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout3ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout3Cfg0 = 0x04401e7c, + .McGeneralizedCarveout4Bom = 0x00000000, + .McGeneralizedCarveout4BomHi = 0x00000000, + .McGeneralizedCarveout4Size128kb = 0x00000008, + .McGeneralizedCarveout4Access0 = 0x00000000, + .McGeneralizedCarveout4Access1 = 0x00000000, + .McGeneralizedCarveout4Access2 = 0x00300000, + .McGeneralizedCarveout4Access3 = 0x00000000, + .McGeneralizedCarveout4Access4 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout4ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout4Cfg0 = 0x04002442, + .McGeneralizedCarveout5Bom = 0x00000000, + .McGeneralizedCarveout5BomHi = 0x00000000, + .McGeneralizedCarveout5Size128kb = 0x00000008, + .McGeneralizedCarveout5Access0 = 0x00000000, + .McGeneralizedCarveout5Access1 = 0x00000000, + .McGeneralizedCarveout5Access2 = 0x00300000, + .McGeneralizedCarveout5Access3 = 0x00000000, + .McGeneralizedCarveout5Access4 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess0 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess1 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess2 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess3 = 0x00000000, + .McGeneralizedCarveout5ForceInternalAccess4 = 0x00000000, + .McGeneralizedCarveout5Cfg0 = 0x04002c42, + .EmcCaTrainingEnable = 0x00000000, + .SwizzleRankByteEncode = 0x0000002e, + .BootRomPatchControl = 0x00000000, + .BootRomPatchData = 0x00000000, + .McMtsCarveoutBom = 0xfff00000, + .McMtsCarveoutAdrHi = 0x00000000, + .McMtsCarveoutSizeMb = 0x00000000, + .McMtsCarveoutRegCtrl = 0x00000000, +}, diff --git a/src/mainboard/google/smaug/bct/sdram-unused.inc b/src/mainboard/google/smaug/bct/sdram-unused.inc new file mode 100644 index 0000000..bef63dc --- /dev/null +++ b/src/mainboard/google/smaug/bct/sdram-unused.inc @@ -0,0 +1,4 @@ +{ /* dummy. */ + .MemoryType = NvBootMemoryType_Unused, + 0, +}, diff --git a/src/mainboard/google/smaug/bct/spi.cfg b/src/mainboard/google/smaug/bct/spi.cfg new file mode 100644 index 0000000..63e2750 --- /dev/null +++ b/src/mainboard/google/smaug/bct/spi.cfg @@ -0,0 +1,16 @@ +# Copyright 2015 Google Inc. All rights reserved. +# Distributed under the terms of the GNU General Public License v2 + +Version = 0x00210001; +BlockSize = 32768; +PageSize = 2048; +PartitionSize = 4194304; + +# +# T210 bct only supports one boot device +# +DevType[0] = NvBootDevType_Spi; +DeviceParam[0].SpiFlashParams.ReadCommandTypeFast = NV_FALSE; +DeviceParam[0].SpiFlashParams.ClockDivider = 0x16; +DeviceParam[0].SpiFlashParams.ClockSource = NvBootSpiClockSource_PllPOut0; +DeviceParam[0].SpiFlashParams.PageSize2kor16k = 0; diff --git a/src/mainboard/google/smaug/boardid.c b/src/mainboard/google/smaug/boardid.c new file mode 100644 index 0000000..525d1f1 --- /dev/null +++ b/src/mainboard/google/smaug/boardid.c @@ -0,0 +1,43 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <boardid.h> +#include <console/console.h> +#include <soc/sdram.h> +#include <stdlib.h> + +#include "gpio.h" + +uint8_t board_id(void) +{ + static int id = -1; + + if (id < 0) { + gpio_t gpio[] = {[1] = BD_ID1, [0] = BD_ID0}; /* ID0 is LSB */ + + id = gpio_base3_value(gpio, ARRAY_SIZE(gpio)); + } + + return id; +} + +uint32_t ram_code(void) +{ + return sdram_get_ram_code(); +} diff --git a/src/mainboard/google/smaug/bootblock.c b/src/mainboard/google/smaug/bootblock.c new file mode 100644 index 0000000..6b46c21 --- /dev/null +++ b/src/mainboard/google/smaug/bootblock.c @@ -0,0 +1,119 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <arch/io.h> +#include <bootblock_common.h> +#include <console/console.h> +#include <device/i2c.h> +#include <soc/addressmap.h> +#include <soc/clk_rst.h> +#include <soc/clock.h> +#include <soc/funitcfg.h> +#include <soc/nvidia/tegra/i2c.h> +#include <soc/padconfig.h> +#include <soc/spi.h> + +#include "pmic.h" + +/********************** PMIC **********************************/ +static const struct pad_config pmic_pads[] = { + PAD_CFG_SFIO(PWR_I2C_SCL, PINMUX_INPUT_ENABLE, I2CPMU), + PAD_CFG_SFIO(PWR_I2C_SDA, PINMUX_INPUT_ENABLE, I2CPMU), +}; + +/********************** SPI Flash *****************************/ +static const struct pad_config spiflash_pads[] = { + /* QSPI fLash: mosi, miso, clk, cs0, hold, wp */ + PAD_CFG_SFIO(QSPI_IO0, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, QSPI), + PAD_CFG_SFIO(QSPI_IO1, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, QSPI), + PAD_CFG_SFIO(QSPI_SCK, PINMUX_INPUT_ENABLE, QSPI), + PAD_CFG_SFIO(QSPI_CS_N, PINMUX_INPUT_ENABLE, QSPI), + PAD_CFG_SFIO(QSPI_IO2, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, QSPI), + PAD_CFG_SFIO(QSPI_IO3, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, QSPI), +}; + +/********************* TPM ************************************/ +static const struct pad_config tpm_pads[] = { + PAD_CFG_SFIO(GEN3_I2C_SCL, PINMUX_INPUT_ENABLE, I2C3), + PAD_CFG_SFIO(GEN3_I2C_SDA, PINMUX_INPUT_ENABLE, I2C3), +}; + +/********************* EC *************************************/ +static const struct pad_config ec_i2c_pads[] = { + PAD_CFG_SFIO(GEN2_I2C_SCL, PINMUX_INPUT_ENABLE, I2C2), + PAD_CFG_SFIO(GEN2_I2C_SDA, PINMUX_INPUT_ENABLE, I2C2), +}; + +/********************* Funits *********************************/ +static const struct funit_cfg funits[] = { + /* PMIC on I2C5 (PWR_I2C* pads) at 400kHz. */ + FUNIT_CFG(I2C5, PLLP, 400, pmic_pads, ARRAY_SIZE(pmic_pads)), + /* SPI flash at 24MHz on QSPI controller. */ + FUNIT_CFG(QSPI, PLLP, 24000, spiflash_pads, ARRAY_SIZE(spiflash_pads)), + /* TPM on I2C3 @ 400kHz */ + FUNIT_CFG(I2C3, PLLP, 400, tpm_pads, ARRAY_SIZE(tpm_pads)), + /* EC on I2C2 - pulled to 3.3V @ 100kHz */ + FUNIT_CFG(I2C2, PLLP, 100, ec_i2c_pads, ARRAY_SIZE(ec_i2c_pads)), +}; + +/********************* UART ***********************************/ +static const struct pad_config uart_console_pads[] = { + /* UARTA: tx, rx, rts, cts */ + PAD_CFG_SFIO(UART1_TX, PINMUX_PULL_NONE, UARTA), + PAD_CFG_SFIO(UART1_RX, PINMUX_INPUT_ENABLE | PINMUX_PULL_UP, UARTA), + PAD_CFG_SFIO(UART1_RTS, PINMUX_PULL_UP, UARTA), + PAD_CFG_SFIO(UART1_CTS, PINMUX_PULL_UP, UARTA), +}; + +void bootblock_mainboard_early_init(void) +{ + soc_configure_pads(uart_console_pads, ARRAY_SIZE(uart_console_pads)); +} + +static void set_clock_sources(void) +{ + /* UARTA gets PLLP, deactivate CLK_UART_DIV_OVERRIDE */ + write32(CLK_RST_REG(clk_src_uarta), PLLP << CLK_SOURCE_SHIFT); +} + +/********************* PADs ***********************************/ +static const struct pad_config padcfgs[] = { + /* Board build id bits 1:0 */ + PAD_CFG_GPIO_INPUT(GPIO_PK1, PINMUX_PULL_NONE), + PAD_CFG_GPIO_INPUT(GPIO_PK0, PINMUX_PULL_NONE), +}; + +void bootblock_mainboard_init(void) +{ + set_clock_sources(); + + /* Set up the pads required to load romstage. */ + soc_configure_pads(padcfgs, ARRAY_SIZE(padcfgs)); + soc_configure_funits(funits, ARRAY_SIZE(funits)); + + /* PMIC */ + i2c_init(I2CPWR_BUS); + pmic_init(I2CPWR_BUS); + + /* TPM */ + i2c_init(I2C3_BUS); + + /* EC */ + i2c_init(I2C2_BUS); +} diff --git a/src/mainboard/google/smaug/chromeos.c b/src/mainboard/google/smaug/chromeos.c new file mode 100644 index 0000000..51e6a22 --- /dev/null +++ b/src/mainboard/google/smaug/chromeos.c @@ -0,0 +1,107 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <boardid.h> +#include <boot/coreboot_tables.h> +#include <console/console.h> +#include <ec/google/chromeec/ec.h> +#include <ec/google/chromeec/ec_commands.h> +#include <string.h> +#include <vendorcode/google/chromeos/chromeos.h> + +#include "gpio.h" + +void fill_lb_gpios(struct lb_gpios *gpios) +{ + int count = 0; + + /* Write Protect: active low */ + gpios->gpios[count].port = WRITE_PROTECT_L; + gpios->gpios[count].polarity = ACTIVE_LOW; + gpios->gpios[count].value = gpio_get(WRITE_PROTECT_L); + strncpy((char *)gpios->gpios[count].name, "write protect", + GPIO_MAX_NAME_LENGTH); + count++; + + /* Recovery: active high */ + gpios->gpios[count].port = -1; + gpios->gpios[count].polarity = ACTIVE_HIGH; + gpios->gpios[count].value = get_recovery_mode_switch(); + strncpy((char *)gpios->gpios[count].name, "recovery", + GPIO_MAX_NAME_LENGTH); + count++; + + /* TODO(furquan): add lid switch */ + + /* Power: active low / high depending on board id */ + gpios->gpios[count].port = POWER_BUTTON; + gpios->gpios[count].polarity = ACTIVE_LOW; + gpios->gpios[count].value = -1; + strncpy((char *)gpios->gpios[count].name, "power", + GPIO_MAX_NAME_LENGTH); + count++; + + /* Developer: virtual GPIO active high */ + gpios->gpios[count].port = -1; + gpios->gpios[count].polarity = ACTIVE_HIGH; + gpios->gpios[count].value = get_developer_mode_switch(); + strncpy((char *)gpios->gpios[count].name, "developer", + GPIO_MAX_NAME_LENGTH); + count++; + + /* EC in RW: active high */ + gpios->gpios[count].port = EC_IN_RW; + gpios->gpios[count].polarity = ACTIVE_HIGH; + gpios->gpios[count].value = -1; + strncpy((char *)gpios->gpios[count].name, "EC in RW", + GPIO_MAX_NAME_LENGTH); + count++; + + /* Reset: active low (output) */ + gpios->gpios[count].port = AP_SYS_RESET_L; + gpios->gpios[count].polarity = ACTIVE_LOW; + gpios->gpios[count].value = -1; + strncpy((char *)gpios->gpios[count].name, "reset", + GPIO_MAX_NAME_LENGTH); + count++; + + gpios->size = sizeof(*gpios) + (count * sizeof(struct lb_gpio)); + gpios->count = count; + + printk(BIOS_ERR, "Added %d GPIOS size %d\n", count, gpios->size); +} + +int get_developer_mode_switch(void) +{ + return 0; +} + +int get_recovery_mode_switch(void) +{ + uint32_t ec_events; + + ec_events = google_chromeec_get_events_b(); + return !!(ec_events & + EC_HOST_EVENT_MASK(EC_HOST_EVENT_KEYBOARD_RECOVERY)); +} + +int get_write_protect_state(void) +{ + return !gpio_get(WRITE_PROTECT_L); +} diff --git a/src/mainboard/google/smaug/devicetree.cb b/src/mainboard/google/smaug/devicetree.cb new file mode 100644 index 0000000..65f02b2 --- /dev/null +++ b/src/mainboard/google/smaug/devicetree.cb @@ -0,0 +1,53 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2015 Google Inc. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc. +## + +chip soc/nvidia/tegra210 + register "spintable_addr" = "0x80000008" + + device cpu_cluster 0 on + device cpu 0 on end + end + + register "display_controller" = "TEGRA_ARM_DISPLAYA" + register "xres" = "2560" + register "yres" = "1800" + + # bits per pixel and color depth + register "framebuffer_bits_per_pixel" = "32" + register "color_depth" = "12" + + # framebuffer resolution + register "display_xres" = "1280" + register "display_yres" = "800" + + register "href_to_sync" = "1" + register "hfront_porch" = "80" + register "hsync_width" = "80" + register "hback_porch" = "80" + + register "vref_to_sync" = "1" + register "vfront_porch" = "4" + register "vsync_width" = "4" + register "vback_porch" = "4" + register "refresh" = "60" + + # use value from kernel driver + register "pixel_clock" = "304416000" + register "win_opt" = "DSI_ENABLE" +end diff --git a/src/mainboard/google/smaug/gpio.h b/src/mainboard/google/smaug/gpio.h new file mode 100644 index 0000000..2574c4f --- /dev/null +++ b/src/mainboard/google/smaug/gpio.h @@ -0,0 +1,72 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef __MAINBOARD_GOOGLE_SMAUG_GPIO_H__ +#define __MAINBOARD_GOOGLE_SMAUG_GPIO_H__ + +#include <gpio.h> +#include <base3.h> + +/* Board ID definitions. */ +enum { + BOARD_REV0 = BASE3(0, 0), + BOARD_REV1 = BASE3(0, 1), + BOARD_REV2 = BASE3(0, Z), + BOARD_REV3 = BASE3(1, 0), + BOARD_REV4 = BASE3(1, 1), + BOARD_REV5 = BASE3(1, Z), + BOARD_REV6 = BASE3(Z, 0), + BOARD_REV7 = BASE3(Z, 1), + BOARD_REV8 = BASE3(Z, Z), + + BOARD_ID_PROTO_0 = BOARD_REV0, + BOARD_ID_PROTO_1 = BOARD_REV1, + BOARD_ID_EVT = BOARD_REV2, + BOARD_ID_DVT = BOARD_REV3, + BOARD_ID_PVT = BOARD_REV4, + BOARD_ID_MP = BOARD_REV5, +}; + +enum { + /* Board ID related GPIOS. */ + BD_ID0 = GPIO(K0), + BD_ID1 = GPIO(K1), + + /* Warm reset */ + AP_SYS_RESET_L = GPIO(M5), + + /* Write Protect */ + SPI_1V8_WP_L = GPIO(K2), + WRITE_PROTECT_L = SPI_1V8_WP_L, + + /* Power button */ + BTN_AP_PWR_L = GPIO(X5), + POWER_BUTTON = BTN_AP_PWR_L, + + /* EC in RW signal */ + EC_IN_RW = GPIO(E3), + + /* Panel related GPIOs */ + LCD_EN = GPIO(V1), + LCD_RST_L = GPIO(V2), + EN_VDD18_LCD = GPIO(V3), + EN_VDD_LCD = GPIO(V4), +}; + +#endif /* __MAINBOARD_GOOGLE_SMAUG_GPIO_H__ */ diff --git a/src/mainboard/google/smaug/mainboard.c b/src/mainboard/google/smaug/mainboard.c new file mode 100644 index 0000000..b57e8b2 --- /dev/null +++ b/src/mainboard/google/smaug/mainboard.c @@ -0,0 +1,229 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <arch/io.h> +#include <arch/mmu.h> +#include <boot/coreboot_tables.h> +#include <device/device.h> +#include <device/i2c.h> +#include <soc/addressmap.h> +#include <soc/clk_rst.h> +#include <soc/clock.h> +#include <soc/funitcfg.h> +#include <soc/padconfig.h> +#include <soc/nvidia/tegra/i2c.h> +#include <soc/nvidia/tegra/pingroup.h> +#include <soc/nvidia/tegra/dc.h> +#include <soc/display.h> +#include <soc/mtc.h> +#include <soc/pmc.h> +#include <soc/power.h> + +#include <vboot_struct.h> +#include <vendorcode/google/chromeos/vboot_handoff.h> +#include <vendorcode/google/chromeos/vboot2/misc.h> +#include <delay.h> + +#include "gpio.h" +#include "pmic.h" + +static const struct pad_config padcfgs[] = { + PAD_CFG_GPIO_INPUT(USB_VBUS_EN1, PINMUX_PULL_NONE | PINMUX_PARKED | + PINMUX_INPUT_ENABLE | PINMUX_LPDR | PINMUX_IO_HV), +}; + +static const struct pad_config audio_codec_pads[] = { + /* GPIO_X1_AUD(BB3) is CODEC_RST_L and DMIC1_DAT(E1) is AUDIO_ENABLE */ + PAD_CFG_GPIO_OUT1(GPIO_X1_AUD, PINMUX_PULL_DOWN), + PAD_CFG_GPIO_OUT1(DMIC1_DAT, PINMUX_PULL_DOWN), +}; + +static const struct pad_config i2s1_pad[] = { + /* I2S1 */ + PAD_CFG_SFIO(DAP1_SCLK, PINMUX_INPUT_ENABLE, I2S1), + PAD_CFG_SFIO(DAP1_FS, PINMUX_INPUT_ENABLE, I2S1), + PAD_CFG_SFIO(DAP1_DOUT, PINMUX_INPUT_ENABLE, I2S1), + PAD_CFG_SFIO(DAP1_DIN, PINMUX_INPUT_ENABLE | PINMUX_TRISTATE, I2S1), + /* codec MCLK via AUD SFIO */ + PAD_CFG_SFIO(AUD_MCLK, PINMUX_PULL_NONE, AUD), +}; + +static const struct funit_cfg audio_funit[] = { + /* We need 1.5MHz for I2S1. So we use CLK_M */ + FUNIT_CFG(I2S1, CLK_M, 1500, i2s1_pad, ARRAY_SIZE(i2s1_pad)), +}; + +static const struct funit_cfg funits[] = { + FUNIT_CFG_USB(USBD), + FUNIT_CFG(SDMMC4, PLLP, 48000, NULL, 0), + /* I2C6 for audio, temp sensor, etc. Enable codec via GPIOs/muxes */ + FUNIT_CFG(I2C6, PLLP, 400, audio_codec_pads, ARRAY_SIZE(audio_codec_pads)), +}; + +/* Audio init: clocks and enables/resets */ +static void setup_audio(void) +{ + /* Audio codec (RT5677) uses 12MHz CLK1/EXTPERIPH1 */ + clock_configure_source(extperiph1, PLLP, 12000); + + /* Configure AUD_MCLK pad drive strength */ + write32((unsigned int *)TEGRA_APB_MISC_GP_BASE + 0xF4, + (0x10 << PINGROUP_DRVUP_SHIFT | 0x10 << PINGROUP_DRVDN_SHIFT)); + + /* Set up audio peripheral clocks/muxes */ + soc_configure_funits(audio_funit, ARRAY_SIZE(audio_funit)); + + /* Enable CLK1_OUT */ + clock_external_output(1); + + /* + * As per NVIDIA hardware team, we need to take ALL audio devices + * connected to AHUB (AUDIO, APB2APE, I2S, SPDIF, etc.) out of reset + * and clock-enabled, otherwise reading AHUB devices (in our case, + * I2S/APBIF/AUDIO<XBAR>) will hang. + */ + soc_configure_ape(); + clock_enable_audio(); +} + +static const struct pad_config lcd_gpio_padcfgs[] = { + /* LCD_EN */ + PAD_CFG_GPIO_OUT0(LCD_BL_EN, PINMUX_PULL_UP), + /* LCD_RST_L */ + PAD_CFG_GPIO_OUT0(LCD_RST, PINMUX_PULL_UP), + /* EN_VDD_LCD */ + PAD_CFG_GPIO_OUT0(LCD_GPIO2, PINMUX_PULL_NONE), + /* EN_VDD18_LCD */ + PAD_CFG_GPIO_OUT0(LCD_GPIO1, PINMUX_PULL_NONE), +}; + +static void configure_display_clocks(void) +{ + u32 lclks = CLK_L_HOST1X | CLK_L_DISP1; /* dc */ + u32 hclks = CLK_H_MIPI_CAL | CLK_H_DSI; /* mipi phy, mipi-dsi a */ + u32 uclks = CLK_U_DSIB; /* mipi-dsi b */ + u32 xclks = CLK_X_UART_FST_MIPI_CAL; /* uart_fst_mipi_cal */ + + clock_enable_clear_reset(lclks, hclks, uclks, 0, 0, xclks, 0); + + /* Give clocks time to stabilize. */ + udelay(IO_STABILIZATION_DELAY); + + /* CLK72MHZ_CLK_SRC */ + clock_configure_source(uart_fst_mipi_cal, PLLP_OUT3, 68000); +} + +static int enable_lcd_vdd(void) +{ + /* Set 1.20V to power AVDD_DSI_CSI */ + /* LD0: 1.20v CNF1: 0x0d */ + pmic_write_reg_77620(I2CPWR_BUS, MAX77620_CNFG1_L0_REG, 0xd0, 1); + + /* Enable VDD_LCD */ + gpio_set(EN_VDD_LCD, 1); + /* wait for 2ms */ + mdelay(2); + + /* Enable PP1800_LCDIO to panel */ + gpio_set(EN_VDD18_LCD, 1); + /* wait for 1ms */ + mdelay(1); + + /* Set panel EN and RST signals */ + gpio_set(LCD_EN, 1); /* enable */ + /* wait for min 10ms */ + mdelay(10); + gpio_set(LCD_RST_L, 1); /* clear reset */ + /* wait for min 3ms */ + mdelay(3); + + return 0; +} + +static int configure_display_blocks(void) +{ + /* enable display related clocks */ + configure_display_clocks(); + + /* configure panel gpio pads */ + soc_configure_pads(lcd_gpio_padcfgs, ARRAY_SIZE(lcd_gpio_padcfgs)); + + /* set and enable panel related vdd */ + if (enable_lcd_vdd()) + return -1; + + return 0; +} + +static void powergate_unused_partitions(void) +{ + static const uint32_t partitions[] = { + POWER_PARTID_PCX, + POWER_PARTID_SAX, + POWER_PARTID_XUSBA, + POWER_PARTID_XUSBB, + POWER_PARTID_XUSBC, + POWER_PARTID_NVDEC, + POWER_PARTID_NVJPG, + POWER_PARTID_DFD, + }; + + int i; + for (i = 0; i < ARRAY_SIZE(partitions); i++) + power_gate_partition(partitions[i]); +} + +static void mainboard_init(device_t dev) +{ + soc_configure_pads(padcfgs, ARRAY_SIZE(padcfgs)); + soc_configure_funits(funits, ARRAY_SIZE(funits)); + + /* I2C6 bus (audio, etc.) */ + soc_configure_i2c6pad(); + i2c_init(I2C6_BUS); + setup_audio(); + + /* if panel needs to bringup */ + if (!vboot_skip_display_init()) + configure_display_blocks(); + + powergate_unused_partitions(); +} + +void display_startup(device_t dev) +{ + dsi_display_startup(dev); +} + +static void mainboard_enable(device_t dev) +{ + dev->ops->init = &mainboard_init; +} + +struct chip_operations mainboard_ops = { + .name = "smaug", + .enable_dev = mainboard_enable, +}; + +void lb_board(struct lb_header *header) +{ + lb_table_add_serialno_from_vpd(header); + soc_add_mtc(header); +} diff --git a/src/mainboard/google/smaug/memlayout.ld b/src/mainboard/google/smaug/memlayout.ld new file mode 100644 index 0000000..a71dcb8 --- /dev/null +++ b/src/mainboard/google/smaug/memlayout.ld @@ -0,0 +1,6 @@ +#if IS_ENABLED(CONFIG_VBOOT2_VERIFY_FIRMWARE) +#include <soc/memlayout_vboot2.ld> +#else +#include <soc/memlayout.ld> +#endif + diff --git a/src/mainboard/google/smaug/pmic.c b/src/mainboard/google/smaug/pmic.c new file mode 100644 index 0000000..17d65e5 --- /dev/null +++ b/src/mainboard/google/smaug/pmic.c @@ -0,0 +1,112 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * Copyright (c) 2013-2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <boardid.h> +#include <console/console.h> +#include <delay.h> +#include <device/i2c.h> +#include <stdint.h> +#include <stdlib.h> + +#include "pmic.h" +#include "reset.h" + +enum { + MAX77620_I2C_ADDR = 0x3c, + MAX77621_CPU_I2C_ADDR = 0x1B, + MAX77621_GPU_I2C_ADDR = 0x1C, +}; + +struct max77620_init_reg { + u8 reg; + u8 val; + u8 delay; +}; + +static struct max77620_init_reg init_list[] = { + /* TODO */ +}; + +static void pmic_write_reg(unsigned bus, uint8_t chip, uint8_t reg, uint8_t val, + int delay) +{ + if (i2c_writeb(bus, chip, reg, val)) { + printk(BIOS_ERR, "%s: reg = 0x%02X, value = 0x%02X failed!\n", + __func__, reg, val); + /* Reset the SoC on any PMIC write error */ + cpu_reset(); + } else { + if (delay) + udelay(500); + } +} + +void pmic_write_reg_77620(unsigned bus, uint8_t reg, uint8_t val, + int delay) +{ + pmic_write_reg(bus, MAX77620_I2C_ADDR, reg, val, delay); +} + +static inline void pmic_write_reg_77621(unsigned bus, uint8_t reg, uint8_t val, + int delay) +{ + pmic_write_reg(bus, MAX77621_CPU_I2C_ADDR, reg, val, delay); +} + +static void pmic_slam_defaults(unsigned bus) +{ + int i; + for (i = 0; i < ARRAY_SIZE(init_list); i++) { + struct max77620_init_reg *reg = &init_list[i]; + pmic_write_reg_77620(bus, reg->reg, reg->val, reg->delay); + } +} + +void pmic_init(unsigned bus) +{ + /* Restore PMIC POR defaults, in case kernel changed 'em */ + pmic_slam_defaults(bus); + + /* Setup/Enable GPIO5 - VDD_CPU_REG_EN */ + pmic_write_reg_77620(bus, MAX77620_GPIO5_REG, 0x09, 1); + + /* Setup/Enable GPIO1 - VDD_HDMI_5V0_BST_EN -- ??? */ + pmic_write_reg_77620(bus, MAX77620_GPIO1_REG, 0x09, 1); + + /* GPIO 0,1,5,6,7 = GPIO, 2,3,4 = alt mode */ + pmic_write_reg_77620(bus, MAX77620_AME_GPIO, 0x1c, 1); + + /* Disable SD1 Remote Sense, Set SD1 for LPDDR4 to 1.125v? */ + pmic_write_reg_77620(bus, MAX77620_CNFG2SD_REG, 0x04, 1); + + pmic_write_reg_77620(bus, MAX77620_SD1_REG, 0x2a, 1); + + /* Max77621 VREG for CPU needs to be set to 0.85V as per SysEng */ + + /* Max77621 CPU VREG, register 0, 0.85V = 0x27(0.60625 + (39*6.25mV)) */ + pmic_write_reg_77621(bus, MAX77621_VOUT_REG, 0x27, 1); + pmic_write_reg_77621(bus, MAX77621_VOUT_REG, 0xa7, 1); + + /* Max77621 CPU VREG DVC, register 1, 0.85V = 0x27 */ + pmic_write_reg_77621(bus, MAX77621_VOUT_DVC_REG, 0x27, 1); + pmic_write_reg_77621(bus, MAX77621_VOUT_DVC_REG, 0xa7, 1); + + printk(BIOS_DEBUG, "PMIC init done\n"); +} diff --git a/src/mainboard/google/smaug/pmic.h b/src/mainboard/google/smaug/pmic.h new file mode 100644 index 0000000..d38b328 --- /dev/null +++ b/src/mainboard/google/smaug/pmic.h @@ -0,0 +1,79 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef __MAINBOARD_GOOGLE_FOSTER_PMIC_H__ +#define __MAINBOARD_GOOGLE_FOSTER_PMIC_H__ + +#define MAX77620_SD0_REG 0x16 +#define MAX77620_SD1_REG 0x17 +#define MAX77620_SD2_REG 0x18 +#define MAX77620_SD3_REG 0x19 +#define MAX77620_CNFG2SD_REG 0x22 + +#define MAX77620_CNFG1_L0_REG 0x23 +#define MAX77620_CNFG2_L0_REG 0x24 +#define MAX77620_CNFG1_L1_REG 0x25 +#define MAX77620_CNFG2_L1_REG 0x26 +#define MAX77620_CNFG1_L2_REG 0x27 +#define MAX77620_CNFG2_L2_REG 0x28 +#define MAX77620_CNFG1_L3_REG 0x29 +#define MAX77620_CNFG2_L3_REG 0x2A +#define MAX77620_CNFG1_L4_REG 0x2B +#define MAX77620_CNFG2_L4_REG 0x2C +#define MAX77620_CNFG1_L5_REG 0x2D +#define MAX77620_CNFG2_L5_REG 0x2E +#define MAX77620_CNFG1_L6_REG 0x2F +#define MAX77620_CNFG2_L6_REG 0x30 +#define MAX77620_CNFG1_L7_REG 0x31 +#define MAX77620_CNFG2_L7_REG 0x32 +#define MAX77620_CNFG1_L8_REG 0x33 +#define MAX77620_CNFG2_L8_REG 0x34 +#define MAX77620_CNFG3_LDO_REG 0x35 + +#define MAX77620_GPIO0_REG 0x36 +#define MAX77620_GPIO1_REG 0x37 +#define MAX77620_GPIO2_REG 0x38 +#define MAX77620_GPIO3_REG 0x39 +#define MAX77620_GPIO4_REG 0x3A +#define MAX77620_GPIO5_REG 0x3B +#define MAX77620_GPIO6_REG 0x3C +#define MAX77620_GPIO7_REG 0x3D +#define MAX77620_GPIO_PUE_GPIO 0x3E +#define MAX77620_GPIO_PDE_GPIO 0x3F + +#define MAX77620_AME_GPIO 0x40 +#define MAX77620_REG_ONOFF_CFG1 0x41 +#define MAX77620_REG_ONOFF_CFG2 0x42 + +#define MAX77620_CID0_REG 0x58 +#define MAX77620_CID1_REG 0x59 +#define MAX77620_CID2_REG 0x5A +#define MAX77620_CID3_REG 0x5B +#define MAX77620_CID4_REG 0x5C +#define MAX77620_CID5_REG 0x5D + +#define MAX77621_VOUT_REG 0x00 +#define MAX77621_VOUT_DVC_REG 0x01 + +void pmic_init(unsigned bus); +void pmic_write_reg_77620(unsigned bus, uint8_t reg, uint8_t val, + int delay); + +#endif /* __MAINBOARD_GOOGLE_FOSTER_PMIC_H__ */ diff --git a/src/mainboard/google/smaug/reset.c b/src/mainboard/google/smaug/reset.c new file mode 100644 index 0000000..9c72a77 --- /dev/null +++ b/src/mainboard/google/smaug/reset.c @@ -0,0 +1,30 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <arch/io.h> +#include <reset.h> + +#include "gpio.h" + +void hard_reset(void) +{ + gpio_output(AP_SYS_RESET_L, 0); + while (1) + ; +} diff --git a/src/mainboard/google/smaug/romstage.c b/src/mainboard/google/smaug/romstage.c new file mode 100644 index 0000000..5229a9f --- /dev/null +++ b/src/mainboard/google/smaug/romstage.c @@ -0,0 +1,57 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2015 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <delay.h> +#include <soc/addressmap.h> +#include <device/i2c.h> +#include <soc/clock.h> +#include <soc/funitcfg.h> +#include <soc/nvidia/tegra/i2c.h> +#include <soc/padconfig.h> +#include <soc/romstage.h> + +#include "gpio.h" +#include "pmic.h" + +static const struct pad_config padcfgs[] = { + /* AP_SYS_RESET_L - active low*/ + PAD_CFG_GPIO_OUT1(SDMMC1_DAT0, PINMUX_PULL_UP), + /* WP_L - active low */ + PAD_CFG_GPIO_INPUT(GPIO_PK2, PINMUX_PULL_NONE), + /* BTN_AP_PWR_L - active low */ + PAD_CFG_GPIO_INPUT(BUTTON_POWER_ON, PINMUX_PULL_UP), + /* BTN_AP_VOLD_L - active low */ + PAD_CFG_GPIO_INPUT(BUTTON_VOL_DOWN, PINMUX_PULL_UP), + /* BTN_AP_VOLU_L - active low */ + PAD_CFG_GPIO_INPUT(SDMMC1_DAT1, PINMUX_PULL_UP), +}; + +void romstage_mainboard_init(void) +{ + soc_configure_pads(padcfgs, ARRAY_SIZE(padcfgs)); +} + +void mainboard_configure_pmc(void) +{ +} + +void mainboard_enable_vdd_cpu(void) +{ + /* VDD_CPU is already enabled in bootblock. */ +} diff --git a/src/mainboard/google/smaug/sdram_configs.c b/src/mainboard/google/smaug/sdram_configs.c new file mode 100644 index 0000000..91e5aef --- /dev/null +++ b/src/mainboard/google/smaug/sdram_configs.c @@ -0,0 +1,54 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <soc/sdram_configs.h> + +static struct sdram_params sdram_configs[] = { +#include "bct/sdram-unused.inc" /* ram_code = 0000 */ +#include "bct/sdram-unused.inc" /* ram_code = 0001 */ +#include "bct/sdram-samsung-3GB-204.inc" /* ram_code = 0010 */ +#include "bct/sdram-samsung-4GB-204.inc" /* ram_code = 0011 */ +#include "bct/sdram-unused.inc" /* ram_code = 0100 */ +#include "bct/sdram-unused.inc" /* ram_code = 0101 */ +#include "bct/sdram-unused.inc" /* ram_code = 0110 */ +#include "bct/sdram-unused.inc" /* ram_code = 0111 */ +#include "bct/sdram-unused.inc" /* ram_code = 1000 */ +#include "bct/sdram-unused.inc" /* ram_code = 1001 */ +#include "bct/sdram-unused.inc" /* ram_code = 1010 */ +#include "bct/sdram-unused.inc" /* ram_code = 1011 */ +#include "bct/sdram-unused.inc" /* ram_code = 1100 */ +#include "bct/sdram-unused.inc" /* ram_code = 1101 */ +#include "bct/sdram-unused.inc" /* ram_code = 1110 */ +#include "bct/sdram-unused.inc" /* ram_code = 1111 */ +}; + +const struct sdram_params *get_sdram_config() +{ + uint32_t ramcode = sdram_get_ram_code(); + /* + * If we need to apply some special hacks to RAMCODE mapping (ex, by + * board_id), do that now. + */ + + printk(BIOS_SPEW, "%s: RAMCODE=%d\n", __func__, ramcode); + if (ramcode >= sizeof(sdram_configs) / sizeof(sdram_configs[0]) || + sdram_configs[ramcode].MemoryType == NvBootMemoryType_Unused) { + die("Invalid RAMCODE."); + } + + return &sdram_configs[ramcode]; +}
