Attention is currently required from: Michał Kopeć. Hello build bot (Jenkins), Arthur Heymans,
https://review.coreboot.org/c/coreboot/+/59870
Change subject: northbridge/amd/pi/00730F01/northbridge.c: remove unneded global variables ......................................................................
Remove global variables `sblink` and `node_nums` and add function `get_node_nums()` which reads from PCI config once and returns a static variable.
TEST=Boot Debian 11 on PC Engines apu3
Signed-off-by: Michał Kopeć michal.kopec@3mdeb.com Change-Id: I20a47f967093ef91355377c164656cabadc30fe6 --- M src/northbridge/amd/pi/00730F01/northbridge.c 1 file changed, 23 insertions(+), 24 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/70/59870/6
