Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6277
commit 7735d8dbd32abe4726578004adcb71c7c1d047fd Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Tue Jul 15 14:38:51 2014 +0300
AMD get_bus_conf(): Drop bus_type array
Only ever used as lvalue, so no point creating the array.
Change-Id: I6699dfae9377a895e9bc4a52579d00ddcfa60a9f Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/mainboard/advansus/a785e-i/get_bus_conf.c | 13 +------------ src/mainboard/advansus/a785e-i/mb_sysconf.h | 1 - src/mainboard/advansus/a785e-i/mptable.c | 1 - src/mainboard/amd/bimini_fam10/get_bus_conf.c | 15 +-------------- src/mainboard/amd/bimini_fam10/mb_sysconf.h | 1 - src/mainboard/amd/bimini_fam10/mptable.c | 1 - src/mainboard/amd/dinar/get_bus_conf.c | 13 +------------ src/mainboard/amd/dinar/mptable.c | 1 - src/mainboard/amd/inagua/get_bus_conf.c | 13 +------------ src/mainboard/amd/inagua/mptable.c | 1 - src/mainboard/amd/mahogany_fam10/mb_sysconf.h | 1 - src/mainboard/amd/olivehill/get_bus_conf.c | 12 +----------- src/mainboard/amd/olivehill/mptable.c | 1 - src/mainboard/amd/parmer/get_bus_conf.c | 11 +---------- src/mainboard/amd/parmer/mptable.c | 1 - src/mainboard/amd/persimmon/get_bus_conf.c | 14 +------------- src/mainboard/amd/persimmon/mptable.c | 1 - src/mainboard/amd/south_station/get_bus_conf.c | 13 +------------ src/mainboard/amd/south_station/mptable.c | 1 - src/mainboard/amd/thatcher/get_bus_conf.c | 12 +----------- src/mainboard/amd/thatcher/mptable.c | 1 - src/mainboard/amd/tilapia_fam10/mb_sysconf.h | 1 - src/mainboard/amd/torpedo/get_bus_conf.c | 12 +----------- src/mainboard/amd/torpedo/mptable.c | 1 - src/mainboard/amd/union_station/get_bus_conf.c | 11 +---------- src/mainboard/amd/union_station/mptable.c | 1 - src/mainboard/asrock/e350m1/get_bus_conf.c | 16 +--------------- src/mainboard/asrock/e350m1/mptable.c | 1 - src/mainboard/asrock/imb-a180/get_bus_conf.c | 12 +----------- src/mainboard/asrock/imb-a180/mptable.c | 1 - src/mainboard/asus/f2a85-m/get_bus_conf.c | 11 +---------- src/mainboard/asus/f2a85-m/mptable.c | 1 - src/mainboard/asus/m4a78-em/mb_sysconf.h | 1 - src/mainboard/asus/m4a785-m/mb_sysconf.h | 1 - src/mainboard/asus/m5a88-v/get_bus_conf.c | 14 +------------- src/mainboard/asus/m5a88-v/mb_sysconf.h | 1 - src/mainboard/asus/m5a88-v/mptable.c | 1 - src/mainboard/avalue/eax-785e/get_bus_conf.c | 14 +------------- src/mainboard/avalue/eax-785e/mb_sysconf.h | 1 - src/mainboard/avalue/eax-785e/mptable.c | 1 - src/mainboard/gigabyte/ma785gm/mb_sysconf.h | 1 - src/mainboard/gizmosphere/gizmo/get_bus_conf.c | 13 +------------ src/mainboard/gizmosphere/gizmo/mptable.c | 1 - src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c | 13 +------------ src/mainboard/hp/pavilion_m6_1035dx/mptable.c | 1 - src/mainboard/iei/kino-780am2-fam10/mb_sysconf.h | 1 - src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c | 15 +-------------- src/mainboard/jetway/nf81-t56n-lf/mptable.c | 1 - src/mainboard/lippert/frontrunner-af/get_bus_conf.c | 14 +------------- src/mainboard/lippert/frontrunner-af/mptable.c | 1 - src/mainboard/lippert/toucan-af/get_bus_conf.c | 15 +-------------- src/mainboard/lippert/toucan-af/mptable.c | 1 - src/mainboard/supermicro/h8qgi/get_bus_conf.c | 13 +------------ src/mainboard/supermicro/h8qgi/mptable.c | 1 - src/mainboard/supermicro/h8scm/get_bus_conf.c | 13 +------------ src/mainboard/supermicro/h8scm/mptable.c | 1 - src/mainboard/supermicro/h8scm_fam10/get_bus_conf.c | 12 +----------- src/mainboard/supermicro/h8scm_fam10/mb_sysconf.h | 1 - src/mainboard/tyan/s8226/get_bus_conf.c | 13 +------------ src/mainboard/tyan/s8226/mptable.c | 1 - 60 files changed, 25 insertions(+), 337 deletions(-)
diff --git a/src/mainboard/advansus/a785e-i/get_bus_conf.c b/src/mainboard/advansus/a785e-i/get_bus_conf.c index 0feeed5..80e1d3e 100644 --- a/src/mainboard/advansus/a785e-i/get_bus_conf.c +++ b/src/mainboard/advansus/a785e-i/get_bus_conf.c @@ -56,7 +56,6 @@ u32 hcdnx[] = { 0x20202020, };
-u32 bus_type[256];
u32 sbdn_rs780; u32 sbdn_sb800; @@ -69,7 +68,7 @@ void get_bus_conf(void) { u32 apicid_base; device_t dev; - int i, j; + int i;
if (get_bus_conf_done == 1) return; /* do it only once */ @@ -92,16 +91,11 @@ void get_bus_conf(void) bus_rs780[i] = 0; }
- for (i = 0; i < 256; i++) { - bus_type[i] = 0; /* default ISA bus. */ - }
- bus_type[0] = 1; /* pci */
bus_rs780[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_sb800[0] = bus_rs780[0];
- bus_type[bus_rs780[0]] = 1;
/* sb800 */ dev = dev_find_slot(bus_sb800[0], PCI_DEVFN(sbdn_sb800 + 0x14, 4)); @@ -109,8 +103,6 @@ void get_bus_conf(void) bus_sb800[1] = pci_read_config8(dev, PCI_SECONDARY_BUS); bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_sb800[1]; j < bus_isa; j++) - bus_type[j] = 1; }
for (i = 0; i < 4; i++) { @@ -121,8 +113,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* rs780 */ for (i = 1; i < ARRAY_SIZE(bus_rs780); i++) { @@ -132,7 +122,6 @@ void get_bus_conf(void) if(255 != bus_rs780[i]) { bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - bus_type[bus_rs780[i]] = 1; /* PCI bus. */ } } } diff --git a/src/mainboard/advansus/a785e-i/mb_sysconf.h b/src/mainboard/advansus/a785e-i/mb_sysconf.h index 289b094..8a693fd 100644 --- a/src/mainboard/advansus/a785e-i/mb_sysconf.h +++ b/src/mainboard/advansus/a785e-i/mb_sysconf.h @@ -37,7 +37,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/advansus/a785e-i/mptable.c b/src/mainboard/advansus/a785e-i/mptable.c index 73ada4d..f60b6b0 100644 --- a/src/mainboard/advansus/a785e-i/mptable.c +++ b/src/mainboard/advansus/a785e-i/mptable.c @@ -30,7 +30,6 @@ extern int bus_isa; extern u8 bus_rs780[11]; extern u8 bus_sb800[6]; extern u32 apicid_sb800; -extern u32 bus_type[256]; extern u32 sbdn_rs780; extern u32 sbdn_sb800;
diff --git a/src/mainboard/amd/bimini_fam10/get_bus_conf.c b/src/mainboard/amd/bimini_fam10/get_bus_conf.c index c4924d4..f7c55143 100644 --- a/src/mainboard/amd/bimini_fam10/get_bus_conf.c +++ b/src/mainboard/amd/bimini_fam10/get_bus_conf.c @@ -53,7 +53,6 @@ u32 hcdnx[] = { 0x20202020, };
-u32 bus_type[256];
u32 sbdn_rs780; u32 sbdn_sb800; @@ -66,7 +65,7 @@ void get_bus_conf(void) { u32 apicid_base; device_t dev; - int i, j; + int i;
if (get_bus_conf_done == 1) return; /* do it only once */ @@ -90,25 +89,16 @@ void get_bus_conf(void) bus_rs780[i] = 0; }
- for (i = 0; i < 256; i++) { - bus_type[i] = 0; /* default ISA bus. */ - } - - bus_type[0] = 1; /* pci */
- bus_type[bus_rs780[0]] = 1; - /* sb800 */ dev = dev_find_slot(bus_sb800[0], PCI_DEVFN(sbdn_sb800 + 0x14, 4)); if (dev) { bus_sb800[1] = pci_read_config8(dev, PCI_SECONDARY_BUS); bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_sb800[1]; j < bus_isa; j++) - bus_type[j] = 1; }
for (i = 0; i < 4; i++) { @@ -119,8 +109,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* rs780 */ for (i = 1; i < ARRAY_SIZE(bus_rs780); i++) { @@ -130,7 +118,6 @@ void get_bus_conf(void) if(255 != bus_rs780[i]) { bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - bus_type[bus_rs780[i]] = 1; /* PCI bus. */ } } } diff --git a/src/mainboard/amd/bimini_fam10/mb_sysconf.h b/src/mainboard/amd/bimini_fam10/mb_sysconf.h index ed04de6..8148093 100644 --- a/src/mainboard/amd/bimini_fam10/mb_sysconf.h +++ b/src/mainboard/amd/bimini_fam10/mb_sysconf.h @@ -37,7 +37,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/amd/bimini_fam10/mptable.c b/src/mainboard/amd/bimini_fam10/mptable.c index 792fa41..bbdb95d 100644 --- a/src/mainboard/amd/bimini_fam10/mptable.c +++ b/src/mainboard/amd/bimini_fam10/mptable.c @@ -30,7 +30,6 @@ extern int bus_isa; extern u8 bus_rs780[11]; extern u8 bus_sb800[6]; extern u32 apicid_sb800; -extern u32 bus_type[256]; extern u32 sbdn_rs780; extern u32 sbdn_sb800;
diff --git a/src/mainboard/amd/dinar/get_bus_conf.c b/src/mainboard/amd/dinar/get_bus_conf.c index d62e111..fcd4684 100644 --- a/src/mainboard/amd/dinar/get_bus_conf.c +++ b/src/mainboard/amd/dinar/get_bus_conf.c @@ -51,15 +51,13 @@ u32 hcdnx[] = { 0x20202020, };
-u32 bus_type[256]; - u32 sbdn_sb700; u32 sbdn_rd890;
void get_bus_conf(void) { device_t dev; - int i, j; + int i;
printk(BIOS_DEBUG, "Mainboard - Get_bus_conf.c - get_bus_conf - Start.\n");
@@ -72,12 +70,6 @@ void get_bus_conf(void) bus_rd890[i] = 0; }
- for (i = 0; i < 256; i++) { - bus_type[i] = 0; /* default ISA bus. */ - } - - - bus_type[0] = 1; /* pci */
bus_rd890[0] = (pci1234x[0] >> 16) & 0xff; bus_sb700[0] = bus_rd890[0]; @@ -92,8 +84,6 @@ void get_bus_conf(void)
bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_sb700[1]; j < bus_isa; j++) - bus_type[j] = 1; }
/* rd890 */ @@ -104,7 +94,6 @@ void get_bus_conf(void) if(255 != bus_rd890[i]) { bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - bus_type[bus_rd890[i]] = 1; /* PCI bus. */ } } } diff --git a/src/mainboard/amd/dinar/mptable.c b/src/mainboard/amd/dinar/mptable.c index 65304e1..671cd37 100644 --- a/src/mainboard/amd/dinar/mptable.c +++ b/src/mainboard/amd/dinar/mptable.c @@ -30,7 +30,6 @@
extern u8 bus_rd890[14]; extern u8 bus_sb700[2]; -extern u32 bus_type[256]; extern u32 sbdn_rd890; extern u32 sbdn_sb700;
diff --git a/src/mainboard/amd/inagua/get_bus_conf.c b/src/mainboard/amd/inagua/get_bus_conf.c index be113b3..2c38bdd 100644 --- a/src/mainboard/amd/inagua/get_bus_conf.c +++ b/src/mainboard/amd/inagua/get_bus_conf.c @@ -43,7 +43,6 @@ u32 pci1234x[] = { 0x0000ff0, };
-u32 bus_type[256]; u32 sbdn_sb800;
void get_bus_conf(void) @@ -51,18 +50,13 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_sb800 = 0;
memset(bus_sb800, 0, sizeof(bus_sb800));
// bus_sb800[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_sb800[0] = (pci1234x[0] >> 16) & 0xff; @@ -75,8 +69,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -88,9 +80,6 @@ void get_bus_conf(void) } }
- for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1; - /* I/O APICs: APIC ID Version State Address */ bus_isa = 10; apicid_base = CONFIG_MAX_CPUS; diff --git a/src/mainboard/amd/inagua/mptable.c b/src/mainboard/amd/inagua/mptable.c index d2f8506..898b597 100644 --- a/src/mainboard/amd/inagua/mptable.c +++ b/src/mainboard/amd/inagua/mptable.c @@ -31,7 +31,6 @@ extern u8 bus_sb800[6];
-extern u32 bus_type[256]; extern u32 sbdn_sb800;
u8 intr_data[] = { diff --git a/src/mainboard/amd/mahogany_fam10/mb_sysconf.h b/src/mainboard/amd/mahogany_fam10/mb_sysconf.h index 768ffd1..25d63d5 100644 --- a/src/mainboard/amd/mahogany_fam10/mb_sysconf.h +++ b/src/mainboard/amd/mahogany_fam10/mb_sysconf.h @@ -38,7 +38,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/amd/olivehill/get_bus_conf.c b/src/mainboard/amd/olivehill/get_bus_conf.c index f1643a4..3aeeb90 100644 --- a/src/mainboard/amd/olivehill/get_bus_conf.c +++ b/src/mainboard/amd/olivehill/get_bus_conf.c @@ -45,7 +45,6 @@ u32 pci1234x[] = { 0x0000ff0, };
-u32 bus_type[256]; u32 sbdn_yangtze;
@@ -55,7 +54,7 @@ void get_bus_conf(void) u32 value;
dev = dev_find_slot(0, PCI_DEVFN(0, 0)); /* clear IoapicSbFeatureEn */ @@ -72,11 +71,6 @@ void get_bus_conf(void)
memset(bus_yangtze, 0, sizeof(bus_yangtze));
// bus_yangtze[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_yangtze[0] = (pci1234x[0] >> 16) & 0xff; @@ -89,8 +83,6 @@ void get_bus_conf(void)
bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_yangtze[1]; j < bus_isa; j++) - bus_type[j] = 1; }
for (i = 0; i < 4; i++) { @@ -101,8 +93,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_yangtze[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ bus_isa = 10; diff --git a/src/mainboard/amd/olivehill/mptable.c b/src/mainboard/amd/olivehill/mptable.c index 3ccb910..79750e9 100644 --- a/src/mainboard/amd/olivehill/mptable.c +++ b/src/mainboard/amd/olivehill/mptable.c @@ -31,7 +31,6 @@ #define IO_APIC_ID CONFIG_MAX_CPUS extern u8 bus_yangtze[6];
-extern u32 bus_type[256]; extern u32 sbdn_yangtze; extern u32 apicid_yangtze;
diff --git a/src/mainboard/amd/parmer/get_bus_conf.c b/src/mainboard/amd/parmer/get_bus_conf.c index 4c4777f..c792887 100644 --- a/src/mainboard/amd/parmer/get_bus_conf.c +++ b/src/mainboard/amd/parmer/get_bus_conf.c @@ -45,7 +45,6 @@ u32 pci1234x[] = { 0x0000ff0, };
-u32 bus_type[256]; u32 sbdn_hudson;
@@ -54,7 +53,7 @@ void get_bus_conf(void) u32 apicid_base;
@@ -62,11 +61,7 @@ void get_bus_conf(void)
memset(bus_hudson, 0, sizeof(bus_hudson));
bus_hudson[0] = (pci1234x[0] >> 16) & 0xff;
@@ -78,8 +73,6 @@ void get_bus_conf(void)
bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_hudson[1]; j < bus_isa; j++) - bus_type[j] = 1; }
for (i = 0; i < 4; i++) { @@ -90,8 +83,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_hudson[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ bus_isa = 10; diff --git a/src/mainboard/amd/parmer/mptable.c b/src/mainboard/amd/parmer/mptable.c index 0980063..b66cb57 100644 --- a/src/mainboard/amd/parmer/mptable.c +++ b/src/mainboard/amd/parmer/mptable.c @@ -31,7 +31,6 @@ #define IO_APIC_ID CONFIG_MAX_CPUS extern u8 bus_hudson[6];
-extern u32 bus_type[256]; extern u32 sbdn_hudson; extern u32 apicid_hudson;
diff --git a/src/mainboard/amd/persimmon/get_bus_conf.c b/src/mainboard/amd/persimmon/get_bus_conf.c index b31f687..995cb42 100644 --- a/src/mainboard/amd/persimmon/get_bus_conf.c +++ b/src/mainboard/amd/persimmon/get_bus_conf.c @@ -45,7 +45,6 @@ u32 pci1234x[] = { 0x0000ff0, };
void get_bus_conf(void) @@ -53,19 +52,13 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_sb800 = 0;
- for (i = 0; i < 256; i++) { - bus_type[i] = 0; /* default ISA bus. */ - } - - bus_type[0] = 1; /* pci */ - // bus_sb800[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_sb800[0] = (pci1234x[0] >> 16) & 0xff;
@@ -77,8 +70,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -90,9 +81,6 @@ void get_bus_conf(void) } }
/* I/O APICs: APIC ID Version State Address */ bus_isa = 10; diff --git a/src/mainboard/amd/persimmon/mptable.c b/src/mainboard/amd/persimmon/mptable.c index 780bb2c..e9e208e 100644 --- a/src/mainboard/amd/persimmon/mptable.c +++ b/src/mainboard/amd/persimmon/mptable.c @@ -35,7 +35,6 @@ extern u8 bus_sb800[6]; extern u32 apicid_sb800; extern u32 apicver_sb800;
static void *smp_write_config_table(void *v) diff --git a/src/mainboard/amd/south_station/get_bus_conf.c b/src/mainboard/amd/south_station/get_bus_conf.c index 99b3880..b95ef1c 100644 --- a/src/mainboard/amd/south_station/get_bus_conf.c +++ b/src/mainboard/amd/south_station/get_bus_conf.c @@ -43,7 +43,6 @@ u32 pci1234x[] = { 0x0000ff0, };
void get_bus_conf(void) @@ -51,19 +50,13 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_sb800 = 0;
// bus_sb800[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_sb800[0] = (pci1234x[0] >> 16) & 0xff; @@ -78,8 +71,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -90,8 +81,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ diff --git a/src/mainboard/amd/south_station/mptable.c b/src/mainboard/amd/south_station/mptable.c index f266b4f..591ece5 100644 --- a/src/mainboard/amd/south_station/mptable.c +++ b/src/mainboard/amd/south_station/mptable.c @@ -31,7 +31,6 @@ extern u8 bus_sb800[6];
u8 intr_data[] = { diff --git a/src/mainboard/amd/thatcher/get_bus_conf.c b/src/mainboard/amd/thatcher/get_bus_conf.c index d4a5654..577ec9f 100644 --- a/src/mainboard/amd/thatcher/get_bus_conf.c +++ b/src/mainboard/amd/thatcher/get_bus_conf.c @@ -45,7 +45,6 @@ u32 pci1234x[] = { 0x0000ff0, };
@@ -54,17 +53,12 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_hudson = 0;
@@ -76,8 +70,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -88,8 +80,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_hudson[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ bus_isa = 10; diff --git a/src/mainboard/amd/thatcher/mptable.c b/src/mainboard/amd/thatcher/mptable.c index 3269089..dfb3b4f 100644 --- a/src/mainboard/amd/thatcher/mptable.c +++ b/src/mainboard/amd/thatcher/mptable.c @@ -31,7 +31,6 @@ #define IO_APIC_ID CONFIG_MAX_CPUS extern u8 bus_hudson[6];
diff --git a/src/mainboard/amd/tilapia_fam10/mb_sysconf.h b/src/mainboard/amd/tilapia_fam10/mb_sysconf.h index 768ffd1..25d63d5 100644 --- a/src/mainboard/amd/tilapia_fam10/mb_sysconf.h +++ b/src/mainboard/amd/tilapia_fam10/mb_sysconf.h @@ -38,7 +38,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/amd/torpedo/get_bus_conf.c b/src/mainboard/amd/torpedo/get_bus_conf.c index b7895e4..1e962e8 100644 --- a/src/mainboard/amd/torpedo/get_bus_conf.c +++ b/src/mainboard/amd/torpedo/get_bus_conf.c @@ -49,14 +49,13 @@ u32 hcdnx[] = { 0x20202020, };
-u32 bus_type[256];
u32 sbdn_sb900;
printk(BIOS_DEBUG, "Mainboard - %s - %s - Start.\n", __FILE__, __func__);
@@ -64,11 +63,6 @@ void get_bus_conf(void)
memset(bus_sb900, 0, sizeof(bus_sb900));
bus_sb900[0] = (pci1234x[0] >> 16) & 0xff;
@@ -79,8 +73,6 @@ void get_bus_conf(void) bus_sb900[1] = pci_read_config8(dev, PCI_SECONDARY_BUS); bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_sb900[1]; j < bus_isa; j++) - bus_type[j] = 1; }
for (i = 0; i < 4; i++) { @@ -93,8 +85,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sb900[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ bus_isa = 10; diff --git a/src/mainboard/amd/torpedo/mptable.c b/src/mainboard/amd/torpedo/mptable.c index ae00cf7..6bc1cb3 100644 --- a/src/mainboard/amd/torpedo/mptable.c +++ b/src/mainboard/amd/torpedo/mptable.c @@ -33,7 +33,6 @@ extern u8 bus_sb900[6];
-extern u32 bus_type[256]; extern u32 sbdn_sb900; u32 apicid_sb900;
diff --git a/src/mainboard/amd/union_station/get_bus_conf.c b/src/mainboard/amd/union_station/get_bus_conf.c index 99b3880..632fede 100644 --- a/src/mainboard/amd/union_station/get_bus_conf.c +++ b/src/mainboard/amd/union_station/get_bus_conf.c @@ -43,7 +43,6 @@ u32 pci1234x[] = { 0x0000ff0, };
void get_bus_conf(void) @@ -51,19 +50,15 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_sb800 = 0;
// bus_sb800[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_sb800[0] = (pci1234x[0] >> 16) & 0xff; @@ -78,8 +73,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -90,8 +83,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ diff --git a/src/mainboard/amd/union_station/mptable.c b/src/mainboard/amd/union_station/mptable.c index f266b4f..591ece5 100644 --- a/src/mainboard/amd/union_station/mptable.c +++ b/src/mainboard/amd/union_station/mptable.c @@ -31,7 +31,6 @@ extern u8 bus_sb800[6];
u8 intr_data[] = { diff --git a/src/mainboard/asrock/e350m1/get_bus_conf.c b/src/mainboard/asrock/e350m1/get_bus_conf.c index 99b3880..d3c2b12 100644 --- a/src/mainboard/asrock/e350m1/get_bus_conf.c +++ b/src/mainboard/asrock/e350m1/get_bus_conf.c @@ -43,7 +43,6 @@ u32 pci1234x[] = { 0x0000ff0, };
void get_bus_conf(void) @@ -51,35 +50,24 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_sb800 = 0;
- for (i = 0; i < 256; i++) { - bus_type[i] = 0; /* default ISA bus. */ - } - - - bus_type[0] = 1; /* pci */ - // bus_sb800[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_sb800[0] = (pci1234x[0] >> 16) & 0xff;
- - if (dev) { bus_sb800[1] = pci_read_config8(dev, PCI_SECONDARY_BUS);
for (i = 0; i < 4; i++) { @@ -90,8 +78,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ diff --git a/src/mainboard/asrock/e350m1/mptable.c b/src/mainboard/asrock/e350m1/mptable.c index 3402da1..689b2b9 100644 --- a/src/mainboard/asrock/e350m1/mptable.c +++ b/src/mainboard/asrock/e350m1/mptable.c @@ -32,7 +32,6 @@ extern u8 bus_sb800[6];
u8 intr_data[] = { diff --git a/src/mainboard/asrock/imb-a180/get_bus_conf.c b/src/mainboard/asrock/imb-a180/get_bus_conf.c index eecffb5..bc93c54 100644 --- a/src/mainboard/asrock/imb-a180/get_bus_conf.c +++ b/src/mainboard/asrock/imb-a180/get_bus_conf.c @@ -42,7 +42,6 @@ u32 pci1234x[] = { 0x0000ff0, };
void get_bus_conf(void) @@ -51,7 +50,7 @@ void get_bus_conf(void) u32 value;
dev = dev_find_slot(0, PCI_DEVFN(0, 0)); /* clear IoapicSbFeatureEn */ pci_write_config32(dev, 0xF8, 0); @@ -67,11 +66,6 @@ void get_bus_conf(void)
// bus_yangtze[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_yangtze[0] = (pci1234x[0] >> 16) & 0xff; @@ -84,8 +78,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -96,8 +88,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_yangtze[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ bus_isa = 10; diff --git a/src/mainboard/asrock/imb-a180/mptable.c b/src/mainboard/asrock/imb-a180/mptable.c index bfad50d..5d91524 100644 --- a/src/mainboard/asrock/imb-a180/mptable.c +++ b/src/mainboard/asrock/imb-a180/mptable.c @@ -31,7 +31,6 @@ #define IO_APIC_ID CONFIG_MAX_CPUS extern u8 bus_yangtze[6];
diff --git a/src/mainboard/asus/f2a85-m/get_bus_conf.c b/src/mainboard/asus/f2a85-m/get_bus_conf.c index 08e5795..e6f79da 100644 --- a/src/mainboard/asus/f2a85-m/get_bus_conf.c +++ b/src/mainboard/asus/f2a85-m/get_bus_conf.c @@ -43,7 +43,6 @@ u32 pci1234x[] = { 0x0000ff0, };
void get_bus_conf(void) @@ -51,17 +50,13 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_hudson = 0;
@@ -73,8 +68,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -85,8 +78,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_hudson[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ bus_isa = 10; diff --git a/src/mainboard/asus/f2a85-m/mptable.c b/src/mainboard/asus/f2a85-m/mptable.c index 25778ca..d0fd124 100644 --- a/src/mainboard/asus/f2a85-m/mptable.c +++ b/src/mainboard/asus/f2a85-m/mptable.c @@ -30,7 +30,6 @@ #define IO_APIC_ID CONFIG_MAX_CPUS extern u8 bus_hudson[6];
diff --git a/src/mainboard/asus/m4a78-em/mb_sysconf.h b/src/mainboard/asus/m4a78-em/mb_sysconf.h index 768ffd1..25d63d5 100644 --- a/src/mainboard/asus/m4a78-em/mb_sysconf.h +++ b/src/mainboard/asus/m4a78-em/mb_sysconf.h @@ -38,7 +38,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/asus/m4a785-m/mb_sysconf.h b/src/mainboard/asus/m4a785-m/mb_sysconf.h index 768ffd1..25d63d5 100644 --- a/src/mainboard/asus/m4a785-m/mb_sysconf.h +++ b/src/mainboard/asus/m4a785-m/mb_sysconf.h @@ -38,7 +38,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/asus/m5a88-v/get_bus_conf.c b/src/mainboard/asus/m5a88-v/get_bus_conf.c index b312ec1..3a9133c 100644 --- a/src/mainboard/asus/m5a88-v/get_bus_conf.c +++ b/src/mainboard/asus/m5a88-v/get_bus_conf.c @@ -53,7 +53,6 @@ u32 hcdnx[] = { 0x20202020, };
-u32 bus_type[256];
if (get_bus_conf_done == 1) return; /* do it only once */ @@ -90,16 +89,10 @@ void get_bus_conf(void) bus_rs780[i] = 0; }
/* sb800 */ dev = dev_find_slot(bus_sb800[0], PCI_DEVFN(sbdn_sb800 + 0x14, 4)); @@ -107,8 +100,6 @@ void get_bus_conf(void) bus_sb800[1] = pci_read_config8(dev, PCI_SECONDARY_BUS); bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_sb800[1]; j < bus_isa; j++) - bus_type[j] = 1; }
for (i = 0; i < 4; i++) { @@ -119,8 +110,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* rs780 */ for (i = 1; i < ARRAY_SIZE(bus_rs780); i++) { @@ -130,7 +119,6 @@ void get_bus_conf(void) if(255 != bus_rs780[i]) { bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - bus_type[bus_rs780[i]] = 1; /* PCI bus. */ } } } diff --git a/src/mainboard/asus/m5a88-v/mb_sysconf.h b/src/mainboard/asus/m5a88-v/mb_sysconf.h index 289b094..8a693fd 100644 --- a/src/mainboard/asus/m5a88-v/mb_sysconf.h +++ b/src/mainboard/asus/m5a88-v/mb_sysconf.h @@ -37,7 +37,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/asus/m5a88-v/mptable.c b/src/mainboard/asus/m5a88-v/mptable.c index cb7aeee..8d04a0c 100644 --- a/src/mainboard/asus/m5a88-v/mptable.c +++ b/src/mainboard/asus/m5a88-v/mptable.c @@ -30,7 +30,6 @@ extern int bus_isa; extern u8 bus_rs780[11]; extern u8 bus_sb800[6]; extern u32 apicid_sb800; -extern u32 bus_type[256]; extern u32 sbdn_rs780; extern u32 sbdn_sb800;
diff --git a/src/mainboard/avalue/eax-785e/get_bus_conf.c b/src/mainboard/avalue/eax-785e/get_bus_conf.c index 9bb26e6..f90c6b8 100644 --- a/src/mainboard/avalue/eax-785e/get_bus_conf.c +++ b/src/mainboard/avalue/eax-785e/get_bus_conf.c @@ -56,7 +56,6 @@ u32 hcdnx[] = { 0x20202020, };
-u32 bus_type[256];
if (get_bus_conf_done == 1) return; /* do it only once */ @@ -93,16 +92,10 @@ void get_bus_conf(void) bus_rs780[i] = 0; }
/* sb800 */ dev = dev_find_slot(bus_sb800[0], PCI_DEVFN(sbdn_sb800 + 0x14, 4)); @@ -110,8 +103,6 @@ void get_bus_conf(void) bus_sb800[1] = pci_read_config8(dev, PCI_SECONDARY_BUS); bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_sb800[1]; j < bus_isa; j++) - bus_type[j] = 1; }
for (i = 0; i < 4; i++) { @@ -122,8 +113,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* rs780 */ for (i = 1; i < ARRAY_SIZE(bus_rs780); i++) { @@ -133,7 +122,6 @@ void get_bus_conf(void) if(255 != bus_rs780[i]) { bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - bus_type[bus_rs780[i]] = 1; /* PCI bus. */ } } } diff --git a/src/mainboard/avalue/eax-785e/mb_sysconf.h b/src/mainboard/avalue/eax-785e/mb_sysconf.h index 289b094..8a693fd 100644 --- a/src/mainboard/avalue/eax-785e/mb_sysconf.h +++ b/src/mainboard/avalue/eax-785e/mb_sysconf.h @@ -37,7 +37,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/avalue/eax-785e/mptable.c b/src/mainboard/avalue/eax-785e/mptable.c index 1889e02..eb76d5e 100644 --- a/src/mainboard/avalue/eax-785e/mptable.c +++ b/src/mainboard/avalue/eax-785e/mptable.c @@ -30,7 +30,6 @@ extern int bus_isa; extern u8 bus_rs780[11]; extern u8 bus_sb800[6]; extern u32 apicid_sb800; -extern u32 bus_type[256]; extern u32 sbdn_rs780; extern u32 sbdn_sb800;
diff --git a/src/mainboard/gigabyte/ma785gm/mb_sysconf.h b/src/mainboard/gigabyte/ma785gm/mb_sysconf.h index 768ffd1..25d63d5 100644 --- a/src/mainboard/gigabyte/ma785gm/mb_sysconf.h +++ b/src/mainboard/gigabyte/ma785gm/mb_sysconf.h @@ -38,7 +38,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/gizmosphere/gizmo/get_bus_conf.c b/src/mainboard/gizmosphere/gizmo/get_bus_conf.c index 44d0b0f..dd9d28c 100755 --- a/src/mainboard/gizmosphere/gizmo/get_bus_conf.c +++ b/src/mainboard/gizmosphere/gizmo/get_bus_conf.c @@ -44,7 +44,6 @@ u32 pci1234x[] = { 0x0000ff0, };
@@ -53,17 +52,13 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_sb800 = 0;
// bus_sb800[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_sb800[0] = (pci1234x[0] >> 16) & 0xff; @@ -76,8 +71,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -89,10 +82,6 @@ void get_bus_conf(void) } }
- for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1; - - /* I/O APICs: APIC ID Version State Address */ bus_isa = 10; apicid_base = CONFIG_MAX_CPUS; diff --git a/src/mainboard/gizmosphere/gizmo/mptable.c b/src/mainboard/gizmosphere/gizmo/mptable.c index c56060e..4cdb131 100755 --- a/src/mainboard/gizmosphere/gizmo/mptable.c +++ b/src/mainboard/gizmosphere/gizmo/mptable.c @@ -32,7 +32,6 @@ extern u8 bus_sb800[6];
u8 intr_data[] = { diff --git a/src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c b/src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c index 78193eb..57ece7c 100644 --- a/src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c +++ b/src/mainboard/hp/pavilion_m6_1035dx/get_bus_conf.c @@ -44,7 +44,6 @@ u32 pci1234x[] = { 0x0000ff0, };
@@ -53,18 +52,12 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_hudson = 0;
- for (i = 0; i < 256; i++) { - bus_type[i] = 0; /* default ISA bus. */ - } - - bus_type[0] = 1; /* pci */ - bus_hudson[0] = (pci1234x[0] >> 16) & 0xff;
/* Hudson */ @@ -75,8 +68,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -87,8 +78,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_hudson[2]; j < bus_isa; j++) - bus_type[j] = 1;
/* I/O APICs: APIC ID Version State Address */ bus_isa = 10; diff --git a/src/mainboard/hp/pavilion_m6_1035dx/mptable.c b/src/mainboard/hp/pavilion_m6_1035dx/mptable.c index d90a453..ff40bf7 100644 --- a/src/mainboard/hp/pavilion_m6_1035dx/mptable.c +++ b/src/mainboard/hp/pavilion_m6_1035dx/mptable.c @@ -31,7 +31,6 @@ #define IO_APIC_ID CONFIG_MAX_CPUS extern u8 bus_hudson[6];
diff --git a/src/mainboard/iei/kino-780am2-fam10/mb_sysconf.h b/src/mainboard/iei/kino-780am2-fam10/mb_sysconf.h index 768ffd1..25d63d5 100644 --- a/src/mainboard/iei/kino-780am2-fam10/mb_sysconf.h +++ b/src/mainboard/iei/kino-780am2-fam10/mb_sysconf.h @@ -38,7 +38,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c b/src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c index 3992cb7..e91072e 100644 --- a/src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c +++ b/src/mainboard/jetway/nf81-t56n-lf/get_bus_conf.c @@ -46,7 +46,6 @@ u32 pci1234x[] = { 0x0000ff0, };
@@ -55,18 +54,12 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_sb800 = 0;
for (i = 0; i < 4; i++) { @@ -91,10 +82,6 @@ void get_bus_conf(void) } }
- for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1; - - /* I/O APICs: APIC ID Version State Address */ bus_isa = 10; apicid_base = CONFIG_MAX_CPUS; diff --git a/src/mainboard/jetway/nf81-t56n-lf/mptable.c b/src/mainboard/jetway/nf81-t56n-lf/mptable.c index 92fc3b0..cc9afbd 100644 --- a/src/mainboard/jetway/nf81-t56n-lf/mptable.c +++ b/src/mainboard/jetway/nf81-t56n-lf/mptable.c @@ -37,7 +37,6 @@ extern u8 bus_sb800[6]; extern u32 apicid_sb800; extern u32 apicver_sb800;
static void *smp_write_config_table(void *v) diff --git a/src/mainboard/lippert/frontrunner-af/get_bus_conf.c b/src/mainboard/lippert/frontrunner-af/get_bus_conf.c index c1a3fc2..dfece88 100644 --- a/src/mainboard/lippert/frontrunner-af/get_bus_conf.c +++ b/src/mainboard/lippert/frontrunner-af/get_bus_conf.c @@ -43,7 +43,6 @@ u32 pci1234x[] = { 0x0000ff0, };
@@ -52,17 +51,12 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_sb800 = 0;
for (i = 0; i < 4; i++) { @@ -88,10 +80,6 @@ void get_bus_conf(void) } }
- for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1; - - /* I/O APICs: APIC ID Version State Address */ bus_isa = 10; apicid_base = CONFIG_MAX_CPUS; diff --git a/src/mainboard/lippert/frontrunner-af/mptable.c b/src/mainboard/lippert/frontrunner-af/mptable.c index 498ae58..d794e56 100644 --- a/src/mainboard/lippert/frontrunner-af/mptable.c +++ b/src/mainboard/lippert/frontrunner-af/mptable.c @@ -31,7 +31,6 @@ extern u8 bus_sb800[6];
u8 intr_data[] = { diff --git a/src/mainboard/lippert/toucan-af/get_bus_conf.c b/src/mainboard/lippert/toucan-af/get_bus_conf.c index c49fff1..eddd645 100644 --- a/src/mainboard/lippert/toucan-af/get_bus_conf.c +++ b/src/mainboard/lippert/toucan-af/get_bus_conf.c @@ -43,7 +43,6 @@ u32 pci1234x[] = { 0x0000ff0, };
void get_bus_conf(void) @@ -51,18 +50,12 @@ void get_bus_conf(void) u32 apicid_base;
sbdn_sb800 = 0;
@@ -74,8 +67,6 @@ void get_bus_conf(void)
for (i = 0; i < 4; i++) { @@ -87,10 +78,6 @@ void get_bus_conf(void) } }
- for (j = bus_sb800[2]; j < bus_isa; j++) - bus_type[j] = 1; - - /* I/O APICs: APIC ID Version State Address */ bus_isa = 10; apicid_base = CONFIG_MAX_CPUS; diff --git a/src/mainboard/lippert/toucan-af/mptable.c b/src/mainboard/lippert/toucan-af/mptable.c index 498ae58..d794e56 100644 --- a/src/mainboard/lippert/toucan-af/mptable.c +++ b/src/mainboard/lippert/toucan-af/mptable.c @@ -31,7 +31,6 @@ extern u8 bus_sb800[6];
u8 intr_data[] = { diff --git a/src/mainboard/supermicro/h8qgi/get_bus_conf.c b/src/mainboard/supermicro/h8qgi/get_bus_conf.c index bce9737..d084e48 100644 --- a/src/mainboard/supermicro/h8qgi/get_bus_conf.c +++ b/src/mainboard/supermicro/h8qgi/get_bus_conf.c @@ -35,7 +35,6 @@ u8 bus_sp5100[2]; u8 bus_sr5650[14];
-u32 bus_type[256];
u32 sbdn_sr5650; u32 sbdn_sp5100; @@ -43,7 +42,7 @@ u32 sbdn_sp5100; void get_bus_conf(void) { device_t dev; - int i, j; + int i;
sbdn_sp5100 = 0;
@@ -54,11 +53,6 @@ void get_bus_conf(void) bus_sr5650[i] = 0; }
bus_sr5650[0] = 0; bus_sp5100[0] = bus_sr5650[0]; @@ -71,8 +65,6 @@ void get_bus_conf(void)
bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_sp5100[1]; j < bus_isa; j++) - bus_type[j] = 1; }
/* sr5650 */ @@ -83,7 +75,6 @@ void get_bus_conf(void) if(255 != bus_sr5650[i]) { bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - bus_type[bus_sr5650[i]] = 1; /* PCI bus. */ } } } @@ -97,8 +88,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sp5100[2]; j < bus_isa; j++) - bus_type[j] = 1; */
diff --git a/src/mainboard/supermicro/h8qgi/mptable.c b/src/mainboard/supermicro/h8qgi/mptable.c index 2206b58..8b36bc7 100644 --- a/src/mainboard/supermicro/h8qgi/mptable.c +++ b/src/mainboard/supermicro/h8qgi/mptable.c @@ -30,7 +30,6 @@
extern u8 bus_sr5650[14]; extern u8 bus_sp5100[2]; -extern u32 bus_type[256]; extern u32 sbdn_sr5650; extern u32 sbdn_sp5100; extern int bus_isa; diff --git a/src/mainboard/supermicro/h8scm/get_bus_conf.c b/src/mainboard/supermicro/h8scm/get_bus_conf.c index 9a70fca..db2ca62 100644 --- a/src/mainboard/supermicro/h8scm/get_bus_conf.c +++ b/src/mainboard/supermicro/h8scm/get_bus_conf.c @@ -35,7 +35,6 @@ u8 bus_sp5100[2]; u8 bus_sr5650[14];
-u32 bus_type[256];
sbdn_sp5100 = 0;
diff --git a/src/mainboard/supermicro/h8scm/mptable.c b/src/mainboard/supermicro/h8scm/mptable.c index 2206b58..8b36bc7 100644 --- a/src/mainboard/supermicro/h8scm/mptable.c +++ b/src/mainboard/supermicro/h8scm/mptable.c @@ -30,7 +30,6 @@
extern u8 bus_sr5650[14]; extern u8 bus_sp5100[2]; -extern u32 bus_type[256]; extern u32 sbdn_sr5650; extern u32 sbdn_sp5100; extern int bus_isa; diff --git a/src/mainboard/supermicro/h8scm_fam10/get_bus_conf.c b/src/mainboard/supermicro/h8scm_fam10/get_bus_conf.c index 142c9e6..0560180 100644 --- a/src/mainboard/supermicro/h8scm_fam10/get_bus_conf.c +++ b/src/mainboard/supermicro/h8scm_fam10/get_bus_conf.c @@ -54,7 +54,6 @@ u32 hcdnx[] = { 0x20202020, };
-u32 bus_type[256];
u32 sbdn_sr5650; u32 sbdn_sp5100; @@ -67,7 +66,7 @@ void get_bus_conf(void) { u32 apicid_base; device_t dev; - int i, j; + int i;
if (get_bus_conf_done == 1) return; /* do it only once */ @@ -92,16 +91,10 @@ void get_bus_conf(void) bus_sr5650[i] = 0; }
bus_sr5650[0] = (sysconf.pci1234[0] >> 16) & 0xff; bus_sp5100[0] = bus_sr5650[0];
- bus_type[bus_sr5650[0]] = 1;
/* sp5100 */ dev = dev_find_slot(bus_sp5100[0], PCI_DEVFN(sbdn_sp5100 + 0x14, 4)); @@ -109,8 +102,6 @@ void get_bus_conf(void) bus_sp5100[1] = pci_read_config8(dev, PCI_SECONDARY_BUS); bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_sp5100[1]; j < bus_isa; j++) - bus_type[j] = 1; }
/* sr5650 */ @@ -121,7 +112,6 @@ void get_bus_conf(void) if(255 != bus_sr5650[i]) { bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - bus_type[bus_sr5650[i]] = 1; /* PCI bus. */ } } } diff --git a/src/mainboard/supermicro/h8scm_fam10/mb_sysconf.h b/src/mainboard/supermicro/h8scm_fam10/mb_sysconf.h index 768ffd1..25d63d5 100644 --- a/src/mainboard/supermicro/h8scm_fam10/mb_sysconf.h +++ b/src/mainboard/supermicro/h8scm_fam10/mb_sysconf.h @@ -38,7 +38,6 @@ struct mb_sysconf_t { u32 sbdn3; u32 sbdn3a[31]; u32 sbdn5[31]; - u32 bus_type[256]; };
#endif diff --git a/src/mainboard/tyan/s8226/get_bus_conf.c b/src/mainboard/tyan/s8226/get_bus_conf.c index e7529c3..ea06499 100644 --- a/src/mainboard/tyan/s8226/get_bus_conf.c +++ b/src/mainboard/tyan/s8226/get_bus_conf.c @@ -34,7 +34,6 @@ u8 bus_sp5100[2]; u8 bus_sr5650[14];
-u32 bus_type[256];
u32 sbdn_sr5650; u32 sbdn_sp5100; @@ -44,7 +43,7 @@ void get_bus_conf(void); void get_bus_conf(void) { device_t dev; - int i, j; + int i;
sbdn_sp5100 = 0;
@@ -55,11 +54,6 @@ void get_bus_conf(void) bus_sr5650[i] = 0; }
bus_sr5650[0] = 0; bus_sp5100[0] = bus_sr5650[0]; @@ -72,8 +66,6 @@ void get_bus_conf(void)
bus_isa = (int)pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - for (j = bus_sp5100[1]; j < bus_isa; j++) - bus_type[j] = 1; }
/* sr5650 */ @@ -84,7 +76,6 @@ void get_bus_conf(void) if(255 != bus_sr5650[i]) { bus_isa = (int)pci_read_config8(dev, PCI_SUBORDINATE_BUS); bus_isa++; - bus_type[bus_sr5650[i]] = 1; /* PCI bus. */ } } } @@ -98,8 +89,6 @@ void get_bus_conf(void) bus_isa++; } } - for (j = bus_sp5100[2]; j < bus_isa; j++) - bus_type[j] = 1; */
diff --git a/src/mainboard/tyan/s8226/mptable.c b/src/mainboard/tyan/s8226/mptable.c index 2206b58..8b36bc7 100644 --- a/src/mainboard/tyan/s8226/mptable.c +++ b/src/mainboard/tyan/s8226/mptable.c @@ -30,7 +30,6 @@
