Attention is currently required from: Matt DeVillier.
Hello Matt DeVillier,
https://review.coreboot.org/c/coreboot/+/68533
Change subject: soc/amd/stoneyridge: initialize GPIOs for serial console ......................................................................
Initialize the two GPIOs of the SoC UART if it's used for serial console to be sure that the I/O mux is configured correctly without having to rely on the bootblock_mainboard_early_init call to do this. This brings Stoneyridge more in line with the other AMD SoCs. Since this code will be factored out to the common AMD SoC code in a follow-up patch, the function prototype is added to southbridge.h instead of creating a new uart.h header file.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Id4aa6734e63dad204d22ce962b983cde6e3abd62 --- M src/soc/amd/stoneyridge/early_fch.c M src/soc/amd/stoneyridge/include/soc/southbridge.h M src/soc/amd/stoneyridge/uart.c 3 files changed, 32 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/33/68533/3
