Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/78294?usp=email )
Change subject: mb/google/dedede: Wait for HPD on dibbi variants ......................................................................
Some Type-C monitors do not immediately assert HPD. If we enter FSP-S before HDP is asserted, display initialisation may fail. So wait for HPD.
This is similar to commit b40c6009141e ("mainboard/hatch: Fix puff DP output on cold boots") on puff, except we don't use google_chromeec_wait_for_displayport() since that EC command was removed for TCPMv2 (https://crrev.com/c/4221975). Instead we use the HPD signals only. By waiting for any HPD signal (Type-C or HDMI), we skip waiting if HDMI is connected, which is the same behaviour as puff and fizz.
TEST=On dibbi, connect a display via a Type-C to HDMI dongle and check the dev and recovery screens are now displayed correctly. Also check the logs in the following cases:
Cold reboot in dev mode, Type-C to HDMI dongle: HPD ready after 800 ms
Warm reboot in dev mode, Type-C to HDMI dongle: HPD ready after 0 ms
Cold/warm reboot in dev mode, direct Type-C: HPD ready after 0 ms
Cold/warm reboot in dev mode, direct HDMI: HPD ready after 0 ms
Cold/warm reboot in dev mode, no display: HPD not ready after 3000 ms. Abort.
Change-Id: Id4657b5d5a95a68ecbd9efcf3585cf96ad1e13e1 Signed-off-by: Reka Norman rekanorman@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/78294 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Sam McNally sammc@google.com --- M src/mainboard/google/dedede/mainboard.c M src/mainboard/google/dedede/variants/baseboard/gpio.c M src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h M src/mainboard/google/dedede/variants/boxy/gpio.c M src/mainboard/google/dedede/variants/dibbi/gpio.c M src/mainboard/google/dedede/variants/taranza/gpio.c 6 files changed, 105 insertions(+), 0 deletions(-)
Approvals: Sam McNally: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/mainboard/google/dedede/mainboard.c b/src/mainboard/google/dedede/mainboard.c index a0a537c..b381d98 100644 --- a/src/mainboard/google/dedede/mainboard.c +++ b/src/mainboard/google/dedede/mainboard.c @@ -3,12 +3,15 @@ #include <acpi/acpi.h> #include <acpi/acpigen.h> #include <baseboard/variants.h> +#include <bootmode.h> #include <console/console.h> +#include <delay.h> #include <device/device.h> #include <drivers/tpm/cr50.h> #include <ec/ec.h> #include <security/tpm/tss.h> #include <soc/soc_chip.h> +#include <timer.h> #include <vb2_api.h>
static void mainboard_update_soc_chip_config(void) @@ -30,12 +33,62 @@ } }
+static bool any_hpd_ready(const gpio_t *gpios, size_t num_gpios) +{ + for (size_t i = 0; i < num_gpios; i++) { + if (gpio_get(gpios[i])) + return true; + } + + return false; +} + +static void mainboard_wait_for_hpd(void) +{ + static const long display_timeout_ms = 3000; + struct stopwatch sw; + size_t num_gpios; + const gpio_t *hpd_gpios = variant_hpd_gpios(&num_gpios); + + if (num_gpios == 0) { + printk(BIOS_WARNING, "No HPD GPIOs, skip waiting\n"); + return; + } + + printk(BIOS_INFO, "Waiting for HPD\n"); + + /* Pins will be configured back by gpio_configure_pads. */ + for (size_t i = 0; i < num_gpios; i++) { + gpio_input(hpd_gpios[i]); + } + + stopwatch_init_msecs_expire(&sw, display_timeout_ms); + while (!any_hpd_ready(hpd_gpios, num_gpios)) { + if (stopwatch_expired(&sw)) { + printk(BIOS_WARNING, + "HPD not ready after %ld ms. Abort.\n", + display_timeout_ms); + return; + } + mdelay(200); + } + printk(BIOS_INFO, "HPD ready after %lld ms\n", + stopwatch_duration_msecs(&sw)); +} + static void mainboard_init(void *chip_info) { const struct pad_config *base_pads; const struct pad_config *override_pads; size_t base_num, override_num;
+ /* + * For chromeboxes, wait for DP HPD to be asserted before + * entering FSP-S, otherwise display init may fail. + */ + if (!CONFIG(SYSTEM_TYPE_LAPTOP) && display_init_required()) + mainboard_wait_for_hpd(); + base_pads = baseboard_gpio_table(&base_num); override_pads = variant_override_gpio_table(&override_num);
diff --git a/src/mainboard/google/dedede/variants/baseboard/gpio.c b/src/mainboard/google/dedede/variants/baseboard/gpio.c index f377d9a..557f6bf 100644 --- a/src/mainboard/google/dedede/variants/baseboard/gpio.c +++ b/src/mainboard/google/dedede/variants/baseboard/gpio.c @@ -489,3 +489,9 @@ };
DECLARE_WEAK_CROS_GPIOS(cros_gpios); + +const gpio_t *__weak variant_hpd_gpios(size_t *num) +{ + *num = 0; + return NULL; +} diff --git a/src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h b/src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h index b258481..bb9fd5d 100644 --- a/src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h +++ b/src/mainboard/google/dedede/variants/baseboard/include/baseboard/variants.h @@ -15,6 +15,7 @@ const struct pad_config *variant_sleep_gpio_table(size_t *num); const struct pad_config *variant_override_gpio_table(size_t *num); const struct pad_config *variant_romstage_gpio_table(size_t *num); +const gpio_t *variant_hpd_gpios(size_t *num);
enum s0ix_entry { S0IX_EXIT, diff --git a/src/mainboard/google/dedede/variants/boxy/gpio.c b/src/mainboard/google/dedede/variants/boxy/gpio.c index f8ed0cf..e8cb9ff 100644 --- a/src/mainboard/google/dedede/variants/boxy/gpio.c +++ b/src/mainboard/google/dedede/variants/boxy/gpio.c @@ -87,3 +87,18 @@ *num = ARRAY_SIZE(gpio_table); return gpio_table; } + +static const gpio_t hpd_gpios[] = { + /* HDMI1 */ + GPP_A17, + /* USB C0 */ + GPP_B23, + /* USB C1 */ + GPP_A16, +}; + +const gpio_t *variant_hpd_gpios(size_t *num) +{ + *num = ARRAY_SIZE(hpd_gpios); + return hpd_gpios; +} diff --git a/src/mainboard/google/dedede/variants/dibbi/gpio.c b/src/mainboard/google/dedede/variants/dibbi/gpio.c index 89a7a77..2998592 100644 --- a/src/mainboard/google/dedede/variants/dibbi/gpio.c +++ b/src/mainboard/google/dedede/variants/dibbi/gpio.c @@ -91,3 +91,18 @@ *num = ARRAY_SIZE(gpio_table); return gpio_table; } + +static const gpio_t hpd_gpios[] = { + /* HDMI1 */ + GPP_A17, + /* HDMI2 */ + GPP_A16, + /* USB C0 */ + GPP_B23, +}; + +const gpio_t *variant_hpd_gpios(size_t *num) +{ + *num = ARRAY_SIZE(hpd_gpios); + return hpd_gpios; +} diff --git a/src/mainboard/google/dedede/variants/taranza/gpio.c b/src/mainboard/google/dedede/variants/taranza/gpio.c index 89a7a77..2998592 100644 --- a/src/mainboard/google/dedede/variants/taranza/gpio.c +++ b/src/mainboard/google/dedede/variants/taranza/gpio.c @@ -91,3 +91,18 @@ *num = ARRAY_SIZE(gpio_table); return gpio_table; } + +static const gpio_t hpd_gpios[] = { + /* HDMI1 */ + GPP_A17, + /* HDMI2 */ + GPP_A16, + /* USB C0 */ + GPP_B23, +}; + +const gpio_t *variant_hpd_gpios(size_t *num) +{ + *num = ARRAY_SIZE(hpd_gpios); + return hpd_gpios; +}
