Alexandru Gagniuc (mr.nuke.me@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13485
commit 0e46df1cbfd247d47f8a2a5d6824276bd28bd4a0 Author: Alexandru Gagniuc mr.nuke.me@gmail.com Date: Tue Jan 26 18:22:43 2016 -0800
arch/x86: Implement minimal bootblock for C_ENVIRONMENT_BOTOBLOCK
Some newer x86 systems can boot from non-memory-mapped boot media (e.g. EMMC). The bootblock may be backed by small amounts of SRAM, or other memory, similar to how most ARM chipsets work. In such cases, we may not have enough code space for romstage very early on. This means that CAR setup and early boot media (e.g. SPI, EMMC) drivers need to be implemented within the limited amount memory of storage available. Since the reset vector has to be contained in this early code memory, the bootblock is the best place to implement loading of other stages.
Implement a bootblock which does the minimal initialization, up to, and including switch to protected mode. This then transfers control to platform-specific code. No stack is needed, and control is transferred via a "jmp" such that no stack operations are involved.
Change-Id: I009b42b9a707cf11a74493bd4d8c189dc09b8ace Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- src/arch/x86/Makefile.inc | 1 + src/arch/x86/bootblock_crt0.S | 55 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 56 insertions(+)
diff --git a/src/arch/x86/Makefile.inc b/src/arch/x86/Makefile.inc index 6667731..9084b11 100644 --- a/src/arch/x86/Makefile.inc +++ b/src/arch/x86/Makefile.inc @@ -112,6 +112,7 @@ $(obj)/arch/x86/id.bootblock.o: $(obj)/build.h
ifeq ($(CONFIG_C_ENVIRONMENT_BOOTBLOCK),y)
+bootblock-y += bootblock_crt0.S bootblock-y += memlayout.ld
ifeq ($(CONFIG_ARCH_BOOTBLOCK_X86_32),y) diff --git a/src/arch/x86/bootblock_crt0.S b/src/arch/x86/bootblock_crt0.S new file mode 100644 index 0000000..926cda0 --- /dev/null +++ b/src/arch/x86/bootblock_crt0.S @@ -0,0 +1,55 @@ +/* + * This is the modern bootblock. It is used by platforms which select + * C_ENVIRONMENT_BOOTBLOCK, and it prepares the system for C environment runtime + * setup. The actual setup is done by hardware-specific code. + * + * It provides a bootflow similar to other architectures, and thus is considered + * to be the modern approach. + * + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Alexandru Gagniuc mr.nuke.me@gmail.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#define CR0_MP (1 << 1) +#define CR0_EM (1 << 2) + +#define CR4_OSFXSR (1 << 9) +#define CR4_OSXMMEXCPT (1 << 10) + +/* + * Include the old code for reset vector and protected mode entry. That code has + * withstood the test of time. + */ +#include <arch/x86/prologue.inc> +#include <cpu/x86/16bit/entry16.inc> +#include <cpu/x86/16bit/reset16.inc> +#include <cpu/x86/32bit/entry32.inc> + + +bootblock_protected_mode_entry: + /* Save BIST result */ + movd %eax, %mm0 + /* Save an early timestamp */ + rdtsc + movd %eax, %mm1 + movd %edx, %mm2 + +#if !IS_ENABLED(CONFIG_SSE) +enable_sse: + mov %cr0, %eax + and $~CR0_EM, %ax /* Clear coprocessor emulation CR0.EM */ + or $CR0_MP, %ax /* Set coprocessor monitoring CR0.MP */ + mov %eax, %cr0 + mov %cr4, %eax + or $(CR4_OSFXSR | CR4_OSXMMEXCPT), %ax + mov %eax, %cr4 +#endif /* IS_ENABLED(CONFIG_SSE) */ + + /* We're done. Now it's up to platform-specific code */ + jmp bootblock_pre_c_entry
