Name of user not set #1004172 has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/63342 )
Change subject: payloads/external/LinuxBoot: Update Linuxboot Kconfig u-root ......................................................................
the u-root have modified repo names, this patch modify the "master" for "main" name repo and remove olds versions of u-root and use new tags
Change-Id: Iabc345cf7d233a94b49650cfec386978e70b655a Signed-off-by: RatatouilleDummie ratatouillemorde@gmail.com --- M payloads/external/LinuxBoot/Kconfig 1 file changed, 16 insertions(+), 12 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/63342/1
diff --git a/payloads/external/LinuxBoot/Kconfig b/payloads/external/LinuxBoot/Kconfig index a1e4e1f..ad9f795 100644 --- a/payloads/external/LinuxBoot/Kconfig +++ b/payloads/external/LinuxBoot/Kconfig @@ -184,19 +184,22 @@ help choose a custom u-root branch
-config LINUXBOOT_UROOT_MASTER - bool "master" +config LINUXBOOT_UROOT_MAIN + bool "main" help Latest u-root version
-config LINUXBOOT_UROOT_V3_0_0 - bool "v3.0.0" +config LINUXBOOT_UROOT_V7_0_0 + bool "v7.0.0"
-config LINUXBOOT_UROOT_V2_0_0 - bool "v2.0.0" +config LINUXBOOT_UROOT_V6_0_0 + bool "v6.0.0"
-config LINUXBOOT_UROOT_V1_0_0 - bool "v1.0.0" +config LINUXBOOT_UROOT_V5_0_0 + bool "v5.0.0" + +config LINUXBOOT_UROOT_V4_0_0 + bool "v4.0.0"
endchoice
@@ -207,10 +210,11 @@ config LINUXBOOT_UROOT_VERSION string default LINUXBOOT_UROOT_CHECKOUT if LINUXBOOT_UROOT_CUSTOM - default "master" if LINUXBOOT_UROOT_MASTER - default "v3.0.0" if LINUXBOOT_UROOT_V3_0_0 - default "v2.0.0" if LINUXBOOT_UROOT_V2_0_0 - default "v1.0.0" if LINUXBOOT_UROOT_V1_0_0 + default "main" if LINUXBOOT_UROOT_MAIN + default "v7.0.0" if LINUXBOOT_UROOT_v7_0_0 + default "v6.0.0" if LINUXBOOT_UROOT_V6_0_0 + default "v5.0.0" if LINUXBOOT_UROOT_V5_0_0 + default "v4.0.0" if LINUXBOOT_UROOT_V4_0_0
choice prompt "Build format"
