Michał Żygowski has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39697 )
Change subject: nb/amd/agesa/family14/acpi/thermal_mixin.asl: handle HTC threshold better ......................................................................
According to BKDGs HTC temperature limit field indicates the threshold where HTC becomes active. HTC active state means that processor is limiting its power consumption and maximum P-State. Using this threshold as _CRT is incorrect, since HTC active is designed to prevent overheating, not causing immediate shutdown.
Change the behavior of temperature limit to act as a passive cooling threshold. Make the passive cooling threshold a reference value for critical and hot temperature with 5 degrees step.
Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Change-Id: Ife64c3aab76f8e125493ecc8183a6e87fb012e3b --- M src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl 1 file changed, 12 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/97/39697/1
diff --git a/src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl b/src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl index 1f877cc..714fb45 100644 --- a/src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl +++ b/src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl @@ -35,7 +35,7 @@ */
#ifndef K10TEMP_HOT_OFFSET -# define K10TEMP_HOT_OFFSET 100 +# define K10TEMP_HOT_OFFSET 50 #endif
#define K10TEMP_KELVIN_OFFSET 2732 @@ -71,7 +71,12 @@ Return (Add (Local0, K10TEMP_KELVIN_OFFSET)) }
- Method (_CRT) { /* Critical temp in tenths degree Kelvin. */ + /* + * TLMT indicates threshold where HTC become active. That is the + * processor will limit P-State and power consumption in order to + * cool down. + */ + Method (_PSV) { Multiply (TLMT, 10, Local0) ShiftRight (Local0, 1, Local0) Add (Local0, K10TEMP_TLIMIT_OFFSET, Local0) @@ -79,6 +84,10 @@ }
Method (_HOT) { /* Hot temp in tenths degree Kelvin. */ - Return (Subtract (_CRT, K10TEMP_HOT_OFFSET)) + Return (Add (_PSV, K10TEMP_HOT_OFFSET)) + } + + Method (_CRT) { /* Critical temp in tenths degree Kelvin. */ + Return (Add (_HOT, K10TEMP_HOT_OFFSET)) } }
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39697 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/39697/1/src/northbridge/amd/agesa/f... File src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl:
https://review.coreboot.org/c/coreboot/+/39697/1/src/northbridge/amd/agesa/f... PS1, Line 74: /* trailing whitespace
https://review.coreboot.org/c/coreboot/+/39697/1/src/northbridge/amd/agesa/f... PS1, Line 75: * TLMT indicates threshold where HTC become active. That is the trailing whitespace
Hello build bot (Jenkins), Nico Huber,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/97/39697/2
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39697 )
Patch Set 2: Code-Review+2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39697 )
Patch Set 2:
(5 comments)
https://review.coreboot.org/c/coreboot/+/39697/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/39697/2//COMMIT_MSG@7 PS2, Line 7: nb/amd/agesa/family14/acpi/thermal_mixin.asl: handle HTC threshold better nb/amd/agesa/family14: Improve HTC threshold handling
https://review.coreboot.org/c/coreboot/+/39697/2//COMMIT_MSG@9 PS2, Line 9: BKDGs Which version?
https://review.coreboot.org/c/coreboot/+/39697/2//COMMIT_MSG@18 PS2, Line 18: Tested how?
https://review.coreboot.org/c/coreboot/+/39697/2/src/northbridge/amd/agesa/f... File src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl:
https://review.coreboot.org/c/coreboot/+/39697/2/src/northbridge/amd/agesa/f... PS2, Line 77: * cool down. Please use 96 character line length limit.
https://review.coreboot.org/c/coreboot/+/39697/2/src/northbridge/amd/agesa/f... PS2, Line 79: Method (_PSV) { Add comment as below about *Passive Temp*?
Change subject: nb/amd/agesa/family14: Improve HTC threshold handling ......................................................................
TEST=boot FreeBSD on PC Engines apu2 and check the thermal zone temperature using sysctl
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/97/39697/3
Michał Żygowski has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39697 )
Patch Set 3:
(3 comments)
Done
Which version?
Each BKDG for each family describes the temperature limit. No point to list all so I did a shortcut using plural.
Tested how?
Tested only Thermal Zone temperature reading as I have no means to test _HOT and _CRT triggering.
Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Change-Id: Ife64c3aab76f8e125493ecc8183a6e87fb012e3b --- M src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl 1 file changed, 11 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/97/39697/4
Patch Set 4:
(2 comments)
Done
Done
Patch Set 4: Code-Review+2
Done
WTF? this was way better readable before. There is no rule to make lines longer, only to break them before 96 chars.
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39697 )
https://review.coreboot.org/c/coreboot/+/39697/4//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/39697/4//COMMIT_MSG@9 PS4, Line 9: According to BKDGs HTC temperature limit field indicates the threshold I think these lines are a bit too long, the commit message looks weird in Gerrit. It should be reflowed:
Hello build bot (Jenkins), Nico Huber, Angel Pons,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/97/39697/5
Patch Set 5:
I think these lines are a bit too long, the commit message looks weird in Gerrit. […]
You're right. Wrapping at 75 is a bad idea.
Michał Żygowski has submitted this change. ( https://review.coreboot.org/c/coreboot/+/39697 )
Signed-off-by: Michał Żygowski michal.zygowski@3mdeb.com Change-Id: Ife64c3aab76f8e125493ecc8183a6e87fb012e3b Reviewed-on: https://review.coreboot.org/c/coreboot/+/39697 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Nico Huber nico.h@gmx.de Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl 1 file changed, 11 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved Angel Pons: Looks good to me, approved
diff --git a/src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl b/src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl index 1f877cc..3c692ce 100644 --- a/src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl +++ b/src/northbridge/amd/agesa/family14/acpi/thermal_mixin.asl @@ -35,7 +35,7 @@ */
#define K10TEMP_KELVIN_OFFSET 2732 @@ -71,7 +71,11 @@ Return (Add (Local0, K10TEMP_KELVIN_OFFSET)) }
- Method (_CRT) { /* Critical temp in tenths degree Kelvin. */ + /* + * TLMT indicates threshold where HTC become active. That is the processor will limit + * P-State and power consumption in order to cool down. + */ + Method (_PSV) { /* Passive temp in tenths degree Kelvin. */ Multiply (TLMT, 10, Local0) ShiftRight (Local0, 1, Local0) Add (Local0, K10TEMP_TLIMIT_OFFSET, Local0) @@ -79,6 +83,10 @@ }
Patch Set 6:
It is actually 72 characters, AFAIUI
Patch Set 6:
Okay, I was just following point 3 from here: https://www.coreboot.org/Git#Commit_messages Which states max 75. https://doc.coreboot.org/tutorial/part2.html also doesn't state the max liens in commit message. I guess we have found a hole in our docs. I may update the tutorial then.
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39697 )
Patch Set 6:
Automatic boot test returned (PASS/FAIL/TOTAL): 5/0/5 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : https://lava.9esec.io/r/1620 EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/1619 EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/1618 Non-emulation targets: HP_COMPAQ_8200_ELITE_SFF_PC using payload TianoCore : SUCCESS : https://lava.9esec.io/r/1622 HP_COMPAQ_8200_ELITE_SFF_PC using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/1621
