Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/41110 )
Change subject: sb/intel/bd82x6x: Do cosmetic fixes ......................................................................
Make the code follow the coding style, and reflow things that fit in 96 characters.
Tested with BUILD_TIMELESS=1, Asus P8Z77-V LX2 does not change.
Change-Id: I6e0acdc9c21d4b416597dc776bd9abab12bff4a0 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/southbridge/intel/bd82x6x/early_pch.c M src/southbridge/intel/bd82x6x/early_rcba.c M src/southbridge/intel/bd82x6x/early_thermal.c 3 files changed, 22 insertions(+), 33 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/10/41110/1
diff --git a/src/southbridge/intel/bd82x6x/early_pch.c b/src/southbridge/intel/bd82x6x/early_pch.c index 530f11a..bd507c4 100644 --- a/src/southbridge/intel/bd82x6x/early_pch.c +++ b/src/southbridge/intel/bd82x6x/early_pch.c @@ -19,15 +19,13 @@
#define SOUTHBRIDGE PCI_DEV(0, 0x1f, 0)
-static void -wait_iobp(void) +static void wait_iobp(void) { while (RCBA8(IOBPS) & 1) ; // implement timeout? }
-static u32 -read_iobp(u32 address) +static u32 read_iobp(u32 address) { u32 ret;
@@ -40,8 +38,7 @@ return ret; }
-static void -write_iobp(u32 address, u32 val) +static void write_iobp(u32 address, u32 val) { /* this function was probably pch_iobp_update with the andvalue * being 0. So either the IOBP read can be removed or this function @@ -137,11 +134,9 @@ ; }
-void -early_pch_init_native (void) +void early_pch_init_native(void) { - pci_write_config8 (SOUTHBRIDGE, 0xa6, - pci_read_config8 (SOUTHBRIDGE, 0xa6) | 2); + pci_write_config8(SOUTHBRIDGE, 0xa6, pci_read_config8(SOUTHBRIDGE, 0xa6) | 2);
RCBA32(CIR1) = 0x00109000; RCBA32(REC); // !!! = 0x00000000 @@ -278,9 +273,8 @@ * - 0x3f8-0x3ff COMA */ pci_write_config16(PCH_LPC_DEV, LPC_IO_DEC, 0x0010); - pci_write_config16(PCH_LPC_DEV, LPC_EN, CNF2_LPC_EN | CNF1_LPC_EN - | MC_LPC_EN | KBC_LPC_EN | FDD_LPC_EN | LPT_LPC_EN - | COMB_LPC_EN | COMA_LPC_EN); + pci_write_config16(PCH_LPC_DEV, LPC_EN, CNF2_LPC_EN | CNF1_LPC_EN | MC_LPC_EN + | KBC_LPC_EN | FDD_LPC_EN | LPT_LPC_EN | COMB_LPC_EN | COMA_LPC_EN);
const struct device *dev = pcidev_on_root(0x1f, 0); const struct southbridge_intel_bd82x6x_config *config = NULL; diff --git a/src/southbridge/intel/bd82x6x/early_rcba.c b/src/southbridge/intel/bd82x6x/early_rcba.c index 915a935..61877bb 100644 --- a/src/southbridge/intel/bd82x6x/early_rcba.c +++ b/src/southbridge/intel/bd82x6x/early_rcba.c @@ -5,8 +5,7 @@ #include <northbridge/intel/sandybridge/sandybridge.h> #include "pch.h"
-void -southbridge_configure_default_intmap(void) +void southbridge_configure_default_intmap(void) { /* * For the PCH internal PCI functions, provide a reasonable @@ -83,8 +82,7 @@ (void) RCBA16(OIC); }
-void -southbridge_rcba_config(void) +void southbridge_rcba_config(void) { RCBA32(FD) = PCH_DISABLE_ALWAYS; } diff --git a/src/southbridge/intel/bd82x6x/early_thermal.c b/src/southbridge/intel/bd82x6x/early_thermal.c index ac7a3a4..e73f3a5 100644 --- a/src/southbridge/intel/bd82x6x/early_thermal.c +++ b/src/southbridge/intel/bd82x6x/early_thermal.c @@ -36,34 +36,31 @@ pci_write_config32(dev, 0x44, 0x0);
/* Activate temporary BAR. */ - pci_write_config32(dev, 0x40, - pci_read_config32(dev, 0x40) | 5); + pci_write_config32(dev, 0x40, pci_read_config32(dev, 0x40) | 5);
- write16p (0x40000004, 0x3a2b); - write8p (0x4000000c, 0xff); - write8p (0x4000000d, 0x00); - write8p (0x4000000e, 0x40); - write8p (0x40000082, 0x00); - write8p (0x40000001, 0xba); + write16p(0x40000004, 0x3a2b); + write8p(0x4000000c, 0xff); + write8p(0x4000000d, 0x00); + write8p(0x4000000e, 0x40); + write8p(0x40000082, 0x00); + write8p(0x40000001, 0xba);
/* Perform init. */ /* Configure TJmax. */ msr = rdmsr(MSR_TEMPERATURE_TARGET); write16p(0x40000012, ((msr.lo >> 16) & 0xff) << 6); - /* Northbridge temperature slope and offset. */ + /* Northbridge temperature slope and offset */ write16p(0x40000016, 0x808c);
- write16p (0x40000014, 0xde87); + write16p(0x40000014, 0xde87);
- /* Enable thermal data reporting, processor, PCH and northbridge. */ + /* Enable thermal data reporting, processor, PCH and northbridge */ write16p(0x4000001a, (read16p(0x4000001a) & ~0xf) | 0x10f0);
- /* Disable temporary BAR. */ - pci_write_config32(dev, 0x40, - pci_read_config32(dev, 0x40) & ~1); + /* Disable temporary BAR */ + pci_write_config32(dev, 0x40, pci_read_config32(dev, 0x40) & ~1); pci_write_config32(dev, 0x40, 0);
- write32 (DEFAULT_RCBA + 0x38b0, - (read32 (DEFAULT_RCBA + 0x38b0) & 0xffff8003) | 0x403c); + write32(DEFAULT_RCBA + 0x38b0, (read32(DEFAULT_RCBA + 0x38b0) & 0xffff8003) | 0x403c); }
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41110 )
Patch Set 1: Code-Review+2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41110 )
Patch Set 1: Code-Review+1
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/41110 )
Change-Id: I6e0acdc9c21d4b416597dc776bd9abab12bff4a0 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/41110 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: HAOUAS Elyes ehaouas@noos.fr Reviewed-by: Paul Menzel paulepanter@users.sourceforge.net --- M src/southbridge/intel/bd82x6x/early_pch.c M src/southbridge/intel/bd82x6x/early_rcba.c M src/southbridge/intel/bd82x6x/early_thermal.c 3 files changed, 22 insertions(+), 33 deletions(-)
Approvals: build bot (Jenkins): Verified Paul Menzel: Looks good to me, but someone else must approve HAOUAS Elyes: Looks good to me, approved
