Attention is currently required from: Yi Chou, Yu-Ping Wu.
Hello Julius Werner, Yu-Ping Wu, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/79144?usp=email
Change subject: libpayload: Fix the stack and data labels ......................................................................
We should make sure the consistency between _stack/_estack and the other labels. And _data & _edata is also useful to clean up the sensitive data on the data section.
BUG=b:248610274 TEST=emerge-cherry libpayload BRANCH=none
Change-Id: I589040f4db60b35813ea9f4ba9503244bd7def00 Signed-off-by: Yi Chou yich@google.com --- M payloads/libpayload/arch/arm/head.S M payloads/libpayload/arch/arm/libpayload.ldscript M payloads/libpayload/arch/arm64/head.S M payloads/libpayload/arch/arm64/libpayload.ldscript M payloads/libpayload/arch/x86/head.S M payloads/libpayload/arch/x86/libpayload.ldscript 6 files changed, 57 insertions(+), 15 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/44/79144/4
