Christian Walter has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/32850
Change subject: src/include/device/pci_ids.h: Added another Kabylake DT src/soc/intelcommon/block/systemagent/systemagent.c: Added another KabyLake DT ......................................................................
Change-Id: I496b3a91f765d4fa137c32c9ee1e244803fc25d8 Signed-off-by: Christian Walter christian.walter@9elements.com --- M src/include/device/pci_ids.h M src/soc/intel/common/block/systemagent/systemagent.c 2 files changed, 2 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/32850/1
diff --git a/src/include/device/pci_ids.h b/src/include/device/pci_ids.h index 6453951..553deaf 100644 --- a/src/include/device/pci_ids.h +++ b/src/include/device/pci_ids.h @@ -3081,6 +3081,7 @@ #define PCI_DEVICE_ID_INTEL_KBL_ID_Y 0x590c #define PCI_DEVICE_ID_INTEL_KBL_ID_H 0x5910 #define PCI_DEVICE_ID_INTEL_KBL_U_R 0x5914 +#define PCI_DEVICE_ID_INTEL_KBL_ID_DT_2 0x5918 #define PCI_DEVICE_ID_INTEL_KBL_ID_DT 0x591f #define PCI_DEVICE_ID_INTEL_CNL_ID_U 0x5A04 #define PCI_DEVICE_ID_INTEL_CNL_ID_Y 0x5A02 diff --git a/src/soc/intel/common/block/systemagent/systemagent.c b/src/soc/intel/common/block/systemagent/systemagent.c index 0f91156..281a7f7 100644 --- a/src/soc/intel/common/block/systemagent/systemagent.c +++ b/src/soc/intel/common/block/systemagent/systemagent.c @@ -351,6 +351,7 @@ PCI_DEVICE_ID_INTEL_KBL_ID_H, PCI_DEVICE_ID_INTEL_KBL_U_R, PCI_DEVICE_ID_INTEL_KBL_ID_DT, + PCI_DEVICE_ID_INTEL_KBL_ID_DT_2, PCI_DEVICE_ID_INTEL_CFL_ID_U, PCI_DEVICE_ID_INTEL_CFL_ID_H, PCI_DEVICE_ID_INTEL_CFL_ID_S,
Alex Thiessen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32850 )
Patch Set 1:
(3 comments)
https://review.coreboot.org/#/c/32850/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/#/c/32850/1//COMMIT_MSG@7 PS1, Line 7: Added use imperative mood in the subject line
https://review.coreboot.org/#/c/32850/1//COMMIT_MSG@7 PS1, Line 7: src/include/device/pci_ids.h: Added another Kabylake DT : src/soc/intelcommon/block/systemagent/systemagent.c: Added another KabyLake DT a too long subject line
https://review.coreboot.org/#/c/32850/1/src/include/device/pci_ids.h File src/include/device/pci_ids.h:
https://review.coreboot.org/#/c/32850/1/src/include/device/pci_ids.h@3084 PS1, Line 3084: guess this should have been a tab, not a space
Hello Patrick Rudolph, build bot (Jenkins),
Change subject: src/include/device/pci_ids.h: Add another Kabylake DT src/soc/intelcommon/block/systemagent/systemagent.c: Add another KabyLake DT ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/32850/2
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/32850/3
Lijian Zhao has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32850 )
Patch Set 3:
Please follow https://doc.coreboot.org/getting_started/gerrit_guidelines.html to change the commit message, also report_platform.c under src/soc/intel/skylake/bootblock need to be updated as well.
Patch Set 3:
one comment was resolved
Done
Change subject: soc/intel/skylake: Add PCI Id for Kabylake DT ......................................................................
Change-Id: I496b3a91f765d4fa137c32c9ee1e244803fc25d8 Signed-off-by: Christian Walter christian.walter@9elements.com --- M src/include/device/pci_ids.h M src/soc/intel/common/block/systemagent/systemagent.c M src/soc/intel/skylake/bootblock/report_platform.c 3 files changed, 3 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/32850/4
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32850 )
Patch Set 4: Code-Review+2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32850 )
Patch Set 4: Code-Review+1
Patch Set 4:
https://review.coreboot.org/#/c/32850/4/src/soc/intel/skylake/bootblock/repo... File src/soc/intel/skylake/bootblock/report_platform.c:
https://review.coreboot.org/#/c/32850/4/src/soc/intel/skylake/bootblock/repo... PS4, Line 62: Kabylake DT DT2? Or at least different name?
(2 comments)
Done
Done
Hello Alex Thiessen, Patrick Rudolph, Paul Menzel, build bot (Jenkins),
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/50/32850/7
Patch Set 7: Code-Review+2
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/32850 )
Change-Id: I496b3a91f765d4fa137c32c9ee1e244803fc25d8 Signed-off-by: Christian Walter christian.walter@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/32850 Reviewed-by: Lijian Zhao lijian.zhao@intel.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/include/device/pci_ids.h M src/soc/intel/common/block/systemagent/systemagent.c M src/soc/intel/skylake/bootblock/report_platform.c 3 files changed, 3 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Lijian Zhao: Looks good to me, approved
diff --git a/src/include/device/pci_ids.h b/src/include/device/pci_ids.h index 6453951..553deaf 100644 --- a/src/include/device/pci_ids.h +++ b/src/include/device/pci_ids.h @@ -3081,6 +3081,7 @@ #define PCI_DEVICE_ID_INTEL_KBL_ID_Y 0x590c #define PCI_DEVICE_ID_INTEL_KBL_ID_H 0x5910 #define PCI_DEVICE_ID_INTEL_KBL_U_R 0x5914 +#define PCI_DEVICE_ID_INTEL_KBL_ID_DT_2 0x5918 #define PCI_DEVICE_ID_INTEL_KBL_ID_DT 0x591f #define PCI_DEVICE_ID_INTEL_CNL_ID_U 0x5A04 #define PCI_DEVICE_ID_INTEL_CNL_ID_Y 0x5A02 diff --git a/src/soc/intel/common/block/systemagent/systemagent.c b/src/soc/intel/common/block/systemagent/systemagent.c index 0f91156..281a7f7 100644 --- a/src/soc/intel/common/block/systemagent/systemagent.c +++ b/src/soc/intel/common/block/systemagent/systemagent.c @@ -351,6 +351,7 @@ PCI_DEVICE_ID_INTEL_KBL_ID_H, PCI_DEVICE_ID_INTEL_KBL_U_R, PCI_DEVICE_ID_INTEL_KBL_ID_DT, + PCI_DEVICE_ID_INTEL_KBL_ID_DT_2, PCI_DEVICE_ID_INTEL_CFL_ID_U, PCI_DEVICE_ID_INTEL_CFL_ID_H, PCI_DEVICE_ID_INTEL_CFL_ID_S, diff --git a/src/soc/intel/skylake/bootblock/report_platform.c b/src/soc/intel/skylake/bootblock/report_platform.c index de845c7..1e81809 100644 --- a/src/soc/intel/skylake/bootblock/report_platform.c +++ b/src/soc/intel/skylake/bootblock/report_platform.c @@ -59,6 +59,7 @@ { PCI_DEVICE_ID_INTEL_KBL_ID_H, "Kabylake-H" }, { PCI_DEVICE_ID_INTEL_KBL_ID_S, "Kabylake-S" }, { PCI_DEVICE_ID_INTEL_KBL_ID_DT, "Kabylake DT" }, + { PCI_DEVICE_ID_INTEL_KBL_ID_DT_2, "Kabylake DT 2" }, };
static struct {
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32850 )
Patch Set 9:
What is DT? If it's supposed to mean Desktop, wouldn't that be Kabylake-S?
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/32850 )
Patch Set 10:
Patch Set 9:
Kabylake DT is an "entry level server" variant.
Patch Set 10:
Patch Set 10:
Patch Set 9:
Thanks.
https://review.coreboot.org/#/c/32850/10/src/include/device/pci_ids.h File src/include/device/pci_ids.h:
https://review.coreboot.org/#/c/32850/10/src/include/device/pci_ids.h@3085 PS10, Line 3085: #define PCI_DEVICE_ID_INTEL_KBL_ID_DT 0x591f Now that I learned about DT, this 0x591f one is documented as S/X in doc 567957.
Again, I guess we could have better lists if Intel would publish the stepping and id guides.
