Aamir Bohra has uploaded this change for review. ( https://review.coreboot.org/27889
Change subject: src/soc/intel/common: Configure the chip select state correctly ......................................................................
This implementation updates the chip select control register programming in gspi controller setup call to program the correct bit fields for chip select state.
Change-Id: Ifab37b0003f09a680024d5b155ab0bb157920a53 Signed-off-by: Aamir Bohra aamir.bohra@intel.com --- M src/soc/intel/common/block/gspi/gspi.c 1 file changed, 1 insertion(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/89/27889/1
diff --git a/src/soc/intel/common/block/gspi/gspi.c b/src/soc/intel/common/block/gspi/gspi.c index 35c34ce..fc7dd46 100644 --- a/src/soc/intel/common/block/gspi/gspi.c +++ b/src/soc/intel/common/block/gspi/gspi.c @@ -481,12 +481,9 @@ cs_ctrl = CS_MODE_SW | CS_0; pol = gspi_csctrl_polarity(cfg.cs_polarity); cs_ctrl |= pol << CS_0_POL_SHIFT; - cs_ctrl |= gspi_csctrl_state(pol, CS_DEASSERT); + cs_ctrl |= gspi_csctrl_state(pol, CS_DEASSERT) << CS_STATE_SHIFT; gspi_write_mmio_reg(p, SPI_CS_CONTROL, cs_ctrl);
- /* De-assert chip select. */ - __gspi_cs_change(p, CS_DEASSERT); - /* Disable SPI controller. */ gspi_write_mmio_reg(p, SSCR0, SSCR0_SSE_DISABLE);
