Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/35390 )
Change subject: [WIP] arch/x86: Replace some __PRE_RAM__ use ......................................................................
Change-Id: I4d8db430f8cd0bf0f161fc5cef052f153e59e2bc Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/arch/x86/include/arch/acpi.h M src/include/cpu/amd/mtrr.h M src/include/cpu/x86/cache.h M src/include/cpu/x86/lapic.h 4 files changed, 2 insertions(+), 8 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/90/35390/1
diff --git a/src/arch/x86/include/arch/acpi.h b/src/arch/x86/include/arch/acpi.h index 42e45fb..6cd4e9f 100644 --- a/src/arch/x86/include/arch/acpi.h +++ b/src/arch/x86/include/arch/acpi.h @@ -974,7 +974,7 @@
#if CONFIG(HAVE_ACPI_RESUME)
-#ifdef __PRE_RAM__ +#if ENV_ROMSTAGE_OR_BEFORE static inline int acpi_is_wakeup_s3(void) { return (acpi_get_sleep_type() == ACPI_S3); diff --git a/src/include/cpu/amd/mtrr.h b/src/include/cpu/amd/mtrr.h index f6b213e..edbf7bb 100644 --- a/src/include/cpu/amd/mtrr.h +++ b/src/include/cpu/amd/mtrr.h @@ -38,7 +38,7 @@ #define TOP_MEM_MASK 0x007fffff #define TOP_MEM_MASK_KB (TOP_MEM_MASK >> 10)
-#if !defined(__PRE_RAM__) && !defined(__ASSEMBLER__) +#if !defined(__ROMCC__) && !defined(__ASSEMBLER__)
#include <cpu/x86/msr.h>
diff --git a/src/include/cpu/x86/cache.h b/src/include/cpu/x86/cache.h index 7f135e5..713ca32 100644 --- a/src/include/cpu/x86/cache.h +++ b/src/include/cpu/x86/cache.h @@ -84,9 +84,7 @@ wbinvd(); }
-#if !defined(__PRE_RAM__) void x86_enable_cache(void); -#endif
#endif /* !__ASSEMBLER__ */ #endif /* CPU_X86_CACHE */ diff --git a/src/include/cpu/x86/lapic.h b/src/include/cpu/x86/lapic.h index 8108174..2c865eb 100644 --- a/src/include/cpu/x86/lapic.h +++ b/src/include/cpu/x86/lapic.h @@ -58,8 +58,6 @@ void stop_this_cpu(void); #endif
-#if !defined(__PRE_RAM__) - #define xchg(ptr, v) ((__typeof__(*(ptr)))__xchg((unsigned long)(v), (ptr), \ sizeof(*(ptr))))
@@ -156,6 +154,4 @@ struct device; int start_cpu(struct device *cpu);
-#endif /* !__PRE_RAM__ */ - #endif /* CPU_X86_LAPIC_H */
Hello build bot (Jenkins),
Change subject: arch/x86: Replace some __PRE_RAM__ use ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/90/35390/3
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35390 )
Patch Set 3: Code-Review+2
Kyösti Mälkki has submitted this change. ( https://review.coreboot.org/c/coreboot/+/35390 )
Change-Id: I4d8db430f8cd0bf0f161fc5cef052f153e59e2bc Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/35390 Reviewed-by: Aaron Durbin adurbin@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/arch/x86/include/arch/acpi.h M src/include/cpu/amd/mtrr.h M src/include/cpu/x86/cache.h M src/include/cpu/x86/lapic.h 4 files changed, 2 insertions(+), 8 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved
#endif /* !__ASSEMBLER__ */ #endif /* CPU_X86_CACHE */ diff --git a/src/include/cpu/x86/lapic.h b/src/include/cpu/x86/lapic.h index 2f40742..6fd1997 100644 --- a/src/include/cpu/x86/lapic.h +++ b/src/include/cpu/x86/lapic.h @@ -58,8 +58,6 @@ void stop_this_cpu(void); #endif
@@ -132,6 +130,4 @@ struct device; int start_cpu(struct device *cpu);
