Duncan Laurie (dlaurie@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16398
commit 0c2a056c37b448366ff2228dae37bcc1d5eb4b6e Author: Duncan Laurie dlaurie@chromium.org Date: Thu Sep 1 16:00:05 2016 -0700
google/reef: Enable I2C TPM
Enable the I2C based TPM on the reef board at bus 2 and address 0x50.
This makes vboot functional without needing MOCK_TPM and results in the following in the SSDT:
Device (TPMI) { Name (_HID, "GOOG0005") // _HID: Hardware ID Name (_UID, Zero) // _UID: Unique ID Name (_DDN, "I2C TPM") // _DDN: DOS Device Name Method (_STA, 0, NotSerialized) // _STA: Status { Return (0x0F) }
Name (_CRS, ResourceTemplate () // _CRS: Current Resource Settings { I2cSerialBus (0x0050, ControllerInitiated, 0x00061A80, AddressingMode7Bit, "\_SB.PCI0.I2C2", 0x00, ResourceConsumer) Interrupt (ResourceConsumer, Edge, ActiveLow, Exclusive) { 0x00000039 } }) }
Change-Id: Ia9775caabeac3e6a3bd72de38f9611b4cea7cea4 Signed-off-by: Duncan Laurie dlaurie@chromium.org --- src/mainboard/google/reef/Kconfig | 10 +++++++++- src/mainboard/google/reef/devicetree.cb | 8 +++++++- 2 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/src/mainboard/google/reef/Kconfig b/src/mainboard/google/reef/Kconfig index 0464e2d..08a5c6a 100644 --- a/src/mainboard/google/reef/Kconfig +++ b/src/mainboard/google/reef/Kconfig @@ -9,8 +9,16 @@ config BOARD_SPECIFIC_OPTIONS select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES select MAINBOARD_HAS_CHROMEOS - select MAINBOARD_HAS_LPC_TPM + select MAINBOARD_HAS_TPM2 select SYSTEM_TYPE_LAPTOP + select TPM2 + select I2C_TPM + +config DRIVER_TPM_I2C_BUS + hex "0x2" + +config DRIVER_TPM_I2C_ADDR + hex "0x50"
config CHROMEOS select LID_SWITCH diff --git a/src/mainboard/google/reef/devicetree.cb b/src/mainboard/google/reef/devicetree.cb index 4d08fae..ac69406 100644 --- a/src/mainboard/google/reef/devicetree.cb +++ b/src/mainboard/google/reef/devicetree.cb @@ -99,7 +99,13 @@ chip soc/intel/apollolake end end device pci 16.1 on end # - I2C 1 - device pci 16.2 on end # - I2C 2 + device pci 16.2 on + chip drivers/i2c/tpm + register "hid" = ""GOOG0005"" + register "irq" = "IRQ_EDGE_LOW(GPIO_28_IRQ)" + device i2c 50 on end + end + end # - I2C 2 device pci 16.3 on chip drivers/i2c/generic register "hid" = ""ELAN0001""
