Attention is currently required from: Eran Mitrani, Jakub Czapiga, Kapil Porwal, Tarun Tuli.
Hello Eran Mitrani, Jakub Czapiga, Kapil Porwal, Tarun Tuli, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/76922?usp=email
Change subject: soc/intel/meteorlake: Add provision to show pre-boot splash screen ......................................................................
This patch adds the ability to show a pre-boot splash screen on Meteor Lake systems using FSP-S.
The patch calls into `fsp_convert_bmp_to_gop_blt()` when the `HAVE_FSP_LOGO_SUPPORT` config is enabled. This function converts a BMP file to a BLT buffer, which is then used by FSP-S to render the splash screen.
Additionally, increase the heap size (malloc'able size) upto 512KB (when HAVE_FSP_LOGO_SUPPORT config is enabled) to accommodate high resolution logo file.
BUG=b:284799726 TEST=Able to see pre-boot splash screen while booting google/rex.
Signed-off-by: Subrata Banik subratabanik@google.com Change-Id: I3608bfacc21574e12cde0e2012a16e6388ce54df --- M src/soc/intel/meteorlake/Kconfig M src/soc/intel/meteorlake/fsp_params.c 2 files changed, 8 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/22/76922/4
