Attention is currently required from: Varshit B Pandya, Maulik V Vaghela, Tim Wawrzynczak, Patrick Rudolph. Hello build bot (Jenkins), Maulik V Vaghela, Tim Wawrzynczak, Subrata Banik, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/58767
Change subject: driver/intel/mipi_camera: Add support for _DSC field ......................................................................
The _DSC (Device State for Configuration) object evaluates to an integer may be used to tell Linux the highest allowed D state for a device during probe. The support for _DSC requires support from the kernel bus type if the bus driver normally sets the device in D0 state for probe.
The D states and thus also the allowed values for _DSC are listed below. Number State Description 0 D0 Device fully powered on 1 D1 2 D2 3 D3hot 4 D3cold Off
More details can be found here https://lkml.org/lkml/2021/10/25/397
BUG=none BRANCH=none TEST=Add corresponding field in brya, boot and dump SSDT to check if _DSC field is as per expectation.
Name (_ADR, Zero) // _ADR: Address Name (_HID, "OVTI8856") // _HID: Hardware ID Name (_UID, Zero) // _UID: Unique ID Name (_DDN, "Ov 8856 Camera") // _DDN: DOS Device Name Method (_STA, 0, NotSerialized) // _STA: Status { Return (0x0F) }
Method (_DSC, 0, NotSerialized) { Return (0x04) }
Signed-off-by: Varshit B Pandya varshit.b.pandya@intel.com Change-Id: I5471f144918413a2982f86beaf3dbf7e4e66cc9b --- M src/drivers/intel/mipi_camera/camera.c M src/drivers/intel/mipi_camera/chip.h 2 files changed, 6 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/67/58767/6
