HAOUAS Elyes has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39062 )
Change subject: mb/amd/persimmon: Drop unmaintained ROMCC board ......................................................................
Remove unmaintained and unsupported old ROMCC board. This board wasn't hooked up for build.
Change-Id: I934b24ddbc2032470aee9b1d6c23c1139442f878 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- D src/mainboard/amd/persimmon/BiosCallOuts.c D src/mainboard/amd/persimmon/Kconfig D src/mainboard/amd/persimmon/Kconfig.name D src/mainboard/amd/persimmon/Makefile.inc D src/mainboard/amd/persimmon/OemCustomize.c D src/mainboard/amd/persimmon/OptionsIds.h D src/mainboard/amd/persimmon/acpi/gpe.asl D src/mainboard/amd/persimmon/acpi/ide.asl D src/mainboard/amd/persimmon/acpi/mainboard.asl D src/mainboard/amd/persimmon/acpi/routing.asl D src/mainboard/amd/persimmon/acpi/sata.asl D src/mainboard/amd/persimmon/acpi/sleep.asl D src/mainboard/amd/persimmon/acpi/superio.asl D src/mainboard/amd/persimmon/acpi/usb_oc.asl D src/mainboard/amd/persimmon/acpi_tables.c D src/mainboard/amd/persimmon/board_info.txt D src/mainboard/amd/persimmon/buildOpts.c D src/mainboard/amd/persimmon/cmos.layout D src/mainboard/amd/persimmon/devicetree.cb D src/mainboard/amd/persimmon/dsdt.asl D src/mainboard/amd/persimmon/irq_tables.c D src/mainboard/amd/persimmon/mainboard.c D src/mainboard/amd/persimmon/mptable.c D src/mainboard/amd/persimmon/platform_cfg.h D src/mainboard/amd/persimmon/romstage.c 25 files changed, 0 insertions(+), 2,832 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/62/39062/1
diff --git a/src/mainboard/amd/persimmon/BiosCallOuts.c b/src/mainboard/amd/persimmon/BiosCallOuts.c deleted file mode 100644 index 23a0e9f..0000000 --- a/src/mainboard/amd/persimmon/BiosCallOuts.c +++ /dev/null @@ -1,91 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <AGESA.h> -#include <amdlib.h> -#include <amdblocks/acpimmio.h> -#include <northbridge/amd/agesa/BiosCallOuts.h> -#include <SB800.h> -#include <stdlib.h> - -static AGESA_STATUS board_BeforeDramInit (UINT32 Func, UINTN Data, VOID *ConfigPtr); -static AGESA_STATUS board_GnbPcieSlotReset (UINT32 Func, UINTN Data, VOID *ConfigPtr); - -const BIOS_CALLOUT_STRUCT BiosCallouts[] = -{ - {AGESA_DO_RESET, agesa_Reset }, - {AGESA_READ_SPD, agesa_ReadSpd }, - {AGESA_READ_SPD_RECOVERY, agesa_NoopUnsupported }, - {AGESA_RUNFUNC_ONAP, agesa_RunFuncOnAp }, - {AGESA_GNB_PCIE_SLOT_RESET, board_GnbPcieSlotReset }, - {AGESA_HOOKBEFORE_DRAM_INIT, board_BeforeDramInit }, - {AGESA_HOOKBEFORE_DRAM_INIT_RECOVERY, agesa_NoopSuccess }, - {AGESA_HOOKBEFORE_DQS_TRAINING, agesa_NoopSuccess }, - {AGESA_HOOKBEFORE_EXIT_SELF_REF, agesa_NoopSuccess }, -}; -const int BiosCalloutsLen = ARRAY_SIZE(BiosCallouts); - -/* Call the host environment interface to provide a user hook opportunity. */ -static AGESA_STATUS board_BeforeDramInit (UINT32 Func, UINTN Data, VOID *ConfigPtr) -{ - // Unlike e.g. AMD Inagua, Persimmon is unable to vary the RAM voltage. - // Make sure the right speed settings are selected. - ((MEM_DATA_STRUCT*)ConfigPtr)->ParameterListPtr->DDR3Voltage = VOLT1_5; - return AGESA_SUCCESS; -} - -/* PCIE slot reset control */ -static AGESA_STATUS board_GnbPcieSlotReset (UINT32 Func, UINTN Data, VOID *ConfigPtr) -{ - AGESA_STATUS Status; - UINTN FcnData; - PCIe_SLOT_RESET_INFO *ResetInfo; - - UINT32 GpioMmioAddr; - UINT32 AcpiMmioAddr; - UINT8 Data8; - UINT16 Data16; - - FcnData = Data; - ResetInfo = ConfigPtr; - // Get SB800 MMIO Base (AcpiMmioAddr) - Data8 = pm_io_read8(0x27); - Data16 = Data8 << 8; - Data8 = pm_io_read8(0x26); - Data16 |= Data8; - AcpiMmioAddr = (UINT32)Data16 << 16; - Status = AGESA_UNSUPPORTED; - GpioMmioAddr = AcpiMmioAddr + GPIO_BASE; - switch (ResetInfo->ResetId) - { - case 46: // GPIO50 = SBGPIO_PCIE_RST# affects LAN0, LAN1, PCIe slot - switch (ResetInfo->ResetControl) { - case AssertSlotReset: - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG50); - Data8 &= ~(UINT8)BIT6; - Write64Mem8(GpioMmioAddr+SB_GPIO_REG50, Data8); - Status = AGESA_SUCCESS; - break; - case DeassertSlotReset: - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG50); - Data8 |= BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG50, Data8); - Status = AGESA_SUCCESS; - break; - } - break; - } - return Status; -} diff --git a/src/mainboard/amd/persimmon/Kconfig b/src/mainboard/amd/persimmon/Kconfig deleted file mode 100644 index f243f0f..0000000 --- a/src/mainboard/amd/persimmon/Kconfig +++ /dev/null @@ -1,77 +0,0 @@ -# -# This file is part of the coreboot project. -# -# Copyright (C) 2011 Advanced Micro Devices, Inc. -# -# This program is free software; you can redistribute it and/or modify -# it under the terms of the GNU General Public License as published by -# the Free Software Foundation; version 2 of the License. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# - -config BOARD_AMD_PERSIMMON - def_bool n - -if BOARD_AMD_PERSIMMON - -config BOARD_SPECIFIC_OPTIONS - def_bool y - #select ROMCC_BOOTBLOCK - select CPU_AMD_AGESA_FAMILY14 - select NORTHBRIDGE_AMD_AGESA_FAMILY14 - select SOUTHBRIDGE_AMD_CIMX_SB800 - select SUPERIO_FINTEK_F81865F - select HAVE_OPTION_TABLE - select HAVE_PIRQ_TABLE - select HAVE_MP_TABLE - select HAVE_ACPI_RESUME - select HAVE_ACPI_TABLES - select BOARD_ROMSIZE_KB_4096 - select GFXUMA - -config MAINBOARD_DIR - string - default "amd/persimmon" - -config MAINBOARD_PART_NUMBER - string - default "Persimmon" - -config HW_MEM_HOLE_SIZEK - hex - default 0x200000 - -config MAX_CPUS - int - default 2 - -config IRQ_SLOT_COUNT - int - default 11 - -config ONBOARD_VGA_IS_PRIMARY - bool - default y - -config VGA_BIOS - bool - default n - -#config VGA_BIOS_FILE -# string "VGA BIOS path and filename" -# depends on VGA_BIOS -# default "rom/video/OntarioGenericVbios.bin" - -config VGA_BIOS_ID - string - default "1002,9802" - -config SB800_AHCI_ROM - bool - default n - -endif # BOARD_AMD_PERSIMMON diff --git a/src/mainboard/amd/persimmon/Kconfig.name b/src/mainboard/amd/persimmon/Kconfig.name deleted file mode 100644 index d50ebbe..0000000 --- a/src/mainboard/amd/persimmon/Kconfig.name +++ /dev/null @@ -1,2 +0,0 @@ -#config BOARD_AMD_PERSIMMON -# bool"Persimmon" diff --git a/src/mainboard/amd/persimmon/Makefile.inc b/src/mainboard/amd/persimmon/Makefile.inc deleted file mode 100644 index ba56286..0000000 --- a/src/mainboard/amd/persimmon/Makefile.inc +++ /dev/null @@ -1,29 +0,0 @@ -# -# This file is part of the coreboot project. -# -# Copyright (C) 2011 Advanced Micro Devices, Inc. -# -# This program is free software; you can redistribute it and/or modify -# it under the terms of the GNU General Public License as published by -# the Free Software Foundation; version 2 of the License. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# - -ifeq ($(CONFIG_AHCI_BIOS),y) -stripped_ahcibios_id = $(call strip_quotes,$(CONFIG_AHCI_BIOS_ID)) -cbfs-files-$(CONFIG_AHCI_BIOS) += pci$(stripped_ahcibios_id).rom -pci$(stripped_ahcibios_id).rom-file := $(call strip_quotes,$(CONFIG_AHCI_BIOS_FILE)) -pci$(stripped_ahcibios_id).rom-type := optionrom -endif - -romstage-y += buildOpts.c -romstage-y += BiosCallOuts.c -romstage-y += OemCustomize.c - -ramstage-y += buildOpts.c -ramstage-y += BiosCallOuts.c -ramstage-y += OemCustomize.c diff --git a/src/mainboard/amd/persimmon/OemCustomize.c b/src/mainboard/amd/persimmon/OemCustomize.c deleted file mode 100644 index 68de652..0000000 --- a/src/mainboard/amd/persimmon/OemCustomize.c +++ /dev/null @@ -1,123 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - - -#include <AGESA.h> -#include <northbridge/amd/agesa/state_machine.h> -#include <PlatformMemoryConfiguration.h> - - -static const PCIe_PORT_DESCRIPTOR PortList[] = { - // Initialize Port descriptor (PCIe port, Lanes 4, PCI Device Number 4, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER(PciePortEngine, 4, 4), - PCIE_PORT_DATA_INITIALIZER(PortEnabled, ChannelTypeExt6db, 4, - HotplugDisabled, - PcieGen2, - PcieGen2, - AspmL0sL1, 46) - }, - // Initialize Port descriptor (PCIe port, Lanes 5, PCI Device Number 5, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER(PciePortEngine, 5, 5), - PCIE_PORT_DATA_INITIALIZER(PortEnabled, ChannelTypeExt6db, 5, - HotplugDisabled, - PcieGen2, - PcieGen2, - AspmL0sL1, 46) - }, - // Initialize Port descriptor (PCIe port, Lanes 6, PCI Device Number 6, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER(PciePortEngine, 6, 6), - PCIE_PORT_DATA_INITIALIZER(PortEnabled, ChannelTypeExt6db, 6, - HotplugDisabled, - PcieGen2, - PcieGen2, - AspmL0sL1, 46) - }, - // Initialize Port descriptor (PCIe port, Lanes 7, PCI Device Number 7, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER(PciePortEngine, 7, 7), - PCIE_PORT_DATA_INITIALIZER(PortDisabled, ChannelTypeExt6db, 7, - HotplugDisabled, - PcieGen2, - PcieGen2, - AspmL0sL1, 0) - }, - // Initialize Port descriptor (PCIe port, Lanes 8, PCI Device Number 8, ...) - { - DESCRIPTOR_TERMINATE_LIST, - PCIE_ENGINE_DATA_INITIALIZER(PciePortEngine, 0, 3), - PCIE_PORT_DATA_INITIALIZER(PortEnabled, ChannelTypeExt6db, 8, - HotplugDisabled, - PcieGen2, - PcieGen2, - AspmL0sL1, 0) - } -}; - -static const PCIe_DDI_DESCRIPTOR DdiList[] = { - // Initialize Ddi descriptor (DDI interface Lanes 8:11, DdA, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER(PcieDdiEngine, 8, 11), - PCIE_DDI_DATA_INITIALIZER(ConnectorTypeLvds, Aux1, Hdp1) - }, - // Initialize Ddi descriptor (DDI interface Lanes 12:15, DdB, ...) - { - DESCRIPTOR_TERMINATE_LIST, - PCIE_ENGINE_DATA_INITIALIZER(PcieDdiEngine, 12, 15), - PCIE_DDI_DATA_INITIALIZER(ConnectorTypeDP, Aux2, Hdp2) - } -}; - -static const PCIe_COMPLEX_DESCRIPTOR PcieComplex = { - .Flags = DESCRIPTOR_TERMINATE_LIST, - .SocketId = 0, - .PciePortList = PortList, - .DdiLinkList = DdiList, -}; - -void board_BeforeInitEarly(struct sysinfo *cb, AMD_EARLY_PARAMS *InitEarly) -{ - InitEarly->GnbConfig.PcieComplexList = &PcieComplex; - InitEarly->GnbConfig.PsppPolicy = 0; -} - -/*---------------------------------------------------------------------------------------- - * CUSTOMER OVERIDES MEMORY TABLE - *---------------------------------------------------------------------------------------- - */ - -/* - * Platform Specific Overriding Table allows IBV/OEM to pass in platform information to AGESA - * (e.g. MemClk routing, the number of DIMM slots per channel,...). If PlatformSpecificTable - * is populated, AGESA will base its settings on the data from the table. Otherwise, it will - * use its default conservative settings. - */ -static CONST PSO_ENTRY ROMDATA PlatformMemoryTable[] = { - NUMBER_OF_DIMMS_SUPPORTED(ANY_SOCKET, ANY_CHANNEL, 2), - NUMBER_OF_CHANNELS_SUPPORTED(ANY_SOCKET, 1), - PSO_END -}; - -void board_BeforeInitPost(struct sysinfo *cb, AMD_POST_PARAMS *InitPost) -{ - InitPost->MemConfig.PlatformMemoryConfiguration = (PSO_ENTRY *)PlatformMemoryTable; -} diff --git a/src/mainboard/amd/persimmon/OptionsIds.h b/src/mainboard/amd/persimmon/OptionsIds.h deleted file mode 100644 index 2d8381b..0000000 --- a/src/mainboard/amd/persimmon/OptionsIds.h +++ /dev/null @@ -1,56 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/** - * @file - * - * IDS Option File - * - * This file is used to switch on/off IDS features. - * - */ -#ifndef _OPTION_IDS_H_ -#define _OPTION_IDS_H_ - -/** - * - * This file generates the defaults tables for the Integrated Debug Support - * Module. The documented build options are imported from a user controlled - * file for processing. The build options for the Integrated Debug Support - * Module are listed below: - * - * IDSOPT_IDS_ENABLED - * IDSOPT_ERROR_TRAP_ENABLED - * IDSOPT_CONTROL_ENABLED - * IDSOPT_TRACING_ENABLED - * IDSOPT_PERF_ANALYSIS - * IDSOPT_ASSERT_ENABLED - * IDS_DEBUG_PORT - * IDSOPT_CAR_CORRUPTION_CHECK_ENABLED - * - **/ - -#define IDSOPT_IDS_ENABLED TRUE -//#define IDSOPT_TRACING_ENABLED TRUE -#define IDSOPT_ASSERT_ENABLED TRUE - -//#define IDSOPT_DEBUG_ENABLED FALSE -//#undef IDSOPT_HOST_SIMNOW -//#define IDSOPT_HOST_SIMNOW FALSE -//#undef IDSOPT_HOST_HDT -//#define IDSOPT_HOST_HDT FALSE -//#define IDS_DEBUG_PORT 0x80 - -#endif diff --git a/src/mainboard/amd/persimmon/acpi/gpe.asl b/src/mainboard/amd/persimmon/acpi/gpe.asl deleted file mode 100644 index 3cf38c0..0000000 --- a/src/mainboard/amd/persimmon/acpi/gpe.asl +++ /dev/null @@ -1,69 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -Scope(_GPE) { /* Start Scope GPE */ - - /* Legacy PM event */ - Method(_L08) { - /* DBGO("\_GPE\_L08\n") */ - } - - /* Temp warning (TWarn) event */ - Method(_L09) { - /* DBGO("\_GPE\_L09\n") */ - /* Notify (_TZ.TZ00, 0x80) */ - } - - /* USB controller PME# */ - Method(_L0B) { - /* DBGO("\_GPE\_L0B\n") */ - Notify(_SB.PCI0.UOH1, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH2, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH3, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH4, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH5, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH6, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UEH1, 0x02) /* NOTIFY_DEVICE_WAKE */ - } - - /* ExtEvent0 SCI event */ - Method(_L10) { - /* DBGO("\_GPE\_L10\n") */ - } - - - /* ExtEvent1 SCI event */ - Method(_L11) { - /* DBGO("\_GPE\_L11\n") */ - } - - /* GPIO0 or GEvent8 event */ - Method(_L18) { - /* DBGO("\_GPE\_L18\n") */ - Notify(_SB.PCI0.PBR4, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.PBR5, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.PBR6, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.PBR7, 0x02) /* NOTIFY_DEVICE_WAKE */ - } - - /* Azalia SCI event */ - Method(_L1B) { - /* DBGO("\_GPE\_L1B\n") */ - Notify(_SB.PCI0.AZHD, 0x02) /* NOTIFY_DEVICE_WAKE */ - } -} /* End Scope GPE */ - -/* Contains the GPEs for USB overcurrent */ -#include "usb_oc.asl" diff --git a/src/mainboard/amd/persimmon/acpi/ide.asl b/src/mainboard/amd/persimmon/acpi/ide.asl deleted file mode 100644 index 59ea078..0000000 --- a/src/mainboard/amd/persimmon/acpi/ide.asl +++ /dev/null @@ -1,240 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* -Scope (_SB) { - Device(PCI0) { - Device(IDEC) { - Name(_ADR, 0x00140001) - #include "ide.asl" - } - } -} -*/ - -/* Some timing tables */ -Name(UDTT, Package(){ /* Udma timing table */ - 120, 90, 60, 45, 30, 20, 15, 0 /* UDMA modes 0 -> 6 */ -}) - -Name(MDTT, Package(){ /* MWDma timing table */ - 480, 150, 120, 0 /* Legacy DMA modes 0 -> 2 */ -}) - -Name(POTT, Package(){ /* Pio timing table */ - 600, 390, 270, 180, 120, 0 /* PIO modes 0 -> 4 */ -}) - -/* Some timing register value tables */ -Name(MDRT, Package(){ /* MWDma timing register table */ - 0x77, 0x21, 0x20, 0xFF /* Legacy DMA modes 0 -> 2 */ -}) - -Name(PORT, Package(){ - 0x99, 0x47, 0x34, 0x22, 0x20, 0x99 /* PIO modes 0 -> 4 */ -}) - -OperationRegion(ICRG, PCI_Config, 0x40, 0x20) /* ide control registers */ - Field(ICRG, AnyAcc, NoLock, Preserve) -{ - PPTS, 8, /* Primary PIO Slave Timing */ - PPTM, 8, /* Primary PIO Master Timing */ - OFFSET(0x04), PMTS, 8, /* Primary MWDMA Slave Timing */ - PMTM, 8, /* Primary MWDMA Master Timing */ - OFFSET(0x08), PPCR, 8, /* Primary PIO Control */ - OFFSET(0x0A), PPMM, 4, /* Primary PIO master Mode */ - PPSM, 4, /* Primary PIO slave Mode */ - OFFSET(0x14), PDCR, 2, /* Primary UDMA Control */ - OFFSET(0x16), PDMM, 4, /* Primary UltraDMA Mode */ - PDSM, 4, /* Primary UltraDMA Mode */ -} - -Method(GTTM, 1) /* get total time*/ -{ - Store(And(Arg0, 0x0F), Local0) /* Recovery Width */ - Increment(Local0) - Store(ShiftRight(Arg0, 4), Local1) /* Command Width */ - Increment(Local1) - Return(Multiply(30, Add(Local0, Local1))) -} - -Device(PRID) -{ - Name (_ADR, Zero) - Method(_GTM, 0, Serialized) - { - NAME(OTBF, Buffer(20) { /* out buffer */ - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00 - }) - - CreateDwordField(OTBF, 0, PSD0) /* PIO spd0 */ - CreateDwordField(OTBF, 4, DSD0) /* DMA spd0 */ - CreateDwordField(OTBF, 8, PSD1) /* PIO spd1 */ - CreateDwordField(OTBF, 12, DSD1) /* DMA spd1 */ - CreateDwordField(OTBF, 16, BFFG) /* buffer flags */ - - /* Just return if the channel is disabled */ - If(And(PPCR, 0x01)) { /* primary PIO control */ - Return(OTBF) - } - - /* Always tell them independent timing available and IOChannelReady used on both drives */ - Or(BFFG, 0x1A, BFFG) - - Store(GTTM(PPTM), PSD0) /* save total time of primary PIO master timming to PIO spd0 */ - Store(GTTM(PPTS), PSD1) /* save total time of primary PIO slave Timing to PIO spd1 */ - - If(And(PDCR, 0x01)) { /* It's under UDMA mode */ - Or(BFFG, 0x01, BFFG) - Store(DerefOf(Index(UDTT, PDMM)), DSD0) - } - Else { - Store(GTTM(PMTM), DSD0) /* Primary MWDMA Master Timing, DmaSpd0 */ - } - - If(And(PDCR, 0x02)) { /* It's under UDMA mode */ - Or(BFFG, 0x04, BFFG) - Store(DerefOf(Index(UDTT, PDSM)), DSD1) - } - Else { - Store(GTTM(PMTS), DSD1) /* Primary MWDMA Slave Timing, DmaSpd0 */ - } - - Return(OTBF) /* out buffer */ - } /* End Method(_GTM) */ - - Method(_STM, 3, Serialized) - { - NAME(INBF, Buffer(20) { /* in buffer */ - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, - 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00 - }) - - CreateDwordField(INBF, 0, PSD0) /* PIO spd0 */ - CreateDwordField(INBF, 4, DSD0) /* PIO spd0 */ - CreateDwordField(INBF, 8, PSD1) /* PIO spd1 */ - CreateDwordField(INBF, 12, DSD1) /* DMA spd1 */ - CreateDwordField(INBF, 16, BFFG) /*buffer flag */ - - Store(Match(POTT, MLE, PSD0, MTR, 0, 0), Local0) - Divide(Local0, 5, PPMM,) /* Primary PIO master Mode */ - Store(Match(POTT, MLE, PSD1, MTR, 0, 0), Local1) - Divide(Local1, 5, PPSM,) /* Primary PIO slave Mode */ - - Store(DerefOf(Index(PORT, Local0)), PPTM) /* Primary PIO Master Timing */ - Store(DerefOf(Index(PORT, Local1)), PPTS) /* Primary PIO Slave Timing */ - - If(And(BFFG, 0x01)) { /* Drive 0 is under UDMA mode */ - Store(Match(UDTT, MLE, DSD0, MTR, 0, 0), Local0) - Divide(Local0, 7, PDMM,) - Or(PDCR, 0x01, PDCR) - } - Else { - If(LNotEqual(DSD0, 0xFFFFFFFF)) { - Store(Match(MDTT, MLE, DSD0, MTR, 0, 0), Local0) - Store(DerefOf(Index(MDRT, Local0)), PMTM) - } - } - - If(And(BFFG, 0x04)) { /* Drive 1 is under UDMA mode */ - Store(Match(UDTT, MLE, DSD1, MTR, 0, 0), Local0) - Divide(Local0, 7, PDSM,) - Or(PDCR, 0x02, PDCR) - } - Else { - If(LNotEqual(DSD1, 0xFFFFFFFF)) { - Store(Match(MDTT, MLE, DSD1, MTR, 0, 0), Local0) - Store(DerefOf(Index(MDRT, Local0)), PMTS) - } - } - /* Return(INBF) */ - } /*End Method(_STM) */ - Device(MST) - { - Name(_ADR, 0) - Method(_GTF, 0, Serialized) { - Name(CMBF, Buffer(21) { - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF5 - }) - CreateByteField(CMBF, 1, POMD) - CreateByteField(CMBF, 8, DMMD) - CreateByteField(CMBF, 5, CMDA) - CreateByteField(CMBF, 12, CMDB) - CreateByteField(CMBF, 19, CMDC) - - Store(0xA0, CMDA) - Store(0xA0, CMDB) - Store(0xA0, CMDC) - - Or(PPMM, 0x08, POMD) - - If(And(PDCR, 0x01)) { - Or(PDMM, 0x40, DMMD) - } - Else { - Store(Match - (MDTT, MLE, GTTM(PMTM), - MTR, 0, 0), Local0) - If(LLess(Local0, 3)) { - Or(0x20, Local0, DMMD) - } - } - Return(CMBF) - } - } /* End Device(MST) */ - - Device(SLAV) - { - Name(_ADR, 1) - Method(_GTF, 0, Serialized) { - Name(CMBF, Buffer(21) { - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x03, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xEF, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF5 - }) - CreateByteField(CMBF, 1, POMD) - CreateByteField(CMBF, 8, DMMD) - CreateByteField(CMBF, 5, CMDA) - CreateByteField(CMBF, 12, CMDB) - CreateByteField(CMBF, 19, CMDC) - - Store(0xB0, CMDA) - Store(0xB0, CMDB) - Store(0xB0, CMDC) - - Or(PPSM, 0x08, POMD) - - If(And(PDCR, 0x02)) { - Or(PDSM, 0x40, DMMD) - } - Else { - Store(Match - (MDTT, MLE, GTTM(PMTS), - MTR, 0, 0), Local0) - If(LLess(Local0, 3)) { - Or(0x20, Local0, DMMD) - } - } - Return(CMBF) - } - } /* End Device(SLAV) */ -} diff --git a/src/mainboard/amd/persimmon/acpi/mainboard.asl b/src/mainboard/amd/persimmon/acpi/mainboard.asl deleted file mode 100644 index 702cb92..0000000 --- a/src/mainboard/amd/persimmon/acpi/mainboard.asl +++ /dev/null @@ -1,61 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* Data to be patched by the BIOS during POST */ -/* FIXME the patching is not done yet! */ -/* Memory related values */ -Name(LOMH, 0x0) /* Start of unused memory in C0000-E0000 range */ -Name(PBAD, 0x0) /* Address of BIOS area (If TOM2 != 0, Addr >> 16) */ -Name(PBLN, 0x0) /* Length of BIOS area */ - -Name(PCBA, CONFIG_MMCONF_BASE_ADDRESS) /* Base address of PCIe config space */ -Name(HPBA, 0xFED00000) /* Base address of HPET table */ - -/* Some global data */ -Name(OSVR, 3) /* Assume nothing. WinXp = 1, Vista = 2, Linux = 3, WinCE = 4 */ -Name(OSV, Ones) /* Assume nothing */ -Name(PMOD, One) /* Assume APIC */ - -Scope(_SB) { - Method(OSFL, 0){ - - if(LNotEqual(OSVR, Ones)) {Return(OSVR)} /* OS version was already detected */ - - if(CondRefOf(_OSI)) - { - Store(1, OSVR) /* Assume some form of XP */ - if (_OSI("Windows 2006")) /* Vista */ - { - Store(2, OSVR) - } - } else { - If(WCMP(_OS,"Linux")) { - Store(3, OSVR) /* Linux */ - } Else { - Store(4, OSVR) /* Gotta be WinCE */ - } - } - Return(OSVR) - } -} - -Scope(_SI) { - Method(_SST, 1) { - /* DBGO("\_SI\_SST\n") */ - /* DBGO(" New Indicator state: ") */ - /* DBGO(Arg0) */ - /* DBGO("\n") */ - } -} /* End Scope SI */ diff --git a/src/mainboard/amd/persimmon/acpi/routing.asl b/src/mainboard/amd/persimmon/acpi/routing.asl deleted file mode 100644 index 2cf17a7..0000000 --- a/src/mainboard/amd/persimmon/acpi/routing.asl +++ /dev/null @@ -1,337 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* -#include <arch/acpi.h> -DefinitionBlock ("DSDT.AML", "DSDT", 0x01, OEM_ID, ACPI_TABLE_CREATOR, 0x00010001 - ) - { - #include "routing.asl" - } -*/ - -/* Routing is in System Bus scope */ -Scope(_SB) { - Name(PR0, Package(){ - /* NB devices */ - /* Bus 0, Dev 0 - RS780 Host Controller */ - /* Bus 0, Dev 1 - PCI Bridge for Internal Graphics */ - Package(){0x0001FFFF, 0, INTC, 0 }, - Package(){0x0001FFFF, 1, INTD, 0 }, - /* Bus 0, Dev 2 - PCIe Bridge for x8 PCIe Slot (GFX0) */ - Package(){0x0002FFFF, 0, INTC, 0 }, - Package(){0x0002FFFF, 1, INTD, 0 }, - Package(){0x0002FFFF, 2, INTA, 0 }, - Package(){0x0002FFFF, 3, INTB, 0 }, - /* Bus 0, Dev 3 - PCIe graphics port 1 bridge */ - Package(){0x0003FFFF, 0, INTD, 0 }, - Package(){0x0003FFFF, 1, INTA, 0 }, - Package(){0x0003FFFF, 2, INTB, 0 }, - Package(){0x0003FFFF, 3, INTC, 0 }, - /* Bus 0, Dev 4 - PCIe Bridge for Express Card Slot */ - Package(){0x0004FFFF, 0, INTA, 0 }, - Package(){0x0004FFFF, 1, INTB, 0 }, - Package(){0x0004FFFF, 2, INTC, 0 }, - Package(){0x0004FFFF, 3, INTD, 0 }, - /* Bus 0, Dev 5 - General purpose PCIe bridge 5 */ - Package(){0x0005FFFF, 0, INTB, 0 }, - Package(){0x0005FFFF, 1, INTC, 0 }, - Package(){0x0005FFFF, 2, INTD, 0 }, - Package(){0x0005FFFF, 3, INTA, 0 }, - /* Bus 0, Dev 6 - PCIe Bridge for Ethernet Chip */ - Package(){0x0006FFFF, 0, INTC, 0 }, - Package(){0x0006FFFF, 1, INTD, 0 }, - Package(){0x0006FFFF, 2, INTA, 0 }, - Package(){0x0006FFFF, 3, INTB, 0 }, - /* Bus 0, Dev 7 - PCIe Bridge for x1 PCIe Slot */ - Package(){0x0007FFFF, 0, INTD, 0 }, - Package(){0x0007FFFF, 1, INTA, 0 }, - Package(){0x0007FFFF, 2, INTB, 0 }, - Package(){0x0007FFFF, 3, INTC, 0 }, - - /* Bus 0, Funct 8 - Southbridge port (normally hidden) */ - - - /* SB devices */ - /* Bus 0, Dev 17 - SATA controller */ - Package(){0x0011FFFF, 0, INTD, 0 }, - - /* OHCI, dev 18, 19, 22 func 0 - * EHCI, dev 18, 19, 22 func 2 */ - Package(){0x0012FFFF, 0, INTC, 0 }, /* Dev 12, INTA, handled by INTC device, Global */ - Package(){0x0012FFFF, 1, INTB, 0 }, /* Dev 12, INTB, handled by INTB device, Global */ - - Package(){0x0013FFFF, 0, INTC, 0 }, - Package(){0x0013FFFF, 1, INTB, 0 }, - - Package(){0x0016FFFF, 0, INTC, 0 }, - Package(){0x0016FFFF, 1, INTB, 0 }, - - /* Bus 0, Dev 20 - F0:SMBus/ACPI; F1:IDE; F2:HDAudio; F3:LPC; F4:PCIBridge; F5:USB */ - Package(){0x0014FFFF, 0, INTA, 0 }, - Package(){0x0014FFFF, 1, INTB, 0 }, - Package(){0x0014FFFF, 2, INTC, 0 }, - Package(){0x0014FFFF, 3, INTD, 0 }, - - Package(){0x0015FFFF, 0, INTA, 0 }, - Package(){0x0015FFFF, 1, INTB, 0 }, - Package(){0x0015FFFF, 2, INTC, 0 }, - Package(){0x0015FFFF, 3, INTD, 0 }, - }) - - Name(APR0, Package(){ - /* NB devices in APIC mode */ - /* Bus 0, Dev 0 - RS780 Host Controller */ - - /* Bus 0, Dev 1 - PCI Bridge for Internal Graphics */ - Package(){0x0001FFFF, 0, 0, 18 }, - Package(){0x0001FFFF, 1, 0, 19 }, - - /* Bus 0, Dev 2 - PCIe Bridge for x8 PCIe Slot (GFX0) */ - Package(){0x0002FFFF, 0, 0, 18 }, - /* Package(){0x0002FFFF, 1, 0, 19 }, */ - /* Package(){0x0002FFFF, 2, 0, 16 }, */ - /* Package(){0x0002FFFF, 3, 0, 17 }, */ - - /* Bus 0, Dev 3 - PCIe graphics port 1 bridge */ - Package(){0x0003FFFF, 0, 0, 19 }, - Package(){0x0003FFFF, 1, 0, 16 }, - Package(){0x0003FFFF, 2, 0, 17 }, - Package(){0x0003FFFF, 3, 0, 18 }, - - /* Bus 0, Dev 4 - PCIe Bridge for Express Card Slot */ - Package(){0x0004FFFF, 0, 0, 16 }, - Package(){0x0004FFFF, 1, 0, 17 }, - Package(){0x0004FFFF, 2, 0, 18 }, - Package(){0x0004FFFF, 3, 0, 19 }, - - /* Bus 0, Dev 5 - General purpose PCIe bridge 5 */ - Package(){0x0005FFFF, 0, 0, 17 }, - Package(){0x0005FFFF, 1, 0, 18 }, - Package(){0x0005FFFF, 2, 0, 19 }, - Package(){0x0005FFFF, 3, 0, 16 }, - - /* Bus 0, Dev 6 - General purpose PCIe bridge 6 */ - Package(){0x0006FFFF, 0, 0, 18 }, - Package(){0x0006FFFF, 1, 0, 19 }, - Package(){0x0006FFFF, 2, 0, 16 }, - Package(){0x0006FFFF, 3, 0, 17 }, - - /* Bus 0, Dev 7 - PCIe Bridge for network card */ - Package(){0x0007FFFF, 0, 0, 19 }, - Package(){0x0007FFFF, 1, 0, 16 }, - Package(){0x0007FFFF, 2, 0, 17 }, - Package(){0x0007FFFF, 3, 0, 18 }, - - /* Bus 0, Funct 8 - Southbridge port (normally hidden) */ - - /* SB devices in APIC mode */ - /* Bus 0, Dev 17 - SATA controller */ - Package(){0x0011FFFF, 0, 0, 19 }, - - /* OHCI, dev 18, 19, 22 func 0 - * EHCI, dev 18, 19, 22 func 2 */ - Package(){0x0012FFFF, 0, 0, 18 }, - Package(){0x0012FFFF, 1, 0, 17 }, - - Package(){0x0013FFFF, 0, 0, 18 }, - Package(){0x0013FFFF, 1, 0, 17 }, - - Package(){0x0016FFFF, 0, 0, 18 }, - Package(){0x0016FFFF, 1, 0, 17 }, - - /* Bus 0, Dev 20 - F0:SMBus/ACPI, F1:IDE; F2:HDAudio; F3:LPC; F4:PCIBridge; F5:USB */ - Package(){0x0014FFFF, 0, 0, 16 }, - Package(){0x0014FFFF, 1, 0, 17 }, - Package(){0x0014FFFF, 2, 0, 18 }, - Package(){0x0014FFFF, 3, 0, 19 }, - /* Package(){0x00140004, 2, 0, 18 }, */ - /* Package(){0x00140004, 3, 0, 19 }, */ - /* Package(){0x00140005, 1, 0, 17 }, */ - /* Package(){0x00140006, 1, 0, 17 }, */ - - /* TODO: pcie */ - Package(){0x0015FFFF, 0, 0, 16 }, - Package(){0x0015FFFF, 1, 0, 17 }, - Package(){0x0015FFFF, 2, 0, 18 }, - Package(){0x0015FFFF, 3, 0, 19 }, - }) - - Name(PR1, Package(){ - /* Internal graphics - RS780 VGA, Bus1, Dev5 */ - Package(){0x0005FFFF, 0, INTA, 0 }, - Package(){0x0005FFFF, 1, INTB, 0 }, - Package(){0x0005FFFF, 2, INTC, 0 }, - Package(){0x0005FFFF, 3, INTD, 0 }, - }) - Name(APR1, Package(){ - /* Internal graphics - RS780 VGA, Bus1, Dev5 */ - Package(){0x0005FFFF, 0, 0, 18 }, - Package(){0x0005FFFF, 1, 0, 19 }, - /* Package(){0x0005FFFF, 2, 0, 20 }, */ - /* Package(){0x0005FFFF, 3, 0, 17 }, */ - }) - - Name(PS2, Package(){ - /* The external GFX - Hooked to PCIe slot 2 */ - Package(){0x0000FFFF, 0, INTC, 0 }, - Package(){0x0000FFFF, 1, INTD, 0 }, - Package(){0x0000FFFF, 2, INTA, 0 }, - Package(){0x0000FFFF, 3, INTB, 0 }, - }) - Name(APS2, Package(){ - /* The external GFX - Hooked to PCIe slot 2 */ - Package(){0x0000FFFF, 0, 0, 18 }, - Package(){0x0000FFFF, 1, 0, 19 }, - Package(){0x0000FFFF, 2, 0, 16 }, - Package(){0x0000FFFF, 3, 0, 17 }, - }) - - Name(PS4, Package(){ - /* PCIe slot - Hooked to PCIe slot 4 */ - Package(){0x0000FFFF, 0, INTA, 0 }, - Package(){0x0000FFFF, 1, INTB, 0 }, - Package(){0x0000FFFF, 2, INTC, 0 }, - Package(){0x0000FFFF, 3, INTD, 0 }, - }) - Name(APS4, Package(){ - /* PCIe slot - Hooked to PCIe slot 4 */ - Package(){0x0000FFFF, 0, 0, 16 }, - Package(){0x0000FFFF, 1, 0, 17 }, - Package(){0x0000FFFF, 2, 0, 18 }, - Package(){0x0000FFFF, 3, 0, 19 }, - }) - - Name(PS5, Package(){ - /* PCIe slot - Hooked to PCIe slot 5 */ - Package(){0x0000FFFF, 0, INTB, 0 }, - Package(){0x0000FFFF, 1, INTC, 0 }, - Package(){0x0000FFFF, 2, INTD, 0 }, - Package(){0x0000FFFF, 3, INTA, 0 }, - }) - Name(APS5, Package(){ - /* PCIe slot - Hooked to PCIe slot 5 */ - Package(){0x0000FFFF, 0, 0, 17 }, - Package(){0x0000FFFF, 1, 0, 18 }, - Package(){0x0000FFFF, 2, 0, 19 }, - Package(){0x0000FFFF, 3, 0, 16 }, - }) - - Name(PS6, Package(){ - /* PCIe slot - Hooked to PCIe slot 6 */ - Package(){0x0000FFFF, 0, INTC, 0 }, - Package(){0x0000FFFF, 1, INTD, 0 }, - Package(){0x0000FFFF, 2, INTA, 0 }, - Package(){0x0000FFFF, 3, INTB, 0 }, - }) - Name(APS6, Package(){ - /* PCIe slot - Hooked to PCIe slot 6 */ - Package(){0x0000FFFF, 0, 0, 18 }, - Package(){0x0000FFFF, 1, 0, 19 }, - Package(){0x0000FFFF, 2, 0, 16 }, - Package(){0x0000FFFF, 3, 0, 17 }, - }) - - Name(PS7, Package(){ - /* The onboard Ethernet chip - Hooked to PCIe slot 7 */ - Package(){0x0000FFFF, 0, INTD, 0 }, - Package(){0x0000FFFF, 1, INTA, 0 }, - Package(){0x0000FFFF, 2, INTB, 0 }, - Package(){0x0000FFFF, 3, INTC, 0 }, - }) - Name(APS7, Package(){ - /* The onboard Ethernet chip - Hooked to PCIe slot 7 */ - Package(){0x0000FFFF, 0, 0, 19 }, - Package(){0x0000FFFF, 1, 0, 16 }, - Package(){0x0000FFFF, 2, 0, 17 }, - Package(){0x0000FFFF, 3, 0, 18 }, - }) - - Name(PE0, Package(){ - /* PCIe slot - Hooked to PCIe slot 10 */ - Package(){0x0000FFFF, 0, INTA, 0 }, - Package(){0x0000FFFF, 1, INTB, 0 }, - Package(){0x0000FFFF, 2, INTC, 0 }, - Package(){0x0000FFFF, 3, INTD, 0 }, - }) - Name(APE0, Package(){ - /* PCIe slot - Hooked to PCIe */ - Package(){0x0000FFFF, 0, 0, 16 }, - Package(){0x0000FFFF, 1, 0, 17 }, - Package(){0x0000FFFF, 2, 0, 18 }, - Package(){0x0000FFFF, 3, 0, 19 }, - }) - - Name(PE1, Package(){ - /* PCIe slot - Hooked to PCIe slot 10 */ - Package(){0x0000FFFF, 0, INTB, 0 }, - Package(){0x0000FFFF, 1, INTC, 0 }, - Package(){0x0000FFFF, 2, INTD, 0 }, - Package(){0x0000FFFF, 3, INTA, 0 }, - }) - Name(APE1, Package(){ - /* PCIe slot - Hooked to PCIe */ - Package(){0x0000FFFF, 0, 0, 17 }, - Package(){0x0000FFFF, 1, 0, 18 }, - Package(){0x0000FFFF, 2, 0, 19 }, - Package(){0x0000FFFF, 3, 0, 16 }, - }) - - Name(PE2, Package(){ - /* PCIe slot - Hooked to PCIe slot 10 */ - Package(){0x0000FFFF, 0, INTC, 0 }, - Package(){0x0000FFFF, 1, INTD, 0 }, - Package(){0x0000FFFF, 2, INTA, 0 }, - Package(){0x0000FFFF, 3, INTB, 0 }, - }) - Name(APE2, Package(){ - /* PCIe slot - Hooked to PCIe */ - Package(){0x0000FFFF, 0, 0, 18 }, - Package(){0x0000FFFF, 1, 0, 19 }, - Package(){0x0000FFFF, 2, 0, 16 }, - Package(){0x0000FFFF, 3, 0, 17 }, - }) - - Name(PE3, Package(){ - /* PCIe slot - Hooked to PCIe slot 10 */ - Package(){0x0000FFFF, 0, INTD, 0 }, - Package(){0x0000FFFF, 1, INTA, 0 }, - Package(){0x0000FFFF, 2, INTB, 0 }, - Package(){0x0000FFFF, 3, INTC, 0 }, - }) - Name(APE3, Package(){ - /* PCIe slot - Hooked to PCIe */ - Package(){0x0000FFFF, 0, 0, 19 }, - Package(){0x0000FFFF, 1, 0, 16 }, - Package(){0x0000FFFF, 2, 0, 17 }, - Package(){0x0000FFFF, 3, 0, 18 }, - }) - - Name(PCIB, Package(){ - /* PCI slots: slot 0, slot 1, slot 2 behind Dev14, Func 4. */ - Package(){0x0003FFFF, 0, 0, 0x14 }, - Package(){0x0003FFFF, 1, 0, 0x15 }, - Package(){0x0003FFFF, 2, 0, 0x16 }, - Package(){0x0003FFFF, 3, 0, 0x17 }, - Package(){0x0004FFFF, 0, 0, 0x15 }, - Package(){0x0004FFFF, 1, 0, 0x16 }, - Package(){0x0004FFFF, 2, 0, 0x17 }, - Package(){0x0004FFFF, 3, 0, 0x14 }, - Package(){0x0005FFFF, 0, 0, 0x16 }, - Package(){0x0005FFFF, 1, 0, 0x17 }, - Package(){0x0005FFFF, 2, 0, 0x14 }, - Package(){0x0005FFFF, 3, 0, 0x15 }, - }) -} diff --git a/src/mainboard/amd/persimmon/acpi/sata.asl b/src/mainboard/amd/persimmon/acpi/sata.asl deleted file mode 100644 index 9e0e535..0000000 --- a/src/mainboard/amd/persimmon/acpi/sata.asl +++ /dev/null @@ -1,145 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* simple name description */ - -/* -Scope (_SB) { - Device(PCI0) { - Device(SATA) { - Name(_ADR, 0x00110000) - #include "sata.asl" - } - } -} -*/ - -Name(STTM, Buffer(20) { - 0x78, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, - 0x78, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, - 0x1f, 0x00, 0x00, 0x00 -}) - -/* Start by clearing the PhyRdyChg bits */ -Method(_INI) { - _GPE._L1F() -} - -Device(PMRY) -{ - Name(_ADR, 0) - Method(_GTM, 0x0, NotSerialized) { - Return(STTM) - } - Method(_STM, 0x3, NotSerialized) {} - - Device(PMST) { - Name(_ADR, 0) - Method(_STA,0) { - if (LGreater(P0IS,0)) { - return (0x0F) /* sata is visible */ - } - else { - return (0x00) /* sata is missing */ - } - } - }/* end of PMST */ - - Device(PSLA) - { - Name(_ADR, 1) - Method(_STA,0) { - if (LGreater(P1IS,0)) { - return (0x0F) /* sata is visible */ - } - else { - return (0x00) /* sata is missing */ - } - } - } /* end of PSLA */ -} /* end of PMRY */ - - -Device(SEDY) -{ - Name(_ADR, 1) /* IDE Scondary Channel */ - Method(_GTM, 0x0, NotSerialized) { - Return(STTM) - } - Method(_STM, 0x3, NotSerialized) {} - - Device(SMST) - { - Name(_ADR, 0) - Method(_STA,0) { - if (LGreater(P2IS,0)) { - return (0x0F) /* sata is visible */ - } - else { - return (0x00) /* sata is missing */ - } - } - } /* end of SMST */ - - Device(SSLA) - { - Name(_ADR, 1) - Method(_STA,0) { - if (LGreater(P3IS,0)) { - return (0x0F) /* sata is visible */ - } - else { - return (0x00) /* sata is missing */ - } - } - } /* end of SSLA */ -} /* end of SEDY */ - -/* SATA Hot Plug Support */ -Scope(_GPE) { - Method(_L1F,0x0,NotSerialized) { - if (_SB.P0PR) { - if (LGreater(_SB.P0IS,0)) { - sleep(32) - } - Notify(_SB.PCI0.STCR.PMRY.PMST, 0x01) /* NOTIFY_DEVICE_CHECK */ - store(one, _SB.P0PR) - } - - if (_SB.P1PR) { - if (LGreater(_SB.P1IS,0)) { - sleep(32) - } - Notify(_SB.PCI0.STCR.PMRY.PSLA, 0x01) /* NOTIFY_DEVICE_CHECK */ - store(one, _SB.P1PR) - } - - if (_SB.P2PR) { - if (LGreater(_SB.P2IS,0)) { - sleep(32) - } - Notify(_SB.PCI0.STCR.SEDY.SMST, 0x01) /* NOTIFY_DEVICE_CHECK */ - store(one, _SB.P2PR) - } - - if (_SB.P3PR) { - if (LGreater(_SB.P3IS,0)) { - sleep(32) - } - Notify(_SB.PCI0.STCR.SEDY.SSLA, 0x01) /* NOTIFY_DEVICE_CHECK */ - store(one, _SB.P3PR) - } - } -} diff --git a/src/mainboard/amd/persimmon/acpi/sleep.asl b/src/mainboard/amd/persimmon/acpi/sleep.asl deleted file mode 100644 index 47de049..0000000 --- a/src/mainboard/amd/persimmon/acpi/sleep.asl +++ /dev/null @@ -1,117 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* Wake status package */ -Name(WKST,Package(){Zero, Zero}) - -/* -* _PTS - Prepare to Sleep method -* -* Entry: -* Arg0=The value of the sleeping state S1=1, S2=2, etc -* -* Exit: -* -none- -* -* The _PTS control method is executed at the beginning of the sleep process -* for S1-S5. The sleeping value is passed to the _PTS control method. This -* control method may be executed a relatively long time before entering the -* sleep state and the OS may abort the operation without notification to -* the ACPI driver. This method cannot modify the configuration or power -* state of any device in the system. -*/ -Method(_PTS, 1) { - /* DBGO("\_PTS\n") */ - /* DBGO("From S0 to S") */ - /* DBGO(Arg0) */ - /* DBGO("\n") */ - - /* Don't allow PCIRST# to reset USB */ - if (LEqual(Arg0,3)){ - Store(0,URRE) - } - - /* Clear sleep SMI status flag and enable sleep SMI trap. */ - /*Store(One, CSSM) - Store(One, SSEN)*/ - - /* On older chips, clear PciExpWakeDisEn */ - /*if (LLessEqual(_SB.SBRI, 0x13)) { - * Store(0,_SB.PWDE) - *} - */ - - /* Clear wake status structure. */ - Store(0, Index(WKST,0)) - Store(0, Index(WKST,1)) -} /* End Method(_PTS) */ - -/* -* _BFS OEM Back From Sleep method -* -* Entry: -* Arg0=The value of the sleeping state S1=1, S2=2 -* -* Exit: -* -none- -*/ -Method(_BFS, 1) { - /* DBGO("\_BFS\n") */ - /* DBGO("From S") */ - /* DBGO(Arg0) */ - /* DBGO(" to S0\n") */ -} - -/* -* _WAK System Wake method -* -* Entry: -* Arg0=The value of the sleeping state S1=1, S2=2 -* -* Exit: -* Return package of 2 DWords -* Dword 1 - Status -* 0x00000000 wake succeeded -* 0x00000001 Wake was signaled but failed due to lack of power -* 0x00000002 Wake was signaled but failed due to thermal condition -* Dword 2 - Power Supply state -* if non-zero the effective S-state the power supply entered -*/ -Method(_WAK, 1) { - /* DBGO("\_WAK\n") */ - /* DBGO("From S") */ - /* DBGO(Arg0) */ - /* DBGO(" to S0\n") */ - - /* Re-enable HPET */ - Store(1,HPDE) - - /* Restore PCIRST# so it resets USB */ - if (LEqual(Arg0,3)){ - Store(1,URRE) - } - - /* Arbitrarily clear PciExpWakeStatus */ - Store(PWST, Local1) - Store(Local1, PWST) - - /* if (DeRefOf(Index(WKST,0))) { - * Store(0, Index(WKST,1)) - * } else { - * Store(Arg0, Index(WKST,1)) - * } - */ - Return(WKST) -} /* End Method(_WAK) */ diff --git a/src/mainboard/amd/persimmon/acpi/superio.asl b/src/mainboard/amd/persimmon/acpi/superio.asl deleted file mode 100644 index daf6e91..0000000 --- a/src/mainboard/amd/persimmon/acpi/superio.asl +++ /dev/null @@ -1,14 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* No Super I/O device or functionality yet */ diff --git a/src/mainboard/amd/persimmon/acpi/usb_oc.asl b/src/mainboard/amd/persimmon/acpi/usb_oc.asl deleted file mode 100644 index a209909..0000000 --- a/src/mainboard/amd/persimmon/acpi/usb_oc.asl +++ /dev/null @@ -1,171 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* simple name description */ -/* -#include <arch/acpi.h> -DefinitionBlock ("DSDT.AML", "DSDT", 0x01, OEM_ID, ACPI_TABLE_CREATOR, 0x00010001 - ) - { - #include "usb.asl" - } -*/ - -/* USB overcurrent mapping pins. */ -Name(UOM0, 0) -Name(UOM1, 2) -Name(UOM2, 0) -Name(UOM3, 7) -Name(UOM4, 2) -Name(UOM5, 2) -Name(UOM6, 6) -Name(UOM7, 2) -Name(UOM8, 6) -Name(UOM9, 6) - -Method(UCOC, 0) { - Sleep(20) - Store(0x13,CMTI) - Store(0,GPSL) -} - -/* USB Port 0 overcurrent uses Gpm 0 */ -If(LLessEqual(UOM0,9)) { - Scope (_GPE) { - Method (_L13) { - UCOC() - if(LEqual(GPB0,PLC0)) { - Not(PLC0,PLC0) - Store(PLC0, _SB.PT0D) - } - } - } -} - -/* USB Port 1 overcurrent uses Gpm 1 */ -If (LLessEqual(UOM1,9)) { - Scope (_GPE) { - Method (_L14) { - UCOC() - if (LEqual(GPB1,PLC1)) { - Not(PLC1,PLC1) - Store(PLC1, _SB.PT1D) - } - } - } -} - -/* USB Port 2 overcurrent uses Gpm 2 */ -If (LLessEqual(UOM2,9)) { - Scope (_GPE) { - Method (_L15) { - UCOC() - if (LEqual(GPB2,PLC2)) { - Not(PLC2,PLC2) - Store(PLC2, _SB.PT2D) - } - } - } -} - -/* USB Port 3 overcurrent uses Gpm 3 */ -If (LLessEqual(UOM3,9)) { - Scope (_GPE) { - Method (_L16) { - UCOC() - if (LEqual(GPB3,PLC3)) { - Not(PLC3,PLC3) - Store(PLC3, _SB.PT3D) - } - } - } -} - -/* USB Port 4 overcurrent uses Gpm 4 */ -If (LLessEqual(UOM4,9)) { - Scope (_GPE) { - Method (_L19) { - UCOC() - if (LEqual(GPB4,PLC4)) { - Not(PLC4,PLC4) - Store(PLC4, _SB.PT4D) - } - } - } -} - -/* USB Port 5 overcurrent uses Gpm 5 */ -If (LLessEqual(UOM5,9)) { - Scope (_GPE) { - Method (_L1A) { - UCOC() - if (LEqual(GPB5,PLC5)) { - Not(PLC5,PLC5) - Store(PLC5, _SB.PT5D) - } - } - } -} - -/* USB Port 6 overcurrent uses Gpm 6 */ -If (LLessEqual(UOM6,9)) { - Scope (_GPE) { - /* Method (_L1C) { */ - Method (_L06) { - UCOC() - if (LEqual(GPB6,PLC6)) { - Not(PLC6,PLC6) - Store(PLC6, _SB.PT6D) - } - } - } -} - -/* USB Port 7 overcurrent uses Gpm 7 */ -If (LLessEqual(UOM7,9)) { - Scope (_GPE) { - /* Method (_L1D) { */ - Method (_L07) { - UCOC() - if (LEqual(GPB7,PLC7)) { - Not(PLC7,PLC7) - Store(PLC7, _SB.PT7D) - } - } - } -} - -/* USB Port 8 overcurrent uses Gpm 8 */ -If (LLessEqual(UOM8,9)) { - Scope (_GPE) { - Method (_L17) { - if (LEqual(G8IS,PLC8)) { - Not(PLC8,PLC8) - Store(PLC8, _SB.PT8D) - } - } - } -} - -/* USB Port 9 overcurrent uses Gpm 9 */ -If (LLessEqual(UOM9,9)) { - Scope (_GPE) { - Method (_L0E) { - if (LEqual(G9IS,0)) { - Store(1,_SB.PT9D) - } - } - } -} diff --git a/src/mainboard/amd/persimmon/acpi_tables.c b/src/mainboard/amd/persimmon/acpi_tables.c deleted file mode 100644 index 97ea649..0000000 --- a/src/mainboard/amd/persimmon/acpi_tables.c +++ /dev/null @@ -1,43 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <arch/acpi.h> -#include <arch/ioapic.h> - -unsigned long acpi_fill_madt(unsigned long current) -{ - /* create all subtables for processors */ - current = acpi_create_madt_lapics(current); - - /* Write SB800 IOAPIC, only one */ - current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, - CONFIG_MAX_CPUS, IO_APIC_ADDR, 0); - - current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) - current, 0, 0, 2, 0); - current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) - current, 0, 9, 9, 0xF); - - /* 0: mean bus 0--->ISA */ - /* 0: PIC 0 */ - /* 2: APIC 2 */ - /* 5 mean: 0101 --> Edge-triggered, Active high */ - - /* create all subtables for processors */ - /* current = acpi_create_madt_lapic_nmis(current, 5, 1); */ - /* 1: LINT1 connect to NMI */ - - return current; -} diff --git a/src/mainboard/amd/persimmon/board_info.txt b/src/mainboard/amd/persimmon/board_info.txt deleted file mode 100644 index 85cb19a..0000000 --- a/src/mainboard/amd/persimmon/board_info.txt +++ /dev/null @@ -1,5 +0,0 @@ -Board name: DBFT1-00-EVAL-KT (Persimmon) -Category: eval -ROM protocol: SPI -ROM socketed: n -Flashrom support: y diff --git a/src/mainboard/amd/persimmon/buildOpts.c b/src/mainboard/amd/persimmon/buildOpts.c deleted file mode 100644 index d99cc81..0000000 --- a/src/mainboard/amd/persimmon/buildOpts.c +++ /dev/null @@ -1,294 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/** - * @file - * - * AMD User options selection for a Brazos platform solution system - * - * This file is placed in the user's platform directory and contains the - * build option selections desired for that platform. - * - * For Information about this file, see @ref platforminstall. - * - */ - -#include <stdlib.h> - - -/* Select the CPU family. */ -#define INSTALL_FAMILY_10_SUPPORT FALSE -#define INSTALL_FAMILY_12_SUPPORT FALSE -#define INSTALL_FAMILY_14_SUPPORT TRUE -#define INSTALL_FAMILY_15_SUPPORT FALSE - -/* Select the CPU socket type. */ -#define INSTALL_G34_SOCKET_SUPPORT FALSE -#define INSTALL_C32_SOCKET_SUPPORT FALSE -#define INSTALL_S1G3_SOCKET_SUPPORT FALSE -#define INSTALL_S1G4_SOCKET_SUPPORT FALSE -#define INSTALL_ASB2_SOCKET_SUPPORT FALSE -#define INSTALL_FS1_SOCKET_SUPPORT FALSE -#define INSTALL_FM1_SOCKET_SUPPORT FALSE -#define INSTALL_FP1_SOCKET_SUPPORT FALSE -#define INSTALL_FT1_SOCKET_SUPPORT TRUE -#define INSTALL_AM3_SOCKET_SUPPORT FALSE - -/* - * Agesa optional capabilities selection. - * Uncomment and mark FALSE those features you wish to include in the build. - * Comment out or mark TRUE those features you want to REMOVE from the build. - */ - -#define BLDOPT_REMOVE_FAMILY_10_SUPPORT TRUE -#define BLDOPT_REMOVE_FAMILY_12_SUPPORT TRUE -#define BLDOPT_REMOVE_FAMILY_14_SUPPORT FALSE -#define BLDOPT_REMOVE_FAMILY_15_SUPPORT TRUE - -#define BLDOPT_REMOVE_AM3_SOCKET_SUPPORT TRUE -#define BLDOPT_REMOVE_ASB2_SOCKET_SUPPORT TRUE -#define BLDOPT_REMOVE_C32_SOCKET_SUPPORT TRUE -#define BLDOPT_REMOVE_FM1_SOCKET_SUPPORT TRUE -#define BLDOPT_REMOVE_FP1_SOCKET_SUPPORT TRUE -#define BLDOPT_REMOVE_FS1_SOCKET_SUPPORT TRUE -#define BLDOPT_REMOVE_FT1_SOCKET_SUPPORT FALSE -#define BLDOPT_REMOVE_G34_SOCKET_SUPPORT TRUE -#define BLDOPT_REMOVE_S1G3_SOCKET_SUPPORT TRUE -#define BLDOPT_REMOVE_S1G4_SOCKET_SUPPORT TRUE - -#define BLDOPT_REMOVE_UDIMMS_SUPPORT FALSE -#define BLDOPT_REMOVE_RDIMMS_SUPPORT TRUE -#define BLDOPT_REMOVE_LRDIMMS_SUPPORT FALSE -#define BLDOPT_REMOVE_ECC_SUPPORT FALSE -//#define BLDOPT_REMOVE_DCT_INTERLEAVE TRUE -#define BLDOPT_REMOVE_BANK_INTERLEAVE FALSE -#define BLDOPT_REMOVE_NODE_INTERLEAVE TRUE -#define BLDOPT_REMOVE_PARALLEL_TRAINING FALSE -#define BLDOPT_REMOVE_DQS_TRAINING FALSE -#define BLDOPT_REMOVE_ONLINE_SPARE_SUPPORT TRUE -#define BLDOPT_REMOVE_MULTISOCKET_SUPPORT TRUE -#define BLDOPT_REMOVE_ACPI_PSTATES FALSE - #define BLDCFG_REMOVE_ACPI_PSTATES_PPC FALSE - #define BLDCFG_REMOVE_ACPI_PSTATES_PCT FALSE - #define BLDCFG_REMOVE_ACPI_PSTATES_PSD FALSE - #define BLDCFG_REMOVE_ACPI_PSTATES_PSS FALSE - #define BLDCFG_REMOVE_ACPI_PSTATES_XPSS FALSE - #define BLDCFG_FORCE_INDEPENDENT_PSD_OBJECT FALSE -#define BLDOPT_REMOVE_SRAT FALSE -#define BLDOPT_REMOVE_SLIT FALSE -#define BLDOPT_REMOVE_WHEA FALSE -#define BLDOPT_REMOVE_DMI TRUE -#define BLDOPT_REMOVE_HT_ASSIST TRUE -#define BLDOPT_REMOVE_ATM_MODE TRUE -//#define BLDOPT_REMOVE_MSG_BASED_C1E TRUE -//#define BLDOPT_REMOVE_LOW_POWER_STATE_FOR_PROCHOT TRUE -#define BLDOPT_REMOVE_MEM_RESTORE_SUPPORT FALSE -//#define BLDOPT_REMOVE_C6_STATE TRUE -#define BLDOPT_REMOVE_GFX_RECOVERY TRUE -#define BLDOPT_REMOVE_EARLY_SAMPLES TRUE - - -#define BLDCFG_PCI_MMIO_BASE CONFIG_MMCONF_BASE_ADDRESS -#define BLDCFG_PCI_MMIO_SIZE CONFIG_MMCONF_BUS_NUMBER - -#define BLDCFG_VRM_CURRENT_LIMIT 24000 -//#define BLDCFG_VRM_NB_CURRENT_LIMIT 0 -#define BLDCFG_VRM_LOW_POWER_THRESHOLD 24000 -#define BLDCFG_VRM_NB_LOW_POWER_THRESHOLD 1 -#define BLDCFG_VRM_SLEW_RATE 5000 -//#define BLDCFG_VRM_NB_SLEW_RATE 5000 -//#define BLDCFG_VRM_ADDITIONAL_DELAY 0 -//#define BLDCFG_VRM_NB_ADDITIONAL_DELAY 0 -#define BLDCFG_VRM_HIGH_SPEED_ENABLE TRUE -//#define BLDCFG_VRM_NB_HIGH_SPEED_ENABLE FALSE -#define BLDCFG_VRM_INRUSH_CURRENT_LIMIT 6000 -//#define BLDCFG_VRM_NB_INRUSH_CURRENT_LIMIT 0 - -//#define BLDCFG_PROCESSOR_SCOPE_NAME0 'C' -//#define BLDCFG_PROCESSOR_SCOPE_NAME1 '0' -//#define BLDCFG_PROCESSOR_SCOPE_IN_SB FALSE -#define BLDCFG_PLAT_NUM_IO_APICS 3 -//#define BLDCFG_PLATFORM_C1E_MODE C1eModeDisabled -//#define BLDCFG_PLATFORM_C1E_OPDATA 0 -//#define BLDCFG_PLATFORM_C1E_MODE_OPDATA1 0 -//#define BLDCFG_PLATFORM_C1E_MODE_OPDATA2 0 -#define BLDCFG_PLATFORM_CSTATE_MODE CStateModeC6 -#define BLDCFG_PLATFORM_CSTATE_OPDATA 0x840 -#define BLDCFG_PLATFORM_CSTATE_IO_BASE_ADDRESS 0x840 -//#define BLDCFG_PLATFORM_CPB_MODE CpbModeAuto -#define BLDCFG_CORE_LEVELING_MODE CORE_LEVEL_LOWEST -#define BLDCFG_AP_MTRR_SETTINGS_LIST &OntarioApMtrrSettingsList -#define BLDCFG_AMD_PLATFORM_TYPE AMD_PLATFORM_MOBILE -//#define BLDCFG_STARTING_BUSNUM 0 -//#define BLDCFG_MAXIMUM_BUSNUM 0xf8 -//#define BLDCFG_ALLOCATED_BUSNUMS 0x20 -//#define BLDCFG_PLATFORM_DEEMPHASIS_LIST 0 -//#define BLDCFG_BUID_SWAP_LIST 0 -//#define BLDCFG_HTDEVICE_CAPABILITIES_OVERRIDE_LIST 0 -//#define BLDCFG_HTFABRIC_LIMITS_LIST 0 -//#define BLDCFG_HTCHAIN_LIMITS_LIST 0 -//#define BLDCFG_BUS_NUMBERS_LIST 0 -//#define BLDCFG_IGNORE_LINK_LIST 0 -//#define BLDCFG_LINK_SKIP_REGANG_LIST 0 -//#define BLDCFG_ADDITIONAL_TOPOLOGIES_LIST 0 -//#define BLDCFG_USE_HT_ASSIST TRUE -//#define BLDCFG_USE_ATM_MODE TRUE -//#define BLDCFG_PLATFORM_CONTROL_FLOW_MODE Nfcm -#define BLDCFG_S3_LATE_RESTORE TRUE -//#define BLDCFG_USE_32_BYTE_REFRESH FALSE -//#define BLDCFG_USE_VARIABLE_MCT_ISOC_PRIORITY FALSE -//#define BLDCFG_PLATFORM_POWER_POLICY_MODE Performance -//#define BLDCFG_SET_HTCRC_SYNC_FLOOD FALSE -//#define BLDCFG_USE_UNIT_ID_CLUMPING FALSE -//#define BLDCFG_SYSTEM_PHYSICAL_SOCKET_MAP 0 -#define BLDCFG_CFG_GNB_HD_AUDIO FALSE -//#define BLDCFG_CFG_ABM_SUPPORT FALSE -//#define BLDCFG_CFG_DYNAMIC_REFRESH_RATE 0 -//#define BLDCFG_CFG_LCD_BACK_LIGHT_CONTROL 0 -//#define BLDCFG_MEM_INIT_PSTATE 0 -//#define BLDCFG_AMD_PSTATE_CAP_VALUE 0 -#define BLDCFG_MEMORY_BUS_FREQUENCY_LIMIT DDR1333_FREQUENCY -#define BLDCFG_MEMORY_MODE_UNGANGED TRUE -//#define BLDCFG_MEMORY_QUAD_RANK_CAPABLE TRUE -//#define BLDCFG_MEMORY_QUADRANK_TYPE QUADRANK_UNBUFFERED -#define BLDCFG_MEMORY_SODIMM_CAPABLE TRUE -#define BLDCFG_MEMORY_LRDIMM_CAPABLE FALSE -#define BLDCFG_MEMORY_ENABLE_BANK_INTERLEAVING TRUE -#define BLDCFG_MEMORY_ENABLE_NODE_INTERLEAVING FALSE -#define BLDCFG_MEMORY_CHANNEL_INTERLEAVING FALSE -#define BLDCFG_MEMORY_POWER_DOWN TRUE -#define BLDCFG_POWER_DOWN_MODE POWER_DOWN_BY_CHIP_SELECT -//#define BLDCFG_ONLINE_SPARE FALSE -//#define BLDCFG_MEMORY_PARITY_ENABLE FALSE -#define BLDCFG_BANK_SWIZZLE TRUE -#define BLDCFG_TIMING_MODE_SELECT TIMING_MODE_AUTO -#define BLDCFG_MEMORY_CLOCK_SELECT DDR1333_FREQUENCY -#define BLDCFG_DQS_TRAINING_CONTROL TRUE -#define BLDCFG_IGNORE_SPD_CHECKSUM FALSE -#define BLDCFG_USE_BURST_MODE FALSE -#define BLDCFG_MEMORY_ALL_CLOCKS_ON FALSE -//#define BLDCFG_ENABLE_ECC_FEATURE TRUE -//#define BLDCFG_ECC_REDIRECTION FALSE -//#define BLDCFG_SCRUB_DRAM_RATE 0 -//#define BLDCFG_SCRUB_L2_RATE 0 -//#define BLDCFG_SCRUB_L3_RATE 0 -//#define BLDCFG_SCRUB_IC_RATE 0 -//#define BLDCFG_SCRUB_DC_RATE 0 -//#define BLDCFG_ECC_SYNC_FLOOD 0 -//#define BLDCFG_ECC_SYMBOL_SIZE 0 -//#define BLDCFG_1GB_ALIGN FALSE -#define BLDCFG_UMA_ALLOCATION_MODE UMA_AUTO -#define BLDCFG_UMA_ALLOCATION_SIZE 0 -#define BLDCFG_UMA_ABOVE4G_SUPPORT FALSE -#define BLDCFG_UMA_ALIGNMENT NO_UMA_ALIGNED -#define BLDCFG_HEAP_DRAM_ADDRESS 0xB0000 -#define BLDCFG_CFG_TEMP_PCIE_MMIO_BASE_ADDRESS 0xD0000000 - -/* - * Agesa configuration values selection. - * Uncomment and specify the value for the configuration options - * needed by the system. - */ -#include <AGESA.h> - -/* The fixed MTRR values to be set after memory initialization. */ -CONST AP_MTRR_SETTINGS ROMDATA OntarioApMtrrSettingsList[] = -{ - { AMD_AP_MTRR_FIX64k_00000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX16k_80000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX16k_A0000, 0x0000000000000000ull }, - { AMD_AP_MTRR_FIX4k_C0000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX4k_C8000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX4k_D0000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX4k_D8000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX4k_E0000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX4k_E8000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX4k_F0000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX4k_F8000, 0x1E1E1E1E1E1E1E1Eull }, - { CPU_LIST_TERMINAL } -}; - -/* Include the files that instantiate the configuration definitions. */ - -#include "cpuRegisters.h" -#include "cpuFamRegisters.h" -#include "cpuFamilyTranslation.h" -#include "AdvancedApi.h" -#include "heapManager.h" -#include "CreateStruct.h" -#include "cpuFeatures.h" -#include "Table.h" -#include "cpuEarlyInit.h" -#include "cpuLateInit.h" -#include "GnbInterface.h" - -/***************************************************************************** - * Define the RELEASE VERSION string - * - * The Release Version string should identify the next planned release. - * When a branch is made in preparation for a release, the release manager - * should change/confirm that the branch version of this file contains the - * string matching the desired version for the release. The trunk version of - * the file should always contain a trailing 'X'. This will make sure that a - * development build from trunk will not be confused for a released version. - * The release manager will need to remove the trailing 'X' and update the - * version string as appropriate for the release. The trunk copy of this file - * should also be updated/incremented for the next expected version, + trailing 'X' - ****************************************************************************/ -// This is the delivery package title, "BrazosPI" -// This string MUST be exactly 8 characters long -#define AGESA_PACKAGE_STRING {'c', 'b', '_', 'A', 'g', 'e', 's', 'a'} - -// This is the release version number of the AGESA component -// This string MUST be exactly 12 characters long -#define AGESA_VERSION_STRING {'V', '1', '.', '1', '.', '0', '.', '3', ' ', ' ', ' ', ' '} - -/* MEMORY_BUS_SPEED */ -#define DDR400_FREQUENCY 200 ///< DDR 400 -#define DDR533_FREQUENCY 266 ///< DDR 533 -#define DDR667_FREQUENCY 333 ///< DDR 667 -#define DDR800_FREQUENCY 400 ///< DDR 800 -#define DDR1066_FREQUENCY 533 ///< DDR 1066 -#define DDR1333_FREQUENCY 667 ///< DDR 1333 -#define DDR1600_FREQUENCY 800 ///< DDR 1600 -#define DDR1866_FREQUENCY 933 ///< DDR 1866 -#define UNSUPPORTED_DDR_FREQUENCY 934 ///< Highest limit of DDR frequency - -/* QUANDRANK_TYPE*/ -#define QUADRANK_REGISTERED 0 ///< Quadrank registered DIMM -#define QUADRANK_UNBUFFERED 1 ///< Quadrank unbuffered DIMM - -/* USER_MEMORY_TIMING_MODE */ -#define TIMING_MODE_AUTO 0 ///< Use best rate possible -#define TIMING_MODE_LIMITED 1 ///< Set user top limit -#define TIMING_MODE_SPECIFIC 2 ///< Set user specified speed - -/* POWER_DOWN_MODE */ -#define POWER_DOWN_BY_CHANNEL 0 ///< Channel power down mode -#define POWER_DOWN_BY_CHIP_SELECT 1 ///< Chip select power down mode - -// The following definitions specify the default values for various parameters in which there are -// no clearly defined defaults to be used in the common file. The values below are based on product -// and BKDG content, please consult the AGESA Memory team for consultation. -#define DFLT_SCRUB_DRAM_RATE (0) -#define DFLT_SCRUB_L2_RATE (0) -#define DFLT_SCRUB_L3_RATE (0) -#define DFLT_SCRUB_IC_RATE (0) -#define DFLT_SCRUB_DC_RATE (0) -#define DFLT_MEMORY_QUADRANK_TYPE QUADRANK_UNBUFFERED -#define DFLT_VRM_SLEW_RATE (5000) - -// Instantiate all solution relevant data. -#include <PlatformInstall.h> diff --git a/src/mainboard/amd/persimmon/cmos.layout b/src/mainboard/amd/persimmon/cmos.layout deleted file mode 100644 index f9f52f7..0000000 --- a/src/mainboard/amd/persimmon/cmos.layout +++ /dev/null @@ -1,68 +0,0 @@ -#***************************************************************************** -# -# This file is part of the coreboot project. -# -# Copyright (C) 2011 Advanced Micro Devices, Inc. -# -# This program is free software; you can redistribute it and/or modify -# it under the terms of the GNU General Public License as published by -# the Free Software Foundation; version 2 of the License. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -#***************************************************************************** - -entries - -0 384 r 0 reserved_memory -384 1 e 4 boot_option -388 4 h 0 reboot_counter -#392 3 r 0 unused -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core -400 1 e 1 power_on_after_fail -412 4 e 6 debug_level -440 4 e 9 slow_cpu -444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory -728 256 h 0 user_data -984 16 h 0 check_sum -# Reserve the extended AMD configuration registers -1000 24 r 0 amd_reserved - - - -enumerations - -#ID value text -1 0 Disable -1 1 Enable -2 0 Enable -2 1 Disable -4 0 Fallback -4 1 Normal -6 5 Notice -6 6 Info -6 7 Debug -6 8 Spew -8 0 400Mhz -8 1 333Mhz -8 2 266Mhz -8 3 200Mhz -9 0 off -9 1 87.5% -9 2 75.0% -9 3 62.5% -9 4 50.0% -9 5 37.5% -9 6 25.0% -9 7 12.5% - -checksums - -checksum 392 983 984 diff --git a/src/mainboard/amd/persimmon/devicetree.cb b/src/mainboard/amd/persimmon/devicetree.cb deleted file mode 100644 index 73cf19d..0000000 --- a/src/mainboard/amd/persimmon/devicetree.cb +++ /dev/null @@ -1,151 +0,0 @@ -# -# This file is part of the coreboot project. -# -# Copyright (C) 2011 Advanced Micro Devices, Inc. -# -# This program is free software; you can redistribute it and/or modify -# it under the terms of the GNU General Public License as published by -# the Free Software Foundation; version 2 of the License. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -chip northbridge/amd/agesa/family14/root_complex - device cpu_cluster 0 on - chip cpu/amd/agesa/family14 - device lapic 0 on end - end - end - device domain 0 on - subsystemid 0x1022 0x1510 inherit - chip northbridge/amd/agesa/family14 - device pci 0.0 on end # Root Complex - device pci 1.0 on end # Internal Graphics P2P bridge 0x980[2456] - device pci 4.0 on end # PCIE P2P bridge on-board NIC - device pci 5.0 off end # PCIE P2P bridge - device pci 6.0 on end # PCIE P2P bridge PCIe slot - device pci 7.0 off end # PCIE P2P bridge - device pci 8.0 off end # NB/SB Link P2P bridge - end # agesa northbridge - - chip southbridge/amd/cimx/sb800 - device pci 11.0 on end # SATA - device pci 12.0 on end # OHCI USB 0-4 - device pci 12.2 on end # EHCI USB 0-4 - device pci 13.0 on end # OHCI USB 5-9 - device pci 13.2 on end # EHCI USB 5-9 - device pci 14.0 on end # SM - device pci 14.1 on end # IDE 0x439c - device pci 14.2 on end # HDA 0x4383 - device pci 14.3 on # LPC 0x439d - chip superio/fintek/f81865f - device pnp 4e.0 off # Floppy - io 0x60 = 0x3f0 - irq 0x70 = 6 - drq 0x74 = 2 - end - device pnp 4e.3 off end # Parallel Port - device pnp 4e.4 off end # Hardware Monitor - device pnp 4e.5 on # Keyboard - io 0x60 = 0x60 - io 0x62 = 0x64 - irq 0x70 = 1 - end - device pnp 4e.6 off end # GPIO - device pnp 4e.a off end # PME - device pnp 4e.10 on # COM1 - io 0x60 = 0x3f8 - irq 0x70 = 4 - end - device pnp 4e.11 on # COM2 - io 0x60 = 0x2f8 - irq 0x70 = 3 - end - end # f81865f - end #LPC - device pci 14.4 on end # PCIB 0x4384, NOTE: PCI interface pins shared with GPIO {GPIO 35:0} - device pci 14.5 off end # OHCI FS/LS USB - device pci 14.6 off end # Hudson-E1 GbE MAC: Broadcom BCM5785 (14E4:1699) - device pci 15.0 off end # PCIe PortA - device pci 15.1 off end # PCIe PortB - device pci 15.2 off end # PCIe PortC - device pci 15.3 off end # PCIe PortD - device pci 16.0 off end # OHCI USB 10-13 - device pci 16.2 off end # EHCI USB 10-13 - register "gpp_configuration" = "0" #4:0:0:0 (really need to disable all 4 somehow) - register "boot_switch_sata_ide" = "0" # 0: boot from SATA. 1: IDE - - #set up SB800 Fan control registers and IMC fan controls - register "imc_port_address" = "0x6E" # 0x2E and 0x6E are common - register "fan0_enabled" = "1" - register "fan1_enabled" = "1" - register "imc_fan_zone0_enabled" = "1" - register "imc_fan_zone1_enabled" = "1" - - register "fan0_config_vals" = "{ \ - FAN_INPUT_INTERNAL_DIODE, FAN_POLARITY_HIGH, \ - FREQ_25KHZ, 0x08, 0x00, 0x00, 0x00, 0x00,\ - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }" - register "fan1_config_vals" = "{ \ - FAN_INPUT_INTERNAL_DIODE, FAN_POLARITY_HIGH, \ - FREQ_25KHZ, 0x10, 0x00, 0x00, 0x00, 0x00, \ - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }" - - register "imc_zone0_mode1" = " \ - IMC_MODE1_FAN_ENABLED | IMC_MODE1_FAN_IMC_CONTROLLED | \ - IMC_MODE1_FAN_STEP_MODE | IMC_MODE1_FANOUT0" - register "imc_zone0_mode2" = " IMC_MODE2_TEMPIN_SB_TSI | \ - IMC_MODE2_FANIN0 | IMC_MODE2_TEMP_AVERAGING_DISABLED" - register "imc_zone0_temp_offset" = "0x00" # No temp offset - register "imc_zone0_hysteresis" = "0x05" # Degrees C Hysteresis - register "imc_zone0_smbus_addr" = "0x98" # Temp Sensor SMBus address - register "imc_zone0_smbus_num" = "IMC_TEMP_SENSOR_ON_SMBUS_3" # SMBUS number - register "imc_zone0_pwm_step" = "0x01" # Fan PWM stepping rate - register "imc_zone0_ramping" = "0x00" # Disable Fan PWM ramping and stepping - - register "imc_zone1_mode1" = " \ - IMC_MODE1_FAN_ENABLED | IMC_MODE1_FAN_IMC_CONTROLLED | \ - IMC_MODE1_FAN_STEP_MODE | IMC_MODE1_FANOUT1" - register "imc_zone1_mode2" = " IMC_MODE2_TEMPIN_SB_TSI | \ - IMC_MODE2_FANIN1 | IMC_MODE2_TEMP_AVERAGING_DISABLED" - register "imc_zone1_temp_offset" = "0x00" # No temp offset - register "imc_zone1_hysteresis" = "0x05" # Degrees C Hysteresis - register "imc_zone1_smbus_addr" = "0x98" # Temp Sensor SMBus address - register "imc_zone1_smbus_num" = "IMC_TEMP_SENSOR_ON_SMBUS_3" # SMBUS number - register "imc_zone1_pwm_step" = "0x01" # Fan PWM stepping rate - register "imc_zone1_ramping" = "0x00" # Disable Fan PWM ramping and stepping - - # T56N has a Maximum operating temperature of 90C - # ZONEX_THRESHOLDS - _AC0 - _AC7, _CRT - Temp Threshold in degrees C - # ZONEX_FANSPEEDS - Fan speeds as a "percentage" - register "imc_zone0_thresholds" = "{ 87, 82, 77, 72, 65, 1, 0, 0, 90 }" - register "imc_zone0_fanspeeds" = "{100, 7, 5, 4, 3, 2, 0, 0 }" - register "imc_zone1_thresholds" = "{ 85, 80, 75, 65, 1, 0, 0, 0, 90 }" - register "imc_zone1_fanspeeds" = "{100, 10, 6, 4, 3, 0, 0, 0 }" - - end #southbridge/amd/cimx/sb800 - - chip northbridge/amd/agesa/family14 - - # These seem unnecessary - device pci 18.0 on end - device pci 18.1 on end - device pci 18.2 on end - device pci 18.3 on end - device pci 18.4 on end - device pci 18.5 on end - device pci 18.6 on end - device pci 18.7 on end - - register "spdAddrLookup" = " - { - { {0xA0, 0xA2}, {0x00, 0x00}, }, // socket 0 - Channel 0 & 1 - 8-bit SPD addresses - { {0x00, 0x00}, {0x00, 0x00}, }, // socket 1 - Channel 0 & 1 - 8-bit SPD addresses - }" - - end # agesa northbridge - - end #domain -end #northbridge/amd/agesa/family14/root_complex diff --git a/src/mainboard/amd/persimmon/dsdt.asl b/src/mainboard/amd/persimmon/dsdt.asl deleted file mode 100644 index 5496288..0000000 --- a/src/mainboard/amd/persimmon/dsdt.asl +++ /dev/null @@ -1,64 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -/* DefinitionBlock Statement */ -#include <arch/acpi.h> -DefinitionBlock ( - "DSDT.AML", /* Output filename */ - "DSDT", /* Signature */ - 0x02, /* DSDT Revision, needs to be 2 for 64bit */ - OEM_ID, - ACPI_TABLE_CREATOR, - 0x00010001 /* OEM Revision */ - ) -{ /* Start of ASL file */ - /* #include <arch/x86/acpi/debug.asl> */ /* Include global debug methods if needed */ - - #include "acpi/mainboard.asl" - - #include <cpu/amd/agesa/family14/acpi/cpu.asl> - - #include "acpi/routing.asl" - - Scope(_SB) { - /* global utility methods expected within the _SB scope */ - #include <arch/x86/acpi/globutil.asl> - - Device(PCI0) { - - /* Describe the AMD Northbridge */ - #include <northbridge/amd/agesa/family14/acpi/northbridge.asl> - - /* Describe the AMD Fusion Controller Hub Southbridge */ - #include <southbridge/amd/cimx/sb800/acpi/fch.asl> - - /* Primary (and only) IDE channel */ - Device(IDEC) { - Name(_ADR, 0x00140001) - #include "acpi/ide.asl" - } /* end IDEC */ - - } - } /* End Scope(_SB) */ - - /* Contains the supported sleep states for this chipset */ - #include <southbridge/amd/common/acpi/sleepstates.asl> - - /* Contains the Sleep methods (WAK, PTS, GTS, etc.) */ - #include "acpi/sleep.asl" - - #include "acpi/gpe.asl" -} -/* End of ASL file */ diff --git a/src/mainboard/amd/persimmon/irq_tables.c b/src/mainboard/amd/persimmon/irq_tables.c deleted file mode 100644 index a066864..0000000 --- a/src/mainboard/amd/persimmon/irq_tables.c +++ /dev/null @@ -1,102 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <console/console.h> -#include <string.h> -#include <stdint.h> -#include <arch/pirq_routing.h> - -static void write_pirq_info(struct irq_info *pirq_info, u8 bus, u8 devfn, - u8 link0, u16 bitmap0, u8 link1, u16 bitmap1, - u8 link2, u16 bitmap2, u8 link3, u16 bitmap3, - u8 slot, u8 rfu) -{ - pirq_info->bus = bus; - pirq_info->devfn = devfn; - pirq_info->irq[0].link = link0; - pirq_info->irq[0].bitmap = bitmap0; - pirq_info->irq[1].link = link1; - pirq_info->irq[1].bitmap = bitmap1; - pirq_info->irq[2].link = link2; - pirq_info->irq[2].bitmap = bitmap2; - pirq_info->irq[3].link = link3; - pirq_info->irq[3].bitmap = bitmap3; - pirq_info->slot = slot; - pirq_info->rfu = rfu; -} - -unsigned long write_pirq_routing_table(unsigned long addr) -{ - - struct irq_routing_table *pirq; - struct irq_info *pirq_info; - u32 slot_num; - u8 *v; - - u8 sum = 0; - int i; - - /* Align the table to be 16 byte aligned. */ - addr += 15; - addr &= ~15; - - /* This table must be between 0xf0000 & 0x100000 */ - printk(BIOS_INFO, "Writing IRQ routing tables to 0x%lx...", addr); - - pirq = (void *)(addr); - v = (u8 *) (addr); - - pirq->signature = PIRQ_SIGNATURE; - pirq->version = PIRQ_VERSION; - - pirq->rtr_bus = 0; - pirq->rtr_devfn = PCI_DEVFN(0x14, 4); - - pirq->exclusive_irqs = 0; - - pirq->rtr_vendor = 0x1002; - pirq->rtr_device = 0x4384; - - pirq->miniport_data = 0; - - memset(pirq->rfu, 0, sizeof(pirq->rfu)); - - pirq_info = (void *)(&pirq->checksum + 1); - slot_num = 0; - - /* pci bridge */ - write_pirq_info(pirq_info, 0, PCI_DEVFN(0x14, 4), - 0x1, 0xdef8, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 0, - 0); - pirq_info++; - - slot_num++; - - pirq->size = 32 + 16 * slot_num; - - for (i = 0; i < pirq->size; i++) - sum += v[i]; - - sum = pirq->checksum - sum; - - if (sum != pirq->checksum) { - pirq->checksum = sum; - } - - printk(BIOS_INFO, "write_pirq_routing_table done.\n"); - - return (unsigned long)pirq_info; - -} diff --git a/src/mainboard/amd/persimmon/mainboard.c b/src/mainboard/amd/persimmon/mainboard.c deleted file mode 100644 index 6ca8a80..0000000 --- a/src/mainboard/amd/persimmon/mainboard.c +++ /dev/null @@ -1,150 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * Copyright (C) 2014 Sage Electronic Engineering, LLC. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <amdblocks/acpimmio.h> -#include <console/console.h> -#include <device/device.h> -#include <device/mmio.h> -#include <southbridge/amd/common/amd_pci_util.h> -#include <southbridge/amd/cimx/sb800/SBPLATFORM.h> -#include <southbridge/amd/cimx/sb800/pci_devs.h> -#include <northbridge/amd/agesa/family14/pci_devs.h> - -/*********************************************************** - * These arrays set up the FCH PCI_INTR registers 0xC00/0xC01. - * This table is responsible for physically routing the PIC and - * IOAPIC IRQs to the different PCI devices on the system. It - * is read and written via registers 0xC00/0xC01 as an - * Index/Data pair. These values are chipset and mainboard - * dependent and should be updated accordingly. - * - * These values are used by the PCI configuration space, - * MP Tables. TODO: Make ACPI use these values too. - * - * The Persimmon PCI INTA/B/C/D pins are connected to - * FCH pins INTE/F/G/H on the schematic so these need - * to be routed as well. - */ -static const u8 mainboard_picr_data[FCH_INT_TABLE_SIZE] = { - /* INTA# - INTH# */ - [0x00] = 0x0A,0x0B,0x0A,0x0B,0x0A,0x0B,0x0A,0x0B, - /* Misc-nil,0,1,2, INT from Serial irq */ - [0x08] = 0x00,0xF0,0x00,0x00,0x1F,0x1F,0x1F,0x1F, - /* SCI, SMBUS0, ASF, HDA, FC, GEC, PerfMon */ - [0x10] = 0x1F,0x1F,0x1F,0x0A,0x1F,0x1F,0x1F, - /* IMC INT0 - 5 */ - [0x20] = 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, - /* USB Devs 18/19/20/22 INTA-C */ - [0x30] = 0x0A,0x0B,0x0A,0x0B,0x0A,0x0B,0x0A, - /* IDE, SATA */ - [0x40] = 0x0B,0x0B, - /* GPPInt0 - 3 */ - [0x50] = 0x0A,0x0B,0x0A,0x0B -}; - -static const u8 mainboard_intr_data[FCH_INT_TABLE_SIZE] = { - /* INTA# - INTH# */ - [0x00] = 0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17, - /* Misc-nil,0,1,2, INT from Serial irq */ - [0x08] = 0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F, - /* SCI, SMBUS0, ASF, HDA, FC, GEC, PerMon */ - [0x10] = 0x09,0x1F,0x1F,0x10,0x1F,0x12,0x1F, - /* IMC INT0 - 5 */ - [0x20] = 0x1F,0x1F,0x1F,0x1F,0x1F,0x1F, - /* USB Devs 18/19/22/20 INTA-C */ - [0x30] = 0x12,0x11,0x12,0x11,0x12,0x11,0x12, - /* IDE, SATA */ - [0x40] = 0x11,0x13, - /* GPPInt0 - 3 */ - [0x50] = 0x10,0x11,0x12,0x13 -}; - -/* - * This table defines the index into the picr/intr_data - * tables for each device. Any enabled device and slot - * that uses hardware interrupts should have an entry - * in this table to define its index into the FCH - * PCI_INTR register 0xC00/0xC01. This index will define - * the interrupt that it should use. Putting PIRQ_A into - * the PIN A index for a device will tell that device to - * use PIC IRQ 10 if it uses PIN A for its hardware INT. - */ -/* - * Persimmon has PCI slot INTA/B/C/D connected to PIRQE/F/G/H - * but because PCI INT_PIN swizzling isn't implemented to match - * the IDSEL (dev 3) of the slot, the table is adjusted for the - * swizzle and INTA is connected to PIRQH so PINA/B/C/D on - * off-chip devices should get mapped to PIRQH/E/F/G. - */ -static const struct pirq_struct mainboard_pirq_data[] = { - /* {PCI_devfn, {PIN A, PIN B, PIN C, PIN D}}, */ - {GFX_DEVFN, {PIRQ_A, PIRQ_B, PIRQ_NC, PIRQ_NC}}, /* VGA: 01.0 */ - {NB_PCIE_PORT1_DEVFN, {PIRQ_A, PIRQ_B, PIRQ_C, PIRQ_D}}, /* NIC: 04.0 */ - {NB_PCIE_PORT3_DEVFN, {PIRQ_A, PIRQ_B, PIRQ_C, PIRQ_D}}, /* PCIe bdg: 06.0 */ - {SATA_DEVFN, {PIRQ_SATA, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* SATA: 11.0 */ - {OHCI1_DEVFN, {PIRQ_OHCI1, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* OHCI1: 12.0 */ - {EHCI1_DEVFN, {PIRQ_NC, PIRQ_EHCI1, PIRQ_NC, PIRQ_NC}}, /* EHCI1: 12.2 */ - {OHCI2_DEVFN, {PIRQ_OHCI2, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* OHCI2: 13.0 */ - {EHCI2_DEVFN, {PIRQ_NC, PIRQ_EHCI2, PIRQ_NC, PIRQ_NC}}, /* EHCI2: 13.2 */ - {SMBUS_DEVFN, {PIRQ_SMBUS, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* SMBUS: 14.0 */ - {IDE_DEVFN, {PIRQ_NC, PIRQ_IDE, PIRQ_NC, PIRQ_NC}}, /* IDE: 14.1 */ - {HDA_DEVFN, {PIRQ_HDA, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* HDA: 14.2 */ - {SB_PCI_PORT_DEVFN, {PIRQ_H, PIRQ_E, PIRQ_F, PIRQ_G}}, /* PCI bdg: 14.4 */ - {OHCI4_DEVFN, {PIRQ_NC, PIRQ_NC, PIRQ_OHCI4, PIRQ_NC}}, /* OHCI4: 14.5 */ - {OHCI3_DEVFN, {PIRQ_OHCI3, PIRQ_NC, PIRQ_NC, PIRQ_NC}}, /* OHCI3: 16.0 */ - {EHCI3_DEVFN, {PIRQ_NC, PIRQ_EHCI3, PIRQ_NC, PIRQ_NC}}, /* EHCI3: 16.2 */ -}; - -/* PIRQ Setup */ -static void pirq_setup(void) -{ - pirq_data_ptr = mainboard_pirq_data; - pirq_data_size = sizeof(mainboard_pirq_data) / sizeof(struct pirq_struct); - intr_data_ptr = mainboard_intr_data; - picr_data_ptr = mainboard_picr_data; -} - -/********************************************** - * Enable the dedicated functions of the board. - **********************************************/ -static void mainboard_enable(struct device *dev) -{ - printk(BIOS_INFO, "Mainboard " CONFIG_MAINBOARD_PART_NUMBER " Enable.\n"); - - /* enable GPP CLK0 thru CLK1 */ - /* disable GPP CLK2 thru SLT_GFX_CLK */ - misc_write8(0, 0xff); - misc_write8(1, 0); - misc_write8(2, 0); - misc_write8(3, 0); - misc_write8(4, 0); - - /* - * Initialize ASF registers to an arbitrary address because someone - * long ago set things up this way inside the SPD read code. The - * SPD read code has been made generic and moved out of the board - * directory, so the ASF init is being done here. - */ - pm_write8(0x29, 0x80); - pm_write8(0x28, 0x61); - - /* Initialize the PIRQ data structures for consumption */ - pirq_setup(); -} - -struct chip_operations mainboard_ops = { - .enable_dev = mainboard_enable, -}; diff --git a/src/mainboard/amd/persimmon/mptable.c b/src/mainboard/amd/persimmon/mptable.c deleted file mode 100644 index bc7a3ac..0000000 --- a/src/mainboard/amd/persimmon/mptable.c +++ /dev/null @@ -1,142 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * Copyright (C) 2014 Sage Electronic Engineering, LLC. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <arch/smp/mpspec.h> -#include <stdint.h> -#include <southbridge/amd/cimx/sb800/SBPLATFORM.h> -#include <southbridge/amd/common/amd_pci_util.h> -#include <drivers/generic/ioapic/chip.h> -#include <arch/ioapic.h> - -static void *smp_write_config_table(void *v) -{ - struct mp_config_table *mc; - int bus_isa; - - /* - * By the time this function gets called, the IOAPIC registers - * have been written so they can be read to get the correct - * APIC ID and Version - */ - u8 ioapic_id = (io_apic_read(VIO_APIC_VADDR, 0x00) >> 24); - u8 ioapic_ver = (io_apic_read(VIO_APIC_VADDR, 0x01) & 0xFF); - - /* Initialize the MP_Table */ - mc = (void *)(((char *)v) + SMP_FLOATING_TABLE_LEN); - - mptable_init(mc, LOCAL_APIC_ADDR); - - /* - * Type 0: Processor Entries: - * LAPIC ID, LAPIC Version, CPU Flags:EN/BP, - * CPU Signature (Stepping, Model, Family), - * Feature Flags - */ - smp_write_processors(mc); - - /* - * Type 1: Bus Entries: - * Bus ID, Bus Type - */ - mptable_write_buses(mc, NULL, &bus_isa); - - /* - * Type 2: I/O APICs: - * APIC ID, Version, APIC Flags:EN, Address - */ - smp_write_ioapic(mc, ioapic_id, ioapic_ver, VIO_APIC_VADDR); - - /* - * Type 3: I/O Interrupt Table Entries: - * Int Type, Int Polarity, Int Level, Source Bus ID, - * Source Bus IRQ, Dest APIC ID, Dest PIN# - */ - mptable_add_isa_interrupts(mc, bus_isa, ioapic_id, 0); - - /* PCI interrupts are level triggered, and are - * associated with a specific bus/device/function tuple. - */ -#define PCI_INT(bus, dev, fn, pin) \ - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, (bus), (((dev)<<2)|(fn)), ioapic_id, (pin)) - - /* APU Internal Graphic Device */ - PCI_INT(0x0, 0x01, 0x0, intr_data_ptr[PIRQ_C]); - PCI_INT(0x0, 0x01, 0x1, intr_data_ptr[PIRQ_D]); - - /* SMBUS / ACPI */ - PCI_INT(0x0, 0x14, 0x0, intr_data_ptr[PIRQ_SMBUS]); - - /* Southbridge HD Audio */ - PCI_INT(0x0, 0x14, 0x2, intr_data_ptr[PIRQ_HDA]); - - /* LPC */ - PCI_INT(0x0, 0x14, 0x3, intr_data_ptr[PIRQ_C]); - - /* USB */ - PCI_INT(0x0, 0x12, 0x0, intr_data_ptr[PIRQ_OHCI1]); - PCI_INT(0x0, 0x12, 0x2, intr_data_ptr[PIRQ_EHCI1]); - PCI_INT(0x0, 0x13, 0x0, intr_data_ptr[PIRQ_OHCI2]); - PCI_INT(0x0, 0x13, 0x2, intr_data_ptr[PIRQ_EHCI2]); - PCI_INT(0x0, 0x14, 0x5, intr_data_ptr[PIRQ_OHCI4]); - - /* IDE */ - PCI_INT(0x0, 0x14, 0x1, intr_data_ptr[PIRQ_IDE]); - - /* SATA */ - PCI_INT(0x0, 0x11, 0x0, intr_data_ptr[PIRQ_SATA]); - - /* on board NIC & Slot PCIE */ - PCI_INT(0x1, 0x0, 0x0, intr_data_ptr[PIRQ_E]); /* Use INTE */ - PCI_INT(0x2, 0x0, 0x0, intr_data_ptr[PIRQ_E]); /* Use INTE */ - - /* PCI slots */ - struct device *dev = pcidev_on_root(0x14, 4); - if (dev && dev->enabled) { - u8 bus_pci = dev->link_list->secondary; - /* PCI_SLOT 0 */ - PCI_INT(bus_pci, 0x5, 0x0, intr_data_ptr[PIRQ_E]); /* INTA -> INTE */ - PCI_INT(bus_pci, 0x5, 0x1, intr_data_ptr[PIRQ_F]); /* INTB -> INTF */ - PCI_INT(bus_pci, 0x5, 0x2, intr_data_ptr[PIRQ_G]); /* INTC -> INTG */ - PCI_INT(bus_pci, 0x5, 0x3, intr_data_ptr[PIRQ_H]); /* INTD -> INTH */ - } - - /* PCIe PortA */ - PCI_INT(0x0, 0x15, 0x0, intr_data_ptr[PIRQ_E]); /* INTA -> INTE */ - /* PCIe PortB */ - PCI_INT(0x0, 0x15, 0x1, intr_data_ptr[PIRQ_F]); /* INTB -> INTF */ - /* PCIe PortC */ - PCI_INT(0x0, 0x15, 0x2, intr_data_ptr[PIRQ_G]); /* INTC -> INTG */ - /* PCIe PortD */ - PCI_INT(0x0, 0x15, 0x3, intr_data_ptr[PIRQ_H]); /* INTD -> INTH */ - - /*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ -#define IO_LOCAL_INT(type, intr, apicid, pin) \ - smp_write_lintsrc(mc, (type), MP_IRQ_TRIGGER_EDGE | MP_IRQ_POLARITY_HIGH, bus_isa, (intr), (apicid), (pin)); - - IO_LOCAL_INT(mp_ExtINT, 0x0, MP_APIC_ALL, 0x0); - IO_LOCAL_INT(mp_NMI, 0x0, MP_APIC_ALL, 0x1); - /* There is no extension information... */ - - /* Compute the checksums */ - return mptable_finalize(mc); -} - -unsigned long write_smp_table(unsigned long addr) -{ - void *v; - v = smp_write_floating_table(addr, 0); /* ADDR, Enable Virtual Wire */ - return (unsigned long)smp_write_config_table(v); -} diff --git a/src/mainboard/amd/persimmon/platform_cfg.h b/src/mainboard/amd/persimmon/platform_cfg.h deleted file mode 100644 index 660be41..0000000 --- a/src/mainboard/amd/persimmon/platform_cfg.h +++ /dev/null @@ -1,254 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - - -#ifndef _PLATFORM_CFG_H_ -#define _PLATFORM_CFG_H_ - -/** - * @def BIOS_SIZE - * BIOS_SIZE_{1,2,4,8,16}M - * - * In SB800, default ROM size is 1M Bytes, if your platform ROM - * bigger than 1M you have to set the ROM size outside CIMx module and - * before AGESA module get call. - */ -#ifndef BIOS_SIZE -#define BIOS_SIZE ((CONFIG_COREBOOT_ROMSIZE_KB >> 10) - 1) -#endif /* BIOS_SIZE */ - -/** - * @def SPREAD_SPECTRUM - * @brief - * 0 - Disable Spread Spectrum function - * 1 - Enable Spread Spectrum function - */ -#define SPREAD_SPECTRUM 0 - -/** - * @def SB_HPET_TIMER - * @brief - * 0 - Disable hpet - * 1 - Enable hpet - */ -#define HPET_TIMER 1 - -/** - * @def USB_CONFIG - * @brief bit[0-6] used to control USB - * 0 - Disable - * 1 - Enable - * Usb Ohci1 Controller (Bus 0 Dev 18 Func0) is define at BIT0 - * Usb Ehci1 Controller (Bus 0 Dev 18 Func2) is define at BIT1 - * Usb Ohci2 Controller (Bus 0 Dev 19 Func0) is define at BIT2 - * Usb Ehci2 Controller (Bus 0 Dev 19 Func2) is define at BIT3 - * Usb Ohci3 Controller (Bus 0 Dev 22 Func0) is define at BIT4 - * Usb Ehci3 Controller (Bus 0 Dev 22 Func2) is define at BIT5 - * Usb Ohci4 Controller (Bus 0 Dev 20 Func5) is define at BIT6 - */ -#define USB_CONFIG 0x7F - -/** - * @def PCI_CLOCK_CTRL - * @brief bit[0-4] used for PCI Slots Clock Control, - * 0 - disable - * 1 - enable - * PCI SLOT 0 define at BIT0 - * PCI SLOT 1 define at BIT1 - * PCI SLOT 2 define at BIT2 - * PCI SLOT 3 define at BIT3 - * PCI SLOT 4 define at BIT4 - */ -#define PCI_CLOCK_CTRL 0x07 - -/** - * @def SATA_CONTROLLER - * @brief INCHIP Sata Controller - */ -#define SATA_CONTROLLER CIMX_OPTION_ENABLED - -/** - * @def SATA_MODE - * @brief INCHIP Sata Controller Mode - * NOTE: DO NOT ALLOW SATA & IDE use same mode - */ -#define SATA_MODE CONFIG_SB800_SATA_MODE - -/** - * @brief INCHIP Sata IDE Controller Mode - */ -#define IDE_LEGACY_MODE 0 -#define IDE_NATIVE_MODE 1 - -/** - * @def SATA_IDE_MODE - * @brief INCHIP Sata IDE Controller Mode - * NOTE: DO NOT ALLOW SATA & IDE use same mode - */ -#define SATA_IDE_MODE IDE_LEGACY_MODE - -/** - * @def EXTERNAL_CLOCK - * @brief 00/10: Reference clock from crystal oscillator via - * PAD_XTALI and PAD_XTALO - * - * @def INTERNAL_CLOCK - * @brief 01/11: Reference clock from internal clock through - * CP_PLL_REFCLK_P and CP_PLL_REFCLK_N via RDL - */ -#define EXTERNAL_CLOCK 0x00 -#define INTERNAL_CLOCK 0x01 - -/* NOTE: inagua have to using internal clock, - * otherwise can not detect sata drive - */ -#define SATA_CLOCK_SOURCE INTERNAL_CLOCK - -/** - * @def SATA_PORT_MULT_CAP_RESERVED - * @brief 1 ON, 0 0FF - */ -#define SATA_PORT_MULT_CAP_RESERVED 1 - - -/** - * @def AZALIA_AUTO - * @brief Detect Azalia controller automatically. - * - * @def AZALIA_DISABLE - * @brief Disable Azalia controller. - - * @def AZALIA_ENABLE - * @brief Enable Azalia controller. - */ -#define AZALIA_AUTO 0 -#define AZALIA_DISABLE 1 -#define AZALIA_ENABLE 2 - -/** - * @brief INCHIP HDA controller - */ -#define AZALIA_CONTROLLER AZALIA_AUTO - -/** - * @def AZALIA_PIN_CONFIG - * @brief - * 0 - disable - * 1 - enable - */ -#define AZALIA_PIN_CONFIG 1 - -/** - * @def AZALIA_SDIN_PIN - * @brief - * SDIN0 is define at BIT0 & BIT1 - * 00 - GPIO PIN - * 01 - Reserved - * 10 - As a Azalia SDIN pin - * SDIN1 is define at BIT2 & BIT3 - * SDIN2 is define at BIT4 & BIT5 - * SDIN3 is define at BIT6 & BIT7 - */ -//#define AZALIA_SDIN_PIN 0xAA -#define AZALIA_SDIN_PIN 0x2A - -/** - * @def GPP_CONTROLLER - */ -#define GPP_CONTROLLER CIMX_OPTION_ENABLED - -/** - * @def GPP_CFGMODE - * @brief GPP Link Configuration - * four possible configuration: - * GPP_CFGMODE_X4000 - * GPP_CFGMODE_X2200 - * GPP_CFGMODE_X2110 - * GPP_CFGMODE_X1111 - */ -#define GPP_CFGMODE GPP_CFGMODE_X1111 - -/** - * @def NB_SB_GEN2 - * 0 - Disable - * 1 - Enable - */ -#define NB_SB_GEN2 TRUE - -/** - * @def SB_GPP_GEN2 - * 0 - Disable - * 1 - Enable - */ -#define SB_GPP_GEN2 TRUE - -/** - * @def SB_GPP_UNHIDE_PORTS - * TRUE - ports visible always, even port empty - * FALSE - ports invisible if port empty - */ -#define SB_GPP_UNHIDE_PORTS FALSE - -/** - * @def GEC_CONFIG - * 0 - Enable - * 1 - Disable - */ -#define GEC_CONFIG 0 - -static const CODECENTRY persimmon_codec_alc269[] = -{ - /* NID, PinConfig */ - {0x12, 0x411111F0}, - {0x14, 0x99130110}, - {0x21, 0x0121401F}, - {0x17, 0x411111F0}, - {0x18, 0x01A19820}, - {0x19, 0x411111F0}, - {0x1A, 0x0181302F}, - {0x1B, 0x411111F0}, - {0x1D, 0x40069E05}, - {0x1E, 0x411111F0}, - {0x20, 0x0001FFFF}, - {0xff, 0xffffffff} /* end of table */ -}; - -static const CODECTBLLIST codec_tablelist[] = -{ - {0x010ec0269, (CODECENTRY*)&persimmon_codec_alc269[0]}, - {0x0FFFFFFFFUL, (CODECENTRY*)0x0FFFFFFFFUL} -}; - -/** - * @def AZALIA_OEM_VERB_TABLE - * Mainboard specific codec verb table list - */ -#define AZALIA_OEM_VERB_TABLE (&codec_tablelist[0]) - -/* set up an ACPI preferred power management profile */ -/* from acpi.h - * PM_UNSPECIFIED = 0, - * PM_DESKTOP = 1, - * PM_MOBILE = 2, - * PM_WORKSTATION = 3, - * PM_ENTERPRISE_SERVER = 4, - * PM_SOHO_SERVER = 5, - * PM_APPLIANCE_PC = 6, - * PM_PERFORMANCE_SERVER = 7, - * PM_TABLET = 8 - */ -#define FADT_PM_PROFILE 1 - -#endif /* _PLATFORM_CFG_H_ */ diff --git a/src/mainboard/amd/persimmon/romstage.c b/src/mainboard/amd/persimmon/romstage.c deleted file mode 100644 index 7ccf167..0000000 --- a/src/mainboard/amd/persimmon/romstage.c +++ /dev/null @@ -1,27 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <northbridge/amd/agesa/state_machine.h> -#include <superio/fintek/common/fintek.h> -#include <superio/fintek/f81865f/f81865f.h> -#include <sb_cimx.h> - -#define SERIAL_DEV PNP_DEV(0x4e, F81865F_SP1) - -void board_BeforeAgesa(struct sysinfo *cb) -{ - sb_Poweron_Init(); - fintek_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); -}
HAOUAS Elyes has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/39062 )
Change subject: mb/amd/persimmon: Drop unmaintained ROMCC board ......................................................................
Abandoned
