Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11985
commit 958ae41f83fc72e71c9d0ebda6d4eb7fc50993e5 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Wed Jun 10 00:35:05 2015 -0500
northbridge/amd/amdfam10: Add ability to set maximum P-state limit
Change-Id: Ifdbb1ad11a856f855c59702ae0ee99e95b08520e Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/mainboard/asus/kgpe-d16/cmos.default | 1 + src/mainboard/asus/kgpe-d16/cmos.layout | 3 ++- src/northbridge/amd/amdfam10/misc_control.c | 24 ++++++++++++++++++++---- 3 files changed, 23 insertions(+), 5 deletions(-)
diff --git a/src/mainboard/asus/kgpe-d16/cmos.default b/src/mainboard/asus/kgpe-d16/cmos.default index 5bfaadd..a52b7fa 100644 --- a/src/mainboard/asus/kgpe-d16/cmos.default +++ b/src/mainboard/asus/kgpe-d16/cmos.default @@ -17,6 +17,7 @@ interleave_memory_channels = Enable cpu_c_states = Enable cpu_cc6_state = Enable sata_ahci_mode = Enable +maximum_p_state_limit = 0xf ieee1394 = Enable power_on_after_fail = On boot_option = Fallback diff --git a/src/mainboard/asus/kgpe-d16/cmos.layout b/src/mainboard/asus/kgpe-d16/cmos.layout index 247fd7b..307bddc 100644 --- a/src/mainboard/asus/kgpe-d16/cmos.layout +++ b/src/mainboard/asus/kgpe-d16/cmos.layout @@ -46,7 +46,8 @@ entries 465 1 e 1 cpu_c_states 466 1 e 1 cpu_cc6_state 467 1 e 1 sata_ahci_mode -468 1 r 0 allow_spd_nvram_cache_restore +468 4 h 0 maximum_p_state_limit +473 1 r 0 allow_spd_nvram_cache_restore 477 1 e 1 ieee1394 728 256 h 0 user_data 984 16 h 0 check_sum diff --git a/src/northbridge/amd/amdfam10/misc_control.c b/src/northbridge/amd/amdfam10/misc_control.c index 8777e8f..703ae51 100644 --- a/src/northbridge/amd/amdfam10/misc_control.c +++ b/src/northbridge/amd/amdfam10/misc_control.c @@ -124,16 +124,32 @@ static void mcf3_set_resources(device_t dev)
static void misc_control_init(struct device *dev) { - u32 cmd; + uint32_t dword; + uint8_t nvram; + uint8_t boost_limit; + uint8_t current_boost;
printk(BIOS_DEBUG, "NB: Function 3 Misc Control.. ");
/* Disable Machine checks from Invalid Locations. * This is needed for PC backwards compatibility. */ - cmd = pci_read_config32(dev, 0x44); - cmd |= (1<<6) | (1<<25); - pci_write_config32(dev, 0x44, cmd ); + dword = pci_read_config32(dev, 0x44); + dword |= (1<<6) | (1<<25); + pci_write_config32(dev, 0x44, dword); + + boost_limit = 0xf; + if (get_option(&nvram, "maximum_p_state_limit") == CB_SUCCESS) + boost_limit = nvram & 0xf; + + /* Set P-state maximum value */ + dword = pci_read_config32(dev, 0xdc); + current_boost = (dword >> 8) & 0x7; + if (boost_limit > current_boost) + boost_limit = current_boost; + dword &= ~(0x7 << 8); + dword |= (boost_limit & 0x7) << 8; + pci_write_config32(dev, 0xdc, dword);
printk(BIOS_DEBUG, "done.\n"); }
