Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9115
commit a0ff48f189501052c2b539e5d79c4c69e2e65541 Author: Patrick Georgi pgeorgi@chromium.org Date: Fri Mar 27 15:32:49 2015 +0100
x86/smm: Move SMM configuration out of generic Makefile
It's x86 specific.
This is inspired by the commit listed below, but rewritten to match upstream, and split in smaller pieces to keep intent clear.
Change-Id: Iacb91b47c89041435dd27c2c9ad34a231adf21d2 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Based-On-Change-Id: I50af7dacf616e0f8ff4c43f4acc679089ad7022b Based-On-Signed-off-by: Julius Werner jwerner@chromium.org Based-On-Reviewed-on: https://chromium-review.googlesource.com/219170 --- Makefile.inc | 10 ---------- src/cpu/x86/smm/Makefile.inc | 4 ++++ 2 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/Makefile.inc b/Makefile.inc index 59ddf7e..c0125a8 100644 --- a/Makefile.inc +++ b/Makefile.inc @@ -134,16 +134,6 @@ endif
bootblock-generic-ccopts += -D__BOOT_BLOCK__ -D__PRE_RAM__
-smmstub-generic-ccopts += -D__SMM__ -smm-generic-ccopts += -D__SMM__ - -# SMM TSEG base is dynamic -ifneq ($(CONFIG_SMM_MODULES),y) -ifeq ($(CONFIG_SMM_TSEG),y) -smm-c-ccopts += -fpic -endif -endif - ramstage-c-deps:=$$(OPTION_TABLE_H) romstage-c-deps:=$$(OPTION_TABLE_H) verstage-c-deps:=$$(OPTION_TABLE_H) diff --git a/src/cpu/x86/smm/Makefile.inc b/src/cpu/x86/smm/Makefile.inc index 971eacf..3fb92a2 100644 --- a/src/cpu/x86/smm/Makefile.inc +++ b/src/cpu/x86/smm/Makefile.inc @@ -27,6 +27,9 @@ $(eval $(call create_class_compiler,smm,x86_64)) $(eval $(call create_class_compiler,smmstub,x86_64)) endif
+smmstub-generic-ccopts += -D__SMM__ +smm-generic-ccopts += -D__SMM__ + $(obj)/cpu/x86/smm/smm.o: $$(smm-objs) $(COMPILER_RT_smm) $(LD_smm) -nostdlib -r -o $@ $(COMPILER_RT_FLAGS_smm) --start-group $(smm-objs) $(COMPILER_RT_smm) --end-group
@@ -101,6 +104,7 @@ endif # Use TSEG specific entry point and linker script ifeq ($(CONFIG_SMM_TSEG),y) smm-y += smmhandler_tseg.S +smm-c-ccopts += -fpic SMM_LDFLAGS := -pie SMM_LDSCRIPT := smm_tseg.ld else
