Attention is currently required from: Cliff Huang, Felix Held, Fred Reitberger, Jason Glenesk, Lance Zhao, Matt DeVillier, Nico Huber, Patrick Rudolph, Tim Wawrzynczak.
Hello Cliff Huang, Fred Reitberger, Jason Glenesk, Lance Zhao, Matt DeVillier, Nico Huber, Patrick Rudolph, Tim Wawrzynczak, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/79927?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Matt DeVillier, Verified+1 by build bot (Jenkins)
Change subject: device: Add support for multiple PCI segment groups ......................................................................
Add initial support for multiple PCI segment groups. Instead of modifying secondary in the bus struct introduce a new variable and keep existing common code.
Since all platforms currently only use 1 segment this is not a functional change. On platforms that support more than 1 segment the segment has to be set when creating the PCI domain.
Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ied3313c41896362dd989ee2ab1b1bcdced840aa8 --- M src/acpi/acpi.c M src/arch/x86/mpspec.c M src/device/Kconfig M src/device/device.c M src/device/device_const.c M src/device/device_util.c M src/device/pci_device.c M src/device/pci_rom.c M src/device/pcix_device.c M src/include/device/device.h M src/include/device/pci_def.h M src/include/device/pci_ops.h M src/lib/smbios.c M src/northbridge/amd/pi/00730F01/northbridge.c M src/soc/amd/common/block/acpi/ivrs.c M src/soc/amd/common/block/data_fabric/domain.c M src/soc/amd/genoa_poc/domain.c M src/soc/intel/xeon_sp/cpx/soc_acpi.c M src/soc/intel/xeon_sp/uncore.c 19 files changed, 100 insertions(+), 42 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/27/79927/8
