Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12055
commit c16062b7739a77b084d139468f40f43d66ee26e0 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Thu Aug 27 13:17:14 2015 -0500
northbridge/amd/amdmct/mct_ddr3: Ensure channel clock skew is properly set up
Change-Id: Iafc233984ae1d44fe6a1cb5b109d36397cbd991a Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/northbridge/amd/amdmct/mct_ddr3/mct_d.c | 46 ++++++++++++++++------------- 1 file changed, 25 insertions(+), 21 deletions(-)
diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c b/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c index 1c3f5a3..a11b227 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/mct_d.c @@ -3051,6 +3051,23 @@ static void DCTInit_D(struct MCTStatStruc *pMCTstat, struct DCTStatStruc *pDCTst printk(BIOS_DEBUG, "\t\tDCTInit_D: mct_SPDCalcWidth Done\n"); if (AutoCycTiming_D(pMCTstat, pDCTstat, dct) < SC_StopError) { printk(BIOS_DEBUG, "\t\tDCTInit_D: AutoCycTiming_D Done\n"); + + /* SkewMemClk must be set before MemClkFreqVal is set + * This relies on DCTInit_D being called for DCT 1 after + * it has already been called for DCT 0... + */ + if (is_fam15h()) { + /* Set memory clock skew if needed */ + if (dct == 1) { + if (!pDCTstat->stopDCT[0]) { + printk(BIOS_DEBUG, "\t\tDCTInit_D: enabling intra-channel clock skew\n"); + dword = Get_NB32_index_wait_DCT(pDCTstat->dev_dct, 0, 0x98, 0x0d0fe00a); + dword |= (0x1 << 4); /* SkewMemClk = 1 */ + Set_NB32_index_wait_DCT(pDCTstat->dev_dct, 0, 0x98, 0x0d0fe00a, dword); + } + } + } + if (AutoConfig_D(pMCTstat, pDCTstat, dct) < SC_StopError) { printk(BIOS_DEBUG, "\t\tDCTInit_D: AutoConfig_D Done\n"); if (PlatformSpec_D(pMCTstat, pDCTstat, dct) < SC_StopError) { @@ -3060,8 +3077,6 @@ static void DCTInit_D(struct MCTStatStruc *pMCTstat, struct DCTStatStruc *pDCTst } } } - - }
static void DCTFinalInit_D(struct MCTStatStruc *pMCTstat, struct DCTStatStruc *pDCTstat, u8 dct) @@ -3069,17 +3084,6 @@ static void DCTFinalInit_D(struct MCTStatStruc *pMCTstat, struct DCTStatStruc *p uint32_t dword;
/* Finalize DRAM init on a single node */ - if (is_fam15h()) { - /* Set memory clock skew if needed */ - if (dct == 0) { - if (!pDCTstat->stopDCT[0] && !pDCTstat->stopDCT[1]) { - dword = Get_NB32_index_wait_DCT(pDCTstat->dev_dct, dct, 0x98, 0x0d0fe00a); - dword |= (0x1 << 4); /* SkewMemClk = 1 */ - Set_NB32_index_wait_DCT(pDCTstat->dev_dct, dct, 0x98, 0x0d0fe00a, dword); - } - } - } - if (!pDCTstat->stopDCT[dct]) { if (!(pMCTstat->GStatus & (1 << GSB_EnDIMMSpareNW))) { printk(BIOS_DEBUG, "\t\tDCTFinalInit_D: StartupDCT_D Start\n"); @@ -3282,28 +3286,28 @@ static void SPD2ndTiming(struct MCTStatStruc *pMCTstat, if (Twtr < val) Twtr = val;
- val = pDCTstat->spd_data.spd_bytes[dct + i][SPD_Upper_tRAS_tRC] & 0xFF; + val = pDCTstat->spd_data.spd_bytes[dct + i][SPD_Upper_tRAS_tRC] & 0xff; val >>= 4; val <<= 8; - val |= pDCTstat->spd_data.spd_bytes[dct + i][SPD_tRCmin] & 0xFF; + val |= pDCTstat->spd_data.spd_bytes[dct + i][SPD_tRCmin] & 0xff; val *= MTB16x; if (Trc < val) Trc = val;
- byte = pDCTstat->spd_data.spd_bytes[dct + i][SPD_Density] & 0xF; + byte = pDCTstat->spd_data.spd_bytes[dct + i][SPD_Density] & 0xf; if (Trfc[LDIMM] < byte) Trfc[LDIMM] = byte;
- val = pDCTstat->spd_data.spd_bytes[dct + i][SPD_Upper_tRAS_tRC] & 0xF; + val = pDCTstat->spd_data.spd_bytes[dct + i][SPD_Upper_tRAS_tRC] & 0xf; val <<= 8; - val |= (pDCTstat->spd_data.spd_bytes[dct + i][SPD_tRASmin] & 0xFF); + val |= (pDCTstat->spd_data.spd_bytes[dct + i][SPD_tRASmin] & 0xff); val *= MTB16x; if (Tras < val) Tras = val;
- val = pDCTstat->spd_data.spd_bytes[dct + i][SPD_Upper_tFAW] & 0xF; + val = pDCTstat->spd_data.spd_bytes[dct + i][SPD_Upper_tFAW] & 0xf; val <<= 8; - val |= pDCTstat->spd_data.spd_bytes[dct + i][SPD_tFAWmin] & 0xFF; + val |= pDCTstat->spd_data.spd_bytes[dct + i][SPD_tFAWmin] & 0xff; val *= MTB16x; if (Tfaw < val) Tfaw = val; @@ -3510,7 +3514,7 @@ static void SPD2ndTiming(struct MCTStatStruc *pMCTstat, /* Trfc0-Trfc3 */ for (i=0; i<4; i++) if (pDCTstat->Trfc[i] == 0x0) - pDCTstat->Trfc[i] = 0x4; + pDCTstat->Trfc[i] = 0x1; dword = Get_NB32_DCT(dev, dct, 0x208); /* DRAM Timing 2 */ dword &= ~(0x07070707); dword |= (pDCTstat->Trfc[3] & 0x7) << 24; /* Trfc3 */
