Attention is currently required from: Felix Held, Jérémy Compostella, Karthik Ramasubramanian, Martin L Roth, Paul Menzel.
Hello Felix Held, Karthik Ramasubramanian, Martin L Roth, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/84575?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Karthik Ramasubramanian, Verified+1 by build bot (Jenkins)
Change subject: util/lint: Use bigint for hexadecimal values in handle_range ......................................................................
The `handle_range` function in `kconfig_lint` was failing to correctly handle large hexadecimal values (64-bit value) due to limitations with Perl's handling of standard integers.
This commit modifies the function to use the `bigint` pragma, enabling it to handle arbitrarily large integers. This prevents issues with 64-bit hexadecimal values and ensures accurate comparisons for range validation.
Change-Id: I402bb9bec9ba5bfb79b4185f35228c41d4a7b674 Signed-off-by: Subrata Banik subratabanik@google.com --- M util/lint/kconfig_lint 1 file changed, 13 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/75/84575/5
