Marty E. Plummer has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/35008 )
Change subject: build: build the open-power ffs tools ......................................................................
Change-Id: I0ed8b8de001835e5676203c384a1659a2f29ff71 Signed-off-by: Marty E. Plummer hanetzer@startmail.com --- M Makefile.inc 1 file changed, 17 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/08/35008/1
diff --git a/Makefile.inc b/Makefile.inc index c275d1e..9ad0c59 100644 --- a/Makefile.inc +++ b/Makefile.inc @@ -515,6 +515,8 @@ IFWITOOL:=$(objutil)/cbfstool/ifwitool IFITTOOL:=$(objutil)/cbfstool/ifittool AMDCOMPRESS:=$(objutil)/cbfstool/amdcompress +FPART:=$(objutil)/ffs/fpart/fpart +ECC:=$(objutil)/ffs/ecc/ecc
$(obj)/cbfstool: $(CBFSTOOL) cp $< $@ @@ -534,6 +536,21 @@ $(obj)/amdcompress: $(AMDCOMPRESS) cp $< $@
+$(FPART): + mkdir -p $(objutil)/ffs + cd $(top)/3rdparty/ffs && autoreconf -i + cd $(objutil)/ffs && $(top)/3rdparty/ffs/configure CC="$(HOSTCC)" LD="$(LD)" + $(MAKE) -C $(objutil)/ffs + +$(ECC): $(FPART) + true + +$(obj)/fpart: $(FPART) + cp $< $@ + +$(obj)/ecc: $(ECC) + cp $< $@ + _WINCHECK=$(shell uname -o 2> /dev/null) STACK= ifeq ($(_WINCHECK),Msys)
Marty E. Plummer has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35008 )
Patch Set 1:
Having some slight issue here. Currently you need to manually do `make build/fpart` to get this to work as the ffs tools do not get built otherwise. Unsure how to do that.
Timothy Pearson has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35008 )
Patch Set 4: Code-Review+2
Patch Set 4:
Actually, don't merge any of these ffs patches yet. I think I have a better way of doin it.
Patch Set 4: -Code-Review
Patch Set 4:
OK, in the future the best way to do that is to set -1/-2 on your own patches to block submission. As it stands I'm trying to review OpenPOWER patches fairly rapidly to encourage development, so there's a high chance of things going through rapidly if I don't see problems with the patch sets (and they don't touch non-POWER parts of the tree).
Hello Timothy Pearson, build bot (Jenkins), Patrick Georgi, Martin Roth,
Change-Id: I0ed8b8de001835e5676203c384a1659a2f29ff71 Signed-off-by: Marty E. Plummer hanetzer@startmail.com --- M Makefile.inc 1 file changed, 22 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/08/35008/6
Patch Set 6:
Patch Set 4:
Ok, noted. I've got it so that fpart is automatically built if you set CONFIG_FFS_HEADERS and as far as I can see it does not impact non ppc64 builds.
