Philip Chen has uploaded this change for review. ( https://review.coreboot.org/20522
Change subject: nefario: add nefario in coreboot ......................................................................
There will be more follow-up changes.
BUG=b:63537905 BRANCH=None TEST=emerge-nefario coreboot libpayload
Change-Id: I6bb80723ea2573df617026a4a5740adb89331892 --- M src/mainboard/google/gru/Kconfig M src/mainboard/google/gru/Kconfig.name 2 files changed, 6 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/22/20522/1
diff --git a/src/mainboard/google/gru/Kconfig b/src/mainboard/google/gru/Kconfig index 0fce7cc..5bc23cd 100644 --- a/src/mainboard/google/gru/Kconfig +++ b/src/mainboard/google/gru/Kconfig @@ -93,6 +93,7 @@ default "Bob" if BOARD_GOOGLE_BOB default "Gru" if BOARD_GOOGLE_GRU default "Kevin" if BOARD_GOOGLE_KEVIN + default "Nefario" if BOARD_GOOGLE_NEFARIO
# The default max sdram freq is 933M(actually 928M dpll), and # 800M is another choice. @@ -108,5 +109,6 @@ default "BOB TEST 7422" if BOARD_GOOGLE_BOB default "GRU TEST 5431" if BOARD_GOOGLE_GRU default "KEVIN TEST 1422" if BOARD_GOOGLE_KEVIN + default "NEFARIO TEST 3735" if BOARD_GOOGLE_NEFARIO
endif # BOARD_GOOGLE_GRU_COMMON diff --git a/src/mainboard/google/gru/Kconfig.name b/src/mainboard/google/gru/Kconfig.name index 55d7a65..f0351fd 100644 --- a/src/mainboard/google/gru/Kconfig.name +++ b/src/mainboard/google/gru/Kconfig.name @@ -13,3 +13,7 @@ config BOARD_GOOGLE_SCARLET bool "Scarlet" select BOARD_GOOGLE_GRU_COMMON + +config BOARD_GOOGLE_NEFARIO + bool "Nefario" + select BOARD_GOOGLE_GRU_COMMON
