Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/74908 )
Change subject: sb/intel/common: Fix corner-case with Kconfig ......................................................................
To select COMMON_SMM should not imply COMMON_PMBASE, it's really a depencency. Select them both explicitly for i82801dx.
Change-Id: I387ade9cfd38b6555ed9e37c1b9178a6da2d7260 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/southbridge/intel/common/Kconfig.common M src/southbridge/intel/i82801dx/Kconfig 2 files changed, 17 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/08/74908/1
diff --git a/src/southbridge/intel/common/Kconfig.common b/src/southbridge/intel/common/Kconfig.common index 2da6971..e138f5e 100644 --- a/src/southbridge/intel/common/Kconfig.common +++ b/src/southbridge/intel/common/Kconfig.common @@ -59,7 +59,7 @@ def_bool n select HAVE_POWER_STATE_AFTER_FAILURE select HAVE_POWER_STATE_PREVIOUS_AFTER_FAILURE - select SOUTHBRIDGE_INTEL_COMMON_PMBASE + depends on SOUTHBRIDGE_INTEL_COMMON_PMBASE
config SOUTHBRIDGE_INTEL_COMMON_FINALIZE bool diff --git a/src/southbridge/intel/i82801dx/Kconfig b/src/southbridge/intel/i82801dx/Kconfig index 8393f38..20a56e7 100644 --- a/src/southbridge/intel/i82801dx/Kconfig +++ b/src/southbridge/intel/i82801dx/Kconfig @@ -6,11 +6,12 @@ select ACPI_COMMON_MADT_LAPIC select ACPI_INTEL_HARDWARE_SLEEP_VALUES select HAVE_SMI_HANDLER - select SOUTHBRIDGE_INTEL_COMMON_SMBUS - select SOUTHBRIDGE_INTEL_COMMON_SMM select SOUTHBRIDGE_INTEL_COMMON_EARLY_SMBUS + select SOUTHBRIDGE_INTEL_COMMON_PMBASE select SOUTHBRIDGE_INTEL_COMMON_RTC select SOUTHBRIDGE_INTEL_COMMON_RESET + select SOUTHBRIDGE_INTEL_COMMON_SMBUS + select SOUTHBRIDGE_INTEL_COMMON_SMM select SOUTHBRIDGE_INTEL_COMMON_USB_DEBUG select HAVE_POWER_STATE_AFTER_FAILURE select HAVE_POWER_STATE_PREVIOUS_AFTER_FAILURE
