Attention is currently required from: Hung-Te Lin.
Liju-Clr Chen has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/69139 )
Change subject: Revert "soc/mediatek/mt8188: Allow CPUfreq hardware to access MCUPM registers" ......................................................................
This reverts commit a8172c329fe309f3b5b409c1a59a227186400dd4.
In this patch, we allow MCUPM to access secure registers and set the domain to DOMAIN_2.
Additional attribute settings are also required when a hardware is set to a specific domain. Otherwise, there would be violation between hardware. Since MT8188 is in bring-up stage, we simply enable access register permission for the DOMAIN_0 by default. So remove the wrong setting for MCUPM, SCP and SSPM.
We will complete DEVAPC setting when the settings are confirmed.
Change-Id: I5d9809f6e84b8d10bc2e6f2ea5a442e676ad3bf9 --- M src/soc/mediatek/mt8188/devapc.c M src/soc/mediatek/mt8188/include/soc/devapc.h 2 files changed, 22 insertions(+), 10 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/39/69139/1
diff --git a/src/soc/mediatek/mt8188/devapc.c b/src/soc/mediatek/mt8188/devapc.c index 260b9ff..1fe3cf8 100644 --- a/src/soc/mediatek/mt8188/devapc.c +++ b/src/soc/mediatek/mt8188/devapc.c @@ -1550,12 +1550,6 @@
static void infra_init(uintptr_t base) { - /* Side band */ - SET32_BITFIELDS(getreg(base, MAS_SEC_0), MCUPM_SEC, SECURE_TRANS); - - /* Master domain */ - SET32_BITFIELDS(getreg(base, MAS_DOM_0), SCP_SSPM_DOM, DOMAIN_2, MCUPM_DOM, DOMAIN_2); - /* Default APC setting */ set_infra_ao_apc(base); } diff --git a/src/soc/mediatek/mt8188/include/soc/devapc.h b/src/soc/mediatek/mt8188/include/soc/devapc.h index d742c22..e0b0f00 100644 --- a/src/soc/mediatek/mt8188/include/soc/devapc.h +++ b/src/soc/mediatek/mt8188/include/soc/devapc.h @@ -17,10 +17,6 @@ AO_APC_CON = 0x00F00, };
-DEFINE_BIT(MCUPM_SEC, 1) -DEFINE_BITFIELD(MCUPM_DOM, 11, 8) -DEFINE_BITFIELD(SCP_SSPM_DOM, 19, 16) - /****************************************************************************** * STRUCTURE DEFINITION ******************************************************************************/
