Attention is currently required from: Kevin3 Yang.
Hello build bot (Jenkins), Derek Huang, Sumeet R Pawnikar,
https://review.coreboot.org/c/coreboot/+/74626
Change subject: mb/google/dedede/var/boxy: Update devicetree and GPIO table ......................................................................
Create overridetree and GPIO config based on latest schematic:
1. Update PCIe ports 2. Update USB ports 3. Remove unused I2Cs 4. Remove unused peripherals (SD card, eDP, speakers) 5. Add LAN 6. Thermal policy for updated temp sensors
BUG=b:277529068 BRANCH=dedede TEST=build
Signed-off-by: Kevin Yang kevin3.yang@lcfc.corp-partner.google.com Change-Id: I5a155ebca50dbd5bdb046713ebabbee395361273 --- A src/mainboard/google/dedede/variants/boxy/MakeFile.inc A src/mainboard/google/dedede/variants/boxy/gpio.c M src/mainboard/google/dedede/variants/boxy/overridetree.cb 3 files changed, 293 insertions(+), 18 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/26/74626/10
