HAOUAS Elyes has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/38162 )
Change subject: crossgcc: Upgrade cmake to version 3.16.2 ......................................................................
Aslo add comment on IASL conflicting use of _ADR and _HID.
Change-Id: I2012f0adcb348a3ea6c50c361a49a0a600d3db3d Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M util/crossgcc/buildgcc D util/crossgcc/sum/cmake-3.16.0.tar.gz.cksum A util/crossgcc/sum/cmake-3.16.2.tar.gz.cksum 3 files changed, 6 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/62/38162/1
diff --git a/util/crossgcc/buildgcc b/util/crossgcc/buildgcc index 6150011..b862b9a 100755 --- a/util/crossgcc/buildgcc +++ b/util/crossgcc/buildgcc @@ -54,13 +54,17 @@ GCC_AUTOCONF_VERSION=2.69 BINUTILS_VERSION=2.33.1 GDB_VERSION=8.3.1 + +# Conflicting use of _ADR and _HID in coreboot tree needs +# to be properly # addressed before we can upgrade IASL version. +# Use IASL version 20190703 For now. IASL_VERSION=20190703 PYTHON_VERSION=3.8.1 EXPAT_VERSION=2.2.9 # CLANG version number CLANG_VERSION=9.0.0 MAKE_VERSION=4.2.1 -CMAKE_VERSION=3.16.0 +CMAKE_VERSION=3.16.2 NASM_VERSION=2.14.02
# GCC toolchain archive locations diff --git a/util/crossgcc/sum/cmake-3.16.0.tar.gz.cksum b/util/crossgcc/sum/cmake-3.16.0.tar.gz.cksum deleted file mode 100644 index 0adcc1a..0000000 --- a/util/crossgcc/sum/cmake-3.16.0.tar.gz.cksum +++ /dev/null @@ -1 +0,0 @@ -9943ebbbf076bbe1b54c7dadcd6df28ad0d241ed tarballs/cmake-3.16.0.tar.gz diff --git a/util/crossgcc/sum/cmake-3.16.2.tar.gz.cksum b/util/crossgcc/sum/cmake-3.16.2.tar.gz.cksum new file mode 100644 index 0000000..c5190b2 --- /dev/null +++ b/util/crossgcc/sum/cmake-3.16.2.tar.gz.cksum @@ -0,0 +1 @@ +f514dbd9aa8332a28ba62dd8ce97b0aa0b099491 tarballs/cmake-3.16.2.tar.gz
HAOUAS Elyes has uploaded a new patch set (#2). ( https://review.coreboot.org/c/coreboot/+/38162 )
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/62/38162/2
Hello build bot (Jenkins),
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/62/38162/3
Also add comment on IASL conflicting use of _ADR and _HID.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/62/38162/4
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38162 )
Patch Set 4: Code-Review+1
Idwer Vollering has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38162 )
Patch Set 4: Code-Review-2
https://review.coreboot.org/c/coreboot/+/38162/4/util/crossgcc/buildgcc File util/crossgcc/buildgcc:
https://review.coreboot.org/c/coreboot/+/38162/4/util/crossgcc/buildgcc@60 PS4, Line 60: version This change is about cmake, not acpica.
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38162 )
Patch Set 4:
Thank you. yes you are right. I'll split it to 2 parts.
Hello Idwer Vollering, Paul Menzel, build bot (Jenkins),
Change-Id: I2012f0adcb348a3ea6c50c361a49a0a600d3db3d Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M util/crossgcc/buildgcc D util/crossgcc/sum/cmake-3.16.0.tar.gz.cksum A util/crossgcc/sum/cmake-3.16.2.tar.gz.cksum 3 files changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/62/38162/5
Patch Set 5: -Code-Review
Stefan Reinauer has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38162 )
Patch Set 5: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/38162 )
Change-Id: I2012f0adcb348a3ea6c50c361a49a0a600d3db3d Signed-off-by: Elyes HAOUAS ehaouas@noos.fr Reviewed-on: https://review.coreboot.org/c/coreboot/+/38162 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Stefan Reinauer stefan.reinauer@coreboot.org --- M util/crossgcc/buildgcc D util/crossgcc/sum/cmake-3.16.0.tar.gz.cksum A util/crossgcc/sum/cmake-3.16.2.tar.gz.cksum 3 files changed, 2 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Stefan Reinauer: Looks good to me, approved
diff --git a/util/crossgcc/buildgcc b/util/crossgcc/buildgcc index b3b92d4..ab2ea89 100755 --- a/util/crossgcc/buildgcc +++ b/util/crossgcc/buildgcc @@ -64,7 +64,7 @@ # CLANG version number CLANG_VERSION=9.0.0 MAKE_VERSION=4.2.1 -CMAKE_VERSION=3.16.0 +CMAKE_VERSION=3.16.2 NASM_VERSION=2.14.02
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38162 )
Patch Set 6:
Automatic boot test returned (PASS/FAIL/TOTAL): 3/0/3 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : No test failed. EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : No test failed. EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : No test failed.
