Rizwan Qureshi (rizwan.qureshi@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16267
commit 4f55b0e97b0e2eadcf9704d1fcda0e6d6f2a02a3 Author: Rizwan Qureshi rizwan.qureshi@intel.com Date: Tue Aug 23 14:31:23 2016 +0530
skylake: Add initial FSP2.0 support
Add Initial pieces of code to support fsp2.0 in skylake keeping the fsp1.1 flow intact.
The soc/romstage.h and soc/ramstage.h have a reference to fsp driver includes, so split these header files for each version of FSP driver.
Add the below files, car_stage.S: Add romstage entry point (car_stage_entry). This calls into romstage_fsp20.c and aslo handles the car teardown. romstage_fsp20.c: Call fsp_memory_init() and also has the callback for filling memory init parameters.
Also add monotonic_timer.c to verstage.
With this patchset and relevant change in kunimitsu mainboard, we are able to boot to romstage.
TEST= Build and Boot Kunimitsu with PLATFORM_USES_FSP1_1 Build and Boot Kunimitsu to romstage with PLATFORM_USES_FSP2_0
Change-Id: I4309c8d4369c84d2bd1b13e8ab7bfeaaec645520 Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com --- src/soc/intel/skylake/Kconfig | 1 + src/soc/intel/skylake/Makefile.inc | 13 +- src/soc/intel/skylake/chip_fsp20.c | 30 +++++ src/soc/intel/skylake/igd.c | 29 +---- src/soc/intel/skylake/include/fsp11/soc/ramstage.h | 36 ++++++ src/soc/intel/skylake/include/fsp11/soc/romstage.h | 30 +++++ src/soc/intel/skylake/include/fsp20/soc/ramstage.h | 39 ++++++ src/soc/intel/skylake/include/fsp20/soc/romstage.h | 30 +++++ src/soc/intel/skylake/include/soc/ramstage.h | 31 ----- src/soc/intel/skylake/include/soc/romstage.h | 30 ----- src/soc/intel/skylake/include/soc/smm.h | 1 - src/soc/intel/skylake/include/soc/vr_config.h | 9 +- src/soc/intel/skylake/memmap.c | 1 - src/soc/intel/skylake/opregion.c | 49 ++++++++ src/soc/intel/skylake/reset.c | 31 +++++ src/soc/intel/skylake/romstage/Makefile.inc | 5 +- src/soc/intel/skylake/romstage/car_stage.S | 131 +++++++++++++++++++++ src/soc/intel/skylake/romstage/romstage_fsp20.c | 44 +++++++ src/soc/intel/skylake/vr_config.c | 27 +++-- 19 files changed, 459 insertions(+), 108 deletions(-)
diff --git a/src/soc/intel/skylake/Kconfig b/src/soc/intel/skylake/Kconfig index 6171c41..edf5db3 100644 --- a/src/soc/intel/skylake/Kconfig +++ b/src/soc/intel/skylake/Kconfig @@ -42,6 +42,7 @@ config CPU_SPECIFIC_OPTIONS select RTC select SOC_INTEL_COMMON select SOC_INTEL_COMMON_ACPI_WAKE_SOURCE + select SOC_INTEL_COMMON_GFX_OPREGION if PLATFORM_USES_FSP2_0 select SOC_INTEL_COMMON_LPSS_I2C select SOC_INTEL_COMMON_NHLT select SOC_INTEL_COMMON_RESET diff --git a/src/soc/intel/skylake/Makefile.inc b/src/soc/intel/skylake/Makefile.inc index 716c3d5..aa3da61 100644 --- a/src/soc/intel/skylake/Makefile.inc +++ b/src/soc/intel/skylake/Makefile.inc @@ -40,12 +40,14 @@ romstage-y += pch.c romstage-y += pcr.c romstage-y += pei_data.c romstage-y += pmutil.c +romstage-$(CONFIG_PLATFORM_USES_FSP2_0) += reset.c romstage-y += smbus_common.c romstage-y += tsc_freq.c romstage-$(CONFIG_UART_DEBUG) += uart_debug.c
ramstage-$(CONFIG_HAVE_ACPI_TABLES) += acpi.c -ramstage-y += chip.c +ramstage-$(CONFIG_PLATFORM_USES_FSP1_1) += chip.c +ramstage-$(CONFIG_PLATFORM_USES_FSP2_0) += chip_fsp20.c ramstage-y += cpu.c ramstage-y += cpu_info.c ramstage-y += dsp.c @@ -59,12 +61,14 @@ ramstage-y += lpc.c ramstage-y += me_status.c ramstage-y += memmap.c ramstage-y += monotonic_timer.c +ramstage-$(CONFIG_PLATFORM_USES_FSP1_1) += opregion.c ramstage-y += pch.c ramstage-y += pcie.c ramstage-y += pcr.c ramstage-y += pei_data.c ramstage-y += pmc.c ramstage-y += pmutil.c +ramstage-$(CONFIG_PLATFORM_USES_FSP2_0) += reset.c ramstage-y += ramstage.c ramstage-y += sd.c ramstage-y += smbus.c @@ -93,7 +97,14 @@ smm-$(CONFIG_UART_DEBUG) += uart_debug.c
CPPFLAGS_common += -I$(src)/soc/intel/skylake CPPFLAGS_common += -I$(src)/soc/intel/skylake/include + +ifeq ($(CONFIG_PLATFORM_USES_FSP1_1),y) +CPPFLAGS_common += -I$(src)/soc/intel/skylake/include/fsp11 CPPFLAGS_common += -I$(src)/vendorcode/intel/fsp/fsp1_1/skylake +else +CPPFLAGS_common += -I$(src)/soc/intel/skylake/include/fsp20 +CPPFLAGS_common += -I$(src)/vendorcode/intel/fsp/fsp2_0/skykabylake +endif
# Currently used for microcode path. CPPFLAGS_common += -I3rdparty/blobs/mainboard/$(MAINBOARD_DIR) diff --git a/src/soc/intel/skylake/chip_fsp20.c b/src/soc/intel/skylake/chip_fsp20.c new file mode 100644 index 0000000..215530c --- /dev/null +++ b/src/soc/intel/skylake/chip_fsp20.c @@ -0,0 +1,30 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <chip.h> +#include <bootstate.h> +#include <device/pci.h> +#include <fsp/api.h> + +/* UPD parameters to be initialized before SiliconInit */ +void platform_fsp_silicon_init_params_cb(struct FSPS_UPD *supd) +{ +} + +struct pci_operations soc_pci_ops = { + /* TODO: Add set subsystem id function */ +}; + diff --git a/src/soc/intel/skylake/igd.c b/src/soc/intel/skylake/igd.c index 3e29ab0..969f386 100644 --- a/src/soc/intel/skylake/igd.c +++ b/src/soc/intel/skylake/igd.c @@ -24,7 +24,6 @@ #include <device/pci.h> #include <device/pci_ids.h> #include <drivers/intel/gma/i915_reg.h> -#include <fsp/gop.h> #include <soc/acpi.h> #include <soc/cpu.h> #include <soc/pm.h> @@ -117,35 +116,10 @@ static void igd_init(struct device *dev) }
/* Initialize IGD OpRegion, called from ACPI code */ -static int init_igd_opregion(igd_opregion_t *opregion) +static int update_igd_opregion(igd_opregion_t *opregion) { - const optionrom_vbt_t *vbt; - uint32_t vbt_len; u16 reg16;
- memset(opregion, 0, sizeof(igd_opregion_t)); - - /* Read VBT table from flash */ - vbt = fsp_get_vbt(&vbt_len); - if (!vbt) - die("vbt data not found"); - - memcpy(&opregion->header.signature, IGD_OPREGION_SIGNATURE, - sizeof(IGD_OPREGION_SIGNATURE) - 1); - memcpy(opregion->header.vbios_version, vbt->coreblock_biosbuild, sizeof(u32)); - memcpy(opregion->vbt.gvd1, vbt, vbt->hdr_vbt_size < - sizeof(opregion->vbt.gvd1) ? vbt->hdr_vbt_size : - sizeof(opregion->vbt.gvd1)); - - /* Size, in KB, of the entire OpRegion structure (including header)*/ - opregion->header.size = sizeof(igd_opregion_t) / KiB; - opregion->header.version = IGD_OPREGION_VERSION; - - /* We just assume we're mobile for now */ - opregion->header.mailboxes = MAILBOXES_MOBILE; - - /* TODO Initialize Mailbox 1 */ - /* Initialize Mailbox 3 */ opregion->mailbox3.bclp = IGD_BACKLIGHT_BRIGHTNESS; opregion->mailbox3.pfit = IGD_FIELD_VALID | IGD_PFIT_STRETCH; @@ -189,6 +163,7 @@ static unsigned long write_acpi_igd_opregion(device_t device, printk(BIOS_DEBUG, "ACPI: * IGD OpRegion\n"); opregion = (igd_opregion_t *)current; init_igd_opregion(opregion); + update_igd_opregion(opregion); current += sizeof(igd_opregion_t); current = acpi_align_current(current);
diff --git a/src/soc/intel/skylake/include/fsp11/soc/ramstage.h b/src/soc/intel/skylake/include/fsp11/soc/ramstage.h new file mode 100644 index 0000000..e469554 --- /dev/null +++ b/src/soc/intel/skylake/include/fsp11/soc/ramstage.h @@ -0,0 +1,36 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2015 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _SOC_RAMSTAGE_H_ +#define _SOC_RAMSTAGE_H_ + +#include <chip.h> +#include <device/device.h> +#include <fsp/gop.h> +#include <fsp/ramstage.h> +#include <fsp/soc_binding.h> + +#define FSP_SIL_UPD SILICON_INIT_UPD +#define FSP_MEM_UPD MEMORY_INIT_UPD + +void pch_enable_dev(device_t dev); +void soc_init_pre_device(void *chip_info); +void soc_init_cpus(device_t dev); +const char *soc_acpi_name(struct device *dev); +int init_igd_opregion(igd_opregion_t *igd_opregion); +extern struct pci_operations soc_pci_ops; + +#endif diff --git a/src/soc/intel/skylake/include/fsp11/soc/romstage.h b/src/soc/intel/skylake/include/fsp11/soc/romstage.h new file mode 100644 index 0000000..6c40bd6 --- /dev/null +++ b/src/soc/intel/skylake/include/fsp11/soc/romstage.h @@ -0,0 +1,30 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2015-2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _SOC_ROMSTAGE_H_ +#define _SOC_ROMSTAGE_H_ + +#include <fsp/romstage.h> + +void systemagent_early_init(void); +void intel_early_me_status(void); +void enable_smbus(void); +int smbus_read_byte(unsigned device, unsigned address); + +int early_spi_read_wpsr(u8 *sr); +void mainboard_fill_spd_data(struct pei_data *pei_data); + +#endif /* _SOC_ROMSTAGE_H_ */ diff --git a/src/soc/intel/skylake/include/fsp20/soc/ramstage.h b/src/soc/intel/skylake/include/fsp20/soc/ramstage.h new file mode 100644 index 0000000..3a9d96b --- /dev/null +++ b/src/soc/intel/skylake/include/fsp20/soc/ramstage.h @@ -0,0 +1,39 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2015 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _SOC_RAMSTAGE_H_ +#define _SOC_RAMSTAGE_H_ + +#include <chip.h> +#include <device/device.h> + +#include <fsp/api.h> +#include <fsp/util.h> +#include <soc/intel/common/opregion.h> + +#define FSP_SIL_UPD struct FSP_S_CONFIG +#define FSP_MEM_UPD struct FSP_M_CONFIG + +void intel_silicon_init(void); +void mainboard_silicon_init_params(struct FSP_S_CONFIG *params); +void pch_enable_dev(device_t dev); +void soc_init_pre_device(void *chip_info); +void soc_init_cpus(device_t dev); +const char *soc_acpi_name(struct device *dev); + +extern struct pci_operations soc_pci_ops; + +#endif diff --git a/src/soc/intel/skylake/include/fsp20/soc/romstage.h b/src/soc/intel/skylake/include/fsp20/soc/romstage.h new file mode 100644 index 0000000..d48ac67 --- /dev/null +++ b/src/soc/intel/skylake/include/fsp20/soc/romstage.h @@ -0,0 +1,30 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Google Inc. + * Copyright (C) 2015-2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _SOC_ROMSTAGE_H_ +#define _SOC_ROMSTAGE_H_ + +#include <arch/cpu.h> +#include <fsp/api.h> + +asmlinkage void *car_stage_c_entry(void); +void mainboard_memory_init_params(struct FSPM_UPD *mupd); + +void systemagent_early_init(void); +int smbus_read_byte(unsigned device, unsigned address); +int early_spi_read_wpsr(u8 *sr); + +#endif /* _SOC_ROMSTAGE_H_ */ diff --git a/src/soc/intel/skylake/include/soc/ramstage.h b/src/soc/intel/skylake/include/soc/ramstage.h deleted file mode 100644 index 55f9972..0000000 --- a/src/soc/intel/skylake/include/soc/ramstage.h +++ /dev/null @@ -1,31 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2014 Google Inc. - * Copyright (C) 2015 Intel Corporation. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef _SOC_RAMSTAGE_H_ -#define _SOC_RAMSTAGE_H_ - -#include <chip.h> -#include <device/device.h> -#include <fsp/ramstage.h> - -void pch_enable_dev(device_t dev); -void soc_init_pre_device(void *chip_info); -void soc_init_cpus(device_t dev); -const char *soc_acpi_name(struct device *dev); - -extern struct pci_operations soc_pci_ops; - -#endif diff --git a/src/soc/intel/skylake/include/soc/romstage.h b/src/soc/intel/skylake/include/soc/romstage.h deleted file mode 100644 index 6c40bd6..0000000 --- a/src/soc/intel/skylake/include/soc/romstage.h +++ /dev/null @@ -1,30 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2014 Google Inc. - * Copyright (C) 2015-2016 Intel Corporation. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef _SOC_ROMSTAGE_H_ -#define _SOC_ROMSTAGE_H_ - -#include <fsp/romstage.h> - -void systemagent_early_init(void); -void intel_early_me_status(void); -void enable_smbus(void); -int smbus_read_byte(unsigned device, unsigned address); - -int early_spi_read_wpsr(u8 *sr); -void mainboard_fill_spd_data(struct pei_data *pei_data); - -#endif /* _SOC_ROMSTAGE_H_ */ diff --git a/src/soc/intel/skylake/include/soc/smm.h b/src/soc/intel/skylake/include/soc/smm.h index fa8da46..1beaaa4 100644 --- a/src/soc/intel/skylake/include/soc/smm.h +++ b/src/soc/intel/skylake/include/soc/smm.h @@ -20,7 +20,6 @@ #include <stdint.h> #include <cpu/x86/msr.h> #include <fsp/memmap.h> -#include <fsp/romstage.h> #include <soc/gpio.h>
struct ied_header { diff --git a/src/soc/intel/skylake/include/soc/vr_config.h b/src/soc/intel/skylake/include/soc/vr_config.h index d70fd21..1c19b88 100644 --- a/src/soc/intel/skylake/include/soc/vr_config.h +++ b/src/soc/intel/skylake/include/soc/vr_config.h @@ -19,7 +19,11 @@ #ifndef _SOC_VR_CONFIG_H_ #define _SOC_VR_CONFIG_H_
+#if IS_ENABLED(CONFIG_PLATFORM_USES_FSP1_1) #include <fsp/soc_binding.h> +#else +#include <fsp/api.h> +#endif
struct vr_config {
@@ -74,7 +78,6 @@ enum vr_domain{ NUM_VR_DOMAINS };
-void fill_vr_domain_config(SILICON_INIT_UPD *params, int domain, - const struct vr_config *cfg); - +void fill_vr_domain_config(void *params, + int domain, const struct vr_config *cfg); #endif diff --git a/src/soc/intel/skylake/memmap.c b/src/soc/intel/skylake/memmap.c index 6af1371..96debfd 100644 --- a/src/soc/intel/skylake/memmap.c +++ b/src/soc/intel/skylake/memmap.c @@ -21,7 +21,6 @@ #include <device/pci.h> #include <soc/msr.h> #include <soc/pci_devs.h> -#include <soc/romstage.h> #include <soc/smm.h> #include <soc/systemagent.h> #include <stdlib.h> diff --git a/src/soc/intel/skylake/opregion.c b/src/soc/intel/skylake/opregion.c new file mode 100644 index 0000000..31987cb --- /dev/null +++ b/src/soc/intel/skylake/opregion.c @@ -0,0 +1,49 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <soc/ramstage.h> +#include <fsp/gop.h> +#include <stdlib.h> +#include <string.h> + +int init_igd_opregion(igd_opregion_t *opregion) +{ + const optionrom_vbt_t *vbt; + uint32_t vbt_len; + + memset(opregion, 0, sizeof(igd_opregion_t)); + + /* Read VBT table from flash */ + vbt = fsp_get_vbt(&vbt_len); + if (!vbt) + die("vbt data not found"); + + memcpy(&opregion->header.signature, IGD_OPREGION_SIGNATURE, + sizeof(IGD_OPREGION_SIGNATURE) - 1); + memcpy(opregion->header.vbios_version, vbt->coreblock_biosbuild, sizeof(u32)); + memcpy(opregion->vbt.gvd1, vbt, vbt->hdr_vbt_size < + sizeof(opregion->vbt.gvd1) ? vbt->hdr_vbt_size : + sizeof(opregion->vbt.gvd1)); + + /* Size, in KB, of the entire OpRegion structure (including header)*/ + opregion->header.size = sizeof(igd_opregion_t) / KiB; + opregion->header.version = IGD_OPREGION_VERSION; + + /* We just assume we're mobile for now */ + opregion->header.mailboxes = MAILBOXES_MOBILE; + + return 0; +} diff --git a/src/soc/intel/skylake/reset.c b/src/soc/intel/skylake/reset.c new file mode 100644 index 0000000..25a41c2 --- /dev/null +++ b/src/soc/intel/skylake/reset.c @@ -0,0 +1,31 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <fsp/util.h> +#include <reset.h> + +void chipset_handle_reset(enum fsp_status status) +{ + switch(status) { + case FSP_STATUS_RESET_REQUIRED_3: /* Global Reset */ + printk(BIOS_DEBUG, "GLOBAL RESET!!\n"); + break; + default: + printk(BIOS_ERR, "unhandled reset type %x\n", status); + die("unknown reset type"); + break; + } +} diff --git a/src/soc/intel/skylake/romstage/Makefile.inc b/src/soc/intel/skylake/romstage/Makefile.inc index 31a452f..e552c39 100644 --- a/src/soc/intel/skylake/romstage/Makefile.inc +++ b/src/soc/intel/skylake/romstage/Makefile.inc @@ -1,7 +1,8 @@ - verstage-y += power_state.c
+romstage-$(CONFIG_PLATFORM_USES_FSP2_0) += car_stage.S romstage-y += power_state.c -romstage-y += romstage.c +romstage-$(CONFIG_PLATFORM_USES_FSP1_1) += romstage.c +romstage-$(CONFIG_PLATFORM_USES_FSP2_0) += romstage_fsp20.c romstage-y += spi.c romstage-y += systemagent.c diff --git a/src/soc/intel/skylake/romstage/car_stage.S b/src/soc/intel/skylake/romstage/car_stage.S new file mode 100644 index 0000000..c6401fa --- /dev/null +++ b/src/soc/intel/skylake/romstage/car_stage.S @@ -0,0 +1,131 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015-2016 Intel Corporation + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + */ + +#include <rules.h> +#include <cpu/x86/mtrr.h> +#include <cpu/x86/cache.h> +#include <cpu/x86/post_code.h> + +.section ".text" +.global car_stage_entry + +car_stage_entry: + + /* Enter the C code */ + call car_stage_c_entry + +/* + * Car teardown + */ + /* + * eax: New stack address + */ + + /* Switch to the stack in RAM */ + movl %eax, %esp + + #include <soc/car_teardown.S> + + /* Display the MTRRs */ + call soc_display_mtrrs + + /* + * The stack contents are initialized in src/soc/intel/common/stack.c + * to be the following: + * + * * + * * + * * + * +36: MTRR mask 1 63:32 + * +32: MTRR mask 1 31:0 + * +28: MTRR base 1 63:32 + * +24: MTRR base 1 31:0 + * +20: MTRR mask 0 63:32 + * +16: MTRR mask 0 31:0 + * +12: MTRR base 0 63:32 + * +8: MTRR base 0 31:0 + * +4: Number of MTRRs to setup (described above) + * +0: Number of variable MTRRs to clear + */ + + /* Clear all of the variable MTRRs. */ + popl %ebx + movl $MTRR_PHYS_BASE(0), %ecx + clr %eax + clr %edx + +1: + testl %ebx, %ebx + jz 1f + wrmsr /* Write MTRR base. */ + inc %ecx + wrmsr /* Write MTRR mask. */ + inc %ecx + dec %ebx + jmp 1b + +1: + /* Get number of MTRRs. */ + popl %ebx + movl $MTRR_PHYS_BASE(0), %ecx +2: + testl %ebx, %ebx + jz 2f + + /* Low 32 bits of MTRR base. */ + popl %eax + /* Upper 32 bits of MTRR base. */ + popl %edx + /* Write MTRR base. */ + wrmsr + inc %ecx + /* Low 32 bits of MTRR mask. */ + popl %eax + /* Upper 32 bits of MTRR mask. */ + popl %edx + /* Write MTRR mask. */ + wrmsr + inc %ecx + + dec %ebx + jmp 2b +2: + + post_code(0x39) + + /* And enable cache again after setting MTRRs. */ + movl %cr0, %eax + andl $~(CR0_CacheDisable | CR0_NoWriteThrough), %eax + movl %eax, %cr0 + + post_code(0x3a) + + /* Enable MTRR. */ + movl $MTRR_DEF_TYPE_MSR, %ecx + rdmsr + orl $MTRR_DEF_TYPE_EN, %eax + wrmsr + + post_code(0x3b) + + /* Invalidate the cache again. */ + invd + +__main: + post_code(POST_PREPARE_RAMSTAGE) + cld /* Clear direction flag. */ + + call copy_and_run diff --git a/src/soc/intel/skylake/romstage/romstage_fsp20.c b/src/soc/intel/skylake/romstage/romstage_fsp20.c new file mode 100644 index 0000000..8a15a69 --- /dev/null +++ b/src/soc/intel/skylake/romstage/romstage_fsp20.c @@ -0,0 +1,44 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <fsp/util.h> +#include <soc/romstage.h> + +asmlinkage void *car_stage_c_entry(void) +{ + bool s3wake = false; + console_init(); + /* TODO: Add fill_powerstate and determine sleep state. */ + fsp_memory_init(s3wake); + return NULL; +} +static void soc_memory_init_params(struct FSP_M_CONFIG *m_cfg) +{ + /* TODO: Fill SoC specific Memory init Params */ +} + +void platform_fsp_memory_init_params_cb(struct FSPM_UPD *mupd){ + + struct FSP_M_CONFIG *m_cfg = &mupd->FspmConfig; + + soc_memory_init_params(m_cfg); + mainboard_memory_init_params(mupd); +} + +__attribute__((weak)) void mainboard_memory_init_params(struct FSPM_UPD *mupd) +{ + /* Do nothing */ +} diff --git a/src/soc/intel/skylake/vr_config.c b/src/soc/intel/skylake/vr_config.c index 40223e3..17ccd7d 100644 --- a/src/soc/intel/skylake/vr_config.c +++ b/src/soc/intel/skylake/vr_config.c @@ -14,6 +14,8 @@ * */
+#include <fsp/api.h> +#include <soc/ramstage.h> #include <soc/vr_config.h>
/* Default values for domain configuration. PSI3 and PSI4 are disabled. */ @@ -80,9 +82,10 @@ static const struct vr_config default_configs[NUM_VR_DOMAINS] = { }, };
-void fill_vr_domain_config(SILICON_INIT_UPD *params, int domain, - const struct vr_config *chip_cfg) +void fill_vr_domain_config(void *params, + int domain, const struct vr_config *chip_cfg) { + FSP_SIL_UPD *vr_params = (FSP_SIL_UPD *)params; const struct vr_config *cfg;
if (domain < 0 || domain >= NUM_VR_DOMAINS) @@ -94,14 +97,14 @@ void fill_vr_domain_config(SILICON_INIT_UPD *params, int domain, else cfg = &default_configs[domain];
- params->VrConfigEnable[domain] = cfg->vr_config_enable; - params->Psi1Threshold[domain] = cfg->psi1threshold; - params->Psi2Threshold[domain] = cfg->psi2threshold; - params->Psi3Threshold[domain] = cfg->psi3threshold; - params->Psi3Enable[domain] = cfg->psi3enable; - params->Psi4Enable[domain] = cfg->psi4enable; - params->ImonSlope[domain] = cfg->imon_slope; - params->ImonOffset[domain] = cfg->imon_offset; - params->IccMax[domain] = cfg->icc_max; - params->VrVoltageLimit[domain] = cfg->voltage_limit; + vr_params->VrConfigEnable[domain] = cfg->vr_config_enable; + vr_params->Psi1Threshold[domain] = cfg->psi1threshold; + vr_params->Psi2Threshold[domain] = cfg->psi2threshold; + vr_params->Psi3Threshold[domain] = cfg->psi3threshold; + vr_params->Psi3Enable[domain] = cfg->psi3enable; + vr_params->Psi4Enable[domain] = cfg->psi4enable; + vr_params->ImonSlope[domain] = cfg->imon_slope; + vr_params->ImonOffset[domain] = cfg->imon_offset; + vr_params->IccMax[domain] = cfg->icc_max; + vr_params->VrVoltageLimit[domain] = cfg->voltage_limit; }
