Jonathan Neuschäfer (j.neuschaefer@gmx.net) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16260
commit f01cdd6a71314df27e9634abddec09da3f0820da Author: Jonathan Neuschäfer j.neuschaefer@gmx.net Date: Fri Aug 19 12:10:20 2016 +0200
arch/riscv: Add functions to read/write memory on behalf of supervisor/user mode
Normally machine-mode code operates completely within physical address space. When emulating less privileged memory accesses (e.g. when the hardware doesn't support unaligned read/write), it is useful to access memory through the MMU (and with virtual addresses); this patch implements this functionality using the MPRV bit.
Change-Id: Ic3b3301f348769faf3ee3ef2a78935dfbcbd15fd Signed-off-by: Jonathan Neuschäfer j.neuschaefer@gmx.net --- src/arch/riscv/include/vm.h | 47 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 47 insertions(+)
diff --git a/src/arch/riscv/include/vm.h b/src/arch/riscv/include/vm.h index cd82b0a..a32efc5 100644 --- a/src/arch/riscv/include/vm.h +++ b/src/arch/riscv/include/vm.h @@ -30,6 +30,7 @@
#include <string.h> #include <stdint.h> +#include <arch/encoding.h>
#define SUPERPAGE_SIZE ((uintptr_t)(RISCV_PGSIZE << RISCV_PGLEVEL_BITS)) #define VM_CHOICE VM_SV39 @@ -70,4 +71,50 @@ void mstatus_init(void); // need to setup mstatus so we know we have virtual mem
void flush_tlb(void);
+ +#define DEFINE_MPRV_READ(name, type, insn) \ + static inline type name(type *p); \ + static inline type name(type *p) \ + { \ + int mprv = MSTATUS_MPRV; \ + type value; \ + asm ( \ + "csrs mstatus, %1\n" \ + STRINGIFY(insn) " %0, 0(%2)\n" \ + "csrc mstatus, %1\n" \ + : "=r"(value) : "r"(mprv), "r"(p) : "memory" \ + ); \ + return value; \ + } + +#define DEFINE_MPRV_WRITE(name, type, insn) \ + static inline void name(type *p, type value); \ + static inline void name(type *p, type value) \ + { \ + int mprv = MSTATUS_MPRV; \ + asm ( \ + "csrs mstatus, %0\n" \ + STRINGIFY(insn) " %1, 0(%2)\n" \ + "csrc mstatus, %0\n" \ + :: "r"(mprv), "r"(value), "r"(p) : "memory" \ + ); \ + } + +DEFINE_MPRV_READ(mprv_read_u8, uint8_t, lbu) +DEFINE_MPRV_READ(mprv_read_u16, uint16_t, lhu) +DEFINE_MPRV_READ(mprv_read_u32, uint32_t, lwu) +DEFINE_MPRV_READ(mprv_read_u64, uint32_t, ld) +DEFINE_MPRV_READ(mprv_read_long, long, ld) +DEFINE_MPRV_READ(mprv_read_ulong, unsigned long, ld) +DEFINE_MPRV_WRITE(mprv_write_u8, uint8_t, sb) +DEFINE_MPRV_WRITE(mprv_write_u16, uint16_t, sh) +DEFINE_MPRV_WRITE(mprv_write_u32, uint32_t, sw) +DEFINE_MPRV_WRITE(mprv_write_u64, uint64_t, sd) +DEFINE_MPRV_WRITE(mprv_write_long, long, sd) +DEFINE_MPRV_WRITE(mprv_write_ulong, unsigned long, sd) + +#undef DEFINE_MPRV_READ +#undef DEFINE_MPRV_WRITE + + #endif
