Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46301 )
Change subject: soc/intel/common: drop default to enable the PIT if SeaBIOS is chosen
Patch Set 1:
Patch Set 1:
Well. Sure that actually works?
The pmtimer is used in case seabios runs on qemu and initializes the (virtual) acpi pci device.
I doubt this also happens when running as coreboot payload.
The TSC needs calibration, and seabios uses the PIT for that I think. Except when running virtualized on KVM, in that case (new enough) seabios can use kvmclock to figure the TSC
frequency.
Well, I have tested disabling PIT and PM timer in coreboot on real hardware (clevo l140cu, if that matters) and qemu. Both worked absolutely fine.
However, since that setting here is just a default, I'd be OK with keeping it
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: Ifd75800678707a92110682347c7cfb93e25109a4
Gerrit-Change-Number: 46301
Gerrit-PatchSet: 1
Gerrit-Owner: Michael Niewöhner
foss@mniewoehner.de
Gerrit-Reviewer: Felix Singer
felixsinger@posteo.net
Gerrit-Reviewer: Aaron Durbin
adurbin@chromium.org
Gerrit-Reviewer: Arthur Heymans
arthur@aheymans.xyz
Gerrit-Reviewer: Furquan Shaikh
furquan@google.com
Gerrit-Reviewer: Gerd Hoffmann
kraxel@redhat.com
Gerrit-Reviewer: Kevin O'Connor
kevin@koconnor.net
Gerrit-Reviewer: Nico Huber
nico.h@gmx.de
Gerrit-Reviewer: Patrick Rudolph
siro@das-labor.org
Gerrit-Reviewer: Paul Menzel
paulepanter@users.sourceforge.net
Gerrit-Reviewer: Subrata Banik
subrata.banik@intel.com
Gerrit-Reviewer: Tim Wawrzynczak
twawrzynczak@chromium.org
no-reply@coreboot.org
Gerrit-Comment-Date: Wed, 14 Oct 2020 12:13:13 +0000
Gerrit-HasComments: No
Gerrit-Has-Labels: No
Gerrit-MessageType: comment
