Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16199
commit af062e8c54ee802d78ce1a20d6401157c70e65ad Author: Aaron Durbin adurbin@chromium.org Date: Thu Aug 11 11:10:42 2016 -0500
lib/cbfs_spi: provide boot_device_rw() support
Provide the RW boot device operations for the common cbfs SPI wrapper. The RW region_device is the same as the read-only one. As noted in the boot_device_rw() introduction patch the mmap() support should not be used in conjuction with writing as that results in incoherent operations. That's fine as the current mmap() support is only used in the cbfs layer which does not support writing, i.e. no cbfs regions would be written to with any previous or outstanding mmap() calls.
BUG=chrome-os-partner:56151
Change-Id: I7cc7309a68ad23b30208ac961b1999a79626b307 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/drivers/spi/cbfs_spi.c | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/src/drivers/spi/cbfs_spi.c b/src/drivers/spi/cbfs_spi.c index bbe9125..1895b9d 100644 --- a/src/drivers/spi/cbfs_spi.c +++ b/src/drivers/spi/cbfs_spi.c @@ -34,10 +34,29 @@ static ssize_t spi_readat(const struct region_device *rd, void *b, return size; }
+static ssize_t spi_writeat(const struct region_device *rd, const void *b, + size_t offset, size_t size) +{ + if (spi_flash_info->write(spi_flash_info, offset, size, b)) + return -1; + return size; +} + +static ssize_t spi_eraseat(const struct region_device *rd, + size_t offset, size_t size) +{ + if (spi_flash_info->erase(spi_flash_info, offset, size)) + return -1; + return size; +} + +/* Provide all operations on the same device. */ static const struct region_device_ops spi_ops = { .mmap = mmap_helper_rdev_mmap, .munmap = mmap_helper_rdev_munmap, .readat = spi_readat, + .writeat = spi_writeat, + .eraseat = spi_eraseat, };
static struct mmap_helper_region_device mdev = @@ -78,3 +97,9 @@ const struct region_device *boot_device_ro(void)
return &mdev.rdev; } + +/* The read-only and read-write implementations are symmetric. */ +const struct region_device *boot_device_rw(void) +{ + return boot_device_ro(); +}
