Attention is currently required from: Angel Pons, Riku Viitanen.
Hello Angel Pons, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/85772?usp=email
Change subject: mb/asrock: Add Z77 Extreme4 ......................................................................
New port based on logs extracted from a board running OEM firmware. VBT extracted from a running system with "intelvbttool --inlegacy".
Tested: - i7-3770K CPU (native raminit) - 2x8GB: G.skill F3-1600C9-8GAR (@1600MHz) - 4x8GB: Corsair CMY16GX3M2A2400C (@1333MHz) - libgfxinit txtmode with onboard HDMI, DVI and VGA - Gigabit Ethernet - CPU fan - PS/2 keyboard or mouse (but not at the same time) - SeaBIOS 1.16.3 booting to Devuan and Void Linux - All internal SATA ports - Rear USB ports - Line out - me_cleaner - PCIe x16 slots, including automatic bifurcation (x8/x8) - PCI slots - Suspend and resume (S3) - Dr. Debug (shows post codes during boot) - Serial port header COM1 (including coreboot output)
Untested: - Intel VBIOS - USB headers - Other fans - LED headers - eSATA, SPDIF - PCIe x1 slots
Change-Id: Idf028c6d411bd501b73a3c526240d0b1d6ecaa0c Signed-off-by: Riku Viitanen riku.viitanen@protonmail.com --- A src/mainboard/asrock/z77_extreme4/Kconfig A src/mainboard/asrock/z77_extreme4/Kconfig.name A src/mainboard/asrock/z77_extreme4/Makefile.mk A src/mainboard/asrock/z77_extreme4/acpi/ec.asl A src/mainboard/asrock/z77_extreme4/acpi/platform.asl A src/mainboard/asrock/z77_extreme4/acpi/superio.asl A src/mainboard/asrock/z77_extreme4/board_info.txt A src/mainboard/asrock/z77_extreme4/cmos.default A src/mainboard/asrock/z77_extreme4/cmos.layout A src/mainboard/asrock/z77_extreme4/data.vbt A src/mainboard/asrock/z77_extreme4/devicetree.cb A src/mainboard/asrock/z77_extreme4/dsdt.asl A src/mainboard/asrock/z77_extreme4/early_init.c A src/mainboard/asrock/z77_extreme4/gma-mainboard.ads A src/mainboard/asrock/z77_extreme4/gpio.c A src/mainboard/asrock/z77_extreme4/hda_verb.c A src/mainboard/asrock/z77_extreme4/mainboard.c 17 files changed, 648 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/72/85772/7
