Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8366
commit e03aae727a355feacd699511fdaa20a93443d596 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Thu Feb 5 15:48:38 2015 +0200
AMD K8 fam10: Refactor Kconfig SB_HT_CHAIN_ON_BUS0
If SB_HT_CHAIN_ON_BUS0 is selected, HyperTransport chain for System Bus is the first to scan and it will be assigned with bus number 0.
If HT_CHAIN_DISTRIBUTE is selected, each link will reserve a fixed range of bus numbers instead of assigning consecutive numbers across all the links.
All fam10 have SB_HT_CHAIN_ON_BUS0 selected under northbridge. Follow-up can easily drop this if we find this is dictated by architecture.
Change-Id: I8deddcb4c3fd679b6b27e2879d9dba3895c4dd6f Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/mainboard/advansus/a785e-i/Kconfig | 4 ---- src/mainboard/amd/bimini_fam10/Kconfig | 4 ---- src/mainboard/amd/dbm690t/Kconfig | 4 ---- src/mainboard/amd/mahogany/Kconfig | 4 ---- src/mainboard/amd/mahogany_fam10/Kconfig | 4 ---- src/mainboard/amd/pistachio/Kconfig | 4 ---- src/mainboard/amd/serengeti_cheetah/Kconfig | 5 +---- src/mainboard/amd/serengeti_cheetah_fam10/Kconfig | 5 +---- src/mainboard/amd/tilapia_fam10/Kconfig | 4 ---- src/mainboard/arima/hdama/Kconfig | 4 ---- src/mainboard/asrock/939a785gmh/Kconfig | 4 ---- src/mainboard/asus/a8n_e/Kconfig | 5 +---- src/mainboard/asus/a8v-e_deluxe/Kconfig | 4 ---- src/mainboard/asus/a8v-e_se/Kconfig | 4 ---- src/mainboard/asus/k8v-x/Kconfig | 4 ---- src/mainboard/asus/kfsn4-dre/Kconfig | 4 ---- src/mainboard/asus/m2n-e/Kconfig | 5 +---- src/mainboard/asus/m2v-mx_se/Kconfig | 4 ---- src/mainboard/asus/m2v/Kconfig | 4 ---- src/mainboard/asus/m4a78-em/Kconfig | 4 ---- src/mainboard/asus/m4a785-m/Kconfig | 4 ---- src/mainboard/asus/m4a785t-m/Kconfig | 4 ---- src/mainboard/asus/m5a88-v/Kconfig | 4 ---- src/mainboard/avalue/eax-785e/Kconfig | 4 ---- src/mainboard/broadcom/blast/Kconfig | 4 ---- src/mainboard/gigabyte/ga_2761gxdk/Kconfig | 5 +---- src/mainboard/gigabyte/m57sli/Kconfig | 5 +---- src/mainboard/gigabyte/ma785gm/Kconfig | 4 ---- src/mainboard/gigabyte/ma785gmt/Kconfig | 4 ---- src/mainboard/gigabyte/ma78gm/Kconfig | 4 ---- src/mainboard/hp/dl145_g1/Kconfig | 5 +---- src/mainboard/hp/dl145_g3/Kconfig | 5 +---- src/mainboard/hp/dl165_g6_fam10/Kconfig | 5 +---- src/mainboard/iei/kino-780am2-fam10/Kconfig | 4 ---- src/mainboard/iwill/dk8_htx/Kconfig | 5 +---- src/mainboard/jetway/pa78vm5/Kconfig | 4 ---- src/mainboard/kontron/kt690/Kconfig | 4 ---- src/mainboard/msi/ms7135/Kconfig | 5 +---- src/mainboard/msi/ms7260/Kconfig | 5 +---- src/mainboard/msi/ms9185/Kconfig | 5 +---- src/mainboard/msi/ms9282/Kconfig | 4 ---- src/mainboard/msi/ms9652_fam10/Kconfig | 4 ---- src/mainboard/nvidia/l1_2pvv/Kconfig | 5 +---- src/mainboard/siemens/sitemp_g1p1/Kconfig | 4 ---- src/mainboard/sunw/ultra40/Kconfig | 5 +---- src/mainboard/supermicro/h8dme/Kconfig | 5 +---- src/mainboard/supermicro/h8dmr/Kconfig | 5 +---- src/mainboard/supermicro/h8dmr_fam10/Kconfig | 5 +---- src/mainboard/supermicro/h8qme_fam10/Kconfig | 5 +---- src/mainboard/supermicro/h8scm_fam10/Kconfig | 4 ---- src/mainboard/technexion/tim5690/Kconfig | 4 ---- src/mainboard/technexion/tim8690/Kconfig | 4 ---- src/mainboard/tyan/s2881/Kconfig | 5 +---- src/mainboard/tyan/s2885/Kconfig | 5 +---- src/mainboard/tyan/s2891/Kconfig | 5 +---- src/mainboard/tyan/s2892/Kconfig | 5 +---- src/mainboard/tyan/s2895/Kconfig | 5 +---- src/mainboard/tyan/s2912/Kconfig | 5 +---- src/mainboard/tyan/s2912_fam10/Kconfig | 5 +---- src/mainboard/winent/mb6047/Kconfig | 5 +---- src/northbridge/amd/amdfam10/Kconfig | 6 ++++++ src/northbridge/amd/amdfam10/northbridge.c | 4 ++-- src/northbridge/amd/amdk8/Kconfig | 6 ++++-- src/northbridge/amd/amdk8/northbridge.c | 4 ++-- 64 files changed, 41 insertions(+), 246 deletions(-)
diff --git a/src/mainboard/advansus/a785e-i/Kconfig b/src/mainboard/advansus/a785e-i/Kconfig index e76a312..c84bf4d 100644 --- a/src/mainboard/advansus/a785e-i/Kconfig +++ b/src/mainboard/advansus/a785e-i/Kconfig @@ -52,10 +52,6 @@ config HW_MEM_HOLE_SIZE_AUTO_INC bool default n
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/amd/bimini_fam10/Kconfig b/src/mainboard/amd/bimini_fam10/Kconfig index 369cb7e..261c60a 100644 --- a/src/mainboard/amd/bimini_fam10/Kconfig +++ b/src/mainboard/amd/bimini_fam10/Kconfig @@ -52,10 +52,6 @@ config HW_MEM_HOLE_SIZE_AUTO_INC bool default n
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/amd/dbm690t/Kconfig b/src/mainboard/amd/dbm690t/Kconfig index 70d63ad..77bafc5 100644 --- a/src/mainboard/amd/dbm690t/Kconfig +++ b/src/mainboard/amd/dbm690t/Kconfig @@ -36,10 +36,6 @@ config MAX_PHYSICAL_CPUS int default 1
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/amd/mahogany/Kconfig b/src/mainboard/amd/mahogany/Kconfig index 394ad77..8861b4a 100644 --- a/src/mainboard/amd/mahogany/Kconfig +++ b/src/mainboard/amd/mahogany/Kconfig @@ -47,10 +47,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/amd/mahogany_fam10/Kconfig b/src/mainboard/amd/mahogany_fam10/Kconfig index ec5ca0b..393882c 100644 --- a/src/mainboard/amd/mahogany_fam10/Kconfig +++ b/src/mainboard/amd/mahogany_fam10/Kconfig @@ -40,10 +40,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/amd/pistachio/Kconfig b/src/mainboard/amd/pistachio/Kconfig index 9a91eec..2296e82 100644 --- a/src/mainboard/amd/pistachio/Kconfig +++ b/src/mainboard/amd/pistachio/Kconfig @@ -44,10 +44,6 @@ config MAX_PHYSICAL_CPUS int default 1
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/amd/serengeti_cheetah/Kconfig b/src/mainboard/amd/serengeti_cheetah/Kconfig index e1363eb..2d2d4d1 100644 --- a/src/mainboard/amd/serengeti_cheetah/Kconfig +++ b/src/mainboard/amd/serengeti_cheetah/Kconfig @@ -10,6 +10,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_AMD_AMD8111 select SOUTHBRIDGE_AMD_AMD8131 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627HF select PARALLEL_CPU_INIT select HAVE_OPTION_TABLE @@ -55,10 +56,6 @@ config MEM_TRAIN_SEQ int default 1
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config HT_CHAIN_END_UNITID_BASE hex default 0x6 diff --git a/src/mainboard/amd/serengeti_cheetah_fam10/Kconfig b/src/mainboard/amd/serengeti_cheetah_fam10/Kconfig index 2a3e6a7..3e6e025 100644 --- a/src/mainboard/amd/serengeti_cheetah_fam10/Kconfig +++ b/src/mainboard/amd/serengeti_cheetah_fam10/Kconfig @@ -8,6 +8,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDFAM10 select SOUTHBRIDGE_AMD_AMD8111 select SOUTHBRIDGE_AMD_AMD8132 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627HF select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -41,10 +42,6 @@ config MAX_PHYSICAL_CPUS int default 8
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config HT_CHAIN_END_UNITID_BASE hex default 0x6 diff --git a/src/mainboard/amd/tilapia_fam10/Kconfig b/src/mainboard/amd/tilapia_fam10/Kconfig index dd46f6a..491a886 100644 --- a/src/mainboard/amd/tilapia_fam10/Kconfig +++ b/src/mainboard/amd/tilapia_fam10/Kconfig @@ -40,10 +40,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/arima/hdama/Kconfig b/src/mainboard/arima/hdama/Kconfig index 49860b3..66177f5 100644 --- a/src/mainboard/arima/hdama/Kconfig +++ b/src/mainboard/arima/hdama/Kconfig @@ -38,10 +38,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x20 diff --git a/src/mainboard/asrock/939a785gmh/Kconfig b/src/mainboard/asrock/939a785gmh/Kconfig index cfaa599..2148385 100644 --- a/src/mainboard/asrock/939a785gmh/Kconfig +++ b/src/mainboard/asrock/939a785gmh/Kconfig @@ -49,10 +49,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/asus/a8n_e/Kconfig b/src/mainboard/asus/a8n_e/Kconfig index 5b7c1e6..1852ae4 100644 --- a/src/mainboard/asus/a8n_e/Kconfig +++ b/src/mainboard/asus/a8n_e/Kconfig @@ -5,6 +5,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select CPU_AMD_SOCKET_939 select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_CK804 + select HT_CHAIN_DISTRIBUTE select SUPERIO_ITE_IT8712F select HAVE_OPTION_TABLE select HAVE_CMOS_DEFAULT @@ -54,10 +55,6 @@ config HT_CHAIN_UNITID_BASE hex default 0x0
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 13 diff --git a/src/mainboard/asus/a8v-e_deluxe/Kconfig b/src/mainboard/asus/a8v-e_deluxe/Kconfig index 8ebff31..a1c2fd9 100644 --- a/src/mainboard/asus/a8v-e_deluxe/Kconfig +++ b/src/mainboard/asus/a8v-e_deluxe/Kconfig @@ -33,10 +33,6 @@ config APIC_ID_OFFSET hex default 0x10
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config MAINBOARD_PART_NUMBER string default "A8V-E Deluxe" diff --git a/src/mainboard/asus/a8v-e_se/Kconfig b/src/mainboard/asus/a8v-e_se/Kconfig index d819b0d..dffe9eb 100644 --- a/src/mainboard/asus/a8v-e_se/Kconfig +++ b/src/mainboard/asus/a8v-e_se/Kconfig @@ -33,10 +33,6 @@ config APIC_ID_OFFSET hex default 0x10
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config MAINBOARD_PART_NUMBER string default "A8V-E SE" diff --git a/src/mainboard/asus/k8v-x/Kconfig b/src/mainboard/asus/k8v-x/Kconfig index 1deb5b6..52bf661 100644 --- a/src/mainboard/asus/k8v-x/Kconfig +++ b/src/mainboard/asus/k8v-x/Kconfig @@ -32,10 +32,6 @@ config APIC_ID_OFFSET hex default 0x10
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config MAINBOARD_PART_NUMBER string default "K8V-X" diff --git a/src/mainboard/asus/kfsn4-dre/Kconfig b/src/mainboard/asus/kfsn4-dre/Kconfig index a7ac369..d3477dc 100644 --- a/src/mainboard/asus/kfsn4-dre/Kconfig +++ b/src/mainboard/asus/kfsn4-dre/Kconfig @@ -40,10 +40,6 @@ config APIC_ID_OFFSET hex default 0
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config MAINBOARD_PART_NUMBER string default "KFSN4-DRE" diff --git a/src/mainboard/asus/m2n-e/Kconfig b/src/mainboard/asus/m2n-e/Kconfig index 7292bf3..448cd9f 100644 --- a/src/mainboard/asus/m2n-e/Kconfig +++ b/src/mainboard/asus/m2n-e/Kconfig @@ -26,6 +26,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_DDR2 select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select MCP55_USE_NIC select MCP55_USE_AZA select SUPERIO_ITE_IT8716F @@ -57,10 +58,6 @@ config MEM_TRAIN_SEQ int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "M2N-E" diff --git a/src/mainboard/asus/m2v-mx_se/Kconfig b/src/mainboard/asus/m2v-mx_se/Kconfig index 27b8253..3b66235 100644 --- a/src/mainboard/asus/m2v-mx_se/Kconfig +++ b/src/mainboard/asus/m2v-mx_se/Kconfig @@ -67,10 +67,6 @@ config HT_CHAIN_UNITID_BASE hex default 0x0
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x20 diff --git a/src/mainboard/asus/m2v/Kconfig b/src/mainboard/asus/m2v/Kconfig index 35ad38d..72527be 100644 --- a/src/mainboard/asus/m2v/Kconfig +++ b/src/mainboard/asus/m2v/Kconfig @@ -36,10 +36,6 @@ config APIC_ID_OFFSET hex default 0x10
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config MAINBOARD_PART_NUMBER string default "M2V" diff --git a/src/mainboard/asus/m4a78-em/Kconfig b/src/mainboard/asus/m4a78-em/Kconfig index b00a0b6..0382daf 100644 --- a/src/mainboard/asus/m4a78-em/Kconfig +++ b/src/mainboard/asus/m4a78-em/Kconfig @@ -39,10 +39,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/asus/m4a785-m/Kconfig b/src/mainboard/asus/m4a785-m/Kconfig index f93c484..a945d2a 100644 --- a/src/mainboard/asus/m4a785-m/Kconfig +++ b/src/mainboard/asus/m4a785-m/Kconfig @@ -40,10 +40,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/asus/m4a785t-m/Kconfig b/src/mainboard/asus/m4a785t-m/Kconfig index d98ad95..a347f02 100644 --- a/src/mainboard/asus/m4a785t-m/Kconfig +++ b/src/mainboard/asus/m4a785t-m/Kconfig @@ -42,10 +42,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/asus/m5a88-v/Kconfig b/src/mainboard/asus/m5a88-v/Kconfig index bded839..8a8fcab 100644 --- a/src/mainboard/asus/m5a88-v/Kconfig +++ b/src/mainboard/asus/m5a88-v/Kconfig @@ -50,10 +50,6 @@ config HW_MEM_HOLE_SIZE_AUTO_INC bool default n
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/avalue/eax-785e/Kconfig b/src/mainboard/avalue/eax-785e/Kconfig index 84f3523..24a5b07 100644 --- a/src/mainboard/avalue/eax-785e/Kconfig +++ b/src/mainboard/avalue/eax-785e/Kconfig @@ -52,10 +52,6 @@ config HW_MEM_HOLE_SIZE_AUTO_INC bool default n
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/broadcom/blast/Kconfig b/src/mainboard/broadcom/blast/Kconfig index b821f7a..ddd2aca 100644 --- a/src/mainboard/broadcom/blast/Kconfig +++ b/src/mainboard/broadcom/blast/Kconfig @@ -31,10 +31,6 @@ config APIC_ID_OFFSET hex default 0x0
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config MAINBOARD_PART_NUMBER string default "Blast" diff --git a/src/mainboard/gigabyte/ga_2761gxdk/Kconfig b/src/mainboard/gigabyte/ga_2761gxdk/Kconfig index a79c28f..e182c99 100644 --- a/src/mainboard/gigabyte/ga_2761gxdk/Kconfig +++ b/src/mainboard/gigabyte/ga_2761gxdk/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_DDR2 select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_SIS_SIS966 + select HT_CHAIN_DISTRIBUTE select SUPERIO_ITE_IT8716F select PARALLEL_CPU_INIT select HAVE_OPTION_TABLE @@ -37,10 +38,6 @@ config MEM_TRAIN_SEQ int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "GA-2761GXDK" diff --git a/src/mainboard/gigabyte/m57sli/Kconfig b/src/mainboard/gigabyte/m57sli/Kconfig index 6ef94ce..cc8be43 100644 --- a/src/mainboard/gigabyte/m57sli/Kconfig +++ b/src/mainboard/gigabyte/m57sli/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_DDR2 select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select MCP55_USE_NIC select MCP55_USE_AZA select SUPERIO_ITE_IT8716F @@ -41,10 +42,6 @@ config MEM_TRAIN_SEQ int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "GA-M57SLI-S4" diff --git a/src/mainboard/gigabyte/ma785gm/Kconfig b/src/mainboard/gigabyte/ma785gm/Kconfig index 8f44e76..bf441e9 100644 --- a/src/mainboard/gigabyte/ma785gm/Kconfig +++ b/src/mainboard/gigabyte/ma785gm/Kconfig @@ -40,10 +40,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/gigabyte/ma785gmt/Kconfig b/src/mainboard/gigabyte/ma785gmt/Kconfig index 03b9237..827c8da 100644 --- a/src/mainboard/gigabyte/ma785gmt/Kconfig +++ b/src/mainboard/gigabyte/ma785gmt/Kconfig @@ -40,10 +40,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/gigabyte/ma78gm/Kconfig b/src/mainboard/gigabyte/ma78gm/Kconfig index 32421e8..3d85708 100644 --- a/src/mainboard/gigabyte/ma78gm/Kconfig +++ b/src/mainboard/gigabyte/ma78gm/Kconfig @@ -40,10 +40,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/hp/dl145_g1/Kconfig b/src/mainboard/hp/dl145_g1/Kconfig index 0c6d642..74ce0e7 100644 --- a/src/mainboard/hp/dl145_g1/Kconfig +++ b/src/mainboard/hp/dl145_g1/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_AMD_AMD8131 select SOUTHBRIDGE_AMD_AMD8111 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627HF select HAVE_HARD_RESET select HAVE_OPTION_TABLE @@ -28,10 +29,6 @@ config APIC_ID_OFFSET hex default 0x0
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "ProLiant DL145 G1" diff --git a/src/mainboard/hp/dl145_g3/Kconfig b/src/mainboard/hp/dl145_g3/Kconfig index 439188a..da20fb3 100644 --- a/src/mainboard/hp/dl145_g3/Kconfig +++ b/src/mainboard/hp/dl145_g3/Kconfig @@ -8,6 +8,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_BROADCOM_BCM21000 select SOUTHBRIDGE_BROADCOM_BCM5785 + select HT_CHAIN_DISTRIBUTE select SUPERIO_SERVERENGINES_PILOT select SUPERIO_NSC_PC87417 select HAVE_OPTION_TABLE @@ -56,10 +57,6 @@ config HT_CHAIN_UNITID_BASE hex default 0x6
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 15 diff --git a/src/mainboard/hp/dl165_g6_fam10/Kconfig b/src/mainboard/hp/dl165_g6_fam10/Kconfig index bbf5e07..408fe66 100644 --- a/src/mainboard/hp/dl165_g6_fam10/Kconfig +++ b/src/mainboard/hp/dl165_g6_fam10/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDFAM10 select SOUTHBRIDGE_BROADCOM_BCM21000 select SOUTHBRIDGE_BROADCOM_BCM5785 + select HT_CHAIN_DISTRIBUTE select SUPERIO_SERVERENGINES_PILOT select SUPERIO_NSC_PC87417 select DIMM_DDR2 @@ -55,10 +56,6 @@ config HT_CHAIN_UNITID_BASE hex default 0x6
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 15 diff --git a/src/mainboard/iei/kino-780am2-fam10/Kconfig b/src/mainboard/iei/kino-780am2-fam10/Kconfig index deea898..4b3bce6 100644 --- a/src/mainboard/iei/kino-780am2-fam10/Kconfig +++ b/src/mainboard/iei/kino-780am2-fam10/Kconfig @@ -40,10 +40,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/iwill/dk8_htx/Kconfig b/src/mainboard/iwill/dk8_htx/Kconfig index cdfd99a..929f47f 100644 --- a/src/mainboard/iwill/dk8_htx/Kconfig +++ b/src/mainboard/iwill/dk8_htx/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_AMD_AMD8111 select SOUTHBRIDGE_AMD_AMD8131 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627HF select PARALLEL_CPU_INIT select HAVE_OPTION_TABLE @@ -38,10 +39,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config HT_CHAIN_END_UNITID_BASE hex default 0x6 diff --git a/src/mainboard/jetway/pa78vm5/Kconfig b/src/mainboard/jetway/pa78vm5/Kconfig index b13bead..30478d2 100644 --- a/src/mainboard/jetway/pa78vm5/Kconfig +++ b/src/mainboard/jetway/pa78vm5/Kconfig @@ -40,10 +40,6 @@ config MAX_PHYSICAL_CPUS int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/kontron/kt690/Kconfig b/src/mainboard/kontron/kt690/Kconfig index 8d1f039..e679e66 100644 --- a/src/mainboard/kontron/kt690/Kconfig +++ b/src/mainboard/kontron/kt690/Kconfig @@ -37,10 +37,6 @@ config MAX_PHYSICAL_CPUS int default 1
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/msi/ms7135/Kconfig b/src/mainboard/msi/ms7135/Kconfig index f2cfd9a..50f989e 100644 --- a/src/mainboard/msi/ms7135/Kconfig +++ b/src/mainboard/msi/ms7135/Kconfig @@ -5,6 +5,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select CPU_AMD_SOCKET_754 select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_CK804 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627THG select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -43,10 +44,6 @@ config HT_CHAIN_END_UNITID_BASE hex default 0x20
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 13 diff --git a/src/mainboard/msi/ms7260/Kconfig b/src/mainboard/msi/ms7260/Kconfig index 0e7e592..e3863a0 100644 --- a/src/mainboard/msi/ms7260/Kconfig +++ b/src/mainboard/msi/ms7260/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_DDR2 select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select MCP55_USE_NIC select MCP55_USE_AZA select SUPERIO_WINBOND_W83627EHG @@ -39,10 +40,6 @@ config MEM_TRAIN_SEQ int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "MS-7260" diff --git a/src/mainboard/msi/ms9185/Kconfig b/src/mainboard/msi/ms9185/Kconfig index 0b0ff1c..355fdcf 100644 --- a/src/mainboard/msi/ms9185/Kconfig +++ b/src/mainboard/msi/ms9185/Kconfig @@ -8,6 +8,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_BROADCOM_BCM5780 select SOUTHBRIDGE_BROADCOM_BCM5785 + select HT_CHAIN_DISTRIBUTE select SUPERIO_NSC_PC87417 select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -34,10 +35,6 @@ config APIC_ID_OFFSET hex default 0x8
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "MS-9185" diff --git a/src/mainboard/msi/ms9282/Kconfig b/src/mainboard/msi/ms9282/Kconfig index f109375..dd96992 100644 --- a/src/mainboard/msi/ms9282/Kconfig +++ b/src/mainboard/msi/ms9282/Kconfig @@ -33,10 +33,6 @@ config APIC_ID_OFFSET hex default 0x10
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config MAINBOARD_PART_NUMBER string default "MS-9282" diff --git a/src/mainboard/msi/ms9652_fam10/Kconfig b/src/mainboard/msi/ms9652_fam10/Kconfig index c1c095b..c64fdda 100644 --- a/src/mainboard/msi/ms9652_fam10/Kconfig +++ b/src/mainboard/msi/ms9652_fam10/Kconfig @@ -76,10 +76,6 @@ config HT_CHAIN_END_UNITID_BASE hex default 0x00
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config VAR_MTRR_HOLE bool default n diff --git a/src/mainboard/nvidia/l1_2pvv/Kconfig b/src/mainboard/nvidia/l1_2pvv/Kconfig index 57911f7..e9664ac 100644 --- a/src/mainboard/nvidia/l1_2pvv/Kconfig +++ b/src/mainboard/nvidia/l1_2pvv/Kconfig @@ -7,6 +7,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_REGISTERED select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select MCP55_USE_NIC select MCP55_USE_AZA select SUPERIO_WINBOND_W83627EHG @@ -43,10 +44,6 @@ config MCP55_NUM int default 2
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "l1_2pvv" diff --git a/src/mainboard/siemens/sitemp_g1p1/Kconfig b/src/mainboard/siemens/sitemp_g1p1/Kconfig index dff329f..d9ad74b 100644 --- a/src/mainboard/siemens/sitemp_g1p1/Kconfig +++ b/src/mainboard/siemens/sitemp_g1p1/Kconfig @@ -43,10 +43,6 @@ config MAX_PHYSICAL_CPUS int default 1
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/sunw/ultra40/Kconfig b/src/mainboard/sunw/ultra40/Kconfig index 8f3ff2a..a29cf16 100644 --- a/src/mainboard/sunw/ultra40/Kconfig +++ b/src/mainboard/sunw/ultra40/Kconfig @@ -5,6 +5,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select CPU_AMD_SOCKET_940 select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_CK804 + select HT_CHAIN_DISTRIBUTE select SUPERIO_SMSC_LPC47B397 select SUPERIO_SMSC_LPC47M10X select HAVE_OPTION_TABLE @@ -56,10 +57,6 @@ config HT_CHAIN_UNITID_BASE hex default 0x0
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 11 diff --git a/src/mainboard/supermicro/h8dme/Kconfig b/src/mainboard/supermicro/h8dme/Kconfig index 52d5581..35f9bf0 100644 --- a/src/mainboard/supermicro/h8dme/Kconfig +++ b/src/mainboard/supermicro/h8dme/Kconfig @@ -7,6 +7,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_REGISTERED select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select MCP55_USE_NIC select MCP55_USE_AZA select SUPERIO_WINBOND_W83627HF @@ -60,10 +61,6 @@ config HT_CHAIN_UNITID_BASE hex default 0x0
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 11 diff --git a/src/mainboard/supermicro/h8dmr/Kconfig b/src/mainboard/supermicro/h8dmr/Kconfig index f85460b..9efc5d2 100644 --- a/src/mainboard/supermicro/h8dmr/Kconfig +++ b/src/mainboard/supermicro/h8dmr/Kconfig @@ -7,6 +7,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_REGISTERED select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select MCP55_USE_NIC select MCP55_USE_AZA select SUPERIO_WINBOND_W83627HF @@ -59,10 +60,6 @@ config HT_CHAIN_UNITID_BASE hex default 0x0
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 11 diff --git a/src/mainboard/supermicro/h8dmr_fam10/Kconfig b/src/mainboard/supermicro/h8dmr_fam10/Kconfig index 0f94620..0d20204 100644 --- a/src/mainboard/supermicro/h8dmr_fam10/Kconfig +++ b/src/mainboard/supermicro/h8dmr_fam10/Kconfig @@ -7,6 +7,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_REGISTERED select NORTHBRIDGE_AMD_AMDFAM10 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select MCP55_USE_NIC select MCP55_USE_AZA select SUPERIO_WINBOND_W83627HF @@ -55,10 +56,6 @@ config HT_CHAIN_UNITID_BASE hex default 0x1
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 11 diff --git a/src/mainboard/supermicro/h8qme_fam10/Kconfig b/src/mainboard/supermicro/h8qme_fam10/Kconfig index 5b195bb..27a74bb 100644 --- a/src/mainboard/supermicro/h8qme_fam10/Kconfig +++ b/src/mainboard/supermicro/h8qme_fam10/Kconfig @@ -8,6 +8,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDFAM10 select SOUTHBRIDGE_AMD_AMD8132 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627HF select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -53,10 +54,6 @@ config HT_CHAIN_UNITID_BASE hex default 0x1
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 11 diff --git a/src/mainboard/supermicro/h8scm_fam10/Kconfig b/src/mainboard/supermicro/h8scm_fam10/Kconfig index 3105493..0673390 100644 --- a/src/mainboard/supermicro/h8scm_fam10/Kconfig +++ b/src/mainboard/supermicro/h8scm_fam10/Kconfig @@ -40,10 +40,6 @@ config MAX_PHYSICAL_CPUS int default 1
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/technexion/tim5690/Kconfig b/src/mainboard/technexion/tim5690/Kconfig index 98dce39..0220d77 100644 --- a/src/mainboard/technexion/tim5690/Kconfig +++ b/src/mainboard/technexion/tim5690/Kconfig @@ -37,10 +37,6 @@ config MAX_PHYSICAL_CPUS int default 1
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/technexion/tim8690/Kconfig b/src/mainboard/technexion/tim8690/Kconfig index 4e0b25a..ad80e85 100644 --- a/src/mainboard/technexion/tim8690/Kconfig +++ b/src/mainboard/technexion/tim8690/Kconfig @@ -36,10 +36,6 @@ config MAX_PHYSICAL_CPUS int default 1
-config SB_HT_CHAIN_ON_BUS0 - int - default 1 - config HT_CHAIN_END_UNITID_BASE hex default 0x1 diff --git a/src/mainboard/tyan/s2881/Kconfig b/src/mainboard/tyan/s2881/Kconfig index 6c759e1..de641cd 100644 --- a/src/mainboard/tyan/s2881/Kconfig +++ b/src/mainboard/tyan/s2881/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_AMD_AMD8131 select SOUTHBRIDGE_AMD_AMD8111 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627HF select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -24,10 +25,6 @@ config APIC_ID_OFFSET hex default 0x0
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "S2881" diff --git a/src/mainboard/tyan/s2885/Kconfig b/src/mainboard/tyan/s2885/Kconfig index 86e43f8..b218ab7 100644 --- a/src/mainboard/tyan/s2885/Kconfig +++ b/src/mainboard/tyan/s2885/Kconfig @@ -7,6 +7,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select SOUTHBRIDGE_AMD_AMD8111 select SOUTHBRIDGE_AMD_AMD8131 select SOUTHBRIDGE_AMD_AMD8151 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627HF select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -23,10 +24,6 @@ config APIC_ID_OFFSET hex default 0x10
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "S2885" diff --git a/src/mainboard/tyan/s2891/Kconfig b/src/mainboard/tyan/s2891/Kconfig index 3d1c1fb..238f5bc 100644 --- a/src/mainboard/tyan/s2891/Kconfig +++ b/src/mainboard/tyan/s2891/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_CK804 select SOUTHBRIDGE_AMD_AMD8131 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627HF select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -23,10 +24,6 @@ config APIC_ID_OFFSET hex default 0x10
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "S2891" diff --git a/src/mainboard/tyan/s2892/Kconfig b/src/mainboard/tyan/s2892/Kconfig index b9c4105..cbe076c 100644 --- a/src/mainboard/tyan/s2892/Kconfig +++ b/src/mainboard/tyan/s2892/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_CK804 select SOUTHBRIDGE_AMD_AMD8131 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627HF select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -43,10 +44,6 @@ config HT_CHAIN_END_UNITID_BASE hex default 0x20
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 11 diff --git a/src/mainboard/tyan/s2895/Kconfig b/src/mainboard/tyan/s2895/Kconfig index 544b0c5..21db63c 100644 --- a/src/mainboard/tyan/s2895/Kconfig +++ b/src/mainboard/tyan/s2895/Kconfig @@ -6,6 +6,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_CK804 select SOUTHBRIDGE_AMD_AMD8131 + select HT_CHAIN_DISTRIBUTE select SUPERIO_SMSC_LPC47B397 select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -47,10 +48,6 @@ config HT_CHAIN_END_UNITID_BASE hex default 0x20
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config IRQ_SLOT_COUNT int default 11 diff --git a/src/mainboard/tyan/s2912/Kconfig b/src/mainboard/tyan/s2912/Kconfig index 26d9a53..7ad1a1c 100644 --- a/src/mainboard/tyan/s2912/Kconfig +++ b/src/mainboard/tyan/s2912/Kconfig @@ -7,6 +7,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_REGISTERED select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select MCP55_USE_NIC select SUPERIO_WINBOND_W83627HF select PARALLEL_CPU_INIT @@ -38,10 +39,6 @@ config MEM_TRAIN_SEQ int default 1
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "S2912" diff --git a/src/mainboard/tyan/s2912_fam10/Kconfig b/src/mainboard/tyan/s2912_fam10/Kconfig index 1dd74ca..b5e31fa 100644 --- a/src/mainboard/tyan/s2912_fam10/Kconfig +++ b/src/mainboard/tyan/s2912_fam10/Kconfig @@ -7,6 +7,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select DIMM_REGISTERED select NORTHBRIDGE_AMD_AMDFAM10 select SOUTHBRIDGE_NVIDIA_MCP55 + select HT_CHAIN_DISTRIBUTE select MCP55_USE_NIC select SUPERIO_WINBOND_W83627HF select PARALLEL_CPU_INIT @@ -35,10 +36,6 @@ config APIC_ID_OFFSET hex default 0
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "S2912 (Fam10)" diff --git a/src/mainboard/winent/mb6047/Kconfig b/src/mainboard/winent/mb6047/Kconfig index 86b0ae0..622441e 100644 --- a/src/mainboard/winent/mb6047/Kconfig +++ b/src/mainboard/winent/mb6047/Kconfig @@ -5,6 +5,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select CPU_AMD_SOCKET_940 select NORTHBRIDGE_AMD_AMDK8 select SOUTHBRIDGE_NVIDIA_CK804 + select HT_CHAIN_DISTRIBUTE select SUPERIO_WINBOND_W83627THG select HAVE_OPTION_TABLE select HAVE_PIRQ_TABLE @@ -25,10 +26,6 @@ config APIC_ID_OFFSET hex default 0x10
-config SB_HT_CHAIN_ON_BUS0 - int - default 2 - config MAINBOARD_PART_NUMBER string default "MB6047" diff --git a/src/northbridge/amd/amdfam10/Kconfig b/src/northbridge/amd/amdfam10/Kconfig index 37993aa..5f6fdec 100644 --- a/src/northbridge/amd/amdfam10/Kconfig +++ b/src/northbridge/amd/amdfam10/Kconfig @@ -65,6 +65,12 @@ config SB_HT_CHAIN_UNITID_OFFSET_ONLY bool default n
+config SB_HT_CHAIN_ON_BUS0 + def_bool y + +config HT_CHAIN_DISTRIBUTE + def_bool n + config DIMM_FBDIMM bool default n diff --git a/src/northbridge/amd/amdfam10/northbridge.c b/src/northbridge/amd/amdfam10/northbridge.c index 8c60e96..5990949 100644 --- a/src/northbridge/amd/amdfam10/northbridge.c +++ b/src/northbridge/amd/amdfam10/northbridge.c @@ -197,11 +197,11 @@ static u32 amdfam10_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool * so we set the subordinate bus number to 0xff for the moment. */
- if ((CONFIG_SB_HT_CHAIN_ON_BUS0 == 0) || !is_sblink) + if (!CONFIG_SB_HT_CHAIN_ON_BUS0 || !is_sblink) max++;
/* One node can have 8 link and segn is the same. */ - if ((CONFIG_SB_HT_CHAIN_ON_BUS0 > 1) && !is_sblink) + if (CONFIG_HT_CHAIN_DISTRIBUTE && !is_sblink) max = ALIGN_UP(max, 8);
link->secondary = max; diff --git a/src/northbridge/amd/amdk8/Kconfig b/src/northbridge/amd/amdk8/Kconfig index 8dd8cea..fd11105 100644 --- a/src/northbridge/amd/amdk8/Kconfig +++ b/src/northbridge/amd/amdk8/Kconfig @@ -66,8 +66,10 @@ config SB_HT_CHAIN_UNITID_OFFSET_ONLY default n
config SB_HT_CHAIN_ON_BUS0 - int - default 0 + def_bool y + +config HT_CHAIN_DISTRIBUTE + def_bool n
config QRANK_DIMM_SUPPORT bool diff --git a/src/northbridge/amd/amdk8/northbridge.c b/src/northbridge/amd/amdk8/northbridge.c index 17c5a13..b1c62cd 100644 --- a/src/northbridge/amd/amdk8/northbridge.c +++ b/src/northbridge/amd/amdk8/northbridge.c @@ -163,11 +163,11 @@ static u32 amdk8_scan_chain(device_t dev, u32 nodeid, struct bus *link, bool is_ * so we set the subordinate bus number to 0xff for the moment. */
/* Second chain will be on 0x40, third 0x80, forth 0xc0. */ - if ((CONFIG_SB_HT_CHAIN_ON_BUS0 > 1) && !is_sblink) + if (CONFIG_HT_CHAIN_DISTRIBUTE && !is_sblink) max = ALIGN_UP(max, 0x40);
