Attention is currently required from: Jérémy Compostella, Patrick Rudolph.
Hello Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/79162?usp=email
Change subject: src/arch/x86/exit_car: Add proper x86_64 code ......................................................................
Don't truncate upper bits in assembly code and thus allow loading of postcar stage above 4GiB.
Tested on qemu with cbmem_top set to TOUUD.
Change-Id: I42d1086f1220e44076ccf613244fc3c6d804805b Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/arch/x86/exit_car.S 1 file changed, 6 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/62/79162/1
diff --git a/src/arch/x86/exit_car.S b/src/arch/x86/exit_car.S index c9ff866..d435dbe 100644 --- a/src/arch/x86/exit_car.S +++ b/src/arch/x86/exit_car.S @@ -67,8 +67,14 @@ invd
movl $_estack, %esp +#if ENV_X86_64 + /* Align stack to 16 bytes at call instruction. */ + movq $0xfffffffffffffff0, %rax + and %rax, %rsp +#else /* Align stack to 16 bytes at call instruction. */ andl $0xfffffff0, %esp +#endif
/* Call this in assembly as some platforms like to mess with the bootflow and call into main directly from chipset_teardown_car. */
