Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18009
commit 2e73d35d2114a649d82152b70083c9b54a76ab73 Author: Arthur Heymans arthur@aheymans.xyz Date: Wed Nov 30 18:40:38 2016 +0100
nb/intel/x4x: Fix raminit on reset path
Previously the raminit failed on hot reset and to work around this issue it unconditionally did a cold reset.
This has the following issues: * it's slow; * when the OS issues a hot reset some disk drives expect their 5V power supply to remain on, which gets cut off by a cold reset, causing data corruption.
To fix this some steps in raminit must be ommited on the reset path. This includes searching for receive enable. To achieve this it stores receive enable results in nvram (which is also needed when implementing S3 suspend/resume from S3).
Change-Id: I6601dd90aebd071a0de7cec070487b0f9845bc30 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/mainboard/gigabyte/ga-g41m-es2l/cmos.layout | 1 + src/mainboard/gigabyte/ga-g41m-es2l/romstage.c | 7 +- src/northbridge/intel/x4x/raminit_ddr2.c | 144 ++++++++++++++++++++---- src/northbridge/intel/x4x/x4x.h | 7 +- 4 files changed, 134 insertions(+), 25 deletions(-)
diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/cmos.layout b/src/mainboard/gigabyte/ga-g41m-es2l/cmos.layout index 3138479..fac9d35 100644 --- a/src/mainboard/gigabyte/ga-g41m-es2l/cmos.layout +++ b/src/mainboard/gigabyte/ga-g41m-es2l/cmos.layout @@ -68,6 +68,7 @@ entries # coreboot config options: check sums 984 16 h 0 check_sum
+1024 144 r 0 recv_enable_results # -----------------------------------------------------------------
enumerations diff --git a/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c b/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c index 2503db9..2302842 100644 --- a/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c +++ b/src/mainboard/gigabyte/ga-g41m-es2l/romstage.c @@ -29,6 +29,7 @@ #include <lib.h> #include <arch/stages.h> #include <cbmem.h> +#include <northbridge/intel/x4x/iomap.h>
#define SERIAL_DEV PNP_DEV(0x2e, IT8718F_SP1) #define GPIO_DEV PNP_DEV(0x2e, IT8718F_GPIO) @@ -136,6 +137,7 @@ void mainboard_romstage_entry(unsigned long bist) { // ch0 ch1 const u8 spd_addrmap[4] = { 0x50, 0, 0x52, 0 }; + u8 boot_path = 0;
/* Disable watchdog timer */ RCBA32(0x3410) = RCBA32(0x3410) | 0x20; @@ -155,8 +157,11 @@ void mainboard_romstage_entry(unsigned long bist)
x4x_early_init();
+ if (MCHBAR32(PMSTS_MCHBAR) & PMSTS_WARM_RESET) + boot_path = BOOT_PATH_RESET; + printk(BIOS_DEBUG, "Initializing memory\n"); - sdram_initialize(0, spd_addrmap); + sdram_initialize(boot_path, spd_addrmap); quick_ram_check(); cbmem_initialize_empty(); printk(BIOS_DEBUG, "Memory initialized\n"); diff --git a/src/northbridge/intel/x4x/raminit_ddr2.c b/src/northbridge/intel/x4x/raminit_ddr2.c index b3ee34a..04b19f9 100644 --- a/src/northbridge/intel/x4x/raminit_ddr2.c +++ b/src/northbridge/intel/x4x/raminit_ddr2.c @@ -20,6 +20,11 @@ #include <console/console.h> #include <commonlib/helpers.h> #include <delay.h> +#include <pc80/mc146818rtc.h> +/* This northbridge can also occur with ICH10 */ +#if IS_ENABLED(CONFIG_SOUTHBRIDGE_INTEL_I82801GX) +#include <southbridge/intel/i82801gx/i82801gx.h> +#endif #include "iomap.h" #include "x4x.h"
@@ -258,10 +263,13 @@ static void checkreset_ddr2(struct sysinfo *s) { u8 pmcon2; u8 reset = 0; + u32 pmir;
+ pmir = pci_read_config32(PCI_DEV(0, 0x1f, 0), 0xac); pmcon2 = pci_read_config8(PCI_DEV(0, 0x1f, 0), 0xa2); - if (!(pmcon2 & 0x80)) { - pmcon2 |= 0x80; + + if (pmcon2 & 0x80) { + pmcon2 &= ~0x80; pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa2, pmcon2); reset = 1;
@@ -273,10 +281,16 @@ static void checkreset_ddr2(struct sysinfo *s) } if (reset) { printk(BIOS_DEBUG, "Reset...\n"); + /* Do a global reset. only useful on ICH10 */ + pmir |= (1 << 20); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0xac, pmir); outb(0xe, 0xcf9); asm ("hlt"); } - pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa2, pmcon2 | 0x80); + pmir &= ~(1 << 20); + pmcon2 |= 0x80; + pci_write_config8(PCI_DEV(0, 0x1f, 0), 0xa2, pmcon2); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0xac, pmir); }
static void setioclk_ddr2(struct sysinfo *s) @@ -1486,6 +1500,83 @@ static void rcven_ddr2(struct sysinfo *s) printk(BIOS_DEBUG, "End rcven\n"); }
+static void sdram_save_receive_enable(void) +{ + int i = 0, j, uneven; + u16 reg16; + u8 values[18]; + u8 lane, ch; + + FOR_EACH_CHANNEL(ch) { + for (lane = 0; lane < 8; lane++) { + uneven = lane % 2; + values[i] = (MCHBAR8(0x400*ch + 0x560 + (lane*4))) + << (uneven * 4); + if (uneven) + i++; + } + values[i++] = (MCHBAR32(0x400*ch + 0x248) >> 16) & 0xff; + reg16 = MCHBAR16(0x400*ch + 0x5fa); + for (j = 0; j < 2; j++) + values[i++] = (reg16 >> (j * 8)) & 0xff; + reg16 = MCHBAR16(0x400*ch + 0x58c); + for (j = 0; j < 2; j++) + values[i++] = (reg16 >> (j * 8)) & 0xff; + } + + for (i = 0; i < ARRAY_SIZE(values); i++) + cmos_write(values[i], 128 + i); +} + +static void sdram_recover_receive_enable(void) +{ + u8 i, j, uneven; + u32 reg32 = 0; + u16 reg16 = 0; + u8 values[18]; + u8 ch, lane; + + for (i = 0; i < ARRAY_SIZE(values); i++) + values[i] = cmos_read(128 + i); + + i = 0; + FOR_EACH_CHANNEL(ch) { + for (lane = 0; lane < 8; lane++) { + uneven = lane % 2; + MCHBAR8(0x400*ch + 0x560 + (lane*4)) = 0x70 + | ((values[i] >> (4 * uneven)) & 0xf); + if (uneven) + i++; + } + reg32 = (MCHBAR32(0x400*ch + 0x248) & ~0xf0000) + | (values[i++] << 16); + MCHBAR32(0x400*ch + 0x248) = reg32; + reg32 = 0; + for (j = 0; j < 2; j++) + reg16 |= (values[i++] << (j * 8)); + MCHBAR16(0x400*ch + 0x5fa) = reg16; + reg16 = 0; + for (j = 0; j < 2; j++) + reg16 |= (values[i++] << (j * 8)); + MCHBAR16(0x400*ch + 0x58c) = reg16; + reg16 = 0; + } +} + +static void sdram_program_receive_enable(struct sysinfo *s) +{ + /* enable upper CMOS */ + RCBA32(0x3400) = (1 << 2); + + /* Program Receive Enable Timings */ + if (s->boot_path == BOOT_PATH_RESET) { + sdram_recover_receive_enable(); + } else { + rcven_ddr2(s); + sdram_save_receive_enable(); + } +} + static void dradrb_ddr2(struct sysinfo *s) { u8 map, i, ch, r, rankpop0, rankpop1; @@ -1860,22 +1951,24 @@ void raminit_ddr2(struct sysinfo *s) checkreset_ddr2(s);
// Clear self refresh - MCHBAR32(0xf14) = MCHBAR32(0xf14) | 0x3; + if (s->boot_path != BOOT_PATH_RESET) { + MCHBAR32(PMSTS_MCHBAR) = MCHBAR32(PMSTS_MCHBAR) + | PMSTS_BOTH_SELFREFRESH;
- // Clear host clk gate reg - MCHBAR32(0x1c) = MCHBAR32(0x1c) | 0xffffffff; + // Clear host clk gate reg + MCHBAR32(0x1c) = MCHBAR32(0x1c) | 0xffffffff;
- // Select DDR2 - MCHBAR8(0x1a8) = MCHBAR8(0x1a8) & ~0x4; + // Select DDR2 + MCHBAR8(0x1a8) = MCHBAR8(0x1a8) & ~0x4;
- // Set freq - MCHBAR32(0xc00) = (MCHBAR32(0xc00) & ~0x70) | - (s->selected_timings.mem_clk << 4) | (1 << 10); + // Set freq + MCHBAR32(0xc00) = (MCHBAR32(0xc00) & ~0x70) | + (s->selected_timings.mem_clk << 4) | (1 << 10);
- // Overwrite freq if chipset rejects it - s->selected_timings.mem_clk = (MCHBAR8(0xc00) & 0x70) >> 4; - if (s->selected_timings.mem_clk > (s->max_fsb + 3)) { - die("Error: DDR is faster than FSB, halt\n"); + // Overwrite freq if chipset rejects it + s->selected_timings.mem_clk = (MCHBAR8(0xc00) & 0x70) >> 4; + if (s->selected_timings.mem_clk > (s->max_fsb + 3)) + die("Error: DDR is faster than FSB, halt\n"); }
udelay(250000); @@ -1885,8 +1978,10 @@ void raminit_ddr2(struct sysinfo *s) printk(BIOS_DEBUG, "Done clk crossing\n");
// DDR2 IO - setioclk_ddr2(s); - printk(BIOS_DEBUG, "Done I/O clk\n"); + if (s->boot_path != BOOT_PATH_RESET) { + setioclk_ddr2(s); + printk(BIOS_DEBUG, "Done I/O clk\n"); + }
// Grant to launch launch_ddr2(s); @@ -1900,16 +1995,21 @@ void raminit_ddr2(struct sysinfo *s) dll_ddr2(s);
// RCOMP - rcomp_ddr2(s); - printk(BIOS_DEBUG, "RCOMP\n"); + if (s->boot_path != BOOT_PATH_RESET) { + rcomp_ddr2(s); + printk(BIOS_DEBUG, "RCOMP\n"); + }
// ODT odt_ddr2(s); printk(BIOS_DEBUG, "Done ODT\n");
// RCOMP update - while ((MCHBAR8(0x130) & 1) != 0 ); - printk(BIOS_DEBUG, "Done RCOMP update\n"); + if (s->boot_path != BOOT_PATH_RESET) { + while ((MCHBAR8(0x130) & 1) != 0) + ; + printk(BIOS_DEBUG, "Done RCOMP update\n"); + }
// Set defaults MCHBAR32(0x260) = (MCHBAR32(0x260) & ~1) | 0xf00000; @@ -1989,7 +2089,7 @@ void raminit_ddr2(struct sysinfo *s) }
// Receive enable - rcven_ddr2(s); + sdram_program_receive_enable(s); printk(BIOS_DEBUG, "Done rcven\n");
// Finish rcven diff --git a/src/northbridge/intel/x4x/x4x.h b/src/northbridge/intel/x4x/x4x.h index 7ca634f..1823b8c 100644 --- a/src/northbridge/intel/x4x/x4x.h +++ b/src/northbridge/intel/x4x/x4x.h @@ -87,8 +87,8 @@ #define MCHBAR32(x) *((volatile u32 *)(DEFAULT_MCHBAR + x))
#define PMSTS_MCHBAR 0x0f14 /* Self refresh channel status */ -#define PMSTS_WARM_RESET (1 << 1) -#define PMSTS_BOTH_SELFREFRESH (1 << 0) +#define PMSTS_WARM_RESET (1 << 8) +#define PMSTS_BOTH_SELFREFRESH (3 << 0)
#define CLKCFG_MCHBAR 0x0c00 #define CLKCFG_FSBCLK_SHIFT 0 @@ -290,6 +290,9 @@ struct sysinfo { struct dimminfo dimms[4]; u8 spd_map[4]; }; +#define BOOT_PATH_NORMAL 0 +#define BOOT_PATH_RESET 1 +#define BOOT_PATH_RESUME 2
enum ddr2_signals { CLKSET0 = 0,
