Attention is currently required from: Jason Glenesk, Raul Rangel, Marshall Dawson, Zheng Bao, Fred Reitberger, Felix Held. Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Marshall Dawson, Zheng Bao, Felix Held,
https://review.coreboot.org/c/coreboot/+/58552
to look at the new patch set (#14).
Change subject: amdfwtool: Put soc name setting to fw.cfg from command line ......................................................................
The fw.cfg should combine the SOC name. This is for future combo feature. Each entry in combo has its own fw.cfg. The soc_id in struct cb_config can only be available after the fw.cfg is processed. Some functions which take soc_id as a parameter can be simplified.
Change-Id: Ib0eead1f2156542ea03d58145f5ad67683bf9b52 Signed-off-by: Zheng Bao fishbaozi@gmail.com --- M src/mainboard/google/guybrush/variants/baseboard/amdfw.cfg M src/soc/amd/cezanne/Makefile.inc M src/soc/amd/cezanne/fw.cfg M src/soc/amd/picasso/Makefile.inc M src/soc/amd/picasso/fw.cfg M src/soc/amd/sabrina/fw.cfg M src/soc/amd/stoneyridge/Makefile.inc M src/soc/amd/stoneyridge/fw_cz.cfg M src/soc/amd/stoneyridge/fw_st.cfg M util/amdfwtool/amdfwtool.c M util/amdfwtool/amdfwtool.h M util/amdfwtool/data_parse.c 12 files changed, 79 insertions(+), 82 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/52/58552/14
