Hannah Williams (hannah.williams@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/12739
commit 69375478e7806e2f7218399c8e917649fd6d6a3e Author: shkim sh_.kim@samsung.com Date: Tue Sep 22 17:53:58 2015 +0900
soc/braswell: Add interface to program USB2_COMPBG register
Add interface to program USB2_COMPBG register to set HS_DISC_BG and HS_SQ reference voltage for each project.
TEST=Get build success and do EFT test
Original-Reviewed-on: https://chromium-review.googlesource.com/300846 Original-Reviewed-by: Shawn N shawnn@chromium.org Original-Tested-by: shkim sh_.kim@samsung.com Change-Id: If2201829e1a16b4f9916547f08c24e9291358325 Signed-off-by: Kenji Chen kenji.chen@intel.com Signed-off-by: shkim sh_.kim@samsung.com Signed-off-by: Hannah Williams hannah.williams@intel.com --- src/soc/intel/braswell/chip.h | 20 ++++++++++ src/soc/intel/braswell/include/soc/iosf.h | 5 +++ src/soc/intel/braswell/iosf.c | 15 +++++++- src/soc/intel/braswell/xhci.c | 62 +++++++++++++++++++++++++++++++ 4 files changed, 101 insertions(+), 1 deletion(-)
diff --git a/src/soc/intel/braswell/chip.h b/src/soc/intel/braswell/chip.h index 6eb1451..fbac84d 100644 --- a/src/soc/intel/braswell/chip.h +++ b/src/soc/intel/braswell/chip.h @@ -38,6 +38,18 @@ enum lpe_clk_src { LPE_CLK_SRC_PLL, };
+enum usb_comp_bg_value { + USB_COMP_BG_575_MV = 7, + USB_COMP_BG_650_MV = 6, + USB_COMP_BG_550_MV = 5, + USB_COMP_BG_537_MV = 4, + USB_COMP_BG_625_MV = 3, + USB_COMP_BG_700_MV = 2, + USB_COMP_BG_600_MV = 1, + USB_COMP_BG_675_MV = 0, +}; + + struct soc_intel_braswell_config { uint8_t enable_xdp_tap; uint8_t clkreq_enable; @@ -61,6 +73,14 @@ struct soc_intel_braswell_config { /* Allow PCIe devices to wake system from suspend. */ int pcie_wake_enable;
+ /* Program USB2_COMPBG register. + * [10:7] - select vref to AFE port + * x111 - 575mV, x110 - 650mV, x101 - 550mV, x100 - 537.5mV, + * x011 - 625mV, x010 - 700mV, x001 - 600mV, x000 - 675mV + */ + enum usb_comp_bg_value usb_comp_bg; + + /* * The following fields come from fsp_vpd.h .aka. VpdHeader.h. * These are configuration values that are passed to FSP during diff --git a/src/soc/intel/braswell/include/soc/iosf.h b/src/soc/intel/braswell/include/soc/iosf.h index add602f..e6758a6 100644 --- a/src/soc/intel/braswell/include/soc/iosf.h +++ b/src/soc/intel/braswell/include/soc/iosf.h @@ -69,6 +69,8 @@ uint32_t iosf_port58_read(int reg); void iosf_port58_write(int reg, uint32_t val); uint32_t iosf_scc_read(int reg); void iosf_scc_write(int reg, uint32_t val); +uint32_t iosf_usbphy_read(int reg); +void iosf_usbphy_write(int reg, uint32_t val);
#if ENV_RAMSTAGE uint64_t reg_script_read_iosf(struct reg_script_context *ctx); @@ -91,6 +93,7 @@ void reg_script_write_iosf(struct reg_script_context *ctx); #define IOSF_PORT_0x5a 0x5a #define IOSF_PORT_USHPHY 0x61 /* USB XHCI PHY */ #define IOSF_PORT_SCC 0x63 /* Storage Control Cluster */ +#define IOSF_PORT_USBPHY 0x43 /* USB PHY */ #define IOSF_PORT_LPSS 0xa0 /* LPSS - Low Power Subsystem */ #define IOSF_PORT_0xa2 0xa2 #define IOSF_PORT_SSUS 0xa8 /* SUS */ @@ -109,6 +112,8 @@ void reg_script_write_iosf(struct reg_script_context *ctx); #define IOSF_OP_WRITE_0x58 (IOSF_OP_READ_0x58 | 1) #define IOSF_OP_READ_SCC 0x06 #define IOSF_OP_WRITE_SCC (IOSF_OP_READ_SCC | 1) +#define IOSF_OP_READ_USBPHY 0x06 +#define IOSF_OP_WRITE_USBPHY (IOSF_OP_READ_USBPHY | 1)
/* * BUNIT Registers. diff --git a/src/soc/intel/braswell/iosf.c b/src/soc/intel/braswell/iosf.c index 1e7b924..98d1610 100644 --- a/src/soc/intel/braswell/iosf.c +++ b/src/soc/intel/braswell/iosf.c @@ -122,6 +122,15 @@ void iosf_scc_write(int reg, uint32_t val) return iosf_write_port(IOSF_WRITE(SCC), reg, val); }
+uint32_t iosf_usbphy_read(int reg) +{ + return iosf_read_port(IOSF_READ(USBPHY), reg); +} + +void iosf_usbphy_write(int reg, uint32_t val) +{ + return iosf_write_port(IOSF_WRITE(USBPHY), reg, val); +}
#if ENV_RAMSTAGE uint64_t reg_script_read_iosf(struct reg_script_context *ctx) @@ -140,6 +149,8 @@ uint64_t reg_script_read_iosf(struct reg_script_context *ctx) return iosf_port58_read(step->reg); case IOSF_PORT_SCC: return iosf_scc_read(step->reg); + case IOSF_PORT_USBPHY: + return iosf_usbphy_read(step->reg); default: printk(BIOS_DEBUG, "No read support for IOSF port 0x%x.\n", step->id); @@ -169,7 +180,9 @@ void reg_script_write_iosf(struct reg_script_context *ctx) case IOSF_PORT_SCC: iosf_scc_write(step->reg, step->value); break; - + case IOSF_PORT_USBPHY: + iosf_usbphy_write(step->reg, step->value); + break; default: printk(BIOS_DEBUG, "No write support for IOSF port 0x%x.\n", step->id); diff --git a/src/soc/intel/braswell/xhci.c b/src/soc/intel/braswell/xhci.c new file mode 100644 index 0000000..e3e3462 --- /dev/null +++ b/src/soc/intel/braswell/xhci.c @@ -0,0 +1,62 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2013 Google Inc. + * Copyright (C) 2015 Intel Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + */ + +#include <arch/acpi.h> +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <stdint.h> +#include <reg_script.h> + +#include <soc/iomap.h> +#include <soc/iosf.h> +#include <soc/pci_devs.h> +#include <soc/pm.h> +#include <soc/ramstage.h> +#include <soc/xhci.h> + +#include "chip.h" + +static void xhci_init(device_t dev) +{ + struct soc_intel_braswell_config *config = dev->chip_info; + + if (config && config->usb_comp_bg) { + struct reg_script ops[] = { + REG_IOSF_WRITE(IOSF_PORT_USBPHY, USBPHY_COMPBG, + config->usb_comp_bg), + REG_SCRIPT_END + }; + printk(BIOS_INFO, "Override USB2_COMPBG to: 0x%X\n", config->usb_comp_bg); + reg_script_run(ops); + } +} + +static struct device_operations xhci_device_ops = { + .read_resources = pci_dev_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = xhci_init, + .ops_pci = &soc_pci_ops, +}; + +static const struct pci_driver soc_xhci __pci_driver = { + .ops = &xhci_device_ops, + .vendor = PCI_VENDOR_ID_INTEL, + .device = XHCI_DEVID +};
