Jean Lucas (jean@4ray.co) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13520
commit 56314c1e71c0775eb6d89ccb57f856f06f182305 Author: Jean Lucas jean@4ray.co Date: Sat Jan 30 01:20:54 2016 -0500
lib/gcov-glue.c: Remove trailing number from COVERAGE_MAGIC macro
The COVERAGE_MAGIC macro has a trailing `4' on it, which makes it a 64-bit large integer, as opposed to a 32-bit unsigned integer, a originally designated in `util/cbmem/cbmem.c'. Remove this number so building with CODE_COVERAGE will succeed.
Change-Id: Ib5d7f2704a4c092c3eca6f62e219edb30950d793 Signed-off-by: Jean Lucas jean@4ray.co --- src/lib/gcov-glue.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/lib/gcov-glue.c b/src/lib/gcov-glue.c index 4e5a9e1..0e45247 100644 --- a/src/lib/gcov-glue.c +++ b/src/lib/gcov-glue.c @@ -34,7 +34,7 @@ typedef struct file {
#define COVERAGE_SIZE (32*1024)
-#define COVERAGE_MAGIC 0x584d41534 +#define COVERAGE_MAGIC 0x584d4153
static FILE *current_file = NULL; static FILE *previous_file = NULL;
