Attention is currently required from: Maulik V Vaghela, Paul Menzel. Hello build bot (Jenkins), Furquan Shaikh, John Zhao, Tim Wawrzynczak, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/55945
Change subject: drivers/intel/usb4/retimer: Update code to assign correct port number ......................................................................
Since TBT controller can have maximum 2 ports per controller, our code will loop over DFP structure twice and determine port number.
Retimer driver used to assign port number as below: 1. Check if power GPIO is assigned for particular DFP entry or not 2. If entry is there, assign loop count as port number
Since loop count is 2, retimer will never assign port number = 2 even if it's present. In case of more than 1 controller, port number assigned will still be 0 or 1 even though actual port index might be 2 or 3. This will create an issue where even if you do transaction on device on controller 2 (port index 2 or 3), EC will route it on port 0 or 1 due to incorrect port index.
Update the driver flow as per below to handle this scenario: 1. Check if power GPIO is assigned for particular DFP entry or not 2. Get USB port number from config since it's stored in usb port information under devicetree 3. Pass the port number to ACPI SSDT and EC code
Above changes will ensure that we're assigning correct port number as per calculation and EC will use correct port index.
BUG=b:189476816 BRANCH=None TEST=Checked that retimer firmware update works on both ports and update happens on correct port index.
Change-Id: Ib11637ae39046e0afdacd33bc34e8a59e6f2bfb1 Signed-off-by: Maulik V Vaghela maulik.v.vaghela@intel.com --- M src/drivers/intel/usb4/retimer/chip.h M src/drivers/intel/usb4/retimer/retimer.c 2 files changed, 27 insertions(+), 14 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/45/55945/4
