Felix Held has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/56163 )
Change subject: Revert "drivers/intel/fsp2_0: use FSP to allocate APEI BERT memory region" ......................................................................
This reverts commit ce0e2a014009390c4527e064efb59260ef4d3a3b which was originally introduced as a workaround for the bug that the Linux kernel doesn't know what to do with type 16 memory region in the e820 table where CBMEM resides and disallowed accessing it. After depthcharge was patched to mark the type 16 region as a normal reserved region, the Linux kernel now can access the BERT region and print BERT errors. When SeaBIOS was used as payload it already marked the memory region correctly, so it already worked in that case.
After commit 8c3a8df1021b8a2789c2a285557401837f9fc2b8 that removed the usage of the BERT memory region reserved by the FSP driver by the AMD Picasso and Cezanne SoCs and made them use CBMEM for the BERT region, no other SoC code uses this functionality. The Intel Alderlake and Tigerlake SoCs put the BERT region in CBMEM and never used this reserved memory region and the change for the Intel server CPU to use this was abandoned and never landed in upstream coreboot. AMD Stoneyridge is the only other SoC/chipset that selects ACPI_BERT, but since it doesn't select or use the FSP driver, it also won't be affected by this change.
TEST=Behavior of the BERT code doesn't change on Mandolin
Change-Id: I6ca095ca327cbf925edb59b89fff42ff9f96de5d Signed-off-by: Felix Held felix-coreboot@felixheld.de --- M src/drivers/intel/fsp2_0/cbmem.c M src/drivers/intel/fsp2_0/hob_verify.c M src/drivers/intel/fsp2_0/memory_init.c 3 files changed, 2 insertions(+), 31 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/56163/1
diff --git a/src/drivers/intel/fsp2_0/cbmem.c b/src/drivers/intel/fsp2_0/cbmem.c index 5388b89..0efb462 100644 --- a/src/drivers/intel/fsp2_0/cbmem.c +++ b/src/drivers/intel/fsp2_0/cbmem.c @@ -6,14 +6,7 @@ void *cbmem_top_chipset(void) { struct range_entry tolum; - uint8_t *tolum_base;
fsp_find_bootloader_tolum(&tolum); - tolum_base = (uint8_t *)(uintptr_t)range_entry_base(&tolum); - - /* - * The TOLUM range may have other memory regions (such as APEI - * BERT region on top of CBMEM (IMD root and IMD small) region. - */ - return tolum_base + cbmem_overhead_size(); + return (void *)(uintptr_t)range_entry_end(&tolum); } diff --git a/src/drivers/intel/fsp2_0/hob_verify.c b/src/drivers/intel/fsp2_0/hob_verify.c index 9bfb0f1..ec526e8 100644 --- a/src/drivers/intel/fsp2_0/hob_verify.c +++ b/src/drivers/intel/fsp2_0/hob_verify.c @@ -43,16 +43,9 @@ die("Space between FSP reserved region and BIOS TOLUM!\n"); }
- if (!CONFIG(ACPI_BERT) && range_entry_end(&tolum) != (uintptr_t)cbmem_top()) { + if (range_entry_end(&tolum) != (uintptr_t)cbmem_top()) { printk(BIOS_CRIT, "TOLUM end: 0x%08llx != %p: cbmem_top\n", range_entry_end(&tolum), cbmem_top()); die("Space between cbmem_top and BIOS TOLUM!\n"); } - - if (CONFIG(ACPI_BERT) && - range_entry_end(&tolum) != (uintptr_t)cbmem_top() + CONFIG_ACPI_BERT_SIZE) { - printk(BIOS_CRIT, "TOLUM end: 0x%08llx != %p: cbmem_top + 0x%x: BERT\n", - range_entry_end(&tolum), cbmem_top(), CONFIG_ACPI_BERT_SIZE); - die("Space between cbmem_top and APEI BERT!\n"); - } } diff --git a/src/drivers/intel/fsp2_0/memory_init.c b/src/drivers/intel/fsp2_0/memory_init.c index b12229d..0c9fe97 100644 --- a/src/drivers/intel/fsp2_0/memory_init.c +++ b/src/drivers/intel/fsp2_0/memory_init.c @@ -266,21 +266,6 @@ /* Reserve enough memory under TOLUD to save CBMEM header */ arch_upd->BootLoaderTolumSize = cbmem_overhead_size();
- /* - * If ACPI APEI BERT region size is defined, reserve memory for it. - * +------------------------+ range_entry_top(tolum) - * | Other reserved regions | - * | APEI BERT region | - * +------------------------+ cbmem_top() - * | CBMEM IMD ROOT | - * | CBMEM IMD SMALL | - * +------------------------+ range_entry_base(tolum), TOLUM - * | CBMEM FSP MEMORY | - * | Other CBMEM regions... | - */ - if (CONFIG(ACPI_BERT)) - arch_upd->BootLoaderTolumSize += CONFIG_ACPI_BERT_SIZE; - /* Fill common settings on behalf of chipset. */ if (fsp_fill_common_arch_params(arch_upd, s3wake, fsp_version, memmap) != CB_SUCCESS)
