Martin Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/52964 )
Change subject: psp_verstage: differentiate bios entry ......................................................................
AMDFW tool stores bios dir entry to bios1_entry in picasso but bios3_entry in cezanne. Separate getting bios_dir_addr into a function and implement it on each platforms.
Signed-off-by: Kangheui Won khwon@chromium.org Change-Id: Ie18ed7979a04319c074b9b251130d419dc7f22dc Reviewed-on: https://review.coreboot.org/c/coreboot/+/52964 Reviewed-by: Martin Roth martinroth@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/amd/cezanne/psp_verstage/chipset.c M src/soc/amd/common/psp_verstage/include/psp_verstage.h M src/soc/amd/common/psp_verstage/psp_verstage.c M src/soc/amd/picasso/psp_verstage/chipset.c 4 files changed, 14 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Martin Roth: Looks good to me, approved
diff --git a/src/soc/amd/cezanne/psp_verstage/chipset.c b/src/soc/amd/cezanne/psp_verstage/chipset.c index 7f944eb..c0593bf 100644 --- a/src/soc/amd/cezanne/psp_verstage/chipset.c +++ b/src/soc/amd/cezanne/psp_verstage/chipset.c @@ -21,6 +21,11 @@ return svc_save_uapp_data(address, size); }
+uint32_t get_bios_dir_addr(struct psp_ef_table *ef_table) +{ + return ef_table->bios3_entry; +} +
/* Functions below are stub functions for not-yet-implemented PSP features. * These functions should be replaced with proper implementations later. diff --git a/src/soc/amd/common/psp_verstage/include/psp_verstage.h b/src/soc/amd/common/psp_verstage/include/psp_verstage.h index 6589725..7bfc8b7 100644 --- a/src/soc/amd/common/psp_verstage/include/psp_verstage.h +++ b/src/soc/amd/common/psp_verstage/include/psp_verstage.h @@ -48,6 +48,8 @@ uint32_t bios0_entry; uint32_t bios1_entry; uint32_t bios2_entry; + uint32_t reserved1; + uint32_t bios3_entry; } __attribute__((packed, aligned(16)));
void test_svc_calls(void); @@ -59,5 +61,6 @@ uint32_t get_max_workbuf_size(uint32_t *size); uint32_t update_psp_bios_dir(uint32_t *psp_dir_offset, uint32_t *bios_dir_offset); uint32_t save_uapp_data(void *address, uint32_t size); +uint32_t get_bios_dir_addr(struct psp_ef_table *ef_table);
#endif /* PSP_VERSTAGE_H */ diff --git a/src/soc/amd/common/psp_verstage/psp_verstage.c b/src/soc/amd/common/psp_verstage/psp_verstage.c index f6cc5e9..2265e17 100644 --- a/src/soc/amd/common/psp_verstage/psp_verstage.c +++ b/src/soc/amd/common/psp_verstage/psp_verstage.c @@ -107,7 +107,7 @@ }
psp_dir_addr = ef_table->psp_table; - bios_dir_addr = ef_table->bios1_entry; + bios_dir_addr = get_bios_dir_addr(ef_table); psp_dir_in_spi = (uint32_t *)((psp_dir_addr & SPI_ADDR_MASK) + (uint32_t)boot_dev.base); bios_dir_in_spi = (uint32_t *)((bios_dir_addr & SPI_ADDR_MASK) + diff --git a/src/soc/amd/picasso/psp_verstage/chipset.c b/src/soc/amd/picasso/psp_verstage/chipset.c index 57a2ff3..b7acbcd 100644 --- a/src/soc/amd/picasso/psp_verstage/chipset.c +++ b/src/soc/amd/picasso/psp_verstage/chipset.c @@ -18,3 +18,8 @@ { return svc_get_max_workbuf_size(size); } + +uint32_t get_bios_dir_addr(struct psp_ef_table *ef_table) +{ + return ef_table->bios1_entry; +}
