Attention is currently required from: Felix Held, Fred Reitberger, Jason Glenesk, Matt DeVillier.
Karthik Ramasubramanian has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/78421?usp=email )
Change subject: soc/amd/phoenix: Disable CCP DMA in PSP Verstage ......................................................................
Some stalls are observed while using CCP DMA in PSP verstage - especially with CBFS verification enabled. Also with RW CBFS verification enabled, the entire firmware body is not loaded during verstage for verification. Instead the files are verified as and when they are loaded from CBFS. Hence the impact to boot time is reduced since only few files are loaded during PSP verstage. Hence disable CCP DMA in PSP verstage until the root cause is identified.
BUG=None TEST=Build and boot to OS in Myst with CBFS verification enabled.
Change-Id: I22ac108b08abcfe432dfd175644393e384888e11 Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com --- M src/soc/amd/phoenix/Kconfig 1 file changed, 2 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/21/78421/1
diff --git a/src/soc/amd/phoenix/Kconfig b/src/soc/amd/phoenix/Kconfig index ec1a9e9..c9aa32c 100644 --- a/src/soc/amd/phoenix/Kconfig +++ b/src/soc/amd/phoenix/Kconfig @@ -25,7 +25,8 @@ select PLATFORM_USES_FSP2_0 select PROVIDES_ROM_SHARING select PSP_SUPPORTS_EFS2_RELATIVE_ADDR if VBOOT_STARTS_BEFORE_BOOTBLOCK - select PSP_VERSTAGE_CCP_DMA if VBOOT_STARTS_BEFORE_BOOTBLOCK + # TODO: (b/303516266) Re-enable CCP DMA after addressing a stall + # select PSP_VERSTAGE_CCP_DMA if VBOOT_STARTS_BEFORE_BOOTBLOCK select RESET_VECTOR_IN_RAM select RTC select SOC_AMD_COMMON
