Dinesh Gehlot has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/74255 )
Change subject: soc/intel/cmd/block/cse: Add config option for storing fw version info ......................................................................
This patch adds a configuration option, `CONFIG_CSE_FIRMWARE_VERSION', which enables the storage of firmware version information in CBMEM memory. This information can be used to identify the firmware version that is currently installed on the system. The option depends on the `DRIVERS_INTEL_ISH` option.
BUG=b:273661726 Test=None
Signed-off-by: Dinesh Gehlot digehlot@google.com Change-Id: I78fef45fd2940536b3e91cfd4d184b7635238499 --- M src/soc/intel/common/block/cse/Kconfig 1 file changed, 27 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/55/74255/1
diff --git a/src/soc/intel/common/block/cse/Kconfig b/src/soc/intel/common/block/cse/Kconfig index f1f53d6..8a2b37a 100644 --- a/src/soc/intel/common/block/cse/Kconfig +++ b/src/soc/intel/common/block/cse/Kconfig @@ -45,6 +45,14 @@ Use this config for SoC platform prior to CNL PCH (with postboot_sai implemented) to make `HECI1` device disable using private configuration register (PCR) write.
+config SOC_INTEL_FIRMWARE_VERSION_STORAGE + bool + depends on DRIVERS_INTEL_ISH + help + This configuration option enables the storage of firmware version information in + CBMEM memory.This information can be used to identify the currently running firmware + partition version. + config SOC_INTEL_CSE_SEND_EOP_EARLY bool "CSE send EOP early" depends on SOC_INTEL_COMMON_BLOCK_CSE
